hi
Has anyone used arrayfire for Jetson Tx2 platform?
Regards
Kunal
hi
Regards
Kunal
Yes. I have been using it (up to v3.6.0) on TX2 (up to L4T R28.2).
Not tried with more recent versions of ArrayFire nor L4T, but I think it should work.
Could you describe your setup? Was it a cross compiled method or was arrayfire directly installed on tx2 Jetson ?
Natively building on TX2. Check the link above for building from source.
Thanks Honey_Patouceul.
I have these follow-up questions:
Is it poosible to run a application on the target via a host PC using arrayfire libraries(of TX2).
Because this way i can run a IDE on the HOST PC and have more control over debugging, profilling etc?
How did u run applications on your jetson, Did u use any IDE?
In my case, the application was running as a standard process, just linked against arrayfire lib for some arrayfire implemented processing.
I have poor experience with cross compiling for Jetson, someone else may better advise.
Probably you’ll be able to profile GPU operations from host with NSight, but not tried with ArrayFire, though.
Additional note: I have recently built master branch (1405a944) of ArrayFire on Xavier NX R32.4.3 for checking, it built fine (needs headers from boost-1.70),
[EDIT: Here are tests with slow clocks and boosted clocks running 6-cores 15W on NX. First time after building with boosted clocks, the test_convolve_cuda didn’t fail. Note that these tests are not intended for performance measurement.
make test
Running tests...
Test project /home/nvidia/Desktop/arrayfire/build
Start 1: test_anisotropic_diffusion_cpu
1/256 Test #1: test_anisotropic_diffusion_cpu .... Passed 5.12 sec
Start 2: test_anisotropic_diffusion_cuda
2/256 Test #2: test_anisotropic_diffusion_cuda ... Passed 12.56 sec
Start 3: test_approx1_cpu
3/256 Test #3: test_approx1_cpu .................. Passed 5.67 sec
Start 4: test_approx1_cuda
4/256 Test #4: test_approx1_cuda ................. Passed 6.85 sec
Start 5: test_approx2_cpu
5/256 Test #5: test_approx2_cpu .................. Passed 5.36 sec
Start 6: test_approx2_cuda
6/256 Test #6: test_approx2_cuda ................. Passed 6.89 sec
Start 7: test_array_cpu
7/256 Test #7: test_array_cpu .................... Passed 0.10 sec
Start 8: test_array_cuda
8/256 Test #8: test_array_cuda ................... Passed 9.22 sec
Start 9: test_arrayio_cpu
9/256 Test #9: test_arrayio_cpu .................. Passed 0.07 sec
Start 10: test_arrayio_cuda
10/256 Test #10: test_arrayio_cuda ................. Passed 4.96 sec
Start 11: test_assign_cpu
11/256 Test #11: test_assign_cpu ................... Passed 0.71 sec
Start 12: test_assign_cuda
12/256 Test #12: test_assign_cuda .................. Passed 5.23 sec
Start 13: test_backend_cpu
13/256 Test #13: test_backend_cpu .................. Passed 0.04 sec
Start 14: test_backend_cuda
14/256 Test #14: test_backend_cuda ................. Passed 4.54 sec
Start 15: test_basic_cpu
15/256 Test #15: test_basic_cpu .................... Passed 0.11 sec
Start 16: test_basic_cuda
16/256 Test #16: test_basic_cuda ................... Passed 4.44 sec
Start 17: test_bilateral_cpu
17/256 Test #17: test_bilateral_cpu ................ Passed 18.21 sec
Start 18: test_bilateral_cuda
18/256 Test #18: test_bilateral_cuda ............... Passed 5.56 sec
Start 19: test_binary_cpu
19/256 Test #19: test_binary_cpu ................... Passed 0.45 sec
Start 20: test_binary_cuda
20/256 Test #20: test_binary_cuda .................. Passed 4.82 sec
Start 21: test_blas_cpu
21/256 Test #21: test_blas_cpu ..................... Passed 3.34 sec
Start 22: test_blas_cuda
22/256 Test #22: test_blas_cuda .................... Passed 6.44 sec
Start 23: test_canny_cpu
23/256 Test #23: test_canny_cpu .................... Passed 1.24 sec
Start 24: test_canny_cuda
24/256 Test #24: test_canny_cuda ................... Passed 4.97 sec
Start 25: test_cast_cpu
25/256 Test #25: test_cast_cpu ..................... Passed 0.06 sec
Start 26: test_cast_cuda
26/256 Test #26: test_cast_cuda .................... Passed 4.54 sec
Start 27: test_cholesky_dense_cpu
27/256 Test #27: test_cholesky_dense_cpu ........... Passed 24.80 sec
Start 28: test_cholesky_dense_cuda
28/256 Test #28: test_cholesky_dense_cuda .......... Passed 13.61 sec
Start 29: test_clamp_cpu
29/256 Test #29: test_clamp_cpu .................... Passed 0.08 sec
Start 30: test_clamp_cuda
30/256 Test #30: test_clamp_cuda ................... Passed 4.53 sec
Start 31: test_compare_cpu
31/256 Test #31: test_compare_cpu .................. Passed 10.16 sec
Start 32: test_compare_cuda
32/256 Test #32: test_compare_cuda ................. Passed 6.50 sec
Start 33: test_complex_cpu
33/256 Test #33: test_complex_cpu .................. Passed 0.06 sec
Start 34: test_complex_cuda
34/256 Test #34: test_complex_cuda ................. Passed 4.84 sec
Start 35: test_confidence_connected_cpu
35/256 Test #35: test_confidence_connected_cpu ..... Passed 1.13 sec
Start 36: test_confidence_connected_cuda
36/256 Test #36: test_confidence_connected_cuda .... Passed 5.40 sec
Start 37: test_constant_cpu
37/256 Test #37: test_constant_cpu ................. Passed 5.31 sec
Start 38: test_constant_cuda
38/256 Test #38: test_constant_cuda ................ Passed 6.37 sec
Start 39: test_convolve_cpu
39/256 Test #39: test_convolve_cpu ................. Passed 7.11 sec
Start 40: test_convolve_cuda
40/256 Test #40: test_convolve_cuda ................ Passed 15.50 sec
