OS: Arch Linux
Driver version: 525.89.02
GPU: GeForce GTX 970
I recently added MSAA support to my renderer that uses dynamic rendering. I need to render in two passes:
- Main render pass. MSAA toggleable on/off.
- Second render pass. No MSAA.
- Writes to color buffer from previous pass.
- Reads depth buffer from previous pass to:
- Do depth tests.
- For sampling in fragment shaders (to implement e.g. soft particles).
Everything works as expected on Intel and AMD GPUs I have available for testing. With MSAA enabled and disabled.
However, on the Nvidia GPU I am testing on everything works as expected when MSAA is disabled but not when it is enabled. It seems like depth testing does not work reliably in the second render pass. E.g. soft particles mostly do not show up. Depending on resolution they are visible in some parts of the screen and sometimes with a checkerboard like pattern like in the following image:
Disabling the depth testing in the soft particle pipelines make the particles always show up. Sampling depth buffer in fragment shader seems to always work. As can be seen in the screenshot, I can also sample the resolved depth buffer OK when drawing it in a debug overlay in a later render pass.
I do not get any warnings from the validation layer with VK_VALIDATION_FEATURE_ENABLE_SYNCHRONIZATION_VALIDATION_EXT enabled. Not on any of the GPU:s regardless of if MSAA is enabled or not. So I am not sure what is wrong. Is the validation layer not validating barriers correctly in this case? Or is there maybe a bug in the Nvidia driver?
Below is how I setup my render passes with dynamic rendering (copied from renderer and modified to make sense “standalone”, hopefully there were no mistakes when I extraced it):
// Main render images and views. VK_SAMPLE_COUNT_1_BIT if MSAA disabled. VK_SAMPLE_COUNT_X_BIT, X > 1, if MSAA enabled.
VkImage color_image = ...;
VkImageView color_image_view = ...;
VkImage depth_image = ...;
VkImageView depth_image_view = ...;
// Resolved images and views. Always VK_SAMPLE_COUNT_1_BIT sample. VK_NULL_HANDLE if MSAA disabled.
VkImage color_resolved_image = ...;
VkImageView color_resolved_image_view = ...;
VkImage depth_resolved_image = ...;
VkImageView depth_resolved_image_view = ...;
////////////////////////////// Main render pass start...
VkImageMemoryBarrier color_barriers[2];
u32 color_barriers_count = 1;
color_barriers[0] = {.sType = VK_STRUCTURE_TYPE_IMAGE_MEMORY_BARRIER};
color_barriers[0].srcAccessMask = VK_ACCESS_MEMORY_READ_BIT;
color_barriers[0].dstAccessMask = VK_ACCESS_COLOR_ATTACHMENT_READ_BIT | VK_ACCESS_COLOR_ATTACHMENT_WRITE_BIT;
color_barriers[0].oldLayout = VK_IMAGE_LAYOUT_UNDEFINED;
color_barriers[0].newLayout = VK_IMAGE_LAYOUT_COLOR_ATTACHMENT_OPTIMAL;
color_barriers[0].srcQueueFamilyIndex = VK_QUEUE_FAMILY_IGNORED;
color_barriers[0].dstQueueFamilyIndex = VK_QUEUE_FAMILY_IGNORED;
color_barriers[0].image = color_image;
color_barriers[0].subresourceRange = {VK_IMAGE_ASPECT_COLOR_BIT, 0, 1, 0, 1};
if (color_resolved_image) {
color_barriers[1] = {.sType = VK_STRUCTURE_TYPE_IMAGE_MEMORY_BARRIER};
color_barriers[1].srcAccessMask = VK_ACCESS_MEMORY_READ_BIT;
color_barriers[1].dstAccessMask = VK_ACCESS_COLOR_ATTACHMENT_READ_BIT | VK_ACCESS_COLOR_ATTACHMENT_WRITE_BIT;
color_barriers[1].oldLayout = VK_IMAGE_LAYOUT_UNDEFINED;
color_barriers[1].newLayout = VK_IMAGE_LAYOUT_COLOR_ATTACHMENT_OPTIMAL;
color_barriers[1].srcQueueFamilyIndex = VK_QUEUE_FAMILY_IGNORED;
