Hey,
I got an array of pointers (it is merely a multidimensional array, but that should not make a difference) and want to use cudaMemcpy to transfer the underlying data to the gpu.
The problem arises when my data is not linear in the memory, i.e. array[i+1] does not point to the subsequent memory location as array[i]. So I can not give cudaMemcpy the pointer array[0] and just copy linear.
Is there a possibility to memcpy such a structure to the gpu and keep it?