Start 41: test_corrcoef_cpu
41/256 Test #41: test_corrcoef_cpu ................. Passed 0.05 sec
Start 42: test_corrcoef_cuda
42/256 Test #42: test_corrcoef_cuda ................ Passed 5.02 sec
Start 43: test_covariance_cpu
43/256 Test #43: test_covariance_cpu ............... Passed 0.30 sec
Start 44: test_covariance_cuda
44/256 Test #44: test_covariance_cuda .............. Passed 4.73 sec
Start 45: test_diagonal_cpu
45/256 Test #45: test_diagonal_cpu ................. Passed 4.58 sec
Start 46: test_diagonal_cuda
46/256 Test #46: test_diagonal_cuda ................ Passed 8.31 sec
Start 47: test_diff1_cpu
47/256 Test #47: test_diff1_cpu .................... Passed 2.07 sec
Start 48: test_diff1_cuda
48/256 Test #48: test_diff1_cuda ................... Passed 5.05 sec
Start 49: test_diff2_cpu
49/256 Test #49: test_diff2_cpu .................... Passed 2.44 sec
Start 50: test_diff2_cuda
50/256 Test #50: test_diff2_cuda ................... Passed 5.19 sec
Start 51: test_dog_cpu
51/256 Test #51: test_dog_cpu ...................... Passed 5.33 sec
Start 52: test_dog_cuda
52/256 Test #52: test_dog_cuda ..................... Passed 4.64 sec
Start 53: test_dot_cpu
53/256 Test #53: test_dot_cpu ...................... Passed 1.59 sec
Start 54: test_dot_cuda
54/256 Test #54: test_dot_cuda ..................... Passed 5.84 sec
Start 55: test_empty_cpu
55/256 Test #55: test_empty_cpu .................... Passed 0.05 sec
Start 56: test_empty_cuda
56/256 Test #56: test_empty_cuda ................... Passed 4.43 sec
Start 57: test_event_cpu
57/256 Test #57: test_event_cpu .................... Passed 0.06 sec
Start 58: test_event_cuda
58/256 Test #58: test_event_cuda ................... Passed 4.76 sec
Start 59: test_fast_cpu
59/256 Test #59: test_fast_cpu ..................... Passed 0.50 sec
Start 60: test_fast_cuda
60/256 Test #60: test_fast_cuda .................... Passed 4.91 sec
Start 61: test_fft_cpu
61/256 Test #61: test_fft_cpu ...................... Passed 24.64 sec
Start 62: test_fft_cuda
62/256 Test #62: test_fft_cuda ..................... Passed 8.45 sec
Start 63: test_fft_large_cpu
63/256 Test #63: test_fft_large_cpu ................ Passed 28.88 sec
Start 64: test_fft_large_cuda
64/256 Test #64: test_fft_large_cuda ............... Passed 9.72 sec
Start 65: test_fft_real_cpu
65/256 Test #65: test_fft_real_cpu ................. Passed 0.80 sec
Start 66: test_fft_real_cuda
66/256 Test #66: test_fft_real_cuda ................ Passed 4.38 sec
Start 67: test_fftconvolve_cpu
67/256 Test #67: test_fftconvolve_cpu .............. Passed 40.05 sec
Start 68: test_fftconvolve_cuda
68/256 Test #68: test_fftconvolve_cuda ............. Passed 7.38 sec
Start 69: test_flat_cpu
69/256 Test #69: test_flat_cpu ..................... Passed 0.05 sec
Start 70: test_flat_cuda
70/256 Test #70: test_flat_cuda .................... Passed 4.91 sec
Start 71: test_flip_cpu
71/256 Test #71: test_flip_cpu ..................... Passed 0.12 sec
Start 72: test_flip_cuda
72/256 Test #72: test_flip_cuda .................... Passed 4.82 sec
Start 73: test_gaussiankernel_cpu
73/256 Test #73: test_gaussiankernel_cpu ........... Passed 0.06 sec
Start 74: test_gaussiankernel_cuda
74/256 Test #74: test_gaussiankernel_cuda .......... Passed 5.04 sec
Start 75: test_gen_assign_cpu
75/256 Test #75: test_gen_assign_cpu ............... Passed 0.58 sec
Start 76: test_gen_assign_cuda
76/256 Test #76: test_gen_assign_cuda .............. Passed 5.52 sec
Start 77: test_gen_index_cpu
77/256 Test #77: test_gen_index_cpu ................ Passed 0.29 sec
Start 78: test_gen_index_cuda
78/256 Test #78: test_gen_index_cuda ............... Passed 4.76 sec
Start 79: test_getting_started_cpu
79/256 Test #79: test_getting_started_cpu .......... Passed 1.03 sec
Start 80: test_getting_started_cuda
80/256 Test #80: test_getting_started_cuda ......... Passed 5.00 sec
Start 81: test_gfor_cpu
81/256 Test #81: test_gfor_cpu ..................... Passed 0.34 sec
Start 82: test_gfor_cuda
82/256 Test #82: test_gfor_cuda .................... Passed 5.11 sec
Start 83: test_gradient_cpu
83/256 Test #83: test_gradient_cpu ................. Passed 0.31 sec
Start 84: test_gradient_cuda
84/256 Test #84: test_gradient_cuda ................ Passed 5.18 sec
Start 85: test_gray_rgb_cpu
85/256 Test #85: test_gray_rgb_cpu ................. Passed 0.33 sec
Start 86: test_gray_rgb_cuda
86/256 Test #86: test_gray_rgb_cuda ................ Passed 5.19 sec
Start 87: test_half_cpu
87/256 Test #87: test_half_cpu ..................... Passed 0.05 sec
Start 88: test_half_cuda
88/256 Test #88: test_half_cuda .................... Passed 4.54 sec
Start 89: test_hamming_cpu
89/256 Test #89: test_hamming_cpu .................. Passed 5.28 sec
Start 90: test_hamming_cuda
90/256 Test #90: test_hamming_cuda ................. Passed 5.25 sec
Start 91: test_harris_cpu
91/256 Test #91: test_harris_cpu ................... Passed 4.58 sec
Start 92: test_harris_cuda
92/256 Test #92: test_harris_cuda .................. Passed 5.26 sec
Start 93: test_histogram_cpu
93/256 Test #93: test_histogram_cpu ................ Passed 0.20 sec
Start 94: test_histogram_cuda
94/256 Test #94: test_histogram_cuda ............... Passed 4.55 sec
Start 95: test_homography_cpu
95/256 Test #95: test_homography_cpu ............... Passed 7.96 sec
Start 96: test_homography_cuda
96/256 Test #96: test_homography_cuda .............. Passed 6.46 sec
Start 97: test_hsv_rgb_cpu
