I have been testing libargus’s captureBurst function with raw bayer output (PIXEL_FMT_RAW16) on a 20MP CSI2 sensor with the Jetson Nano (JetPack 4.3) and am running into a nvargus-daemon timeout on the 6th invocation of captureBurst, when the burst includes five exposures. I run into a timeout on the 5th invocation of captureBurst if the burst includes six exposures.
I don’t run into a timeout at all if the burst length is four or less exposures, and I also don’t see any timeouts if I set iStreamSettings->setPixelFormat(PIXEL_FMT_YCbCr_420_888).
From what I recall, I didn’t experience a timeout when testing the same code on the Jetson TX2, so I believe this is particular to the Jetson Nano. I haven’t tried this on a Jetson TX1.
I don’t have a lower resolution sensor to test at the moment unfortunately due to COVID19 so I won’t be able to provide sample comparisons with e.g rasberry pi module v.2 IMX219 at the moment.
Here is my sample test code, based on the Argus yuvJpeg sample. To test, simply copy this over jetson_multimedia_api/argus/samples/yuvJpeg/main.cpp and compile+run argus_yuvjpeg:
#include "ArgusHelpers.h"
#include "CommonOptions.h"
#include "Error.h"
#include "Thread.h"
#include <Argus/Argus.h>
#include <EGLStream/EGLStream.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <fcntl.h>
#include <iostream>
using namespace Argus;
using namespace EGLStream;
namespace ArgusSamples
// Debug print macros.
#define PRODUCER_PRINT(...) printf("PRODUCER: " __VA_ARGS__)
#define CONSUMER_PRINT(...) printf("CONSUMER: " __VA_ARGS__)
* FrameConsumer thread:
* Creates a FrameConsumer object to read frames from the OutputStream, then
* acquires and prints frame info from the IImage and IImage2D interfaces
* while frames are presented. Writes bayer images to file
class ConsumerThread : public Thread
public:
explicit ConsumerThread(std::vector<OutputStream*> streams, bool& exit) :
m_streams(streams), m_exit(exit)
~ConsumerThread()
private:
/** @name Thread methods */
virtual bool threadInitialize();
virtual bool threadExecute();
virtual bool threadShutdown();
std::vector<OutputStream*> m_streams;
std::vector<FrameConsumer*> m_consumers;
bool& m_exit;
bool ConsumerThread::threadInitialize()
// Create the FrameConsumer.
for (OutputStream* stream : m_streams)
CONSUMER_PRINT("Creating stream\n");
m_consumers.push_back(FrameConsumer::create(stream));
return true;
bool ConsumerThread::threadExecute()
IEGLOutputStream *iStream = interface_cast<IEGLOutputStream>(stream);
// Wait until the producer has connected to the stream.
if (iStream->waitUntilConnected() != STATUS_OK)
ORIGINATE_ERROR("Stream failed to connect.");
uint32_t frameNum = 0;
while (true)
if (m_exit)
break;
for (FrameConsumer* consumer : m_consumers)
IFrameConsumer *iFrameConsumer = interface_cast<IFrameConsumer>(consumer);
UniqueObj<Frame> frame(iFrameConsumer->acquireFrame());
// Use the IFrame interface to print out the frame number/timestamp, and
// to provide access to the Image in the Frame.
IFrame *iFrame = interface_cast<IFrame>(frame);
if (!iFrame)
ORIGINATE_ERROR("Failed to get IFrame interface.");
CONSUMER_PRINT("Acquired Frame: %llu, time %llu\n",
static_cast<unsigned long long>(iFrame->getNumber()),
static_cast<unsigned long long>(iFrame->getTime()));
// Print out some capture metadata from the frame.
IArgusCaptureMetadata *iArgusCaptureMetadata = interface_cast<IArgusCaptureMetadata>(frame);
if (!iArgusCaptureMetadata)
ORIGINATE_ERROR("Failed to get IArgusCaptureMetadata interface.");
CaptureMetadata *metadata = iArgusCaptureMetadata->getMetadata();
ICaptureMetadata *iMetadata = interface_cast<ICaptureMetadata>(metadata);
if (!iMetadata)
ORIGINATE_ERROR("Failed to get ICaptureMetadata interface.");
CONSUMER_PRINT("\tSensor Timestamp: %llu, LUX: %f\n",
static_cast<unsigned long long>(iMetadata->getSensorTimestamp()),
iMetadata->getSceneLux());
// Print out image details, and map the buffers to read out some data.
Image *image = iFrame->getImage();
IImage *iImage = interface_cast<IImage>(image);
IImage2D *iImage2D = interface_cast<IImage2D>(image);
const uint8_t *data_ptr = static_cast<const uint8_t*>(iImage->mapBuffer());
if (!data_ptr)
ORIGINATE_ERROR("\tFailed to map buffer\n");
Size2D<uint32_t> size = iImage2D->getSize(0);
const uint16_t *d = static_cast<const uint16_t*>(iImage->mapBuffer());
CONSUMER_PRINT("\tIImage(2D): "
"buffer (%ux%u, %u stride), "
"%02d %02d %02d %02d %02d %02d %02d %02d %02d %02d %02d %02d\n",
size.width(), size.height(), iImage2D->getStride(0),
d[10000], d[10001], d[10002], d[10003], d[10004], d[10005],
d[10006], d[10007], d[10008], d[10009], d[10010], d[10011]);
CONSUMER_PRINT("Done.\n");
PROPAGATE_ERROR(requestShutdown());
return true;
bool ConsumerThread::threadShutdown()
for (FrameConsumer* frameConsumer : m_consumers)
frameConsumer->destroy();
return true;
* Argus Producer thread:
* Opens the Argus camera driver, creates an OutputStream to output to a
* FrameConsumer, then performs repeating capture requests for CAPTURE_TIME
* seconds before closing the producer and Argus driver.
static bool execute(const CommonOptions& options)
// Create the CameraProvider object and get the core interface.
UniqueObj<CameraProvider> cameraProvider = UniqueObj<CameraProvider>(CameraProvider::create());
ICameraProvider *iCameraProvider = interface_cast<ICameraProvider>(cameraProvider);
if (!iCameraProvider)
ORIGINATE_ERROR("Failed to create CameraProvider");
printf("Argus Version: %s\n", iCameraProvider->getVersion().c_str());
// Get the selected camera device and sensor mode.
CameraDevice* cameraDevice = ArgusHelpers::getCameraDevice(
cameraProvider.get(), options.cameraDeviceIndex());
if (!cameraDevice)
ORIGINATE_ERROR("Selected camera device is not available");
SensorMode* sensorMode = ArgusHelpers::getSensorMode(cameraDevice, options.sensorModeIndex());
ISensorMode *iSensorMode = interface_cast<ISensorMode>(sensorMode);
if (!iSensorMode)
ORIGINATE_ERROR("Selected sensor mode not available");
// Create the capture session using the selected device and get the core interface.
