xargon
June 8, 2010, 6:34pm
#1
I have been struggling for a while with this. I have a C++ array that is allocated dynamically as follows:
[codebox]
float ** A = new float *[equations];
for (unsigned k = 0; k < equations; ++k)
A[k] = new float[parameters];
[/codebox]
Now, what I want to do is transfer this to the device. However, I have been unsuccessful in doing so:
I tried cudaMemcpy and cudamemcpy2D. With cudamemcpy2D, i tried the following:
[codebox]
float *d_A = 0;
cudaMalloc((void**)d_A, equationsparameters size));
cudaMemcpy2D(d_A, equations * sizeof(float), A, equations * sizeof(float),
equations, parameters, cudaMemcpyHostToDevice));
[/codebox]
However, when I examine the copied values, they are rubbish.
Does anyone know what I should do to achieve this?
Thanks,
Luca
tera
June 9, 2010, 12:07am
#2
An array of pointers is not the same thing as a two-dimensional array. As you allocate each of the 1d stripes separately in the host, you will have to do just the same on the device:
[codebox]
float **d_A = 0;
cudaMalloc(&(d_A[k]), parameters*sizeof(float));
cudaMemcpy(d_A[k], A[k], equations * sizeof(float), cudaMemcpyHostToDevice);
[/codebox]
It might be worth turning this into one big allocation of an array with equations*parameters floats, so that you can alloc (and later copy) them in one go, instead of per-stripe.
And it’s definitely worth to add error-checking.
xargon
June 9, 2010, 10:52pm
#3
[codebox]
float **d_A = 0;
[/codebox]
Thanks. I ended up factoring my code to change it into a single linear array.
