Hi everybody!
jetson nano version : Jetpack 4.6.4
I am going to build opencv 4.1.1 with cuda on jetson nano 4G evaluation board.
and open cv version 4.1.1;
ı tyr this : GitHub - mdegans/nano_build_opencv: Build OpenCV on Nvidia Jetson Nano
The build was successful, but it appears as CUDA:No
please help
Please try the below script but update the version to 4.1.1:
I got this error
Scanning dependencies of target opencv_videoio_plugins
[ 24%] Built target opencv_videoio_plugins
Scanning dependencies of target opencv_core_pch_dephelp
[ 24%] Building CXX object modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/opencv_core_pch_dephelp.cxx.o
[ 24%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/internal/utility.cc.o
In file included from /home/tom07/Downloads/workspace/opencv-4.1.1/modules/core/src/precomp.hpp:55:0,
from /home/tom07/Downloads/workspace/opencv-4.1.1/release/modules/core/opencv_core_pch_dephelp.cxx:1:
/home/tom07/Downloads/workspace/opencv-4.1.1/modules/core/include/opencv2/core/private.hpp:66:12: fatal error: Eigen/Core: No such file or directory
# include <Eigen/Core>
compilation terminated.
modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/build.make:62: recipe for target 'modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/opencv_core_pch_dephelp.cxx.o' failed
make[2]: *** [modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/opencv_core_pch_dephelp.cxx.o] Error 1
CMakeFiles/Makefile2:2768: recipe for target 'modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/all' failed
make[1]: *** [modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 24%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/json_util.cc.o
[ 24%] Building CXX object 3rdparty/carotene/hal/carotene/CMakeFiles/carotene_objs.dir/src/separable_filter.cpp.o
[ 24%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/message_differencer.cc.o
[ 24%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/time_util.cc.o
[ 24%] Building CXX object 3rdparty/carotene/hal/carotene/CMakeFiles/carotene_objs.dir/src/sobel.cpp.o
[ 24%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/util/type_resolver_util.cc.o
[ 24%] Building CXX object 3rdparty/carotene/hal/carotene/CMakeFiles/carotene_objs.dir/src/sub.cpp.o
[ 24%] Building CXX object 3rdparty/carotene/hal/carotene/CMakeFiles/carotene_objs.dir/src/sum.cpp.o
[ 24%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/wire_format.cc.o
[ 24%] Building CXX object 3rdparty/carotene/hal/carotene/CMakeFiles/carotene_objs.dir/src/template_matching.cpp.o
[ 24%] Building CXX object 3rdparty/carotene/hal/carotene/CMakeFiles/carotene_objs.dir/src/threshold.cpp.o
[ 24%] Building CXX object 3rdparty/carotene/hal/carotene/CMakeFiles/carotene_objs.dir/src/warp_affine.cpp.o
[ 24%] Building CXX object 3rdparty/protobuf/CMakeFiles/libprotobuf.dir/src/google/protobuf/wrappers.pb.cc.o
[ 24%] Building CXX object 3rdparty/carotene/hal/carotene/CMakeFiles/carotene_objs.dir/src/warp_perspective.cpp.o
[ 24%] Built target carotene_objs
[ 24%] Linking CXX static library ../lib/liblibprotobuf.a
[ 24%] Built target libprotobuf
Makefile:162: recipe for target 'all' failed
make: *** [all] Error 2
[sudo] password for tom07:
[ 0%] Built target gen-pkgconfig
[ 7%] Built target libwebp
[ 9%] Built target libjasper
[ 15%] Built target IlmImf
[ 19%] Built target libprotobuf
[ 19%] Built target quirc
[ 22%] Built target carotene_objs
Scanning dependencies of target tegra_hal
[ 23%] Linking CXX static library ../../lib/libtegra_hal.a
[ 23%] Built target tegra_hal
[ 24%] Built target ittnotify
[ 25%] Built target ade
[ 25%] Built target opencv_videoio_plugins
Scanning dependencies of target opencv_cudev
[ 25%] Building CXX object modules/cudev/CMakeFiles/opencv_cudev.dir/src/stub.cpp.o
[ 25%] Linking CXX shared library ../../lib/libopencv_cudev.so
[ 25%] Built target opencv_cudev
[ 25%] Building CXX object modules/core/CMakeFiles/opencv_core_pch_dephelp.dir/opencv_core_pch_dephelp.cxx.o
** Install opencv-4.1.1 successfully
** Bye :)
log
log.txt (56.5 KB)
I flashed Jetson, changed the file you suggested to 4.1.1 and ran it.
