nvidia@nvidia-desktop:~/caffe-master/build$ sudo make
[sudo] password for nvidia:
CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument value or use a … suffix to tell
CMake that the project does not need compatibility with older versions.
CMake Warning (dev) at cmake/Misc.cmake:32 (set):
implicitly converting ‘BOOLEAN’ to ‘STRING’ type.
Call Stack (most recent call first):
CMakeLists.txt:25 (include)
This warning is for project developers. Use -Wno-dev to suppress it.
– Found Boost: /usr/include (found suitable version “1.65.1”, minimum required is “1.54”) found components: system thread filesystem chrono date_time atomic
– Found gflags (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libgflags.so)
– Found glog (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libglog.so)
– Found PROTOBUF Compiler: /usr/bin/protoc
– Found lmdb (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/liblmdb.so)
– Found LevelDB (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libleveldb.so)
– Found Snappy (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libsnappy.so)
– CUDA detected: 10.2
– Found cuDNN: ver. 8.0.0 found (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libcudnn.so)
– Added CUDA NVCC flags for: sm_53
– OpenCV found (/usr/lib/aarch64-linux-gnu/cmake/opencv4)
– Found Atlas (include: /usr/include/aarch64-linux-gnu library: /usr/lib/aarch64-linux-gnu/libatlas.so lapack: /usr/lib/aarch64-linux-gnu/liblapack.so
– NumPy ver. 1.13.3 found (include: /usr/lib/python2.7/dist-packages/numpy/core/include)
– Found Boost: /usr/include (found suitable version “1.65.1”, minimum required is “1.46”) found components: python
– Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
– ******************* Caffe Configuration Summary *******************
– General:
– Version : 1.0.0
– Git : unknown
– System : Linux
– C++ compiler : /usr/bin/c++
– Release CXX flags : -O3 -DNDEBUG -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
– Debug CXX flags : -g -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
– Build type : Release
– BUILD_SHARED_LIBS : ON
– BUILD_python : ON
– BUILD_matlab : OFF
– BUILD_docs : ON
– CPU_ONLY : OFF
– USE_OPENCV : ON
– USE_LEVELDB : ON
– USE_LMDB : ON
– USE_NCCL : OFF
– ALLOW_LMDB_NOLOCK : OFF
– USE_HDF5 : ON
– Dependencies:
– BLAS : Yes (Atlas)
– Boost : Yes (ver. 1.65)
– glog : Yes
– gflags : Yes
– protobuf : Yes (ver. 3.0.0)
– lmdb : Yes (ver. 0.9.21)
– LevelDB : Yes (ver. 1.20)
– Snappy : Yes (ver. ..)
– OpenCV : Yes (ver. 4.1.1)
– CUDA : Yes (ver. 10.2)
– NVIDIA CUDA:
– Target GPU(s) : Auto
– GPU arch(s) : sm_53
– cuDNN : Yes (ver. 8.0.0)
– Python:
– Interpreter : /usr/bin/python2.7 (ver. 2.7.17)
– Libraries : /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.17)
– NumPy : /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.13.3)
– Documentaion:
– Doxygen : No
– config_file :
– Install:
– Install path : /home/nvidia/caffe-master/.build_release/install
– Configuring done
– Generating done
– Build files have been written to: /home/nvidia/caffe-master/.build_release
Consolidate compiler generated dependencies of target caffeproto
[ 1%] Built target caffeproto
[ 1%] Building CXX object src/caffe/CMakeFiles/caffe.dir/layers/cudnn_conv_layer.cpp.o
In file included from /home/nvidia/caffe-master/include/caffe/util/device_alternate.hpp:40:0,
from /home/nvidia/caffe-master/include/caffe/common.hpp:19,
from /home/nvidia/caffe-master/include/caffe/blob.hpp:8,
from /home/nvidia/caffe-master/include/caffe/layers/cudnn_conv_layer.hpp:6,
from /home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:5:
/home/nvidia/caffe-master/include/caffe/util/cudnn.hpp: In function ‘const char* cudnnGetErrorString(cudnnStatus_t)’:
/home/nvidia/caffe-master/include/caffe/util/cudnn.hpp:21:10: warning: enumeration value ‘CUDNN_STATUS_VERSION_MISMATCH’ not handled in switch [-Wswitch]
switch (status) {
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp: In member function ‘virtual void caffe::CuDNNConvolutionLayer::Reshape(const std::vector<caffe::Blob>&, const std::vector<caffe::Blob>&)’:
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:136:7: error: ‘CUDNN_CONVOLUTION_FWD_SPECIFY_WORKSPACE_LIMIT’ was not declared in this scope
CUDNN_CONVOLUTION_FWD_SPECIFY_WORKSPACE_LIMIT,