color_barriers[1].dstQueueFamilyIndex = VK_QUEUE_FAMILY_IGNORED;
color_barriers[1].image = color_resolved_image;
color_barriers[1].subresourceRange = {VK_IMAGE_ASPECT_COLOR_BIT, 0, 1, 0, 1};
color_barriers_count++;
vkCmdPipelineBarrier(command_buffer,
VK_PIPELINE_STAGE_BOTTOM_OF_PIPE_BIT,
VK_PIPELINE_STAGE_COLOR_ATTACHMENT_OUTPUT_BIT,
VK_DEPENDENCY_BY_REGION_BIT,
0,
nullptr,
0,
nullptr,
color_barriers_count,
color_barriers);
VkImageMemoryBarrier depth_barrier = {.sType = VK_STRUCTURE_TYPE_IMAGE_MEMORY_BARRIER};
depth_barrier.srcAccessMask = VK_ACCESS_SHADER_READ_BIT;
depth_barrier.dstAccessMask = VK_ACCESS_DEPTH_STENCIL_ATTACHMENT_WRITE_BIT;
depth_barrier.oldLayout = VK_IMAGE_LAYOUT_UNDEFINED;
depth_barrier.newLayout = VK_IMAGE_LAYOUT_DEPTH_ATTACHMENT_OPTIMAL;
depth_barrier.srcQueueFamilyIndex = VK_QUEUE_FAMILY_IGNORED;
depth_barrier.dstQueueFamilyIndex = VK_QUEUE_FAMILY_IGNORED;
depth_barrier.image = depth_image;
depth_barrier.subresourceRange = {VK_IMAGE_ASPECT_DEPTH_BIT, 0, 1, 0, 1};
VK_PIPELINE_STAGE_FRAGMENT_SHADER_BIT,
VK_PIPELINE_STAGE_EARLY_FRAGMENT_TESTS_BIT,
0,
nullptr,
0,
nullptr,
1,
&depth_barrier);
if (depth_resolved_image) {
VkImageMemoryBarrier depth_resolve_barrier = {.sType = VK_STRUCTURE_TYPE_IMAGE_MEMORY_BARRIER};
depth_resolve_barrier.srcAccessMask = VK_ACCESS_SHADER_READ_BIT;
depth_resolve_barrier.dstAccessMask = VK_ACCESS_COLOR_ATTACHMENT_WRITE_BIT;
depth_resolve_barrier.oldLayout = VK_IMAGE_LAYOUT_UNDEFINED;
depth_resolve_barrier.newLayout = VK_IMAGE_LAYOUT_DEPTH_ATTACHMENT_OPTIMAL;
depth_resolve_barrier.srcQueueFamilyIndex = VK_QUEUE_FAMILY_IGNORED;
depth_resolve_barrier.dstQueueFamilyIndex = VK_QUEUE_FAMILY_IGNORED;
depth_resolve_barrier.image = depth_resolved_image;
depth_resolve_barrier.subresourceRange = {VK_IMAGE_ASPECT_DEPTH_BIT, 0, 1, 0, 1};
0,
nullptr,
0,
nullptr,
1,
&depth_resolve_barrier);
VkRenderingAttachmentInfo color_attachment = {.sType = VK_STRUCTURE_TYPE_RENDERING_ATTACHMENT_INFO};
color_attachment.imageView = color_image_view;
color_attachment.imageLayout = VK_IMAGE_LAYOUT_COLOR_ATTACHMENT_OPTIMAL;
color_attachment.resolveMode = VK_RESOLVE_MODE_AVERAGE_BIT;
color_attachment.resolveImageView = color_resolved_image_view;
color_attachment.resolveImageLayout = VK_IMAGE_LAYOUT_COLOR_ATTACHMENT_OPTIMAL;
color_attachment.loadOp = VK_ATTACHMENT_LOAD_OP_CLEAR;
color_attachment.storeOp = VK_ATTACHMENT_STORE_OP_STORE;
color_attachment.clearValue = {0.0f, 0.0f, 0.0f, 1.0f};
VkRenderingAttachmentInfo depth_attachment = {.sType = VK_STRUCTURE_TYPE_RENDERING_ATTACHMENT_INFO};
depth_attachment.imageView = depth_image_view;
depth_attachment.imageLayout = VK_IMAGE_LAYOUT_DEPTH_ATTACHMENT_OPTIMAL;
depth_attachment.resolveMode = VK_RESOLVE_MODE_MIN_BIT;
depth_attachment.resolveImageView = depth_resolved_image_view;
depth_attachment.resolveImageLayout = VK_IMAGE_LAYOUT_DEPTH_ATTACHMENT_OPTIMAL;
depth_attachment.loadOp = VK_ATTACHMENT_LOAD_OP_CLEAR;
depth_attachment.storeOp = VK_ATTACHMENT_STORE_OP_STORE;
depth_attachment.clearValue.depthStencil = {1.0f, 0};
VkRenderingInfo rendering_info = {.sType = VK_STRUCTURE_TYPE_RENDERING_INFO};
rendering_info.renderArea.extent = {width, height};
rendering_info.layerCount = 1;
rendering_info.colorAttachmentCount = 1;
rendering_info.pColorAttachments = &color_attachment;
rendering_info.pDepthAttachment = &depth_attachment;
vkCmdBeginRendering(command_buffer, &rendering_info);
////////////////////////////// Main render pass rendering...
