Caffe SSD on TX2 - CUDNN_STATUS_INTERNAL_ERROR
Hi Experts!
I am trying to install Caffe SSD on TX2 (Jetpack 3.1). It builds correctly but the unit tests result in the following error
F0806 00:38:52.693260 13235 cudnn_softmax_layer.cpp:15] Check failed: status == CUDNN_STATUS_SUCCESS (4 vs. 0)  CUDNN_STATUS_INTERNAL_ERROR
The same error is there even if I downgrade CuDNN to 5.1. Would be super helpful to give some directions what to look into :-) Thanks!
Caffe SSD is cloned from: https://github.com/weiliu89/caffe/tree/ssd
Environment:
nvidia@tegra-ubuntu:~/caffe_ssd/caffe$ make all -j4
-- Boost version: 1.58.0
-- Found the following Boost libraries:
--   system
--   thread
--   filesystem
--   regex
--   chrono
--   date_time
--   atomic
-- Found gflags  (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libgflags.so)
-- Found glog    (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libglog.so)
-- Found PROTOBUF Compiler: /usr/bin/protoc
-- Found lmdb    (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/liblmdb.so)
-- Found LevelDB (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libleveldb.so)
-- Found Snappy  (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libsnappy.so)
-- CUDA detected: 8.0
-- Found cuDNN: ver. 5.1.10 found (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libcudnn.so)
-- Added CUDA NVCC flags for: sm_62
-- OpenCV found (/usr/share/OpenCV)
-- Found Atlas (include: /usr/include, library: /usr/lib/libatlas.so)
-- NumPy ver. 1.11.0 found (include: /usr/lib/python2.7/dist-packages/numpy/core/include)
--   python
-- Could NOT find Doxygen (missing:  DOXYGEN_EXECUTABLE)
-- ******************* Caffe Configuration Summary *******************
-- General:
--   Version           :   1.0.0-rc3
--   Git               :   rc2-1389-g9d6e815-dirty
--   System            :   Linux
--   C++ compiler      :   /usr/bin/c++
--   Release CXX flags :   -O3 -DNDEBUG -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
--   Debug CXX flags   :   -g -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
--   Build type        :   Release
--   BUILD_SHARED_LIBS :   ON
--   BUILD_python      :   ON
--   BUILD_matlab      :   OFF
--   BUILD_docs        :   ON
--   CPU_ONLY          :   OFF
--   USE_OPENCV        :   ON
--   USE_LEVELDB       :   ON
--   USE_LMDB          :   ON
--   ALLOW_LMDB_NOLOCK :   OFF
-- Dependencies:
--   BLAS              :   Yes (Atlas)
--   Boost             :   Yes (ver. 1.58)
--   glog              :   Yes
--   gflags            :   Yes
--   protobuf          :   Yes (ver. 2.6.1)
--   lmdb              :   Yes (ver. 0.9.17)
--   LevelDB           :   Yes (ver. 1.18)
--   Snappy            :   Yes (ver. 1.1.3)
--   OpenCV            :   Yes (ver. 2.4.13.1)
--   CUDA              :   Yes (ver. 8.0)
-- NVIDIA CUDA:
--   Target GPU(s)     :   Auto
--   GPU arch(s)       :   sm_62
--   cuDNN             :   Yes (ver. 5.1.10)
-- Python:
--   Interpreter       :   /usr/bin/python2.7 (ver. 2.7.12)
--   Libraries         :   /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.12)
--   NumPy             :   /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.11.0)
-- Documentaion:
--   Doxygen           :   No
--   config_file       :
-- Install:
--   Install path      :   /home/nvidia/caffe_ssd/caffe/install
Error:
----------] 26 tests from NetTest/0, where TypeParam = caffe::CPUDevice<float>
[ RUN      ] NetTest/0.TestGetBlob
*** Check failure stack trace: ***
    @       0x7f9bfb5718  google::LogMessage::Fail()
    @       0x7f9bfb7614  google::LogMessage::SendToLog()
    @       0x7f9bfb5290  google::LogMessage::Flush()
    @       0x7f9bfb7eb4  google::LogMessageFatal::~LogMessageFatal()
    @       0x7f9c3e911c  caffe::CuDNNSoftmaxLayer<>::LayerSetUp()
    @       0x7f9c43f334  caffe::SoftmaxWithLossLayer<>::LayerSetUp()
    @       0x7f9c2732a4  caffe::Net<>::Init()
    @       0x7f9c274b30  caffe::Net<>::Net()
    @           0xc839c0  caffe::NetTest<>::InitNetFromProtoString()
    @           0xc2a738  caffe::NetTest<>::InitTinyNet()
    @           0xc7b780  caffe::NetTest_TestGetBlob_Test<>::TestBody()
    @           0xed1a64  testing::internal::HandleExceptionsInMethodIfSupported<>()
    @           0xec89bc  testing::Test::Run()
    @           0xec8af8  testing::TestInfo::Run()
    @           0xec8c04  testing::TestCase::Run()
    @           0xeca668  testing::internal::UnitTestImpl::RunAllTests()
    @           0xeca97c  testing::UnitTest::Run()
    @           0x92ba40  main
    @       0x7f97a838a0  __libc_start_main
src/caffe/test/CMakeFiles/runtest.dir/build.make:57: recipe for target 'src/caffe/test/CMakeFiles/runtest' failed
make[3]: *** [src/caffe/test/CMakeFiles/runtest] Aborted (core dumped)
CMakeFiles/Makefile2:328: recipe for target 'src/caffe/test/CMakeFiles/runtest.dir/all' failed
make[2]: *** [src/caffe/test/CMakeFiles/runtest.dir/all] Error 2
CMakeFiles/Makefile2:335: recipe for target 'src/caffe/test/CMakeFiles/runtest.dir/rule' failed
make[1]: *** [src/caffe/test/CMakeFiles/runtest.dir/rule] Error 2
Makefile:240: recipe for target 'runtest' failed
make: *** [runtest] Error 2
I can build SSD without error. Here are my steps:
1. Flash TX2 with JetPack3.1
2. Prerequirement:
sudo apt-get update
sudo apt-get install software-properties-common
sudo add-apt-repository universe
sudo add-apt-repository multiverse
sudo apt-get install libboost-dev libboost-all-dev
sudo apt-get install libgflags-dev libgoogle-glog-dev liblmdb-dev libatlas-base-dev liblmdb-dev libblas-dev libatlas-base-dev libprotobuf-dev libleveldb-dev libsnappy-dev libhdf5-serial-dev protobuf-compiler
3. Source
git clone https://github.com/weiliu89/caffe.git
cd caffe
git checkout ssd
Apply this change:
diff --git a/Makefile b/Makefile
index 3fd68d1..3498d53 100644
--- a/Makefile
+++ b/Makefile
@@ -178,7 +178,7 @@ ifneq ($(CPU_ONLY), 1)
        LIBRARIES := cudart cublas curand
 endif
-LIBRARIES += glog gflags protobuf boost_system boost_filesystem boost_regex m hdf5_hl hdf5
+LIBRARIES += glog gflags protobuf boost_system boost_filesystem boost_regex m hdf5_serial_hl hdf5_serial