97/256 Test #97: test_hsv_rgb_cpu .................. Passed 12.92 sec
Start 98: test_hsv_rgb_cuda
98/256 Test #98: test_hsv_rgb_cuda ................. Passed 13.43 sec
Start 99: test_iir_cpu
99/256 Test #99: test_iir_cpu ...................... Passed 3.60 sec
Start 100: test_iir_cuda
100/256 Test #100: test_iir_cuda ..................... Passed 5.86 sec
Start 101: test_imageio_cpu
101/256 Test #101: test_imageio_cpu .................. Passed 1.69 sec
Start 102: test_imageio_cuda
102/256 Test #102: test_imageio_cuda ................. Passed 6.41 sec
Start 103: test_index_cpu
103/256 Test #103: test_index_cpu .................... Passed 2.25 sec
Start 104: test_index_cuda
104/256 Test #104: test_index_cuda ................... Passed 5.57 sec
Start 105: test_info_cpu
105/256 Test #105: test_info_cpu ..................... Passed 0.04 sec
Start 106: test_info_cuda
106/256 Test #106: test_info_cuda .................... Passed 4.69 sec
Start 107: test_internal_cpu
107/256 Test #107: test_internal_cpu ................. Passed 0.04 sec
Start 108: test_internal_cuda
108/256 Test #108: test_internal_cuda ................ Passed 4.68 sec
Start 109: test_inverse_deconv_cpu
109/256 Test #109: test_inverse_deconv_cpu ........... Passed 0.58 sec
Start 110: test_inverse_deconv_cuda
110/256 Test #110: test_inverse_deconv_cuda .......... Passed 5.33 sec
Start 111: test_inverse_dense_cpu
111/256 Test #111: test_inverse_dense_cpu ............ Passed 26.88 sec
Start 112: test_inverse_dense_cuda
112/256 Test #112: test_inverse_dense_cuda ........... Passed 17.17 sec
Start 113: test_iota_cpu
113/256 Test #113: test_iota_cpu ..................... Passed 11.87 sec
Start 114: test_iota_cuda
114/256 Test #114: test_iota_cuda .................... Passed 7.30 sec
Start 115: test_ireduce_cpu
115/256 Test #115: test_ireduce_cpu .................. Passed 0.55 sec
Start 116: test_ireduce_cuda
116/256 Test #116: test_ireduce_cuda ................. Passed 4.74 sec
Start 117: test_iterative_deconv_cpu
117/256 Test #117: test_iterative_deconv_cpu ......... Passed 11.20 sec
Start 118: test_iterative_deconv_cuda
118/256 Test #118: test_iterative_deconv_cuda ........ Passed 6.58 sec
Start 119: test_jit_cpu
119/256 Test #119: test_jit_cpu ...................... Passed 6.31 sec
Start 120: test_jit_cuda
120/256 Test #120: test_jit_cuda ..................... Passed 14.34 sec
Start 121: test_join_cpu
121/256 Test #121: test_join_cpu ..................... Passed 3.68 sec
Start 122: test_join_cuda
122/256 Test #122: test_join_cuda .................... Passed 6.43 sec
Start 123: test_lu_dense_cpu
123/256 Test #123: test_lu_dense_cpu ................. Passed 10.20 sec
Start 124: test_lu_dense_cuda
124/256 Test #124: test_lu_dense_cuda ................ Passed 8.47 sec
Start 125: test_match_template_cpu
125/256 Test #125: test_match_template_cpu ........... Passed 0.11 sec
Start 126: test_match_template_cuda
126/256 Test #126: test_match_template_cuda .......... Passed 4.74 sec
Start 127: test_math_cpu
127/256 Test #127: test_math_cpu ..................... Passed 0.92 sec
Start 128: test_math_cuda
128/256 Test #128: test_math_cuda .................... Passed 5.39 sec
Start 129: test_matrix_manipulation_cpu
129/256 Test #129: test_matrix_manipulation_cpu ...... Passed 0.05 sec
Start 130: test_matrix_manipulation_cuda
130/256 Test #130: test_matrix_manipulation_cuda ..... Passed 4.62 sec
Start 131: test_mean_cpu
131/256 Test #131: test_mean_cpu ..................... Passed 2.35 sec
Start 132: test_mean_cuda
132/256 Test #132: test_mean_cuda .................... Passed 5.25 sec
Start 133: test_meanshift_cpu
133/256 Test #133: test_meanshift_cpu ................ Passed 16.70 sec
Start 134: test_meanshift_cuda
134/256 Test #134: test_meanshift_cuda ............... Passed 6.36 sec
Start 135: test_meanvar_cpu
135/256 Test #135: test_meanvar_cpu .................. Passed 0.32 sec
Start 136: test_meanvar_cuda
136/256 Test #136: test_meanvar_cuda ................. Passed 4.52 sec
Start 137: test_medfilt_cpu
137/256 Test #137: test_medfilt_cpu .................. Passed 0.17 sec
Start 138: test_medfilt_cuda
138/256 Test #138: test_medfilt_cuda ................. Passed 4.58 sec
Start 139: test_median_cpu
139/256 Test #139: test_median_cpu ................... Passed 1.79 sec
Start 140: test_median_cuda
140/256 Test #140: test_median_cuda .................. Passed 5.08 sec
Start 141: test_memory_cpu
141/256 Test #141: test_memory_cpu ................... Passed 0.30 sec
Start 142: test_memory_cuda
142/256 Test #142: test_memory_cuda .................. Passed 4.75 sec
Start 143: test_memory_lock_cpu
143/256 Test #143: test_memory_lock_cpu .............. Passed 0.04 sec
Start 144: test_memory_lock_cuda
144/256 Test #144: test_memory_lock_cuda ............. Passed 4.71 sec
Start 145: test_missing_cpu
145/256 Test #145: test_missing_cpu .................. Passed 0.05 sec
Start 146: test_missing_cuda
146/256 Test #146: test_missing_cuda ................. Passed 5.05 sec
Start 147: test_moddims_cpu
147/256 Test #147: test_moddims_cpu .................. Passed 0.12 sec
Start 148: test_moddims_cuda
148/256 Test #148: test_moddims_cuda ................. Passed 4.85 sec
Start 149: test_moments_cpu
149/256 Test #149: test_moments_cpu .................. Passed 0.30 sec
Start 150: test_moments_cuda
150/256 Test #150: test_moments_cuda ................. Passed 5.27 sec
Start 151: test_morph_cpu
151/256 Test #151: test_morph_cpu .................... Passed 6.38 sec