UniqueObj<CaptureSession> captureSession(iCameraProvider->createCaptureSession(cameraDevice));
ICaptureSession *iCaptureSession = interface_cast<ICaptureSession>(captureSession);
if (!iCaptureSession)
ORIGINATE_ERROR("Failed to get ICaptureSession interface");
// Create the OutputStream.
PRODUCER_PRINT("Creating output stream\n");
UniqueObj<OutputStreamSettings> streamSettings(
iCaptureSession->createOutputStreamSettings(STREAM_TYPE_EGL));
IEGLOutputStreamSettings *iStreamSettings =
interface_cast<IEGLOutputStreamSettings>(streamSettings);
if (iStreamSettings)
// iStreamSettings->setPixelFormat(PIXEL_FMT_YCbCr_420_888); // PIX_FMT_YCbCr_420_888 has no problems
iStreamSettings->setPixelFormat(PIXEL_FMT_RAW16); // PIX_FMT_RAW16 hangs on 6th burst capture, if burst includes 5 or more captures
iStreamSettings->setResolution(iSensorMode->getResolution());
iStreamSettings->setMode(EGL_STREAM_MODE_FIFO);
iStreamSettings->setMetadataEnable(true);
std::vector<OutputStream*> outputStreams;
std::vector<const Request*> requests;
std::vector<std::pair<OutputStream*, Request*>> outputRequestPairs;
std::vector<std::pair<uint64_t,uint64_t>> nsec_exp_dur_pairs =
{10000000, 50000000},
{20000000, 50000000},
{30000000, 50000000},
{40000000, 50000000}, // no nvargus-daemon timeout with only four exposures in a burst sequence
{50000000, 50000000}, // with five exposures in a burst sequence, nvargus-daemon timeouts on 6th invocation of captureBurst
// {50000000, 50000000}, // with six exposures in a burst sequence, nvargus-daemon timeouts on 5th invocation of captureBurst
for (std::pair<uint64_t,uint64_t> nsec_exp_dur: nsec_exp_dur_pairs)
uint64_t nsec_exp = nsec_exp_dur.first;
uint64_t nsec_dur = nsec_exp_dur.second;
// Launch the FrameConsumer thread to consume frames from the OutputStream.
PRODUCER_PRINT("Create output stream and request for for %llu nsec exposure\n", static_cast<unsigned long long>(nsec_exp));
// create output stream and request, and enable output stream on request
OutputStream* outputStream = iCaptureSession->createOutputStream(streamSettings.get());
Request* request = iCaptureSession->createRequest(Argus::CAPTURE_INTENT_STILL_CAPTURE);
outputRequestPairs.push_back(std::make_pair(outputStream, request));
IRequest *iRequest = interface_cast<IRequest>(request);
if (!iRequest)
ORIGINATE_ERROR("Failed to create Request");
iRequest->enableOutputStream(outputStream);
// lock AE
IAutoControlSettings *iAutoControlSettings =
interface_cast<IAutoControlSettings>(iRequest->getAutoControlSettings());
if (!iAutoControlSettings)
ORIGINATE_ERROR("Failed to get IAutoControlSettings interface");
if (iAutoControlSettings->setAeLock(true) != Argus::STATUS_OK)
ORIGINATE_ERROR("Failed to set AE lock");
if (iAutoControlSettings->setIspDigitalGainRange(Range<float>(1.0)) != Argus::STATUS_OK)
ORIGINATE_ERROR("Failed to set digital gain range");
// Configure source settings in the request.
ISourceSettings *iSourceSettings = interface_cast<ISourceSettings>(request);
if (!iSourceSettings)
ORIGINATE_ERROR("Failed to get source settings request interface");
iSourceSettings->setSensorMode(sensorMode);
Range<uint64_t> durRange = Range<uint64_t>(nsec_dur);
iSourceSettings->setFrameDurationRange(durRange);
Range<uint64_t> expRange = Range<uint64_t>(nsec_exp);
iSourceSettings->setExposureTimeRange(expRange);
Range<float> gainRange = iSourceSettings->getGainRange();
iSourceSettings->setGainRange(Range<float>(1.0));
outputStreams.push_back(outputStream);
requests.push_back(request);
bool exit = false;
ConsumerThread frameConsumerThread(outputStreams, exit);
PROPAGATE_ERROR(frameConsumerThread.initialize());
// Wait until the consumer is connected to the stream.
PROPAGATE_ERROR(frameConsumerThread.waitRunning());
for (int i = 0 ; i < 9; i++)
PRODUCER_PRINT("Capture burst of length %lu, max burst length %u\n", requests.size(), iCaptureSession->maxBurstRequests());
uint32_t requestId = iCaptureSession->captureBurst(requests);
// wait three seconds between calls to captureBurst
usleep(3000000);
// send capture request to wake consumer thread
exit = true;
PRODUCER_PRINT("Capture final burst of length %lu, max burst length %u\n", requests.size(), iCaptureSession->maxBurstRequests());
// Wait for the consumer thread to complete.
PROPAGATE_ERROR(frameConsumerThread.shutdown());
for (OutputStream* outputStream : outputStreams)
// Destroy the output stream to end the consumer thread.
outputStream->destroy();
for (const Request* request: requests)
Request *req = (Request*)request;
req->destroy();
PRODUCER_PRINT("Done -- exiting.\n");
return true;
}; // namespace ArgusSamples
int main(int argc, char** argv)
ArgusSamples::CommonOptions options(basename(argv[0]),
ArgusSamples::CommonOptions::Option_D_CameraDevice |
ArgusSamples::CommonOptions::Option_M_SensorMode |
ArgusSamples::CommonOptions::Option_T_CaptureTime);
if (!options.parse(argc, argv))
return EXIT_FAILURE;
if (options.requestedExit())
return EXIT_SUCCESS;
for ( int i = 0; i < 1; i++) {
PRODUCER_PRINT("Argus execute %d\n", i);
if (!ArgusSamples::execute(options))
This is the timeout I am referring to in the nvargus-daemon printout:
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 637)
SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 358)
FiberScheduler: fiber 0x7f30001110 exiting
SCF: Error IoctlFailed: (propagating from src/common/Utils.cpp, function workerThread(), line 116) disposing CC 127 Session 2
SCF: Error IoctlFailed: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
Here is kernel dmesg at the point of nvargus-daemon timeout:
[ 8676.995435] isp 54600000.isp: pin_array_ids: could not map attachment err=-12
[ 8677.002693] vi 54080000.vi: nvhost_ioctl_channel_submit: failed with err -12
[ 8677.009800] vi 54080000.vi: submit_add_gathers: failed to copy user inputs: class_ids=000000001c00dd78 num_cmdbufs=2
[ 8677.020370] vi 54080000.vi: nvhost_ioctl_channel_submit: failed with err -22
Here is a snippet from start/end of nvargus-daemon output, running the sample program:
root@localhost:/dev/shm/output# echo file csi2_fops.c +p > /sys/kernel/debug/dynamic_debug/control
root@localhost:/dev/shm/output# echo file vi2_fops.c +p > /sys/kernel/debug/dynamic_debug/control
root@localhost:/dev/shm/output# echo file imx283.c +p > /sys/kernel/debug/dynamic_debug/control
root@localhost:/dev/shm/output# echo "8" > /proc/sys/kernel/printk
root@localhost:/dev/shm/output# echo 1 > /sys/kernel/debug/tracing/tracing_on
root@localhost:/dev/shm/output# echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
root@localhost:/dev/shm/output# echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
root@localhost:/dev/shm/output# echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
root@localhost:/dev/shm/output# echo 2 > /sys/kernel/debug/camrtc/log-level
bash: /sys/kernel/debug/camrtc/log-level: No such file or directory
root@localhost:/dev/shm/output# echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
root@localhost:/dev/shm/output# echo > /sys/kernel/debug/tracing/trace
root@localhost:/dev/shm/output# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 0/0 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
root@localhost:/dev/shm/output# systemctl stop nvargus-daemon
root@localhost:/dev/shm/output# export enableCamPclLogs=5
root@localhost:/dev/shm/output# export enableCamScfLogs=5
root@localhost:/dev/shm/output# /usr/sbin/nvargus-daemon &
[1] 24095
root@localhost:/dev/shm/output# === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...