 # handle IO dependencies
 USE_LEVELDB ?= 1
diff --git a/Makefile.config.example b/Makefile.config.example
index eac9312..25f3364 100644
--- a/Makefile.config.example
+++ b/Makefile.config.example
@@ -2,7 +2,7 @@
 # Contributions simplifying and improving our build system are welcome!
 # cuDNN acceleration switch (uncomment to build with cuDNN).
-# USE_CUDNN := 1
+USE_CUDNN := 1
 # CPU-only switch (uncomment to build without GPU support).
 # CPU_ONLY := 1
@@ -38,14 +38,15 @@ CUDA_ARCH := -gencode arch=compute_20,code=sm_20 \
              -gencode arch=compute_35,code=sm_35 \
              -gencode arch=compute_50,code=sm_50 \
              -gencode arch=compute_52,code=sm_52 \
+             -gencode arch=compute_62,code=sm_62 \
              -gencode arch=compute_61,code=sm_61
 # BLAS choice:
 # atlas for ATLAS (default)
 # mkl for MKL
 # open for OpenBlas
-# BLAS := atlas
-BLAS := open
+BLAS := atlas
+# BLAS := open
 # Custom (MKL/ATLAS/OpenBLAS) include and lib directories.
 # Leave commented to accept the defaults for your choice of BLAS
 # (which should work)!
@@ -89,7 +90,7 @@ PYTHON_LIB := /usr/lib
 # WITH_PYTHON_LAYER := 1
 # Whatever else you find you need goes here.
-INCLUDE_DIRS := $(PYTHON_INCLUDE) /usr/local/include
+INCLUDE_DIRS := $(PYTHON_INCLUDE) /usr/local/include /usr/include/hdf5/serial/
 LIBRARY_DIRS := $(PYTHON_LIB) /usr/local/lib /usr/lib
 # If Homebrew is installed at a non standard location (for example your home directory) and you use it for general dependencies
4. Build
cp Makefile.config.example Makefile.config
make -j4
make pycaffe
What’s the latency supposed to be from a USB webcam? I’m using a Logitech C920, and I’m getting a latency of 2-2.5 seconds with the SSD.
It’s reporting an 8-9fps frame rate.
I’m using the model included here, and the clocks are set to max.
https://myurasov.github.io/2016/11/27/ssd-tx1.html
I did verify that the Webcam works correctly (little to no latency) with the Jetson-Inference examples.
We only run ssd_pascal_video.py sample.
If you want to enable Webcam script, please build OpenCV with v4l2 support.
Also, please modify the script to open camera with GStreamer. (GPU-based pipeline)
With the ssd_pascal_video.py sample I’m getting around 7-8fps on average with max clocks enabled. With the default boot up clocking it’s around 3.5fps.
Guess that ssd_pascal_webcam.py open camera with OpenCV.
Default OpenCV use FFmpeg-based CPU decoder. You can switch to GStreamer for acceleration.
Hello, so what are we supposed to change in the script from comment #2 to use the camera on the jetson dev kit?
also when i type
git checkout ssd
i get "error:pathspec ‘ssd’ did not match any file(s) known to git
First, you need a GStreamer enabled OpenCV. (OpenCV4Tegra doesn’t enable GStreamer)
http://dev.t7.ai/jetson/opencv/
Then, read camera with the command like this:
gst-launch-1.0 v4l2src ! video/x-raw, width=(int)1280, height=(int)720,format=(string)I420, framerate=(fraction)24/1 ! nvvidconv flip-method=2 ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink
For error in comment #8, do you use the source of SSD GitHub?
hello, i was following the opencv download instruction from link provided and when i write:
cmake -j4
i get:
[ 29%] Built target pch_Generate_opencv_perf_stitching
[ 29%] Generating perf_precomp.hpp.gch/opencv_perf_superres_RELEASE.gch
[ 29%] Generating precomp.hpp.gch/opencv_videostab_RELEASE.gch
[ 29%] Built target pch_Generate_opencv_superres
Scanning dependencies of target opencv_core
[ 29%] Building CXX object modules/core/CMakeFiles/opencv_core.dir/src/system.cpp.o
[ 29%] Built target pch_Generate_opencv_test_superres
[ 29%] Building CXX object modules/core/CMakeFiles/opencv_core.dir/src/hal_internal.cpp.o
In file included from /home/nvidia/opencv-3.2.0/modules/core/src/hal_internal.cpp:49:0:
/home/nvidia/opencv-3.2.0/release/opencv_lapack.h:2:45: fatal error: LAPACKE_H_PATH-NOTFOUND/lapacke.h: No such file or directory
compilation terminated.
[ 29%] Built target pch_Generate_opencv_perf_superres
[ 29%] Building CXX object modules/core/CMakeFiles/opencv_core.dir/src/gl_core_3_1.cpp.o
[ 29%] Building CXX object modules/core/CMakeFiles/opencv_core.dir/src/matop.cpp.o
modules/core/CMakeFiles/opencv_core.dir/build.make:727: recipe for target 'modules/core/CMakeFiles/opencv_core.dir/src/hal_internal.cpp.o' failed
make[2]: *** [modules/core/CMakeFiles/opencv_core.dir/src/hal_internal.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
[ 29%] Built target pch_Generate_opencv_videostab
CMakeFiles/Makefile2:1532: recipe for target 'modules/core/CMakeFiles/opencv_core.dir/all' failed
make[1]: *** [modules/core/CMakeFiles/opencv_core.dir/all] Error 2
Makefile:160: recipe for target 'all' failed
make: *** [all] Error 2
how do i fix this?
TX2 GPU architecture is sm_62, sm_53 is for TX1.
cmake -D WITH_CUDA=ON -D CUDA_ARCH_BIN="6.2" -D CUDA_ARCH_PTX="" -D WITH_OPENGL=ON -D WITH_LIBV4L=ON -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local ..
Do you have rech 8.9 fps frame?
We reach this on video use-case. The environment is JetPack3.1.
I almost tried all the ways posted on devtalk.nivida.com, but it still can’t figure out.