Start 152: test_morph_cuda
152/256 Test #152: test_morph_cuda ................... Passed 6.01 sec
Start 153: test_nearest_neighbour_cpu
153/256 Test #153: test_nearest_neighbour_cpu ........ Passed 111.28 sec
Start 154: test_nearest_neighbour_cuda
154/256 Test #154: test_nearest_neighbour_cuda ....... Passed 8.01 sec
Start 155: test_nodevice_cpu
155/256 Test #155: test_nodevice_cpu ................. Passed 0.04 sec
Start 156: test_nodevice_cuda
156/256 Test #156: test_nodevice_cuda ................ Passed 0.06 sec
Start 157: test_cuda_cuda
157/256 Test #157: test_cuda_cuda .................... Passed 4.55 sec
Start 158: test_cuda_unified
158/256 Test #158: test_cuda_unified ................. Passed 4.48 sec
Start 159: test_orb_cpu
159/256 Test #159: test_orb_cpu ...................... Passed 1.51 sec
Start 160: test_orb_cuda
160/256 Test #160: test_orb_cuda ..................... Passed 4.95 sec
Start 161: test_pad_borders_cpu
161/256 Test #161: test_pad_borders_cpu .............. Passed 0.07 sec
Start 162: test_pad_borders_cuda
162/256 Test #162: test_pad_borders_cuda ............. Passed 5.13 sec
Start 163: test_pinverse_cpu
163/256 Test #163: test_pinverse_cpu ................. Passed 52.83 sec
Start 164: test_pinverse_cuda
164/256 Test #164: test_pinverse_cuda ................ Passed 23.02 sec
Start 165: test_qr_dense_cpu
165/256 Test #165: test_qr_dense_cpu ................. Passed 50.05 sec
Start 166: test_qr_dense_cuda
166/256 Test #166: test_qr_dense_cuda ................ Passed 11.64 sec
Start 167: test_random_cpu
167/256 Test #167: test_random_cpu ................... Passed 40.71 sec
Start 168: test_random_cuda
168/256 Test #168: test_random_cuda .................. Passed 7.96 sec
Start 169: test_rng_quality_cuda
169/256 Test #169: test_rng_quality_cuda ............. Passed 352.94 sec
Start 170: test_range_cpu
170/256 Test #170: test_range_cpu .................... Passed 5.55 sec
Start 171: test_range_cuda
171/256 Test #171: test_range_cuda ................... Passed 14.50 sec
Start 172: test_rank_dense_cpu
172/256 Test #172: test_rank_dense_cpu ............... Passed 20.11 sec
Start 173: test_rank_dense_cuda
173/256 Test #173: test_rank_dense_cuda .............. Passed 8.28 sec
Start 174: test_reduce_cpu
174/256 Test #174: test_reduce_cpu ................... Passed 64.24 sec
Start 175: test_reduce_cuda
175/256 Test #175: test_reduce_cuda .................. Passed 14.26 sec
Start 176: test_regions_cpu
176/256 Test #176: test_regions_cpu .................. Passed 0.48 sec
Start 177: test_regions_cuda
177/256 Test #177: test_regions_cuda ................. Passed 4.55 sec
Start 178: test_reorder_cpu
178/256 Test #178: test_reorder_cpu .................. Passed 0.85 sec
Start 179: test_reorder_cuda
179/256 Test #179: test_reorder_cuda ................. Passed 4.81 sec
Start 180: test_replace_cpu
180/256 Test #180: test_replace_cpu .................. Passed 3.21 sec
Start 181: test_replace_cuda
181/256 Test #181: test_replace_cuda ................. Passed 4.95 sec
Start 182: test_resize_cpu
182/256 Test #182: test_resize_cpu ................... Passed 3.30 sec
Start 183: test_resize_cuda
183/256 Test #183: test_resize_cuda .................. Passed 7.29 sec
Start 184: test_rotate_cpu
184/256 Test #184: test_rotate_cpu ................... Passed 9.52 sec
Start 185: test_rotate_cuda
185/256 Test #185: test_rotate_cuda .................. Passed 14.88 sec
Start 186: test_rotate_linear_cpu
186/256 Test #186: test_rotate_linear_cpu ............ Passed 11.95 sec
Start 187: test_rotate_linear_cuda
187/256 Test #187: test_rotate_linear_cuda ........... Passed 18.05 sec
Start 188: test_sat_cpu
188/256 Test #188: test_sat_cpu ...................... Passed 0.58 sec
Start 189: test_sat_cuda
189/256 Test #189: test_sat_cuda ..................... Passed 5.37 sec
Start 190: test_scan_cpu
190/256 Test #190: test_scan_cpu ..................... Passed 8.27 sec
Start 191: test_scan_cuda
191/256 Test #191: test_scan_cuda .................... Passed 5.91 sec
Start 192: test_scan_by_key_cpu
192/256 Test #192: test_scan_by_key_cpu .............. Passed 52.60 sec
Start 193: test_scan_by_key_cuda
193/256 Test #193: test_scan_by_key_cuda ............. Passed 28.45 sec
Start 194: test_select_cpu
194/256 Test #194: test_select_cpu ................... Passed 15.40 sec
Start 195: test_select_cuda
195/256 Test #195: test_select_cuda .................. Passed 8.95 sec
Start 196: test_set_cpu
196/256 Test #196: test_set_cpu ...................... Passed 0.07 sec
Start 197: test_set_cuda
197/256 Test #197: test_set_cuda ..................... Passed 5.72 sec
Start 198: test_shift_cpu
198/256 Test #198: test_shift_cpu .................... Passed 1.21 sec
Start 199: test_shift_cuda
199/256 Test #199: test_shift_cuda ................... Passed 6.78 sec
Start 200: test_sobel_cpu
200/256 Test #200: test_sobel_cpu .................... Passed 0.06 sec
Start 201: test_sobel_cuda
201/256 Test #201: test_sobel_cuda ................... Passed 4.67 sec
Start 202: test_solve_dense_cpu
202/256 Test #202: test_solve_dense_cpu .............. Passed 114.17 sec
Start 203: test_solve_dense_cuda
203/256 Test #203: test_solve_dense_cuda ............. Passed 46.50 sec
Start 204: test_sort_cpu
204/256 Test #204: test_sort_cpu ..................... Passed 0.93 sec
Start 205: test_sort_cuda
205/256 Test #205: test_sort_cuda .................... Passed 4.90 sec