root@localhost:/dev/shm/output# sudo systemctl stop nvargus-daemon^C
root@localhost:/dev/shm/output# /home/rgbdaemon/tegra_multimedia_api/argus/build/samples/yuvJpeg/argus_yuvjpeg
Executing Argus Sample: argus_yuvjpeg
PRODUCER: Argus execute 0
=== argus_yuvjpeg[24104]: Connection established (7F9ADE31D0)Thread 1 getting next capture
Thread 1 is waiting
Thread 2 getting next capture
Thread 2 is waiting
Thread 3 getting next capture
Thread 3 is waiting
Thread 4 getting next capture
Thread 4 is waiting
Thread 5 getting next capture
Thread 5 is waiting
Thread 6 getting next capture
Thread 6 is waiting
Thread 7 getting next capture
Thread 7 is waiting
Thread 8 getting next capture
Thread 8 is waiting
Thread 9 getting next capture
Thread 9 is waiting
Thread 10 getting next capture
Thread 10 is waiting
Thread 11 getting next capture
Thread 11 is waiting
Thread 12 getting next capture
Thread 12 is waiting
Starting services...
Worker thread IspHw statsComplete start
Worker thread IspHw frameComplete start
Worker thread CaptureScheduler checkFramePending start
Worker thread CaptureScheduler frameStart start
Worker thread V4L2CaptureScheduler checkCaptureComplete start
Worker thread V4L2CaptureScheduler issueCaptures start
Worker thread PS handleRequests start
getInstance: s_instance(0x7f947d9480)
subscribe: SensorType(gyroscope)
subscribe: create SensorType(gyroscope) sensor(0x7f94773040)
subscribe: SensorType(accelerometer)
subscribe: create SensorType(accelerometer) sensor(0x7f947e0f30)
AC plugin not present: dlopen "acplugin.so", acplugin.so: cannot open shared object file: No such file or directory
Services are started
NvPclSetHotplugCallback: ++++++++++++++++++++++
---- Imager: Calibration blob file handling supported in this build ----
NvPclHwGetModuleList: OFParserListModules Succeeded
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
NvPclHwPrintModuleDefinition -- Name: imx283_center_framos
NvPclHwPrintModuleDefinition -- Position: 2
NvPclHwPrintModuleDefinition -- CalibrationData Found: 1
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].Name: v4l2_sensor
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx283 6-001a
NvPclModuleListInitialize: NvPclModule list[0]: imx283_center_framos position2
NvPclHwScanExternalCameras -- adding video0 to discover list
getHotplugMonitor: Getting hotplug monitor instance
initializeHotplug++
hotPlugfunc ++
addWatch: Watch added wd='1'
CheckProcDTExists: INFO: accessing /proc/device-tree/tegra-virtual-camera-platform/modules; No such file or directory
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
setHotplugCallback: Registered new callback client
NvPclSetHotplugCallback: ----------------------
hotPlugfunc: reading from inotify FD, Thread waiting
NvPclOpen: ++++++++++++++++++++++
NvPclStateControllerOpen: Found GUID 2 match at index[0]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94720910
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f947755f0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94730de0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f944cbd30
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94725440
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f947253b0
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16
CheckOverridesPermissions: stat(/Calib/camera_override.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/camera_overrides.isp] 2/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/camera_overrides.isp] 5/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx283_center_framos.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx283_center_framos.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx283_center_framos.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx283_center_framos.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx283_center_framos.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx283_center_framos.isp) call failed
---- imager: No override file found. ----
Imager: looking for override file [/mnt/factory/camera/factory.bin] 1/16
Imager: looking for override file [/Calib/factory.bin] 2/16
Imager: looking for override file [/Calib/calibration.bin] 3/16
Imager: looking for override file [(null)] 4/16
Imager: looking for override file [(null)] 5/16
Imager: looking for override file [(null)] 6/16
Imager: looking for override file [(null)] 7/16
Imager: looking for override file [(null)] 8/16
Imager: looking for override file [(null)] 9/16
Imager: looking for override file [(null)] 10/16
Imager: looking for override file [(null)] 11/16
Imager: looking for override file [(null)] 12/16
Imager: looking for override file [(null)] 13/16
Imager: looking for override file [(null)] 14/16
Imager: looking for override file [(null)] 15/16
Imager: looking for override file [(null)] 16/16
Imager: looking for override file [/data/vendor/nvcam/settings/factory.bin] 1/16
Imager: looking for override file [/data/vendor/nvcam/settings/imx283_center_framos.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx283_center_framos.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx283_center_framos.bin] 4/16
NvPclCreateDriver: Found NvPcl Driver Hal dev_name match (v4l2_sensor)
NvPclCreateDriver: Found a Driver name match (v4l2_sensor)
NvPclConnectDrivers: hImager was NULL, creating new imager
NvPclInitializeDrivers: v4l2_sensor ++++++++++++++++++
OFDPropertyGetString: could not read property [devnode-bus]
OFDPropertyCopyToLong: could not read property [has-eeprom]
OFDPropertyGetString: could not read property [type]
loadSubType: Sensor type missing in DT, 206
OFDPropertyCopyToLong: could not read property [set_mode_delay_ms]
OFDPropertyCopyToLong: could not read property [mode0.vc_id]
OFDPropertyCopyToLongLong: could not read property [mode0.serdes_pix_clk_hz]
OFDPropertyCopyToLongLong: could not read property [mode0.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode0.gain_step_pitch]
OFDPropertyCopyToLong: could not read property [mode0.embedded_metadata_width]
OFDPropertyGetString: could not read property [mode0.dpcm_enable]
OFDPropertyGetString: could not read property [mode0.x_start]