vkCmdEndRendering(command_buffer);
color_barriers[0].srcAccessMask = VK_ACCESS_COLOR_ATTACHMENT_READ_BIT | VK_ACCESS_COLOR_ATTACHMENT_WRITE_BIT;
color_barriers[0].dstAccessMask = VK_ACCESS_MEMORY_READ_BIT;
color_barriers[0].oldLayout = VK_IMAGE_LAYOUT_COLOR_ATTACHMENT_OPTIMAL;
color_barriers[0].newLayout = VK_IMAGE_LAYOUT_SHADER_READ_ONLY_OPTIMAL;
color_barriers[1].srcAccessMask = VK_ACCESS_COLOR_ATTACHMENT_READ_BIT | VK_ACCESS_COLOR_ATTACHMENT_WRITE_BIT;
color_barriers[1].dstAccessMask = VK_ACCESS_MEMORY_READ_BIT;
color_barriers[1].oldLayout = VK_IMAGE_LAYOUT_COLOR_ATTACHMENT_OPTIMAL;
color_barriers[1].newLayout = VK_IMAGE_LAYOUT_SHADER_READ_ONLY_OPTIMAL;
VK_PIPELINE_STAGE_FRAGMENT_SHADER_BIT | VK_PIPELINE_STAGE_COMPUTE_SHADER_BIT,
0,
nullptr,
0,
nullptr,
color_barriers);
depth_barrier.srcAccessMask = VK_ACCESS_DEPTH_STENCIL_ATTACHMENT_WRITE_BIT;
depth_barrier.dstAccessMask = VK_ACCESS_SHADER_READ_BIT;
depth_barrier.oldLayout = VK_IMAGE_LAYOUT_DEPTH_ATTACHMENT_OPTIMAL;
depth_barrier.newLayout = VK_IMAGE_LAYOUT_DEPTH_READ_ONLY_OPTIMAL;
VK_PIPELINE_STAGE_LATE_FRAGMENT_TESTS_BIT,
0,
nullptr,
0,
nullptr,
1,
&depth_barrier);
depth_resolve_barrier.srcAccessMask = VK_ACCESS_COLOR_ATTACHMENT_WRITE_BIT;
depth_resolve_barrier.dstAccessMask = VK_ACCESS_SHADER_READ_BIT;
depth_resolve_barrier.oldLayout = VK_IMAGE_LAYOUT_DEPTH_ATTACHMENT_OPTIMAL;
depth_resolve_barrier.newLayout = VK_IMAGE_LAYOUT_DEPTH_READ_ONLY_OPTIMAL;
0,
nullptr,
0,
nullptr,
1,
////////////////////////////// Main render pass done. Start second render pass that only reads depth buffer from main render pass.
VkImageMemoryBarrier color_barrier = {.sType = VK_STRUCTURE_TYPE_IMAGE_MEMORY_BARRIER};
color_barrier.srcAccessMask = VK_ACCESS_MEMORY_READ_BIT;
color_barrier.dstAccessMask = VK_ACCESS_COLOR_ATTACHMENT_READ_BIT | VK_ACCESS_COLOR_ATTACHMENT_WRITE_BIT;
color_barrier.oldLayout = VK_IMAGE_LAYOUT_SHADER_READ_ONLY_OPTIMAL;
color_barrier.newLayout = VK_IMAGE_LAYOUT_COLOR_ATTACHMENT_OPTIMAL;
color_barrier.srcQueueFamilyIndex = VK_QUEUE_FAMILY_IGNORED;
color_barrier.dstQueueFamilyIndex = VK_QUEUE_FAMILY_IGNORED;
color_barrier.image = color_resolved_image ? color_resolved_image : color_image;
color_barrier.subresourceRange = {VK_IMAGE_ASPECT_COLOR_BIT, 0, 1, 0, 1};
0,
nullptr,
0,
nullptr,
1,
&color_barrier);
color_attachment.imageView = color_resolved_image ? color_resolved_image_view : color_image_view;
color_attachment.loadOp = VK_ATTACHMENT_LOAD_OP_LOAD;
depth_attachment.imageView = depth_resolved_image ? depth_resolved_image_view : depth_image_view;
depth_attachment.imageLayout = VK_IMAGE_LAYOUT_DEPTH_READ_ONLY_OPTIMAL;
depth_attachment.loadOp = VK_ATTACHMENT_LOAD_OP_LOAD;
depth_attachment.storeOp = VK_ATTACHMENT_STORE_OP_NONE;
////////////////////////////// Second render pass rendering...
color_barrier.srcAccessMask = VK_ACCESS_COLOR_ATTACHMENT_READ_BIT | VK_ACCESS_COLOR_ATTACHMENT_WRITE_BIT;
color_barrier.dstAccessMask = VK_ACCESS_MEMORY_READ_BIT;
color_barrier.oldLayout = VK_IMAGE_LAYOUT_COLOR_ATTACHMENT_OPTIMAL;
color_barrier.newLayout = VK_IMAGE_LAYOUT_SHADER_READ_ONLY_OPTIMAL;
0,
nullptr,
0,
nullptr,
1,
&color_barrier);
////////////////////////////// Second render pass done.
Another thing I am a bit confused about is that when using VkRenderPass, I had dependencies setup to handle SYNC-HAZARD-WRITE_AFTER_WRITE as described in Synchronization Examples · KhronosGroup/Vulkan-Docs Wiki · GitHub . Also had similar dependencies for SYNC-HAZARD-READ_AFTER_WRITE to handle depth tests and reading of depth buffer in secondary render pass. When migrating to dynamic rendering I could not see how to translate this to image barriers. But since everything seemed to work without any warnings from the validation layer, I hoped things were still OK. Everything worked as expected until I added MSAA and tried it on the Nvidia GPU. Not sure if it is relevant but… maybe it is?