Start 206: test_sort_by_key_cpu
206/256 Test #206: test_sort_by_key_cpu .............. Passed 0.36 sec
Start 207: test_sort_by_key_cuda
207/256 Test #207: test_sort_by_key_cuda ............. Passed 4.88 sec
Start 208: test_sort_index_cpu
208/256 Test #208: test_sort_index_cpu ............... Passed 0.89 sec
Start 209: test_sort_index_cuda
209/256 Test #209: test_sort_index_cuda .............. Passed 5.49 sec
Start 210: test_sparse_cpu
210/256 Test #210: test_sparse_cpu ................... Passed 44.82 sec
Start 211: test_sparse_cuda
211/256 Test #211: test_sparse_cuda .................. Passed 24.17 sec
Start 212: test_sparse_arith_cpu
212/256 Test #212: test_sparse_arith_cpu ............. Passed 45.57 sec
Start 213: test_sparse_arith_cuda
213/256 Test #213: test_sparse_arith_cuda ............ Passed 20.75 sec
Start 214: test_sparse_convert_cpu
214/256 Test #214: test_sparse_convert_cpu ........... Passed 8.19 sec
Start 215: test_sparse_convert_cuda
215/256 Test #215: test_sparse_convert_cuda .......... Passed 7.17 sec
Start 216: test_stdev_cpu
216/256 Test #216: test_stdev_cpu .................... Passed 0.12 sec
Start 217: test_stdev_cuda
217/256 Test #217: test_stdev_cuda ................... Passed 4.57 sec
Start 218: test_susan_cpu
218/256 Test #218: test_susan_cpu .................... Passed 16.73 sec
Start 219: test_susan_cuda
219/256 Test #219: test_susan_cuda ................... Passed 6.55 sec
Start 220: test_svd_dense_cpu
220/256 Test #220: test_svd_dense_cpu ................ Passed 57.85 sec
Start 221: test_svd_dense_cuda
221/256 Test #221: test_svd_dense_cuda ............... Passed 18.11 sec
Start 222: test_threading_cpu
222/256 Test #222: test_threading_cpu ................ Passed 28.09 sec
Start 223: test_threading_cuda
223/256 Test #223: test_threading_cuda ............... Passed 32.87 sec
Start 224: test_tile_cpu
224/256 Test #224: test_tile_cpu ..................... Passed 23.64 sec
Start 225: test_tile_cuda
225/256 Test #225: test_tile_cuda .................... Passed 27.52 sec
Start 226: test_topk_cpu
226/256 Test #226: test_topk_cpu ..................... Passed 0.91 sec
Start 227: test_topk_cuda
227/256 Test #227: test_topk_cuda .................... Passed 5.16 sec
Start 228: test_transform_cpu
228/256 Test #228: test_transform_cpu ................ Passed 5.12 sec
Start 229: test_transform_cuda
229/256 Test #229: test_transform_cuda ............... Passed 8.41 sec
Start 230: test_transform_coordinates_cpu
230/256 Test #230: test_transform_coordinates_cpu .... Passed 0.05 sec
Start 231: test_transform_coordinates_cuda
231/256 Test #231: test_transform_coordinates_cuda ... Passed 4.89 sec
Start 232: test_translate_cpu
232/256 Test #232: test_translate_cpu ................ Passed 6.46 sec
Start 233: test_translate_cuda
233/256 Test #233: test_translate_cuda ............... Passed 11.21 sec
Start 234: test_transpose_cpu
234/256 Test #234: test_transpose_cpu ................ Passed 2.33 sec
Start 235: test_transpose_cuda
235/256 Test #235: test_transpose_cuda ............... Passed 7.63 sec
Start 236: test_transpose_inplace_cpu
236/256 Test #236: test_transpose_inplace_cpu ........ Passed 1.05 sec
Start 237: test_transpose_inplace_cuda
237/256 Test #237: test_transpose_inplace_cuda ....... Passed 5.05 sec
Start 238: test_triangle_cpu
238/256 Test #238: test_triangle_cpu ................. Passed 73.63 sec
Start 239: test_triangle_cuda
239/256 Test #239: test_triangle_cuda ................ Passed 43.44 sec
Start 240: test_unwrap_cpu
240/256 Test #240: test_unwrap_cpu ................... Passed 16.46 sec
Start 241: test_unwrap_cuda
241/256 Test #241: test_unwrap_cuda .................. Passed 23.24 sec
Start 242: test_var_cpu
242/256 Test #242: test_var_cpu ...................... Passed 6.33 sec
Start 243: test_var_cuda
243/256 Test #243: test_var_cuda ..................... Passed 6.01 sec
Start 244: test_where_cpu
244/256 Test #244: test_where_cpu .................... Passed 0.59 sec
Start 245: test_where_cuda
245/256 Test #245: test_where_cuda ................... Passed 5.40 sec
Start 246: test_wrap_cpu
246/256 Test #246: test_wrap_cpu ..................... Passed 5.72 sec
Start 247: test_wrap_cuda
247/256 Test #247: test_wrap_cuda .................... Passed 7.06 sec
Start 248: test_write_cpu
248/256 Test #248: test_write_cpu .................... Passed 0.21 sec
Start 249: test_write_cuda
249/256 Test #249: test_write_cuda ................... Passed 5.10 sec
Start 250: test_ycbcr_rgb_cpu
250/256 Test #250: test_ycbcr_rgb_cpu ................ Passed 7.01 sec
Start 251: test_ycbcr_rgb_cuda
251/256 Test #251: test_ycbcr_rgb_cuda ............... Passed 10.86 sec
Start 252: test_basic_c_cpu
252/256 Test #252: test_basic_c_cpu .................. Passed 0.03 sec
Start 253: test_basic_c_cuda
253/256 Test #253: test_basic_c_cuda ................. Passed 5.51 sec
Start 254: test_basic_c_unified
254/256 Test #254: test_basic_c_unified .............. Passed 5.39 sec
Start 255: test_matrixmarket_cpu
255/256 Test #255: test_matrixmarket_cpu ............. Passed 0.05 sec
Start 256: test_matrixmarket_cuda
256/256 Test #256: test_matrixmarket_cuda ............ Passed 6.44 sec
100% tests passed, 0 tests failed out of 256
Total Test time (real) = 2683.89 sec
ArrayFire v3.8.0 (CUDA, 64-bit Linux, build 1405a944)
Platform: CUDA Runtime 10.2, Driver: 10020
[0] Xavier, 7764 MB, CUDA Compute 7.2
sudo jetson_clocks
[sudo] password for nvidia:
make test
Running tests...