OFDPropertyGetString: could not read property [mode0.y_start]
OFDPropertyGetString: could not read property [mode0.x_end]
OFDPropertyGetString: could not read property [mode0.y_end]
OFDPropertyGetString: could not read property [mode0.h_scaling]
OFDPropertyGetString: could not read property [mode0.v_scaling]
OFDPropertyCopyToLong: could not read property [mode1.vc_id]
OFDPropertyCopyToLongLong: could not read property [mode1.serdes_pix_clk_hz]
OFDPropertyCopyToLongLong: could not read property [mode1.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode1.gain_step_pitch]
OFDPropertyCopyToLong: could not read property [mode1.embedded_metadata_width]
OFDPropertyGetString: could not read property [mode1.dpcm_enable]
OFDPropertyGetString: could not read property [mode1.x_start]
OFDPropertyGetString: could not read property [mode1.y_start]
OFDPropertyGetString: could not read property [mode1.x_end]
OFDPropertyGetString: could not read property [mode1.y_end]
OFDPropertyGetString: could not read property [mode1.h_scaling]
OFDPropertyGetString: could not read property [mode1.v_scaling]
OFDPropertyCopyToLong: could not read property [mode2.vc_id]
OFDPropertyCopyToLongLong: could not read property [mode2.serdes_pix_clk_hz]
OFDPropertyCopyToLongLong: could not read property [mode2.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode2.gain_step_pitch]
OFDPropertyCopyToLong: could not read property [mode2.embedded_metadata_width]
OFDPropertyGetString: could not read property [mode2.dpcm_enable]
OFDPropertyGetString: could not read property [mode2.x_start]
OFDPropertyGetString: could not read property [mode2.y_start]
OFDPropertyGetString: could not read property [mode2.x_end]
OFDPropertyGetString: could not read property [mode2.y_end]
OFDPropertyGetString: could not read property [mode2.h_scaling]
OFDPropertyGetString: could not read property [mode2.v_scaling]
OFDPropertyCopyToLong: could not read property [mode3.vc_id]
OFDPropertyCopyToLongLong: could not read property [mode3.serdes_pix_clk_hz]
OFDPropertyCopyToLongLong: could not read property [mode3.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode3.gain_step_pitch]
OFDPropertyCopyToLong: could not read property [mode3.embedded_metadata_width]
OFDPropertyGetString: could not read property [mode3.dpcm_enable]
OFDPropertyGetString: could not read property [mode3.x_start]
OFDPropertyGetString: could not read property [mode3.y_start]
OFDPropertyGetString: could not read property [mode3.x_end]
OFDPropertyGetString: could not read property [mode3.y_end]
OFDPropertyGetString: could not read property [mode3.h_scaling]
OFDPropertyGetString: could not read property [mode3.v_scaling]
initialize: Loaded Driver: 4 Modes Available--------------
NvPclInitializeDrivers: v4l2_sensor ------------------
NvPclOpen: ----------------------
LSC: LSC surface is not based on full res!
=== argus_yuvjpeg[24104]: CameraProvider initialized (0x7f94831ed0)Argus Version: 0.97.3 (multi-process)
sourceRegistry[0] assigned
ispRegistry[0] assigned
Using Source GUID 2
Worker thread ViCsiHw frameComplete start
Worker thread ViCsiHw frameStart start
NvPclPowerOn: +++++++++++
NvPclPowerOn: -----------
Using ISP A
NvPHSSendThroughputHints: sensorId=2, m_usecase=4, m_type=2, m_value=4294967295, m_timeout_ms=1000
No library found, disabling AC plugin.
Worker thread CaptureDispatcher start
PRODUCER: Creating output stream
PRODUCER: Create output stream and request for for 10000000 nsec exposure
PRODUCER: Create output stream and request for for 20000000 nsec exposure
PRODUCER: Create output stream and request for for 30000000 nsec exposure
PRODUCER: Create output stream and request for for 40000000 nsec exposure
PRODUCER: Create output stream and request for for 50000000 nsec exposure
CONSUMER: Creating stream
PRODUCER: Capture burst of length 5, max burst length 6
Session::updatePerfHints()
updatePerfHints(): guid=2ll, CaptureIntent=1
updatePerfHints(): NvCameraCoreUseCase_Preview
NvPHSSendThroughputHints: sensorId=2, m_usecase=4, m_type=1, m_value=30, m_timeout_ms=1000
NvPHSSendThroughputHints: sensorId=2, m_usecase=4, m_type=15, m_value=0, m_timeout_ms=1000
No output buffers for 0
No output buffers for 2
InstructionList:
+ GraphSettings
| SensorMode: 5496x3694 BayerS16RGGB 20.0fps
| output 0: 5496x3694 Pitch BayerS16RGGB
| inputClipRect 0: (0.00,0.00, 1.00,1.00)
+ Instruction List
+ 0: CCDataSetupStage
| EstimatedIspOutLatencyFrames: 6
| NumConcurrentCaptures: 1
| UnprocessedYuvBufferMask: 0
+ 1: ACSynchronizeStage
+ 2: AeAfApplyStage
+ 3: AcPluginStage
| operation: opApply
+ 4: AcMergeStage
| IspIn: [5496, 3694]
| IspOut0: [5496, 3694]
| IspOut1: [0, 0]
| IspOut2: [0, 0]
+ 5: TempBufferAcquireStage
| Buffer Index: 4
| BufferRequirements: 5496x1 Pitch NonColor8
+ 6: SensorCaptureStage
| Master: 1
| Source GUID: 2
| Output Buffer: 0
| SensorMetadata Buffer: 4
+ 7: TempBufferAcquireStage
| Buffer Index: 2
| BufferRequirements: 5496x3694 BL Y8_ER 420
+ 8: TempBufferAcquireStage
| Buffer Index: 3
| BufferRequirements: 524288x1 Pitch NonColor8
+ 9: MemoryToISPCaptureStage
| Master: 1
| Input Buffer: 0
| Output A Buffer: 2
| Output IspStats Buffer: 3
| Source GUID: 2
+ 10: StatsBufferAcquireStage
| Buffer Index: 1
| BufferRequirements: 640x430 Pitch Y8_ER 420
+ 11: BlitStage
| Input Buffer: 2
| Output Buffer: 1
| Filter: Nearest
| Transform: None
| Src Rect: Not used
| Dst Rect: Not used
+ 12: StatsUpdateStage
| Output Meta Buffer: 4
+ 13: BufferReturnStage
| Output A Buffer: 4
+ 14: BufferReturnStage
| Output A Buffer: 3
+ 15: AcPluginStage
| operation: opAnalyze
+ 16: AfAnalysisStage
+ 17: MonitorStage
+ 18: ExifStage
+ 19: MakerNoteStage
+ 20: BufferReturnStage
| Output A Buffer: 2
+ 21: BufferReturnStage
| Output A Buffer: 0
+ 22: MetadataReturnStage
+ 23: PerfStatsStage
Created fiber 0x7f30000b20 for CC 101 globalID 101 session 2
Thread 1 is working on CC 101 session 2 globalID 101 step 0
CC 101 session 2 completed step 0 in fiber 0x7f30000b20
cc 101(1) session 2 runCount=0 runIspOut=0, latest ccId=0
CC 101 session 2 completed step 1 in fiber 0x7f30000b20
NV AE and AfApply algorithms are active.