when I run VGG19 on my TX2(JetPackage3.1), an error ocurred as mentioned above, That is,
‘F1213 11:51:46.367198 2015 cudnn_conv_layer.cpp:53] Check failed: status == CUDNN_STATUS_SUCCESS (4 vs. 0) CUDNN_STATUS_INTERNAL_ERROR’
My Makefile.config and Makefile as follows When I compiled caffe:
1.Makefile.config
## Refer to http://caffe.berkeleyvision.org/installation.html
USE_CUDNN := 1
# CPU_ONLY := 1
# uncomment to disable IO dependencies and corresponding data layers
# USE_OPENCV := 0
# USE_LEVELDB := 0
# USE_LMDB := 0
# uncomment to allow MDB_NOLOCK when reading LMDB files (only if necessary)
#	You should not set this flag if you will be reading LMDBs with any
#	possibility of simultaneous read and write
# ALLOW_LMDB_NOLOCK := 1
# Uncomment if you're using OpenCV 3
# OPENCV_VERSION := 3
# To customize your choice of compiler, uncomment and set the following.
# N.B. the default for Linux is g++ and the default for OSX is clang++
# CUSTOM_CXX := g++
# CUDA directory contains bin/ and lib/ directories that we need.
CUDA_DIR := /usr/local/cuda
# On Ubuntu 14.04, if cuda tools are installed via
# "sudo apt-get install nvidia-cuda-toolkit" then use this instead:
# CUDA_DIR := /usr
# CUDA architecture setting: going with all of them.
# For CUDA < 6.0, comment the *_50 through *_61 lines for compatibility.
# For CUDA < 8.0, comment the *_60 and *_61 lines for compatibility.
# For CUDA >= 9.0, comment the *_20 and *_21 lines for compatibility.
CUDA_ARCH := -gencode arch=compute_30,code=sm_30 \
		-gencode arch=compute_60,code=sm_60 \
		-gencode arch=compute_61,code=sm_61 \
		-gencode arch=compute_61,code=compute_61 \
		-gencode arch=compute_62,code=compute_62
# BLAS choice:
# mkl for MKL
# open for OpenBlas
BLAS := atlas
# BLAS_INCLUDE := /path/to/your/blas
# BLAS_LIB := /path/to/your/blas
# Homebrew puts openblas in a directory that is not on the standard search path
# BLAS_INCLUDE := $(shell brew --prefix openblas)/include
# BLAS_LIB := $(shell brew --prefix openblas)/lib
# This is required only if you will compile the matlab interface.
# MATLAB directory should contain the mex binary in /bin.
# MATLAB_DIR := /usr/local
# MATLAB_DIR := /Applications/MATLAB_R2012b.app
# NOTE: this is required only if you will compile the python interface.
# We need to be able to find Python.h and numpy/arrayobject.h.
PYTHON_INCLUDE := /usr/include/python2.7 \
# Anaconda Python distribution is quite popular. Include path:
# Verify anaconda location, sometimes it's in root.
# ANACONDA_HOME := $(HOME)/anaconda
# PYTHON_INCLUDE := $(ANACONDA_HOME)/include \
		# $(ANACONDA_HOME)/include/python2.7 \
		# $(ANACONDA_HOME)/lib/python2.7/site-packages/numpy/core/include
# Uncomment to use Python 3 (default is Python 2)
# PYTHON_LIBRARIES := boost_python3 python3.5m
# PYTHON_INCLUDE := /usr/include/python3.5m \
#                 /usr/lib/python3.5/dist-packages/numpy/core/include
# We need to be able to find libpythonX.X.so or .dylib.
# PYTHON_LIB := $(ANACONDA_HOME)/lib
# Homebrew installs numpy in a non standard path (keg only)
# PYTHON_INCLUDE += $(dir $(shell python -c 'import numpy.core; print(numpy.core.__file__)'))/include
# PYTHON_LIB += $(shell brew --prefix numpy)/lib
# Uncomment to support layers written in Python (will link against Python libs)
# INCLUDE_DIRS += $(shell brew --prefix)/include
# LIBRARY_DIRS += $(shell brew --prefix)/lib
# NCCL acceleration switch (uncomment to build with NCCL)
# https://github.com/NVIDIA/nccl (last tested version: v1.2.3-1+cuda8.0)
# USE_NCCL := 1
# Uncomment to use `pkg-config` to specify OpenCV library paths.
# (Usually not necessary -- OpenCV libraries are normally installed in one of the above $LIBRARY_DIRS.)
# USE_PKG_CONFIG := 1
# N.B. both build and distribute dirs are cleared on `make clean`
BUILD_DIR := build
DISTRIBUTE_DIR := distribute
# Uncomment for debugging. Does not work on OSX due to https://github.com/BVLC/caffe/issues/171
# DEBUG := 1
# The ID of the GPU that 'make runtest' will use to run unit tests.
TEST_GPUID := 0
# enable pretty build (comment to see full commands)
Q ?= @
  1. Makefile
PROJECT := caffe
CONFIG_FILE := Makefile.config
# Explicitly check for the config file, otherwise make -k will proceed anyway.
ifeq ($(wildcard $(CONFIG_FILE)),)
$(error $(CONFIG_FILE) not found. See $(CONFIG_FILE).example.)
endif
include $(CONFIG_FILE)
BUILD_DIR_LINK := $(BUILD_DIR)
ifeq ($(RELEASE_BUILD_DIR),)
	RELEASE_BUILD_DIR := .$(BUILD_DIR)_release
endif
ifeq ($(DEBUG_BUILD_DIR),)
	DEBUG_BUILD_DIR := .$(BUILD_DIR)_debug
endif
DEBUG ?= 0
ifeq ($(DEBUG), 1)
	BUILD_DIR := $(DEBUG_BUILD_DIR)
	OTHER_BUILD_DIR := $(RELEASE_BUILD_DIR)
else
	OTHER_BUILD_DIR := $(DEBUG_BUILD_DIR)
endif
# All of the directories containing code.
SRC_DIRS := $(shell find * -type d -exec bash -c "find {} -maxdepth 1 \
	\( -name '*.cpp' -o -name '*.proto' \) | grep -q ." \; -print)
# The target shared library name
LIBRARY_NAME := $(PROJECT)
LIB_BUILD_DIR := $(BUILD_DIR)/lib
STATIC_NAME := $(LIB_BUILD_DIR)/lib$(LIBRARY_NAME).a
DYNAMIC_VERSION_MAJOR 		:= 1
DYNAMIC_VERSION_MINOR 		:= 0
DYNAMIC_VERSION_REVISION 	:= 0
DYNAMIC_NAME_SHORT := lib$(LIBRARY_NAME).so
#DYNAMIC_SONAME_SHORT := $(DYNAMIC_NAME_SHORT).$(DYNAMIC_VERSION_MAJOR)
DYNAMIC_VERSIONED_NAME_SHORT := $(DYNAMIC_NAME_SHORT).$(DYNAMIC_VERSION_MAJOR).$(DYNAMIC_VERSION_MINOR).$(DYNAMIC_VERSION_REVISION)
DYNAMIC_NAME := $(LIB_BUILD_DIR)/$(DYNAMIC_VERSIONED_NAME_SHORT)
COMMON_FLAGS += -DCAFFE_VERSION=$(DYNAMIC_VERSION_MAJOR).$(DYNAMIC_VERSION_MINOR).$(DYNAMIC_VERSION_REVISION)
# Get all source files
# CXX_SRCS are the source files excluding the test ones.
CXX_SRCS := $(shell find src/$(PROJECT) ! -name "test_*.cpp" -name "*.cpp")
# CU_SRCS are the cuda source files
CU_SRCS := $(shell find src/$(PROJECT) ! -name "test_*.cu" -name "*.cu")
# TEST_SRCS are the test source files
TEST_MAIN_SRC := src/$(PROJECT)/test/test_caffe_main.cpp
TEST_SRCS := $(shell find src/$(PROJECT) -name "test_*.cpp")
TEST_SRCS := $(filter-out $(TEST_MAIN_SRC), $(TEST_SRCS))
TEST_CU_SRCS := $(shell find src/$(PROJECT) -name "test_*.cu")
GTEST_SRC := src/gtest/gtest-all.cpp
# TOOL_SRCS are the source files for the tool binaries
TOOL_SRCS := $(shell find tools -name "*.cpp")
# EXAMPLE_SRCS are the source files for the example binaries
EXAMPLE_SRCS := $(shell find examples -name "*.cpp")