1/256 Test #1: test_anisotropic_diffusion_cpu .... Passed 7.21 sec
2/256 Test #2: test_anisotropic_diffusion_cuda ... Passed 5.59 sec
3/256 Test #3: test_approx1_cpu .................. Passed 4.33 sec
4/256 Test #4: test_approx1_cuda ................. Passed 6.28 sec
5/256 Test #5: test_approx2_cpu .................. Passed 5.27 sec
6/256 Test #6: test_approx2_cuda ................. Passed 6.81 sec
7/256 Test #7: test_array_cpu .................... Passed 0.08 sec
8/256 Test #8: test_array_cuda ................... Passed 9.38 sec
9/256 Test #9: test_arrayio_cpu .................. Passed 0.08 sec
10/256 Test #10: test_arrayio_cuda ................. Passed 4.44 sec
11/256 Test #11: test_assign_cpu ................... Passed 0.55 sec
12/256 Test #12: test_assign_cuda .................. Passed 4.97 sec
13/256 Test #13: test_backend_cpu .................. Passed 0.03 sec
14/256 Test #14: test_backend_cuda ................. Passed 4.87 sec
15/256 Test #15: test_basic_cpu .................... Passed 0.10 sec
16/256 Test #16: test_basic_cuda ................... Passed 4.50 sec
17/256 Test #17: test_bilateral_cpu ................ Passed 17.72 sec
18/256 Test #18: test_bilateral_cuda ............... Passed 4.83 sec
19/256 Test #19: test_binary_cpu ................... Passed 0.44 sec
20/256 Test #20: test_binary_cuda .................. Passed 4.97 sec
21/256 Test #21: test_blas_cpu ..................... Passed 2.71 sec
22/256 Test #22: test_blas_cuda .................... Passed 5.15 sec
23/256 Test #23: test_canny_cpu .................... Passed 1.15 sec
24/256 Test #24: test_canny_cuda ................... Passed 4.85 sec
25/256 Test #25: test_cast_cpu ..................... Passed 0.05 sec
26/256 Test #26: test_cast_cuda .................... Passed 4.34 sec
27/256 Test #27: test_cholesky_dense_cpu ........... Passed 25.61 sec
28/256 Test #28: test_cholesky_dense_cuda .......... Passed 11.36 sec
29/256 Test #29: test_clamp_cpu .................... Passed 0.07 sec
30/256 Test #30: test_clamp_cuda ................... Passed 4.52 sec
31/256 Test #31: test_compare_cpu .................. Passed 9.93 sec
32/256 Test #32: test_compare_cuda ................. Passed 6.20 sec
33/256 Test #33: test_complex_cpu .................. Passed 0.04 sec
34/256 Test #34: test_complex_cuda ................. Passed 4.53 sec
35/256 Test #35: test_confidence_connected_cpu ..... Passed 1.08 sec
36/256 Test #36: test_confidence_connected_cuda .... Passed 4.68 sec
37/256 Test #37: test_constant_cpu ................. Passed 5.21 sec
38/256 Test #38: test_constant_cuda ................ Passed 5.93 sec
39/256 Test #39: test_convolve_cpu ................. Passed 6.54 sec
40/256 Test #40: test_convolve_cuda ................***Failed 15.38 sec
42/256 Test #42: test_corrcoef_cuda ................ Passed 4.82 sec
43/256 Test #43: test_covariance_cpu ............... Passed 0.13 sec
44/256 Test #44: test_covariance_cuda .............. Passed 4.56 sec
45/256 Test #45: test_diagonal_cpu ................. Passed 4.95 sec
46/256 Test #46: test_diagonal_cuda ................ Passed 8.38 sec
47/256 Test #47: test_diff1_cpu .................... Passed 1.86 sec
48/256 Test #48: test_diff1_cuda ................... Passed 4.95 sec
49/256 Test #49: test_diff2_cpu .................... Passed 2.30 sec
50/256 Test #50: test_diff2_cuda ................... Passed 4.95 sec
51/256 Test #51: test_dog_cpu ...................... Passed 5.17 sec
52/256 Test #52: test_dog_cuda ..................... Passed 4.86 sec
53/256 Test #53: test_dot_cpu ...................... Passed 1.58 sec
54/256 Test #54: test_dot_cuda ..................... Passed 6.10 sec
55/256 Test #55: test_empty_cpu .................... Passed 0.07 sec
56/256 Test #56: test_empty_cuda ................... Passed 4.63 sec
57/256 Test #57: test_event_cpu .................... Passed 0.05 sec
58/256 Test #58: test_event_cuda ................... Passed 4.43 sec
59/256 Test #59: test_fast_cpu ..................... Passed 0.46 sec
60/256 Test #60: test_fast_cuda .................... Passed 4.80 sec
61/256 Test #61: test_fft_cpu ...................... Passed 24.02 sec
62/256 Test #62: test_fft_cuda ..................... Passed 7.38 sec
63/256 Test #63: test_fft_large_cpu ................ Passed 27.17 sec
64/256 Test #64: test_fft_large_cuda ............... Passed 8.10 sec
65/256 Test #65: test_fft_real_cpu ................. Passed 0.76 sec
66/256 Test #66: test_fft_real_cuda ................ Passed 5.49 sec
67/256 Test #67: test_fftconvolve_cpu .............. Passed 39.92 sec
68/256 Test #68: test_fftconvolve_cuda ............. Passed 6.41 sec
70/256 Test #70: test_flat_cuda .................... Passed 4.56 sec
71/256 Test #71: test_flip_cpu ..................... Passed 0.09 sec
72/256 Test #72: test_flip_cuda .................... Passed 4.69 sec
74/256 Test #74: test_gaussiankernel_cuda .......... Passed 4.86 sec
75/256 Test #75: test_gen_assign_cpu ............... Passed 0.57 sec
76/256 Test #76: test_gen_assign_cuda .............. Passed 5.23 sec
77/256 Test #77: test_gen_index_cpu ................ Passed 0.35 sec
78/256 Test #78: test_gen_index_cuda ............... Passed 4.59 sec
79/256 Test #79: test_getting_started_cpu .......... Passed 0.89 sec
80/256 Test #80: test_getting_started_cuda ......... Passed 4.51 sec
81/256 Test #81: test_gfor_cpu ..................... Passed 0.58 sec
82/256 Test #82: test_gfor_cuda .................... Passed 4.75 sec
83/256 Test #83: test_gradient_cpu ................. Passed 0.26 sec
84/256 Test #84: test_gradient_cuda ................ Passed 4.69 sec
85/256 Test #85: test_gray_rgb_cpu ................. Passed 0.21 sec
86/256 Test #86: test_gray_rgb_cuda ................ Passed 4.71 sec
88/256 Test #88: test_half_cuda .................... Passed 4.41 sec
89/256 Test #89: test_hamming_cpu .................. Passed 5.18 sec