/home/nvidia/caffe-master/include/caffe/util/cudnn.hpp:15:28: note: in definition of macro ‘CUDNN_CHECK’
cudnnStatus_t status = condition;
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:136:7: note: suggested alternative: ‘CUDNN_CONVOLUTION_FWD_ALGO_DIRECT’
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:131:17: error: there are no arguments to ‘cudnnGetConvolutionForwardAlgorithm’ that depend on a template parameter, so a declaration of ‘cudnnGetConvolutionForwardAlgorithm’ must be available [-fpermissive]
CUDNN_CHECK(cudnnGetConvolutionForwardAlgorithm(handle_[0],
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:131:17: note: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:151:11: error: ‘CUDNN_CONVOLUTION_BWD_FILTER_SPECIFY_WORKSPACE_LIMIT’ was not declared in this scope
CUDNN_CONVOLUTION_BWD_FILTER_SPECIFY_WORKSPACE_LIMIT,
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:151:11: note: suggested alternative: ‘CUDNN_CONVOLUTION_BWD_FILTER_ALGO_COUNT’
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:149:17: error: there are no arguments to ‘cudnnGetConvolutionBackwardFilterAlgorithm’ that depend on a template parameter, so a declaration of ‘cudnnGetConvolutionBackwardFilterAlgorithm’ must be available [-fpermissive]
CUDNN_CHECK(cudnnGetConvolutionBackwardFilterAlgorithm(handle_[0],
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:162:11: error: ‘CUDNN_CONVOLUTION_BWD_DATA_SPECIFY_WORKSPACE_LIMIT’ was not declared in this scope
CUDNN_CONVOLUTION_BWD_DATA_SPECIFY_WORKSPACE_LIMIT,
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:162:11: note: suggested alternative: ‘CUDNN_CONVOLUTION_BWD_DATA_ALGO_COUNT’
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:160:17: error: there are no arguments to ‘cudnnGetConvolutionBackwardDataAlgorithm’ that depend on a template parameter, so a declaration of ‘cudnnGetConvolutionBackwardDataAlgorithm’ must be available [-fpermissive]
CUDNN_CHECK(cudnnGetConvolutionBackwardDataAlgorithm(handle_[0],
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp: In instantiation of ‘void caffe::CuDNNConvolutionLayer::Reshape(const std::vector<caffe::Blob>&, const std::vector<caffe::Blob>&) [with Dtype = float]’:
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:266:1: required from here
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:131:52: error: ‘cudnnGetConvolutionForwardAlgorithm’ was not declared in this scope
bottom_descs_[i],
filter_desc_,
conv_descs_[i],
top_descs_[i],
workspace_limit_bytes,
&fwd_algo_[i]));
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:131:52: note: suggested alternative: ‘cudnnGetConvolutionForwardAlgorithm_v7’
bottom_descs_[i],
filter_desc_,
conv_descs_[i],
top_descs_[i],
&fwd_algo_[i]));
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:149:59: error: ‘cudnnGetConvolutionBackwardFilterAlgorithm’ was not declared in this scope
bottom_descs_[i], top_descs_[i], conv_descs_[i], filter_desc_,
workspace_limit_bytes, &bwd_filter_algo_[i]) );
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:149:59: note: suggested alternative: ‘cudnnGetConvolutionBackwardFilterAlgorithm_v7’
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:160:57: error: ‘cudnnGetConvolutionBackwardDataAlgorithm’ was not declared in this scope
filter_desc_, top_descs_[i], conv_descs_[i], bottom_descs_[i],
workspace_limit_bytes, &bwd_data_algo_[i]));
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp:160:57: note: suggested alternative: ‘cudnnGetConvolutionBackwardDataAlgorithm_v7’
/home/nvidia/caffe-master/src/caffe/layers/cudnn_conv_layer.cpp: In instantiation of ‘void caffe::CuDNNConvolutionLayer::Reshape(const std::vector<caffe::Blob>&, const std::vector<caffe::Blob>&) [with Dtype = double]’:
bottom_descs_[i],
filter_desc_,
conv_descs_[i],
top_descs_[i],
&fwd_algo_[i]));
bottom_descs_[i],
filter_desc_,
conv_descs_[i],
top_descs_[i],
&fwd_algo_[i]));
src/caffe/CMakeFiles/caffe.dir/build.make:39275: recipe for target ‘src/caffe/CMakeFiles/caffe.dir/layers/cudnn_conv_layer.cpp.o’ failed
make[2]: *** [src/caffe/CMakeFiles/caffe.dir/layers/cudnn_conv_layer.cpp.o] Error 1
CMakeFiles/Makefile2:377: recipe for target ‘src/caffe/CMakeFiles/caffe.dir/all’ failed
make[1]: *** [src/caffe/CMakeFiles/caffe.dir/all] Error 2
Makefile:135: recipe for target ‘all’ failed
make: *** [all] Error 2