# BUILD_INCLUDE_DIR contains any generated header files we want to include.
BUILD_INCLUDE_DIR := $(BUILD_DIR)/src
# PROTO_SRCS are the protocol buffer definitions
PROTO_SRC_DIR := src/$(PROJECT)/proto
PROTO_SRCS := $(wildcard $(PROTO_SRC_DIR)/*.proto)
# PROTO_BUILD_DIR will contain the .cc and obj files generated from
# PROTO_SRCS; PROTO_BUILD_INCLUDE_DIR will contain the .h header files
PROTO_BUILD_DIR := $(BUILD_DIR)/$(PROTO_SRC_DIR)
PROTO_BUILD_INCLUDE_DIR := $(BUILD_INCLUDE_DIR)/$(PROJECT)/proto
# NONGEN_CXX_SRCS includes all source/header files except those generated
# automatically (e.g., by proto).
NONGEN_CXX_SRCS := $(shell find \
	src/$(PROJECT) \
	include/$(PROJECT) \
	python/$(PROJECT) \
	matlab/+$(PROJECT)/private \
	examples \
	tools \
	-name "*.cpp" -or -name "*.hpp" -or -name "*.cu" -or -name "*.cuh")
LINT_SCRIPT := scripts/cpp_lint.py
LINT_OUTPUT_DIR := $(BUILD_DIR)/.lint
LINT_EXT := lint.txt
LINT_OUTPUTS := $(addsuffix .$(LINT_EXT), $(addprefix $(LINT_OUTPUT_DIR)/, $(NONGEN_CXX_SRCS)))
EMPTY_LINT_REPORT := $(BUILD_DIR)/.$(LINT_EXT)
NONEMPTY_LINT_REPORT := $(BUILD_DIR)/$(LINT_EXT)
# PY$(PROJECT)_SRC is the python wrapper for $(PROJECT)
PY$(PROJECT)_SRC := python/$(PROJECT)/_$(PROJECT).cpp
PY$(PROJECT)_SO := python/$(PROJECT)/_$(PROJECT).so
PY$(PROJECT)_HXX := include/$(PROJECT)/layers/python_layer.hpp
# MAT$(PROJECT)_SRC is the mex entrance point of matlab package for $(PROJECT)
MAT$(PROJECT)_SRC := matlab/+$(PROJECT)/private/$(PROJECT)_.cpp
ifneq ($(MATLAB_DIR),)
	MAT_SO_EXT := $(shell $(MATLAB_DIR)/bin/mexext)
endif
MAT$(PROJECT)_SO := matlab/+$(PROJECT)/private/$(PROJECT)_.$(MAT_SO_EXT)
# Derive generated files
# The generated files for protocol buffers
PROTO_GEN_HEADER_SRCS := $(addprefix $(PROTO_BUILD_DIR)/, \
		$(notdir ${PROTO_SRCS:.proto=.pb.h}))
PROTO_GEN_HEADER := $(addprefix $(PROTO_BUILD_INCLUDE_DIR)/, \
PROTO_GEN_CC := $(addprefix $(BUILD_DIR)/, ${PROTO_SRCS:.proto=.pb.cc})
PY_PROTO_BUILD_DIR := python/$(PROJECT)/proto
PY_PROTO_INIT := python/$(PROJECT)/proto/__init__.py
PROTO_GEN_PY := $(foreach file,${PROTO_SRCS:.proto=_pb2.py}, \
		$(PY_PROTO_BUILD_DIR)/$(notdir $(file)))
# The objects corresponding to the source files
# These objects will be linked into the final shared library, so we
# exclude the tool, example, and test objects.
CXX_OBJS := $(addprefix $(BUILD_DIR)/, ${CXX_SRCS:.cpp=.o})
CU_OBJS := $(addprefix $(BUILD_DIR)/cuda/, ${CU_SRCS:.cu=.o})
PROTO_OBJS := ${PROTO_GEN_CC:.cc=.o}
OBJS := $(PROTO_OBJS) $(CXX_OBJS) $(CU_OBJS)
# tool, example, and test objects
TOOL_OBJS := $(addprefix $(BUILD_DIR)/, ${TOOL_SRCS:.cpp=.o})
TOOL_BUILD_DIR := $(BUILD_DIR)/tools
TEST_CXX_BUILD_DIR := $(BUILD_DIR)/src/$(PROJECT)/test
TEST_CU_BUILD_DIR := $(BUILD_DIR)/cuda/src/$(PROJECT)/test
TEST_CXX_OBJS := $(addprefix $(BUILD_DIR)/, ${TEST_SRCS:.cpp=.o})
TEST_CU_OBJS := $(addprefix $(BUILD_DIR)/cuda/, ${TEST_CU_SRCS:.cu=.o})
TEST_OBJS := $(TEST_CXX_OBJS) $(TEST_CU_OBJS)
GTEST_OBJ := $(addprefix $(BUILD_DIR)/, ${GTEST_SRC:.cpp=.o})
EXAMPLE_OBJS := $(addprefix $(BUILD_DIR)/, ${EXAMPLE_SRCS:.cpp=.o})
# Output files for automatic dependency generation
DEPS := ${CXX_OBJS:.o=.d} ${CU_OBJS:.o=.d} ${TEST_CXX_OBJS:.o=.d} \
	${TEST_CU_OBJS:.o=.d} $(BUILD_DIR)/${MAT$(PROJECT)_SO:.$(MAT_SO_EXT)=.d}
# tool, example, and test bins
TOOL_BINS := ${TOOL_OBJS:.o=.bin}
EXAMPLE_BINS := ${EXAMPLE_OBJS:.o=.bin}
# symlinks to tool bins without the ".bin" extension
TOOL_BIN_LINKS := ${TOOL_BINS:.bin=}
# Put the test binaries in build/test for convenience.
TEST_BIN_DIR := $(BUILD_DIR)/test
TEST_CU_BINS := $(addsuffix .testbin,$(addprefix $(TEST_BIN_DIR)/, \
		$(foreach obj,$(TEST_CU_OBJS),$(basename $(notdir $(obj))))))
TEST_CXX_BINS := $(addsuffix .testbin,$(addprefix $(TEST_BIN_DIR)/, \
		$(foreach obj,$(TEST_CXX_OBJS),$(basename $(notdir $(obj))))))
TEST_BINS := $(TEST_CXX_BINS) $(TEST_CU_BINS)