90/256 Test #90: test_hamming_cuda ................. Passed 4.45 sec
91/256 Test #91: test_harris_cpu ................... Passed 4.28 sec
92/256 Test #92: test_harris_cuda .................. Passed 5.03 sec
93/256 Test #93: test_histogram_cpu ................ Passed 0.19 sec
94/256 Test #94: test_histogram_cuda ............... Passed 4.79 sec
95/256 Test #95: test_homography_cpu ............... Passed 7.73 sec
96/256 Test #96: test_homography_cuda .............. Passed 5.51 sec
97/256 Test #97: test_hsv_rgb_cpu .................. Passed 11.72 sec
98/256 Test #98: test_hsv_rgb_cuda ................. Passed 13.13 sec
99/256 Test #99: test_iir_cpu ...................... Passed 3.41 sec
100/256 Test #100: test_iir_cuda ..................... Passed 5.13 sec
101/256 Test #101: test_imageio_cpu .................. Passed 1.53 sec
102/256 Test #102: test_imageio_cuda ................. Passed 6.34 sec
103/256 Test #103: test_index_cpu .................... Passed 2.26 sec
104/256 Test #104: test_index_cuda ................... Passed 5.20 sec
106/256 Test #106: test_info_cuda .................... Passed 4.71 sec
107/256 Test #107: test_internal_cpu ................. Passed 0.05 sec
108/256 Test #108: test_internal_cuda ................ Passed 4.60 sec
109/256 Test #109: test_inverse_deconv_cpu ........... Passed 0.61 sec
110/256 Test #110: test_inverse_deconv_cuda .......... Passed 4.77 sec
111/256 Test #111: test_inverse_dense_cpu ............ Passed 26.10 sec
112/256 Test #112: test_inverse_dense_cuda ........... Passed 15.79 sec
113/256 Test #113: test_iota_cpu ..................... Passed 11.56 sec
114/256 Test #114: test_iota_cuda .................... Passed 6.49 sec
115/256 Test #115: test_ireduce_cpu .................. Passed 0.49 sec
116/256 Test #116: test_ireduce_cuda ................. Passed 4.81 sec
117/256 Test #117: test_iterative_deconv_cpu ......... Passed 10.93 sec
118/256 Test #118: test_iterative_deconv_cuda ........ Passed 5.28 sec
119/256 Test #119: test_jit_cpu ...................... Passed 6.38 sec
120/256 Test #120: test_jit_cuda ..................... Passed 14.36 sec
121/256 Test #121: test_join_cpu ..................... Passed 3.25 sec
122/256 Test #122: test_join_cuda .................... Passed 6.21 sec
123/256 Test #123: test_lu_dense_cpu ................. Passed 8.17 sec
124/256 Test #124: test_lu_dense_cuda ................ Passed 7.40 sec
125/256 Test #125: test_match_template_cpu ........... Passed 0.08 sec
126/256 Test #126: test_match_template_cuda .......... Passed 4.69 sec
127/256 Test #127: test_math_cpu ..................... Passed 0.88 sec
128/256 Test #128: test_math_cuda .................... Passed 5.20 sec
129/256 Test #129: test_matrix_manipulation_cpu ...... Passed 0.04 sec
130/256 Test #130: test_matrix_manipulation_cuda ..... Passed 4.60 sec
131/256 Test #131: test_mean_cpu ..................... Passed 2.36 sec
132/256 Test #132: test_mean_cuda .................... Passed 5.28 sec
133/256 Test #133: test_meanshift_cpu ................ Passed 16.78 sec
134/256 Test #134: test_meanshift_cuda ............... Passed 4.92 sec
135/256 Test #135: test_meanvar_cpu .................. Passed 0.26 sec
136/256 Test #136: test_meanvar_cuda ................. Passed 4.60 sec
137/256 Test #137: test_medfilt_cpu .................. Passed 0.15 sec
138/256 Test #138: test_medfilt_cuda ................. Passed 4.47 sec
139/256 Test #139: test_median_cpu ................... Passed 1.77 sec
140/256 Test #140: test_median_cuda .................. Passed 4.64 sec
141/256 Test #141: test_memory_cpu ................... Passed 0.33 sec
142/256 Test #142: test_memory_cuda .................. Passed 4.53 sec
144/256 Test #144: test_memory_lock_cuda ............. Passed 4.60 sec
146/256 Test #146: test_missing_cuda ................. Passed 4.60 sec
147/256 Test #147: test_moddims_cpu .................. Passed 0.08 sec
148/256 Test #148: test_moddims_cuda ................. Passed 4.61 sec
149/256 Test #149: test_moments_cpu .................. Passed 0.26 sec
150/256 Test #150: test_moments_cuda ................. Passed 4.68 sec
151/256 Test #151: test_morph_cpu .................... Passed 6.17 sec
152/256 Test #152: test_morph_cuda ................... Passed 5.57 sec
153/256 Test #153: test_nearest_neighbour_cpu ........ Passed 111.03 sec
154/256 Test #154: test_nearest_neighbour_cuda ....... Passed 6.25 sec
157/256 Test #157: test_cuda_cuda .................... Passed 4.42 sec
158/256 Test #158: test_cuda_unified ................. Passed 4.46 sec
159/256 Test #159: test_orb_cpu ...................... Passed 1.55 sec
160/256 Test #160: test_orb_cuda ..................... Passed 4.59 sec
161/256 Test #161: test_pad_borders_cpu .............. Passed 0.06 sec
162/256 Test #162: test_pad_borders_cuda ............. Passed 5.11 sec
163/256 Test #163: test_pinverse_cpu ................. Passed 62.58 sec
164/256 Test #164: test_pinverse_cuda ................ Passed 21.36 sec
165/256 Test #165: test_qr_dense_cpu ................. Passed 20.53 sec
166/256 Test #166: test_qr_dense_cuda ................ Passed 9.56 sec
167/256 Test #167: test_random_cpu ................... Passed 40.49 sec
168/256 Test #168: test_random_cuda .................. Passed 5.68 sec
169/256 Test #169: test_rng_quality_cuda ............. Passed 338.41 sec
170/256 Test #170: test_range_cpu .................... Passed 5.68 sec
171/256 Test #171: test_range_cuda ................... Passed 11.19 sec
172/256 Test #172: test_rank_dense_cpu ............... Passed 39.25 sec
173/256 Test #173: test_rank_dense_cuda .............. Passed 7.29 sec
174/256 Test #174: test_reduce_cpu ................... Passed 63.96 sec
175/256 Test #175: test_reduce_cuda .................. Passed 12.62 sec
176/256 Test #176: test_regions_cpu .................. Passed 0.45 sec