Based on this error:
Please try to install the dependency.
$ sudo apt install libeigen3-dev
$ cd /usr/include
$ sudo ln -sf eigen3/Eigen Eigen
hi i reset the sd card and applied the following file.
Log file is attached. But it shows as Cudnn:No.
And should I make a setting to run open cv on GPU. I am new to this code, thank you for your help.
-- NVIDIA CUDA: YES (ver 10.2, CUFFT CUBLAS FAST_MATH)
-- NVIDIA GPU arch: 53
-- NVIDIA PTX archs:
-- cuDNN: NO
-- OpenCL: YES (no extra features)
-- Include path: /home/tom07/opencv/3rdparty/include/opencl/1.2
-- Link libraries: Dynamic load
openCV_build.log (441.9 KB)
cuDNN is used for neural network inference.
Based on your log, CUDA support is enabled.
That’s good to hear, it’s finally happened. But when I try to open the py file I attached, I get the following error.
net.setPreferableBackend(cv2.dnn.DNN_BACKEND_CUDA)
AttributeError: module 'cv2.dnn' has no attribute 'DNN_BACKEND_CUDA'
open cv version =4.1.1,
Python =3.6.9
weight file prepared and trained with custom dataset
real_time_yolo.py (2.5 KB)
I tried readNet and readNetFromDarknet the same error
You need OpenCV 4.2 or above to use “DNN_BACKEND_CUDA”.
https://github.com/AastaNV/JEP/blob/master/script/install_opencv4.5.0_Jetson.sh
I set it to 4.2.0 and built again, this time I get the attached error.
/Downloads/workspace/opencv-4.2.0/modules/dnn/src/dnn.cpp (1363) setUpNet DNN module was not built with CUDA backend; switching to CPU
General configuration for OpenCV 4.2.0 =====================================
Version control: unknown
Extra modules:
Location (extra): /home/tom07/Downloads/workspace/opencv_contrib-4.2.0/modules
Version control (extra): unknown
Platform:
Timestamp: 2023-09-12T08:52:21Z
Host: Linux 4.9.253-tegra aarch64
CMake: 3.10.2
CMake generator: Unix Makefiles
CMake build tool: /usr/bin/make
Configuration: RELEASE
CPU/HW features:
Baseline: NEON FP16
required: NEON
disabled: VFPV3
C/C++:
Built as dynamic libs?: YES
C++ Compiler: /usr/bin/c++ (ver 7.5.0)
C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /usr/bin/cc
C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release): -Wl,--gc-sections
Linker flags (Debug): -Wl,--gc-sections
ccache: NO
Precompiled headers: NO
Extra dependencies: m pthread cudart_static -lpthread dl rt nppc nppial nppicc nppicom nppidei nppif nppig nppim nppist nppisu nppitc npps cublas cufft -L/usr/local/cuda/lib64 -L/usr/lib/aarch64-linux-gnu
3rdparty dependencies:
OpenCV modules:
To be built: aruco bgsegm bioinspired calib3d ccalib core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev datasets dnn dnn_objdetect dnn_superres dpm face features2d flann freetype fuzzy gapi hfs highgui img_hash imgcodecs imgproc line_descriptor ml objdetect optflow phase_unwrapping photo plot python3 quality reg rgbd saliency shape stereo stitching structured_light superres surface_matching text tracking video videoio videostab xfeatures2d ximgproc xobjdetect xphoto
Disabled: python2 world
Disabled by dependency: -
Unavailable: cnn_3dobj cvv hdf java js matlab ovis sfm ts viz
Applications: apps
Documentation: NO
Non-free algorithms: NO
GUI:
GTK+: YES (ver 3.22.30)
GThread : YES (ver 2.56.4)
GtkGlExt: NO
VTK support: NO
Media I/O:
ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so (ver 80)
WEBP: build (ver encoder: 0x020e)
PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.34)
TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.9)
JPEG 2000: build (ver 1.900.1)
OpenEXR: build (ver 2.3.0)
HDR: YES
SUNRASTER: YES
PXM: YES
PFM: YES
Video I/O:
DC1394: YES (2.2.5)
FFMPEG: YES
avcodec: YES (57.107.100)
avformat: YES (57.83.100)
avutil: YES (55.78.100)
swscale: YES (4.8.100)
avresample: NO
GStreamer: YES (1.14.5)
v4l/v4l2: YES (linux/videodev2.h)
Parallel framework: pthreads
Trace: YES (with Intel ITT)
Other third-party libraries:
Lapack: NO
Eigen: YES (ver 3.3.4)
Custom HAL: YES (carotene (ver 0.0.1))
Protobuf: build (3.5.1)
NVIDIA CUDA: YES (ver 10.2, CUFFT CUBLAS)
NVIDIA GPU arch: 53 62 72
NVIDIA PTX archs:
cuDNN: NO
Include path: /home/tom07/Downloads/workspace/opencv-4.2.0/3rdparty/include/opencl/1.2
Python 3:
Interpreter: /usr/bin/python3 (ver 3.6.9)
Libraries: /usr/lib/aarch64-linux-gnu/libpython3.6m.so (ver 3.6.9)
numpy: /usr/lib/python3/dist-packages/numpy/core/include (ver 1.13.3)
install path: lib/python3.6/dist-packages/cv2/python-3.6
Python (for build): /usr/bin/python2.7
Java:
ant: NO
JNI: NO
Java wrappers: NO
Java tests: NO
Install to: /usr/local
As Mt.Hiker mentioned, if you want to use the OpenCV DNN function, you will need to build it with some extra flags.
For more details, please check below topic:
Why I am getting this errors:
[ 27%] Linking CXX static library ../../lib/libtegra_hal.a
[ 27%] Built target tegra_hal
[ 27%] Building CXX object modules/cudev/CMakeFiles/opencv_cudev.dir/src/stub.cpp.o
[ 27%] Linking CXX shared library ../../lib/libopencv_cudev.so
/usr/bin/ld: cannot find -laarch64-linux-gnu
collect2: error: ld returned 1 exit status
modules/cudev/CMakeFiles/opencv_cudev.dir/build.make:95: recipe for target 'lib/libopencv_cudev.so.4.2.0' failed
make[2]: *** [lib/libopencv_cudev.so.4.2.0] Error 1
CMakeFiles/Makefile2:2599: recipe for target 'modules/cudev/CMakeFiles/opencv_cudev.dir/all' failed
make[1]: *** [modules/cudev/CMakeFiles/opencv_cudev.dir/all] Error 2
[ 27%] Linking CXX static library ../lib/liblibprotobuf.a
[ 27%] Built target libprotobuf
real 4m29,689s
user 15m58,480s
sys 1m0,916s
Make did not build
Retrying ...
[ 8%] Built target libwebp
[ 11%] Built target libjasper
[ 18%] Built target IlmImf
[ 22%] Built target libprotobuf
[ 22%] Built target quirc
[ 25%] Built target carotene_objs
[ 26%] Built target tegra_hal
[ 26%] Built target ittnotify
[ 27%] Built target ade
[ 27%] Built target opencv_videoio_plugins
Make did not successfully build
Please fix issues and retry build
finaly Cmake:
time cmake -D CMAKE_BUILD_TYPE=RELEASE \
-D CUDNN_LIBRARY=/usr/lib/aarch64-linux-gnu/ \
-D CUDNN_INCLUDE_DIR=/usr/include/ \
-D CUDNN_VERSION=8.2 \
-D WITH_CUDNN=ON \
-D OPENCV_DNN_CUDA=ON \
-D CMAKE_INSTALL_PREFIX=${CMAKE_INSTALL_PREFIX} \
-D WITH_CUDA=ON \
-D CUDA_ARCH_BIN=${ARCH_BIN} \
-D CUDA_ARCH_PTX="" \
-D CUDA_FAST_MATH=ON \
-D WITH_CUBLAS=1 \
-D WITH_LIBV4L=ON \
-D WITH_V4L=ON \
-D WITH_GSTREAMER=ON \
-D WITH_GSTREAMER_0_10=OFF \
-D WITH_QT=ON \
-D BUILD_opencv_python2=OFF \
-D BUILD_opencv_python3=ON \
-D BUILD_TESTS=OFF \
-D BUILD_PERF_TESTS=OFF \
-D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib/modules \
$"PACKAGE_OPENCV" \
full sh file:
buildOpenCV.sh (7.3 KB)
Do you run it on the Jetson platform?
The error indicates it cannot find the compiling tool.