CC 101 session 2 completed step 2 in fiber 0x7f30000b20
CC 101 session 2 completed step 3 in fiber 0x7f30000b20
Created fiber 0x7f30000dd0 for CC 102 globalID 102 session 2
Thread 2 is working on CC 102 session 2 globalID 102 step 0
CC 102 session 2 completed step 0 in fiber 0x7f30000dd0
cc 102(2) session 2 runCount=1 runIspOut=0, latest ccId=0
CC 102 session 2 completed step 1 in fiber 0x7f30000dd0
CC 102 session 2 completed step 2 in fiber 0x7f30000dd0
CC 102 session 2 completed step 3 in fiber 0x7f30000dd0
CC 102 session 2 stalled step 4 in fiber 0x7f30000dd0
FiberScheduler: cc 102, session 2 fiber 0x7f30000dd0 not ready to execute stalled on 0x7f94824020 stage...
Thread 2 is working on CC 102 session 2 globalID 102 step 4
CC 101 session 2 completed step 4 in fiber 0x7f30000b20
Thread 4 is waiting
Thread 3 is waiting
CC 101 session 2 completed step 5 in fiber 0x7f30000b20
CC 101 session 2 processing step 6 in fiber 0x7f30000b20
FiberScheduler: cc 101, session 2, fiber 0x7f30000b20 in progress...
Thread 1 is waiting
Thread 5 is waiting
CC 102 session 2 completed step 4 in fiber 0x7f30000dd0
CC 102 session 2 completed step 5 in fiber 0x7f30000dd0
CC 102 session 2 processing step 6 in fiber 0x7f30000dd0
FiberScheduler: cc 102, session 2, fiber 0x7f30000dd0 in progress...
Thread 2 is waiting
Thread 6 is waiting
NvPclSettingsUpdate: Sending Updated Settings through PCL
NvPclSettingsApply: Applying last settings through PCL
apply:+++++++++++++++++++++++
writeMode: Target mode Id(0): Resolution 5496x3694
writeFrameRate: INPUT frameRate:20.000000
writeGain: INPUT gainCtrl:0 analogGain:0.000000
updateOutputSettings: OUTPUT frameRate:20.000000
updateOutputSettings: OUTPUT analogGain:1.000000
apply:-----------------------
NvPclSettingsApply: Reading PCL settings
writeExposure: INPUT expTime:0.010000
updateOutputSettings: OUTPUT expTime:0.009999
PowerServiceHw:addRequest: table size: before: 0, after:1NvPclSettingsApply: Reading PCL settings
request table for ISP 0:
req[0]: output1 width=0, output1 height=0, output1 Bpp=0
req[0]: output2 width=0, output2 height=0, output2 Bpp=0
req[0]: input width=5496, input height=3694, input Bpp=12
req[0]: output width=5496, output height=3694, output Bpp=16
req[0]: input fps=20
req[0]: guID=2, stage type=MemIspCapture
req[0]: clock=0 Hz, iso bw=0 KB/s, non-iso bw=1596351 KB/s
req[450]: timeout=0
PowerServiceHwIsp:setLaBw: m_bwVal_Iso=0 and m_bwVal_NonIso=1596351 KBpS
PowerServiceCore:setCameraBw: totalNonIsoBw=1596351
Created fiber 0x7f30000f70 for CC 103 globalID 103 session 2
Thread 7 is working on CC 103 session 2 globalID 103 step 0
CC 103 session 2 completed step 0 in fiber 0x7f30000f70
cc 103(3) session 2 runCount=2 runIspOut=0, latest ccId=0
CC 103 session 2 completed step 1 in fiber 0x7f30000f70
CC 103 session 2 completed step 2 in fiber 0x7f30000f70
CC 103 session 2 completed step 3 in fiber 0x7f30000f70
CC 103 session 2 completed step 4 in fiber 0x7f30000f70
CC 103 session 2 completed step 5 in fiber 0x7f30000f70
CC 103 session 2 processing step 6 in fiber 0x7f30000f70
FiberScheduler: cc 103, session 2, fiber 0x7f30000f70 in progress...
Thread 7 is waiting
Thread 8 is waiting
Thread 9 is working on CC 104 session 2 globalID 104 step 0
CC 104 session 2 completed step 0 in fiber 0x7f30001110NvPclSettingsApply: Applying last settings through PCLCreated fiber 0x7f30001110 for CC 104 globalID 104 session 2
cc 104(4) session 2 runCount=3 runIspOut=0, latest ccId=0
CC 104 session 2 completed step 1 in fiber 0x7f30001110
CC 104 session 2 completed step 2 in fiber 0x7f30001110
CC 104 session 2 completed step 3 in fiber 0x7f30001110
writeExposure: INPUT expTime:0.020000
CC 104 session 2 completed step 4 in fiber 0x7f30001110
CC 104 session 2 completed step 5 in fiber 0x7f30001110
CC 104 session 2 processing step 6 in fiber 0x7f30001110
FiberScheduler: cc 104, session 2, fiber 0x7f30001110 in progress...
Thread 9 is waiting
updateOutputSettings: OUTPUT expTime:0.019999
updatePerfHints(): guid=2ll, CaptureIntent=1NvPclSettingsApply: Applying last settings through PCL
writeExposure: INPUT expTime:0.030000
Created fiber 0x7f300012b0 for CC 105 globalID 105 session 2
Thread 11 is working on CC 105 session 2 globalID 105 step 0
CC 105 session 2 completed step 0 in fiber 0x7f300012b0
cc 105(5) session 2 runCount=4 runIspOut=0, latest ccId=0
CC 105 session 2 completed step 1 in fiber 0x7f300012b0
CC 105 session 2 completed step 2 in fiber 0x7f300012b0
CC 105 session 2 completed step 3 in fiber 0x7f300012b0
CC 105 session 2 completed step 4 in fiber 0x7f300012b0
CC 105 session 2 completed step 5 in fiber 0x7f300012b0
CC 105 session 2 processing step 6 in fiber 0x7f300012b0
FiberScheduler: cc 105, session 2, fiber 0x7f300012b0 in progress...