177/256 Test #177: test_regions_cuda ................. Passed 4.45 sec
178/256 Test #178: test_reorder_cpu .................. Passed 0.84 sec
179/256 Test #179: test_reorder_cuda ................. Passed 4.89 sec
180/256 Test #180: test_replace_cpu .................. Passed 3.12 sec
181/256 Test #181: test_replace_cuda ................. Passed 4.93 sec
182/256 Test #182: test_resize_cpu ................... Passed 3.40 sec
183/256 Test #183: test_resize_cuda .................. Passed 7.07 sec
184/256 Test #184: test_rotate_cpu ................... Passed 9.57 sec
185/256 Test #185: test_rotate_cuda .................. Passed 14.12 sec
186/256 Test #186: test_rotate_linear_cpu ............ Passed 12.16 sec
187/256 Test #187: test_rotate_linear_cuda ........... Passed 16.42 sec
188/256 Test #188: test_sat_cpu ...................... Passed 0.53 sec
189/256 Test #189: test_sat_cuda ..................... Passed 4.66 sec
190/256 Test #190: test_scan_cpu ..................... Passed 8.43 sec
191/256 Test #191: test_scan_cuda .................... Passed 6.60 sec
192/256 Test #192: test_scan_by_key_cpu .............. Passed 51.71 sec
193/256 Test #193: test_scan_by_key_cuda ............. Passed 27.49 sec
194/256 Test #194: test_select_cpu ................... Passed 15.62 sec
195/256 Test #195: test_select_cuda .................. Passed 7.06 sec
196/256 Test #196: test_set_cpu ...................... Passed 0.06 sec
197/256 Test #197: test_set_cuda ..................... Passed 4.37 sec
198/256 Test #198: test_shift_cpu .................... Passed 1.26 sec
199/256 Test #199: test_shift_cuda ................... Passed 4.53 sec
200/256 Test #200: test_sobel_cpu .................... Passed 0.07 sec
201/256 Test #201: test_sobel_cuda ................... Passed 4.41 sec
202/256 Test #202: test_solve_dense_cpu .............. Passed 128.57 sec
203/256 Test #203: test_solve_dense_cuda ............. Passed 38.08 sec
204/256 Test #204: test_sort_cpu ..................... Passed 0.98 sec
206/256 Test #206: test_sort_by_key_cpu .............. Passed 0.37 sec
207/256 Test #207: test_sort_by_key_cuda ............. Passed 4.50 sec
208/256 Test #208: test_sort_index_cpu ............... Passed 0.91 sec
209/256 Test #209: test_sort_index_cuda .............. Passed 5.25 sec
210/256 Test #210: test_sparse_cpu ................... Passed 44.94 sec
211/256 Test #211: test_sparse_cuda .................. Passed 21.43 sec
212/256 Test #212: test_sparse_arith_cpu ............. Passed 46.44 sec
213/256 Test #213: test_sparse_arith_cuda ............ Passed 17.91 sec
214/256 Test #214: test_sparse_convert_cpu ........... Passed 8.34 sec
215/256 Test #215: test_sparse_convert_cuda .......... Passed 7.35 sec
216/256 Test #216: test_stdev_cpu .................... Passed 0.15 sec
217/256 Test #217: test_stdev_cuda ................... Passed 4.85 sec
218/256 Test #218: test_susan_cpu .................... Passed 19.09 sec
219/256 Test #219: test_susan_cuda ................... Passed 5.10 sec
220/256 Test #220: test_svd_dense_cpu ................ Passed 99.22 sec
221/256 Test #221: test_svd_dense_cuda ............... Passed 16.37 sec
222/256 Test #222: test_threading_cpu ................ Passed 16.52 sec
223/256 Test #223: test_threading_cuda ............... Passed 18.66 sec
224/256 Test #224: test_tile_cpu ..................... Passed 23.80 sec
225/256 Test #225: test_tile_cuda .................... Passed 25.92 sec
226/256 Test #226: test_topk_cpu ..................... Passed 0.93 sec
227/256 Test #227: test_topk_cuda .................... Passed 5.03 sec
228/256 Test #228: test_transform_cpu ................ Passed 5.16 sec
229/256 Test #229: test_transform_cuda ............... Passed 7.98 sec
230/256 Test #230: test_transform_coordinates_cpu .... Passed 0.07 sec
231/256 Test #231: test_transform_coordinates_cuda ... Passed 4.40 sec
232/256 Test #232: test_translate_cpu ................ Passed 6.40 sec
233/256 Test #233: test_translate_cuda ............... Passed 10.07 sec
234/256 Test #234: test_transpose_cpu ................ Passed 2.44 sec
235/256 Test #235: test_transpose_cuda ............... Passed 5.63 sec
236/256 Test #236: test_transpose_inplace_cpu ........ Passed 1.03 sec
237/256 Test #237: test_transpose_inplace_cuda ....... Passed 5.04 sec
238/256 Test #238: test_triangle_cpu ................. Passed 44.97 sec
239/256 Test #239: test_triangle_cuda ................ Passed 41.81 sec
240/256 Test #240: test_unwrap_cpu ................... Passed 17.01 sec
241/256 Test #241: test_unwrap_cuda .................. Passed 21.60 sec
242/256 Test #242: test_var_cpu ...................... Passed 6.01 sec
243/256 Test #243: test_var_cuda ..................... Passed 5.25 sec
244/256 Test #244: test_where_cpu .................... Passed 0.62 sec
245/256 Test #245: test_where_cuda ................... Passed 4.98 sec
246/256 Test #246: test_wrap_cpu ..................... Passed 5.79 sec
247/256 Test #247: test_wrap_cuda .................... Passed 6.21 sec
248/256 Test #248: test_write_cpu .................... Passed 0.20 sec
249/256 Test #249: test_write_cuda ................... Passed 4.48 sec
250/256 Test #250: test_ycbcr_rgb_cpu ................ Passed 6.78 sec
251/256 Test #251: test_ycbcr_rgb_cuda ............... Passed 6.75 sec
252/256 Test #252: test_basic_c_cpu .................. Passed 0.02 sec
253/256 Test #253: test_basic_c_cuda ................. Passed 4.74 sec
254/256 Test #254: test_basic_c_unified .............. Passed 4.70 sec
255/256 Test #255: test_matrixmarket_cpu ............. Passed 0.06 sec
256/256 Test #256: test_matrixmarket_cuda ............ Passed 4.53 sec
99% tests passed, 1 tests failed out of 256
Total Test time (real) = 2569.83 sec
The following tests FAILED:
40 - test_convolve_cuda (Failed)
Errors while running CTest
Makefile:129: recipe for target 'test' failed
make: *** [test] Error 8