# TEST_ALL_BIN is the test binary that links caffe dynamically.
TEST_ALL_BIN := $(TEST_BIN_DIR)/test_all.testbin
# Derive compiler warning dump locations
WARNS_EXT := warnings.txt
CXX_WARNS := $(addprefix $(BUILD_DIR)/, ${CXX_SRCS:.cpp=.o.$(WARNS_EXT)})
CU_WARNS := $(addprefix $(BUILD_DIR)/cuda/, ${CU_SRCS:.cu=.o.$(WARNS_EXT)})
TOOL_WARNS := $(addprefix $(BUILD_DIR)/, ${TOOL_SRCS:.cpp=.o.$(WARNS_EXT)})
EXAMPLE_WARNS := $(addprefix $(BUILD_DIR)/, ${EXAMPLE_SRCS:.cpp=.o.$(WARNS_EXT)})
TEST_WARNS := $(addprefix $(BUILD_DIR)/, ${TEST_SRCS:.cpp=.o.$(WARNS_EXT)})
TEST_CU_WARNS := $(addprefix $(BUILD_DIR)/cuda/, ${TEST_CU_SRCS:.cu=.o.$(WARNS_EXT)})
ALL_CXX_WARNS := $(CXX_WARNS) $(TOOL_WARNS) $(EXAMPLE_WARNS) $(TEST_WARNS)
ALL_CU_WARNS := $(CU_WARNS) $(TEST_CU_WARNS)
ALL_WARNS := $(ALL_CXX_WARNS) $(ALL_CU_WARNS)
EMPTY_WARN_REPORT := $(BUILD_DIR)/.$(WARNS_EXT)
NONEMPTY_WARN_REPORT := $(BUILD_DIR)/$(WARNS_EXT)
# Derive include and lib directories
CUDA_INCLUDE_DIR := $(CUDA_DIR)/include
CUDA_LIB_DIR :=
# add <cuda>/lib64 only if it exists
ifneq ("$(wildcard $(CUDA_DIR)/lib64)","")
	CUDA_LIB_DIR += $(CUDA_DIR)/lib64
endif
INCLUDE_DIRS += $(BUILD_INCLUDE_DIR) ./src ./include
	INCLUDE_DIRS += $(CUDA_INCLUDE_DIR)
	LIBRARY_DIRS += $(CUDA_LIB_DIR)
endif
USE_LEVELDB ?= 1
USE_LMDB ?= 1
USE_OPENCV ?= 1
ifeq ($(USE_LEVELDB), 1)
	LIBRARIES += leveldb snappy
endif
ifeq ($(USE_LMDB), 1)
	LIBRARIES += lmdb
endif
ifeq ($(USE_OPENCV), 1)
	LIBRARIES += opencv_core opencv_highgui opencv_imgproc
	ifeq ($(OPENCV_VERSION), 3)
		LIBRARIES += opencv_imgcodecs
	endif
endif
PYTHON_LIBRARIES ?= boost_python python2.7
WARNINGS := -Wall -Wno-sign-compare
# Set build directories
DISTRIBUTE_DIR ?= distribute
DISTRIBUTE_SUBDIRS := $(DISTRIBUTE_DIR)/bin $(DISTRIBUTE_DIR)/lib
DIST_ALIASES := dist
ifneq ($(strip $(DISTRIBUTE_DIR)),distribute)
		DIST_ALIASES += distribute
endif
ALL_BUILD_DIRS := $(sort $(BUILD_DIR) $(addprefix $(BUILD_DIR)/, $(SRC_DIRS)) \
	$(addprefix $(BUILD_DIR)/cuda/, $(SRC_DIRS)) \
	$(LIB_BUILD_DIR) $(TEST_BIN_DIR) $(PY_PROTO_BUILD_DIR) $(LINT_OUTPUT_DIR) \
	$(DISTRIBUTE_SUBDIRS) $(PROTO_BUILD_INCLUDE_DIR))
# Set directory for Doxygen-generated documentation
DOXYGEN_CONFIG_FILE ?= ./.Doxyfile
# should be the same as OUTPUT_DIRECTORY in the .Doxyfile
DOXYGEN_OUTPUT_DIR ?= ./doxygen
DOXYGEN_COMMAND ?= doxygen
# All the files that might have Doxygen documentation.
DOXYGEN_SOURCES := $(shell find \
	src/$(PROJECT) \
	python/ \
	matlab/ \
	examples \
	tools \
	-name "*.cpp" -or -name "*.hpp" -or -name "*.cu" -or -name "*.cuh" -or \
        -name "*.py" -or -name "*.m")
DOXYGEN_SOURCES += $(DOXYGEN_CONFIG_FILE)
# Configure build
# Determine platform
UNAME := $(shell uname -s)
ifeq ($(UNAME), Linux)
	LINUX := 1
else ifeq ($(UNAME), Darwin)
	OSX := 1
	OSX_MAJOR_VERSION := $(shell sw_vers -productVersion | cut -f 1 -d .)
	OSX_MINOR_VERSION := $(shell sw_vers -productVersion | cut -f 2 -d .)
endif
# Linux
ifeq ($(LINUX), 1)
	CXX ?= /usr/bin/g++
	GCCVERSION := $(shell $(CXX) -dumpversion | cut -f1,2 -d.)
	# older versions of gcc are too dumb to build boost with -Wuninitalized
	ifeq ($(shell echo | awk '{exit $(GCCVERSION) < 4.6;}'), 1)
		WARNINGS += -Wno-uninitialized
	endif
	# boost::thread is reasonably called boost_thread (compare OS X)
	# We will also explicitly add stdc++ to the link target.
	LIBRARIES += boost_thread stdc++
	VERSIONFLAGS += -Wl,-soname,$(DYNAMIC_VERSIONED_NAME_SHORT) -Wl,-rpath,$(ORIGIN)/../lib
endif
# OS X:
# clang++ instead of g++
# libstdc++ for NVCC compatibility on OS X >= 10.9 with CUDA < 7.0
ifeq ($(OSX), 1)
	CXX := /usr/bin/clang++
		CUDA_VERSION := $(shell $(CUDA_DIR)/bin/nvcc -V | grep -o 'release [0-9.]*' | tr -d '[a-z ]')
		ifeq ($(shell echo | awk '{exit $(CUDA_VERSION) < 7.0;}'), 1)
			CXXFLAGS += -stdlib=libstdc++
			LINKFLAGS += -stdlib=libstdc++
		endif
		# clang throws this warning for cuda headers
		WARNINGS += -Wno-unneeded-internal-declaration
		# 10.11 strips DYLD_* env vars so link CUDA (rpath is available on 10.5+)
		OSX_10_OR_LATER   := $(shell [ $(OSX_MAJOR_VERSION) -ge 10 ] && echo true)
		OSX_10_5_OR_LATER := $(shell [ $(OSX_MINOR_VERSION) -ge 5 ] && echo true)
		ifeq ($(OSX_10_OR_LATER),true)
			ifeq ($(OSX_10_5_OR_LATER),true)
				LDFLAGS += -Wl,-rpath,$(CUDA_LIB_DIR)
			endif
		endif
	endif
	# gtest needs to use its own tuple to not conflict with clang
	COMMON_FLAGS += -DGTEST_USE_OWN_TR1_TUPLE=1
	# boost::thread is called boost_thread-mt to mark multithreading on OS X
	LIBRARIES += boost_thread-mt
	# we need to explicitly ask for the rpath to be obeyed
	ORIGIN := @loader_path
	VERSIONFLAGS += -Wl,-install_name,@rpath/$(DYNAMIC_VERSIONED_NAME_SHORT) -Wl,-rpath,$(ORIGIN)/../../build/lib
else
	ORIGIN := \$$ORIGIN
endif
# Custom compiler
ifdef CUSTOM_CXX
	CXX := $(CUSTOM_CXX)
endif
# Static linking
ifneq (,$(findstring clang++,$(CXX)))
	STATIC_LINK_COMMAND := -Wl,-force_load $(STATIC_NAME)
else ifneq (,$(findstring g++,$(CXX)))
	STATIC_LINK_COMMAND := -Wl,--whole-archive $(STATIC_NAME) -Wl,--no-whole-archive
else
  # The following line must not be indented with a tab, since we are not inside a target
  $(error Cannot static link with the $(CXX) compiler)
endif
# Debugging
ifeq ($(DEBUG), 1)