updateOutputSettings: OUTPUT expTime:0.029999
FiberScheduler: cc 101, session 2, fiber 0x7f30000b20 succeeded async operation
Thread 4 is working on CC 101 session 2 globalID 101 step 7
writeExposure: INPUT expTime:0.040000
CC 101 session 2 completed step 7 in fiber 0x7f30000b20
CC 101 session 2 completed step 8 in fiber 0x7f30000b20
CC 101 session 2 processing step 9 in fiber 0x7f30000b20
Thread 3 is waiting
Thread 4 is waiting
updateOutputSettings: OUTPUT expTime:0.039999
PowerServiceHw:addRequest: table size: before: 1, after:2
req[402]: timeout=0
req[1]: output1 width=0, output1 height=0, output1 Bpp=0
req[1]: output2 width=0, output2 height=0, output2 Bpp=0
req[1]: input width=5496, input height=3694, input Bpp=16
req[1]: output width=5496, output height=3694, output Bpp=12
req[1]: input fps=20
req[1]: guID=2, stage type=MemIspCapture
req[1]: clock=0 Hz, iso bw=0 KB/s, non-iso bw=1596351 KB/s
req[450]: timeout=0
PowerServiceHw:updateRequests: table size: before: 2, after:2
req[378]: timeout=0
req[426]: timeout=0
FiberScheduler: cc 102, session 2, fiber 0x7f30000dd0 succeeded async operation
Thread 1 is working on CC 102 session 2 globalID 102 step 7
CC 102 session 2 completed step 7 in fiber 0x7f30000dd0
CC 102 session 2 completed step 8 in fiber 0x7f30000dd0
CC 102 session 2 processing step 9 in fiber 0x7f30000dd0
Thread 1 is waiting
Thread 5 is waiting
writeExposure: INPUT expTime:0.050000
updateOutputSettings: OUTPUT expTime:0.050000
Thread 2 is working on CC 101 session 2 globalID 101 step 10
CC 101 session 2 completed step 10 in fiber 0x7f30000b20
request table for VIC 0:
req[0]: output width=640, output height=430, output Bpp=13
req[0]: guID=2, stage type=Blit
req[0]: clock=88822232 Hz, iso bw=0 KB/s, non-iso bw=618010 KB/s
req[450]: timeout=0
PowerServiceHw:updateRequests: table size: before: 1, after:1
req[440]: timeout=0
PowerServiceHwVic:setClock: PowerServiceHw[1]: requested_clock_Hz=88822232
PowerServiceCore:setCameraBw: totalNonIsoBw=2214361
CC 101 session 2 completed step 11 in fiber 0x7f30000b20
exposureTime=0.010000 analogGain=1.000000 digitalGain=1.000000 commonGain=0.010000 expComp=1.000000
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 700.462
CC 101 session 2 completed step 12 in fiber 0x7f30000b20
CC 101 session 2 completed step 13 in fiber 0x7f30000b20
CC 101 session 2 completed step 14 in fiber 0x7f30000b20
CC 101 session 2 completed step 15 in fiber 0x7f30000b20
NV AF analysis algorithm is active.
AfAnalysis cc 101 push FK_ISP_RUN_NUMBER=1.
CC 101 session 2 completed step 16 in fiber 0x7f30000b20
CC 101 session 2 completed step 17 in fiber 0x7f30000b20
CC 101 session 2 completed step 18 in fiber 0x7f30000b20
CC 101 session 2 completed step 19 in fiber 0x7f30000b20
CC 101 session 2 completed step 20 in fiber 0x7f30000b20
CC 101 session 2 completed step 21 in fiber 0x7f30000b20
CC 101 session 2 completed step 22 in fiber 0x7f30000b20
PerfStatsStageStage[sensorId=2][cc=101], sensorStart_ms=8662079, captureDone_ms=8662126, now_ms=8662224, frameDuration_ms=145, framerate=6.9
NvPHSSendThroughputHints: sensorId=2, m_usecase=4, m_type=20, m_value=751840319, m_timeout_ms=1000
CC 101 session 2 completed step 23 in fiber 0x7f30000b20
FiberScheduler: cc 101, session 2, fiber 0x7f30000b20 complete
FiberScheduler: fiber 0x7f30000b20 exiting
disposing CC 101 Session 2
Thread 2 is waiting
Thread 7 is waiting
Thread 6 is waiting
CONSUMER: Acquired Frame: 1, time 8662225093000
CONSUMER: Sensor Timestamp: 8662079793000, LUX: 700.461853
FiberScheduler: cc 103, session 2, fiber 0x7f30000f70 succeeded async operation
CONSUMER: IImage(2D): buffer (5496x3694, 11008 stride), 32 28 20 28 48 36 44 20 24 20 36 20
Thread 8 is working on CC 103 session 2 globalID 103 step 7
CC 103 session 2 completed step 7 in fiber 0x7f30000f70
CC 103 session 2 completed step 8 in fiber 0x7f30000f70
CC 103 session 2 processing step 9 in fiber 0x7f30000f70
Thread 9 is waiting
Thread 8 is waiting
Issue bubble captures
Thread 10 is working on CC 102 session 2 globalID 102 step 10
CC 102 session 2 completed step 10 in fiber 0x7f30000dd0
CC 102 session 2 completed step 11 in fiber 0x7f30000dd0
FiberScheduler: cc 104, session 2, fiber 0x7f30001110 succeeded async operation
Thread 12 is working on CC 104 session 2 globalID 104 step 7
exposureTime=0.020000 analogGain=1.000000 digitalGain=1.000000 commonGain=0.020000 expComp=1.000000
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 710.621
CC 102 session 2 completed step 12 in fiber 0x7f30000dd0
CC 102 session 2 completed step 13 in fiber 0x7f30000dd0
CC 102 session 2 completed step 14 in fiber 0x7f30000dd0
CC 102 session 2 completed step 15 in fiber 0x7f30000dd0
AfAnalysis cc 102 push FK_ISP_RUN_NUMBER=2.
CC 102 session 2 completed step 16 in fiber 0x7f30000dd0
CC 102 session 2 completed step 17 in fiber 0x7f30000dd0
CC 102 session 2 completed step 18 in fiber 0x7f30000dd0
CC 102 session 2 completed step 19 in fiber 0x7f30000dd0
CC 104 session 2 completed step 7 in fiber 0x7f30001110
CC 102 session 2 completed step 20 in fiber 0x7f30000dd0
CC 104 session 2 completed step 8 in fiber 0x7f30001110
CC 104 session 2 processing step 9 in fiber 0x7f30001110
CC 102 session 2 completed step 21 in fiber 0x7f30000dd0
CC 102 session 2 completed step 22 in fiber 0x7f30000dd0
NvPHSSendThroughputHints: sensorId=2, m_usecase=4, m_type=20, m_value=756034673, m_timeout_ms=1000
CC 102 session 2 completed step 23 in fiber 0x7f30000dd0
FiberScheduler: cc 102, session 2, fiber 0x7f30000dd0 complete
FiberScheduler: fiber 0x7f30000dd0 exiting
Thread 3 is waiting
disposing CC 102 Session 2
Thread 4 is waiting
CONSUMER: Acquired Frame: 1, time 8662288706000
CONSUMER: Sensor Timestamp: 8662129533000, LUX: 710.620850
CONSUMER: IImage(2D): buffer (5496x3694, 11008 stride), 84 60 84 60 76 60 68 52 72 64 80 60
Thread 1 is working on CC 103 session 2 globalID 103 step 10
CC 103 session 2 completed step 10 in fiber 0x7f30000f70
CC 103 session 2 completed step 11 in fiber 0x7f30000f70
exposureTime=0.030000 analogGain=1.000000 digitalGain=1.000000 commonGain=0.030000 expComp=1.000000
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 715.669
CC 103 session 2 completed step 12 in fiber 0x7f30000f70
CC 103 session 2 completed step 13 in fiber 0x7f30000f70
CC 103 session 2 completed step 14 in fiber 0x7f30000f70
CC 103 session 2 completed step 15 in fiber 0x7f30000f70
AfAnalysis cc 103 push FK_ISP_RUN_NUMBER=3.
CC 103 session 2 completed step 16 in fiber 0x7f30000f70
CC 103 session 2 completed step 17 in fiber 0x7f30000f70
CC 103 session 2 completed step 18 in fiber 0x7f30000f70
CC 103 session 2 completed step 19 in fiber 0x7f30000f70
CC 103 session 2 completed step 20 in fiber 0x7f30000f70
CC 103 session 2 completed step 21 in fiber 0x7f30000f70
CC 103 session 2 completed step 22 in fiber 0x7f30000f70
NvPHSSendThroughputHints: sensorId=2, m_usecase=4, m_type=20, m_value=757345443, m_timeout_ms=1000
CC 103 session 2 completed step 23 in fiber 0x7f30000f70
FiberScheduler: cc 103, session 2, fiber 0x7f30000f70 complete
FiberScheduler: fiber 0x7f30000f70 exiting
disposing CC 103 Session 2
Thread 1 is waiting
Thread 5 is waiting
Thread 2 is waiting
CONSUMER: Acquired Frame: 1, time 8662309142000
CONSUMER: Sensor Timestamp: 8662179583000, LUX: 715.669067
CONSUMER: IImage(2D): buffer (5496x3694, 11008 stride), 116 72 104 96 128 96 112 68 116 96 100 88
FiberScheduler: cc 105, session 2, fiber 0x7f300012b0 succeeded async operation
Thread 7 is working on CC 105 session 2 globalID 105 step 7
CC 105 session 2 completed step 7 in fiber 0x7f300012b0
CC 105 session 2 completed step 8 in fiber 0x7f300012b0
CC 105 session 2 processing step 9 in fiber 0x7f300012b0
Thread 7 is waiting
Thread 6 is waiting
Thread 9 is working on CC 104 session 2 globalID 104 step 10
CC 104 session 2 completed step 10 in fiber 0x7f30001110
CC 104 session 2 completed step 11 in fiber 0x7f30001110
exposureTime=0.040000 analogGain=1.000000 digitalGain=1.000000 commonGain=0.040000 expComp=1.000000
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 718.792
CC 104 session 2 completed step 12 in fiber 0x7f30001110
CC 104 session 2 completed step 13 in fiber 0x7f30001110
CC 104 session 2 completed step 14 in fiber 0x7f30001110
CC 104 session 2 completed step 15 in fiber 0x7f30001110
AfAnalysis cc 104 push FK_ISP_RUN_NUMBER=4.
CC 104 session 2 completed step 16 in fiber 0x7f30001110
CC 104 session 2 completed step 17 in fiber 0x7f30001110
CC 104 session 2 completed step 18 in fiber 0x7f30001110
CC 104 session 2 completed step 19 in fiber 0x7f30001110
CC 104 session 2 completed step 20 in fiber 0x7f30001110
CC 104 session 2 completed step 21 in fiber 0x7f30001110
CC 104 session 2 completed step 22 in fiber 0x7f30001110
NvPHSSendThroughputHints: sensorId=2, m_usecase=4, m_type=20, m_value=759377109, m_timeout_ms=1000
CC 104 session 2 completed step 23 in fiber 0x7f30001110
FiberScheduler: cc 104, session 2, fiber 0x7f30001110 complete
disposing CC 104 Session 2
Thread 8 is waiting
Thread 9 is waiting
CONSUMER: Acquired Frame: 1, time 8662339818000
CONSUMER: Sensor Timestamp: 8662229516000, LUX: 718.792419
CONSUMER: IImage(2D): buffer (5496x3694, 11008 stride), 152 116 160 124 136 136 124 128 140 108 160 100
Thread 12 is working on CC 105 session 2 globalID 105 step 10
CC 105 session 2 completed step 10 in fiber 0x7f300012b0
CC 105 session 2 completed step 11 in fiber 0x7f300012b0
exposureTime=0.050000 analogGain=1.000000 digitalGain=1.000000 commonGain=0.050000 expComp=1.000000
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 719.043
CC 105 session 2 completed step 12 in fiber 0x7f300012b0
CC 105 session 2 completed step 13 in fiber 0x7f300012b0
CC 105 session 2 completed step 14 in fiber 0x7f300012b0
CC 105 session 2 completed step 15 in fiber 0x7f300012b0
AfAnalysis cc 105 push FK_ISP_RUN_NUMBER=5.
CC 105 session 2 completed step 16 in fiber 0x7f300012b0
CC 105 session 2 completed step 17 in fiber 0x7f300012b0
CC 105 session 2 completed step 18 in fiber 0x7f300012b0
CC 105 session 2 completed step 19 in fiber 0x7f300012b0
CC 105 session 2 completed step 20 in fiber 0x7f300012b0
CC 105 session 2 completed step 21 in fiber 0x7f300012b0
CC 105 session 2 completed step 22 in fiber 0x7f300012b0
NvPHSSendThroughputHints: sensorId=2, m_usecase=4, m_type=20, m_value=761081095, m_timeout_ms=1000
CC 105 session 2 completed step 23 in fiber 0x7f300012b0
FiberScheduler: cc 105, session 2, fiber 0x7f300012b0 complete
FiberScheduler: fiber 0x7f300012b0 exiting
Thread 3 is waiting
CONSUMER: Acquired Frame: 1, time 8662365638000
CONSUMER: Sensor Timestamp: 8662279522000, LUX: 719.043396
CONSUMER: IImage(2D): buffer (5496x3694, 11008 stride), 224 152 212 148 204 140 168 152 188 148 184 148
req[400]: timeout=0
req[0]: timeout=0
req[0]: timeout=0
PowerServiceHwVic:setClock: PowerServiceHw[1]: requested_clock_Hz=0
... [Skipping lines due to NVIDIA forum's character limit]
disposing CC 125 Session 2
Created fiber 0x7f30001ad0 for CC 126 globalID 126 session 2
Thread 6 is working on CC 126 session 2 globalID 126 step 0
CC 126 session 2 completed step 0 in fiber 0x7f30001ad0
cc 126(26) session 2 runCount=25 runIspOut=25, latest ccId=125
AC Stats Delay Count:1
CC 126 session 2 completed step 1 in fiber 0x7f30001ad0
CC 126 session 2 completed step 2 in fiber 0x7f30001ad0
CC 126 session 2 completed step 3 in fiber 0x7f30001ad0
CC 126 session 2 completed step 4 in fiber 0x7f30001ad0
CC 126 session 2 completed step 5 in fiber 0x7f30001ad0
CC 126 session 2 processing step 6 in fiber 0x7f30001ad0
FiberScheduler: cc 126, session 2, fiber 0x7f30001ad0 in progress...