	COMMON_FLAGS += -DDEBUG -g -O0
	NVCCFLAGS += -G
else
	COMMON_FLAGS += -DNDEBUG -O2
endif
# cuDNN acceleration configuration.
ifeq ($(USE_CUDNN), 1)
	LIBRARIES += cudnn
	COMMON_FLAGS += -DUSE_CUDNN
endif
# NCCL acceleration configuration
ifeq ($(USE_NCCL), 1)
	LIBRARIES += nccl
	COMMON_FLAGS += -DUSE_NCCL
endif
# configure IO libraries
	COMMON_FLAGS += -DUSE_OPENCV
endif
	COMMON_FLAGS += -DUSE_LEVELDB
endif
	COMMON_FLAGS += -DUSE_LMDB
ifeq ($(ALLOW_LMDB_NOLOCK), 1)
	COMMON_FLAGS += -DALLOW_LMDB_NOLOCK
endif
endif
# CPU-only configuration
ifeq ($(CPU_ONLY), 1)
	TEST_FILTER := --gtest_filter="-*GPU*"
	COMMON_FLAGS += -DCPU_ONLY
endif
# Python layer support
ifeq ($(WITH_PYTHON_LAYER), 1)
	COMMON_FLAGS += -DWITH_PYTHON_LAYER
	LIBRARIES += $(PYTHON_LIBRARIES)
endif
# BLAS configuration (default = ATLAS)
BLAS ?= atlas
ifeq ($(BLAS), mkl)
	# MKL
	LIBRARIES += mkl_rt
	COMMON_FLAGS += -DUSE_MKL
	MKLROOT ?= /opt/intel/mkl
	BLAS_INCLUDE ?= $(MKLROOT)/include
	BLAS_LIB ?= $(MKLROOT)/lib $(MKLROOT)/lib/intel64
else ifeq ($(BLAS), open)
	# OpenBLAS
	LIBRARIES += openblas
else
	# ATLAS
	ifeq ($(LINUX), 1)
		ifeq ($(BLAS), atlas)
			# Linux simply has cblas and atlas
			LIBRARIES += cblas atlas
		endif
	else ifeq ($(OSX), 1)
		# OS X packages atlas as the vecLib framework
		LIBRARIES += cblas
		# 10.10 has accelerate while 10.9 has veclib
		XCODE_CLT_VER := $(shell pkgutil --pkg-info=com.apple.pkg.CLTools_Executables | grep 'version' | sed 's/[^0-9]*\([0-9]\).*//')
		XCODE_CLT_GEQ_7 := $(shell [ $(XCODE_CLT_VER) -gt 6 ] && echo 1)
		XCODE_CLT_GEQ_6 := $(shell [ $(XCODE_CLT_VER) -gt 5 ] && echo 1)
		ifeq ($(XCODE_CLT_GEQ_7), 1)
			BLAS_INCLUDE ?= /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/$(shell ls /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/ | sort | tail -1)/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/Headers
		else ifeq ($(XCODE_CLT_GEQ_6), 1)
			BLAS_INCLUDE ?= /System/Library/Frameworks/Accelerate.framework/Versions/Current/Frameworks/vecLib.framework/Headers/
			LDFLAGS += -framework Accelerate
		else
			BLAS_INCLUDE ?= /System/Library/Frameworks/vecLib.framework/Versions/Current/Headers/
			LDFLAGS += -framework vecLib
		endif
	endif
endif
INCLUDE_DIRS += $(BLAS_INCLUDE)
LIBRARY_DIRS += $(BLAS_LIB)
LIBRARY_DIRS += $(LIB_BUILD_DIR)
# Automatic dependency generation (nvcc is handled separately)
CXXFLAGS += -MMD -MP
# Complete build flags.
COMMON_FLAGS += $(foreach includedir,$(INCLUDE_DIRS),-I$(includedir))
CXXFLAGS += -pthread -fPIC $(COMMON_FLAGS) $(WARNINGS)
NVCCFLAGS += -ccbin=$(CXX) -Xcompiler -fPIC $(COMMON_FLAGS)
# mex may invoke an older gcc that is too liberal with -Wuninitalized
MATLAB_CXXFLAGS := $(CXXFLAGS) -Wno-uninitialized
LINKFLAGS += -pthread -fPIC $(COMMON_FLAGS) $(WARNINGS)
USE_PKG_CONFIG ?= 0
ifeq ($(USE_PKG_CONFIG), 1)
	PKG_CONFIG := $(shell pkg-config opencv --libs)
else
	PKG_CONFIG :=
endif
LDFLAGS += $(foreach librarydir,$(LIBRARY_DIRS),-L$(librarydir)) $(PKG_CONFIG) \
		$(foreach library,$(LIBRARIES),-l$(library))
PYTHON_LDFLAGS := $(LDFLAGS) $(foreach library,$(PYTHON_LIBRARIES),-l$(library))