Thread 6 is waiting
Created fiber 0x7f30001110 for CC 127 globalID 127 session 2Session::updatePerfHints()NvPclSettingsUpdate: Sending Updated Settings through PCL
Thread 12 is working on CC 127 session 2 globalID 127 step 0
CC 127 session 2 completed step 0 in fiber 0x7f30001110
cc 127(27) session 2 runCount=26 runIspOut=25, latest ccId=125
AC Stats Delay Count:2
CC 127 session 2 completed step 1 in fiber 0x7f30001110
CC 127 session 2 completed step 2 in fiber 0x7f30001110
CC 127 session 2 completed step 3 in fiber 0x7f30001110
CC 127 session 2 completed step 4 in fiber 0x7f30001110
CC 127 session 2 completed step 5 in fiber 0x7f30001110
CC 127 session 2 processing step 6 in fiber 0x7f30001110
FiberScheduler: cc 127, session 2, fiber 0x7f30001110 in progress...
Thread 9 is waiting
Created fiber 0x7f300015f0 for CC 128 globalID 128 session 2
Thread 5 is working on CC 128 session 2 globalID 128 step 0
CC 128 session 2 completed step 0 in fiber 0x7f300015f0
cc 128(28) session 2 runCount=27 runIspOut=25, latest ccId=125
AC Stats Delay Count:3
CC 128 session 2 completed step 1 in fiber 0x7f300015f0
CC 128 session 2 completed step 2 in fiber 0x7f300015f0
CC 128 session 2 completed step 3 in fiber 0x7f300015f0
CC 128 session 2 completed step 4 in fiber 0x7f300015f0
CC 128 session 2 completed step 5 in fiber 0x7f300015f0
CC 128 session 2 processing step 6 in fiber 0x7f300015f0
FiberScheduler: cc 128, session 2, fiber 0x7f300015f0 in progress...
Thread 5 is waiting
Thread 1 is waiting
NvRmChannelSubmit: NvError_IoctlFailed with error code 22
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 22, SyncPointValue = 0)
SCF: Error IoctlFailed: (propagating from src/services/capture/NvViCsiHw.cpp, function startCapture(), line 508)
SCF: Error IoctlFailed: (propagating from src/services/capture/CaptureRecord.cpp, function doCSItoMemCapture(), line 517)
SCF: Error IoctlFailed: (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(), line 454)
SCF: Error IoctlFailed: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1276)
SCF: Error IoctlFailed: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1107)
FiberScheduler: cc 127, session 2, fiber 0x7f30001110 aborted in async operation
Created fiber 0x7f300012b0 for CC 129 globalID 129 session 2
Thread 3 is working on CC 129 session 2 globalID 129 step 0
CC 129 session 2 completed step 0 in fiber 0x7f300012b0
cc 129(29) session 2 runCount=28 runIspOut=25, latest ccId=125
AC Stats Delay Count:4
CC 129 session 2 completed step 1 in fiber 0x7f300012b0
CC 129 session 2 completed step 2 in fiber 0x7f300012b0
CC 129 session 2 completed step 3 in fiber 0x7f300012b0
CC 129 session 2 completed step 4 in fiber 0x7f300012b0
CC 129 session 2 completed step 5 in fiber 0x7f300012b0
CC 129 session 2 processing step 6 in fiber 0x7f300012b0
FiberScheduler: cc 129, session 2, fiber 0x7f300012b0 in progress...
Thread 3 is waiting
Thread 2 is waiting
FiberScheduler: cc 126, session 2, fiber 0x7f30001ad0 succeeded async operation
Thread 7 is working on CC 126 session 2 globalID 126 step 7
CC 126 session 2 completed step 7 in fiber 0x7f30001ad0
CC 126 session 2 completed step 8 in fiber 0x7f30001ad0
CC 126 session 2 processing step 9 in fiber 0x7f30001ad0
Thread 7 is waiting
Thread 8 is waiting
^C=== argus_yuvjpeg[24104]: Connection closed (7F9ADE31D0)
root@localhost:/dev/shm/output# SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
Created fiber 0x7f30001f30 for CC 130 globalID 130 session 2
Thread 4 is working on CC 130 session 2 globalID 130 step 0
Fiber 0x7f30001f30 is aborting in CC 130 Session 2
FiberScheduler: cc 130 session 2, fiber 0x7f30001f30 aborted
FiberScheduler: fiber 0x7f30001f30 exiting
Thread 4 is waiting
Thread 6 is waiting
=== argus_yuvjpeg[24104]: There were pending client requests in the server at the time of CameraProvider destruction, and they failed to complete within a reasonable time (1500 ms). This may be due to a hardware or libargus error. Forced destruction will now proceed, which may leave the libargus server in a bad state.=== argus_yuvjpeg[24104]: WARNING: CameraProvider was not destroyed before client connection terminated.=== argus_yuvjpeg[24104]: The client may have abnormally terminated. Destroying CameraProvider...=== argus_yuvjpeg[24104]: CameraProvider destroyed (0x7f94831ed0)=== argus_yuvjpeg[24104]: WARNING: Cleaning up 5 outstanding requests...=== argus_yuvjpeg[24104]: WARNING: Cleaning up 5 outstanding streams...SCF: Error InvalidState: 1 buffers still pending during EGLStreamProducer destruction (propagating from src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 305)
SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function ~EGLStreamProducer(), line 50)
=== argus_yuvjpeg[24104]: WARNING: Cleaning up 1 outstanding stream settings...=== argus_yuvjpeg[24104]: WARNING: Cleaning up 1 outstanding sessions...waitForIdleLocked remaining request 129
waitForIdleLocked remaining request 128
waitForIdleLocked remaining request 126
SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 920)
(Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function destroy(), line 166)
I am able to work around this at the moment by release/recreating the Argus CaptureSession + sets of OutputStream and Request objects, but this is inducing extra heat output + energy consumption (libargus objects seem to take considerable CPU cycles to init) and user action latency.
Thank you for your help