# 'superclean' target recursively* deletes all files ending with an extension
# in $(SUPERCLEAN_EXTS) below.  This may be useful if you've built older
# versions of Caffe that do not place all generated files in a location known
# to the 'clean' target.
# 'supercleanlist' will list the files to be deleted by make superclean.
# * Recursive with the exception that symbolic links are never followed, per the
# default behavior of 'find'.
SUPERCLEAN_EXTS := .so .a .o .bin .testbin .pb.cc .pb.h _pb2.py .cuo
# Set the sub-targets of the 'everything' target.
EVERYTHING_TARGETS := all py$(PROJECT) test warn lint
# Only build matcaffe as part of "everything" if MATLAB_DIR is specified.
	EVERYTHING_TARGETS += mat$(PROJECT)
endif
# Define build targets
.PHONY: all lib test clean docs linecount lint lintclean tools examples $(DIST_ALIASES) \
	py mat py$(PROJECT) mat$(PROJECT) proto runtest \
	superclean supercleanlist supercleanfiles warn everything
all: lib tools examples
lib: $(STATIC_NAME) $(DYNAMIC_NAME)
everything: $(EVERYTHING_TARGETS)
linecount:
	cloc --read-lang-def=$(PROJECT).cloc \
		src/$(PROJECT) include/$(PROJECT) tools examples \
		python matlab
lint: $(EMPTY_LINT_REPORT)
lintclean:
	@ $(RM) -r $(LINT_OUTPUT_DIR) $(EMPTY_LINT_REPORT) $(NONEMPTY_LINT_REPORT)
docs: $(DOXYGEN_OUTPUT_DIR)
	@ cd ./docs ; ln -sfn ../$(DOXYGEN_OUTPUT_DIR)/html doxygen
$(DOXYGEN_OUTPUT_DIR): $(DOXYGEN_CONFIG_FILE) $(DOXYGEN_SOURCES)
	$(DOXYGEN_COMMAND) $(DOXYGEN_CONFIG_FILE)
$(EMPTY_LINT_REPORT): $(LINT_OUTPUTS) | $(BUILD_DIR)
	@ cat $(LINT_OUTPUTS) > $@
	@ if [ -s "$@" ]; then \
		cat $@; \
		mv $@ $(NONEMPTY_LINT_REPORT); \
		echo "Found one or more lint errors."; \
		exit 1; \
	  fi; \
	  $(RM) $(NONEMPTY_LINT_REPORT); \
	  echo "No lint errors!";
$(LINT_OUTPUTS): $(LINT_OUTPUT_DIR)/%.lint.txt : % $(LINT_SCRIPT) | $(LINT_OUTPUT_DIR)
	@ mkdir -p $(dir $@)
	@ python $(LINT_SCRIPT) $< 2>&1 \
		| grep -v "^Done processing " \
		| grep -v "^Total errors found: 0" \
		|| true
test: $(TEST_ALL_BIN) $(TEST_ALL_DYNLINK_BIN) $(TEST_BINS)
tools: $(TOOL_BINS) $(TOOL_BIN_LINKS)
examples: $(EXAMPLE_BINS)
py$(PROJECT): py
py: $(PY$(PROJECT)_SO) $(PROTO_GEN_PY)
$(PY$(PROJECT)_SO): $(PY$(PROJECT)_SRC) $(PY$(PROJECT)_HXX) | $(DYNAMIC_NAME)
	@ echo CXX/LD -o $@ $<
	$(Q)$(CXX) -shared -o $@ $(PY$(PROJECT)_SRC) \
		-o $@ $(LINKFLAGS) -l$(LIBRARY_NAME) $(PYTHON_LDFLAGS) \
mat$(PROJECT): mat
mat: $(MAT$(PROJECT)_SO)
$(MAT$(PROJECT)_SO): $(MAT$(PROJECT)_SRC) $(STATIC_NAME)
	@ if [ -z "$(MATLAB_DIR)" ]; then \
		echo "MATLAB_DIR must be specified in $(CONFIG_FILE)" \
			"to build mat$(PROJECT)."; \
		exit 1; \
	fi
	@ echo MEX $<
	$(Q)$(MATLAB_DIR)/bin/mex $(MAT$(PROJECT)_SRC) \
			CXX="$(CXX)" \
			CXXFLAGS="\$$CXXFLAGS $(MATLAB_CXXFLAGS)" \
			CXXLIBS="\$$CXXLIBS $(STATIC_LINK_COMMAND) $(LDFLAGS)" -output $@
	@ if [ -f "$(PROJECT)_.d" ]; then \
		mv -f $(PROJECT)_.d $(BUILD_DIR)/${MAT$(PROJECT)_SO:.$(MAT_SO_EXT)=.d}; \
	fi
runtest: $(TEST_ALL_BIN)
	$(TOOL_BUILD_DIR)/caffe
	$(TEST_ALL_BIN) $(TEST_GPUID) --gtest_shuffle $(TEST_FILTER)
pytest: py
	cd python; python -m unittest discover -s caffe/test
mattest: mat
	cd matlab; $(MATLAB_DIR)/bin/matlab -nodisplay -r 'caffe.run_tests(), exit()'
warn: $(EMPTY_WARN_REPORT)
$(EMPTY_WARN_REPORT): $(ALL_WARNS) | $(BUILD_DIR)
	@ cat $(ALL_WARNS) > $@
		cat $@; \
		mv $@ $(NONEMPTY_WARN_REPORT); \
		echo "Compiler produced one or more warnings."; \
		exit 1; \
	  fi; \
	  $(RM) $(NONEMPTY_WARN_REPORT); \
	  echo "No compiler warnings!";
$(ALL_WARNS): %.o.$(WARNS_EXT) : %.o
$(BUILD_DIR_LINK): $(BUILD_DIR)/.linked
# Create a target ".linked" in this BUILD_DIR to tell Make that the "build" link
# is currently correct, then delete the one in the OTHER_BUILD_DIR in case it
# exists and $(DEBUG) is toggled later.
$(BUILD_DIR)/.linked:
	@ mkdir -p $(BUILD_DIR)
	@ $(RM) $(OTHER_BUILD_DIR)/.linked
	@ $(RM) -r $(BUILD_DIR_LINK)
	@ ln -s $(BUILD_DIR) $(BUILD_DIR_LINK)
	@ touch $@
$(ALL_BUILD_DIRS): | $(BUILD_DIR_LINK)
	@ mkdir -p $@
$(DYNAMIC_NAME): $(OBJS) | $(LIB_BUILD_DIR)
	@ echo LD -o $@
	$(Q)$(CXX) -shared -o $@ $(OBJS) $(VERSIONFLAGS) $(LINKFLAGS) $(LDFLAGS)
	@ cd $(BUILD_DIR)/lib; rm -f $(DYNAMIC_NAME_SHORT);   ln -s $(DYNAMIC_VERSIONED_NAME_SHORT) $(DYNAMIC_NAME_SHORT)
$(STATIC_NAME): $(OBJS) | $(LIB_BUILD_DIR)
	@ echo AR -o $@
	$(Q)ar rcs $@ $(OBJS)
$(BUILD_DIR)/%.o: %.cpp | $(ALL_BUILD_DIRS)
	@ echo CXX $<
	$(Q)$(CXX) $< $(CXXFLAGS) -c -o $@ 2> $@.$(WARNS_EXT) \
		|| (cat $@.$(WARNS_EXT); exit 1)
	@ cat $@.$(WARNS_EXT)
$(PROTO_BUILD_DIR)/%.pb.o: $(PROTO_BUILD_DIR)/%.pb.cc $(PROTO_GEN_HEADER) \
		| $(PROTO_BUILD_DIR)
	@ echo CXX $<
$(BUILD_DIR)/cuda/%.o: %.cu | $(ALL_BUILD_DIRS)
	@ echo NVCC $<
	$(Q)$(CUDA_DIR)/bin/nvcc $(NVCCFLAGS) $(CUDA_ARCH) -M $< -o ${@:.o=.d} \
		-odir $(@D)
	$(Q)$(CUDA_DIR)/bin/nvcc $(NVCCFLAGS) $(CUDA_ARCH) -c $< -o $@ 2> $@.$(WARNS_EXT) \
$(TEST_ALL_BIN): $(TEST_MAIN_SRC) $(TEST_OBJS) $(GTEST_OBJ) \
		| $(DYNAMIC_NAME) $(TEST_BIN_DIR)
	$(Q)$(CXX) $(TEST_MAIN_SRC) $(TEST_OBJS) $(GTEST_OBJ) \
		-o $@ $(LINKFLAGS) $(LDFLAGS) -l$(LIBRARY_NAME) -Wl,-rpath,$(ORIGIN)/../lib
$(TEST_CU_BINS): $(TEST_BIN_DIR)/%.testbin: $(TEST_CU_BUILD_DIR)/%.o \
	$(GTEST_OBJ) | $(DYNAMIC_NAME) $(TEST_BIN_DIR)
	@ echo LD $<
	$(Q)$(CXX) $(TEST_MAIN_SRC) $< $(GTEST_OBJ) \
$(TEST_CXX_BINS): $(TEST_BIN_DIR)/%.testbin: $(TEST_CXX_BUILD_DIR)/%.o \
	@ echo LD $<
# Target for extension-less symlinks to tool binaries with extension '*.bin'.
$(TOOL_BUILD_DIR)/%: $(TOOL_BUILD_DIR)/%.bin | $(TOOL_BUILD_DIR)
	@ $(RM) $@
	@ ln -s $(notdir $<) $@
$(TOOL_BINS): %.bin : %.o | $(DYNAMIC_NAME)
	@ echo CXX/LD -o $@
	$(Q)$(CXX) $< -o $@ $(LINKFLAGS) -l$(LIBRARY_NAME) $(LDFLAGS) \
$(EXAMPLE_BINS): %.bin : %.o | $(DYNAMIC_NAME)
	@ echo CXX/LD -o $@
		-Wl,-rpath,$(ORIGIN)/../../lib
proto: $(PROTO_GEN_CC) $(PROTO_GEN_HEADER)
$(PROTO_BUILD_DIR)/%.pb.cc $(PROTO_BUILD_DIR)/%.pb.h : \
		$(PROTO_SRC_DIR)/%.proto | $(PROTO_BUILD_DIR)
	@ echo PROTOC $<
	$(Q)protoc --proto_path=$(PROTO_SRC_DIR) --cpp_out=$(PROTO_BUILD_DIR) $<
$(PY_PROTO_BUILD_DIR)/%_pb2.py : $(PROTO_SRC_DIR)/%.proto \
		$(PY_PROTO_INIT) | $(PY_PROTO_BUILD_DIR)
	@ echo PROTOC \(python\) $<
	$(Q)protoc --proto_path=$(PROTO_SRC_DIR) --python_out=$(PY_PROTO_BUILD_DIR) $<
$(PY_PROTO_INIT): | $(PY_PROTO_BUILD_DIR)
	touch $(PY_PROTO_INIT)
clean:
	@- $(RM) -rf $(ALL_BUILD_DIRS)
	@- $(RM) -rf $(OTHER_BUILD_DIR)
	@- $(RM) -rf $(BUILD_DIR_LINK)
	@- $(RM) -rf $(DISTRIBUTE_DIR)
	@- $(RM) $(PY$(PROJECT)_SO)
	@- $(RM) $(MAT$(PROJECT)_SO)
supercleanfiles:
	$(eval SUPERCLEAN_FILES := $(strip \
			$(foreach ext,$(SUPERCLEAN_EXTS), $(shell find . -name '*$(ext)' \
			-not -path './data/*'))))
supercleanlist: supercleanfiles
	if [ -z "$(SUPERCLEAN_FILES)" ]; then \
		echo "No generated files found."; \
	else \
		echo $(SUPERCLEAN_FILES) | tr ' ' '\n'; \
	fi
superclean: clean supercleanfiles
	else \
		echo "Deleting the following generated files:"; \
		$(RM) $(SUPERCLEAN_FILES); \
	fi
$(DIST_ALIASES): $(DISTRIBUTE_DIR)
$(DISTRIBUTE_DIR): all py | $(DISTRIBUTE_SUBDIRS)
	# add proto
	cp -r src/caffe/proto $(DISTRIBUTE_DIR)/
	# add include
	cp -r include $(DISTRIBUTE_DIR)/
	mkdir -p $(DISTRIBUTE_DIR)/include/caffe/proto
	cp $(PROTO_GEN_HEADER_SRCS) $(DISTRIBUTE_DIR)/include/caffe/proto
	# add tool and example binaries
	cp $(TOOL_BINS) $(DISTRIBUTE_DIR)/bin
	cp $(EXAMPLE_BINS) $(DISTRIBUTE_DIR)/bin
	# add libraries
	cp $(STATIC_NAME) $(DISTRIBUTE_DIR)/lib
	install -m 644 $(DYNAMIC_NAME) $(DISTRIBUTE_DIR)/lib
	cd $(DISTRIBUTE_DIR)/lib; rm -f $(DYNAMIC_NAME_SHORT);   ln -s $(DYNAMIC_VERSIONED_NAME_SHORT) $(DYNAMIC_NAME_SHORT)
	# add python - it's not the standard way, indeed...
	cp -r python $(DISTRIBUTE_DIR)/
-include $(DEPS)
According to the Makefile & Makefile.config, caffe has been compiled successfully.
Please help with this tough problem.
Could you use a smaller network to check if it can be executed correctly? Ex. AlexNet?
This check will narrow down the root cause comes from memory or not.
Hi AastaLLL,
If I do not use CUDNN, then VGG19 can run on TX2 successfully. But using it will cause a such problem. Does using CUDNN will need more memory compared to the one does not? By the way, how do I check If I install CUDNN successfully?
With cuDNN, Caffe will inference a model on GPU mode.
We have launched VGG16 on GPU mode successfully but have no experience on VGG19.
Before giving a further suggestion, could you run a smaller network to check if this issue is from out of memory?
hi I also meet the same problem on tx2 when I am trying to run caffe-ssd.
After building caffe-ssd I can run it with :
python ssd_detect_py
but ,when I try to use ssd_detect.bin,it just list the following errors:
F1216 08:25:32.651688 1943 cudnn_conv_layer.cpp:53] Check failed: status == CUDNN_STATUS_SUCCESS (4 vs. 0) CUDNN_STATUS_INTERNAL_ERROR
@ 0x7fb3201718 google::LogMessage::Fail()
@ 0x7fb3203614 google::LogMessage::SendToLog()
@ 0x7fb3201290 google::LogMessage::Flush()
@ 0x7fb3203eb4 google::LogMessageFatal::~LogMessageFatal()
@ 0x7fb35d43e8 caffe::CuDNNConvolutionLayer<>::LayerSetUp()
@ 0x7fb363fbc4 caffe::Net<>::Init()
@ 0x7fb364193c caffe::Net<>::Net()
@ 0x40870c Detector::Detector()
@ 0x4053ec main
@ 0x7fb27d78a0 __libc_start_main
I have cancled USE_CUDNN := 1 in the Makefile.config before build this project.
Can you give me some advice?Thanks.
Hi chay1991,
We have replied your question on this topic:
Let’s track this issue on that topic.
