A simple SDL2 program triggers a memory leak:
#include <SDL2/SDL.h>
#include <cstdio>
#include <memory>
#include <cstdlib>
int main() {
if (std::atexit(SDL_Quit)) {
printf("Registration failed\n");
return 1;
if (SDL_Init(SDL_INIT_VIDEO) < 0) {
printf("SDL_Init error: %s", SDL_GetError());
std::exit(1);
auto free_window = [](SDL_Window* w) { SDL_DestroyWindow(w); };
std::unique_ptr<SDL_Window, decltype(free_window)> window{
SDL_CreateWindow("test window", SDL_WINDOWPOS_CENTERED, SDL_WINDOWPOS_CENTERED, 400, 400,
0),
std::move(free_window)};
if (!window) {
printf("SDL_CreateWindow error: %s", SDL_GetError());
std::exit(1);
auto free_surface = [](SDL_Surface* s) { SDL_FreeSurface(s); };
std::unique_ptr<SDL_Surface, decltype(free_surface)> surface{SDL_GetWindowSurface(window.get()),
std::move(free_surface)};
if (!surface) {
printf("SDL_GetWindowSurface error: %s", SDL_GetError());
std::exit(1);
SDL_memset(surface->pixels, 0, surface->h * surface->pitch);
while (true) {
SDL_Event event;
while (SDL_PollEvent(&event)) {
if (event.type == SDL_QUIT) {
std::exit(0);
auto* pixels = reinterpret_cast<unsigned*>(surface->pixels);
for (int y = 0; y != 400; ++y) {
for (int x = 0; x != 400; ++x) {
pixels[y * 400 + x] = SDL_MapRGB(surface->format, 255, 255, 255);
SDL_UpdateWindowSurface(window.get());
Build:
g++ leak.cc -isystem /usr/include/SDL2 -fsanitize=address -o leak /usr/lib/libSDL2.so
ASAN output:
==46550==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 6280 byte(s) in 3 object(s) allocated from:
#0 0x7fd08a6bf411 in __interceptor_calloc /usr/src/debug/gcc/libsanitizer/asan/asan_malloc_linux.cpp:77
#1 0x7fd0858ba06f (/usr/lib/libnvidia-glcore.so.515.57+0xeba06f)
Direct leak of 1024 byte(s) in 1 object(s) allocated from:
#0 0x7fd08a6be7ea in __interceptor_realloc /usr/src/debug/gcc/libsanitizer/asan/asan_malloc_linux.cpp:85
#1 0x7fd0858b951a (/usr/lib/libnvidia-glcore.so.515.57+0xeb951a)
Direct leak of 520 byte(s) in 13 object(s) allocated from:
#0 0x7fd08a6bfa89 in __interceptor_malloc /usr/src/debug/gcc/libsanitizer/asan/asan_malloc_linux.cpp:69
#1 0x7fd08a0c2876 (<unknown module>)
Direct leak of 368 byte(s) in 2 object(s) allocated from:
#1 0x7fd08a0b11e0 (/usr/lib/libasan.so.8.0.0+0x7d11e0)
Direct leak of 112 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0be120 (<unknown module>)
Direct leak of 96 byte(s) in 3 object(s) allocated from:
#1 0x7fd08a0beed5 (<unknown module>)
Direct leak of 40 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0bf348 (<unknown module>)
Direct leak of 24 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0c6b00 (<unknown module>)
Direct leak of 8 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0b765a (/usr/lib/libasan.so.8.0.0+0x7d765a)
Indirect leak of 144448 byte(s) in 453 object(s) allocated from:
Indirect leak of 7989 byte(s) in 18 object(s) allocated from:
#1 0x7fd08a0befd5 (<unknown module>)
Indirect leak of 4930 byte(s) in 374 object(s) allocated from:
#1 0x7fd0858b9bdc (/usr/lib/libnvidia-glcore.so.515.57+0xeb9bdc)
Indirect leak of 1596 byte(s) in 3 object(s) allocated from:
#1 0x7fd08a0bf595 (<unknown module>)
Indirect leak of 920 byte(s) in 5 object(s) allocated from:
Indirect leak of 752 byte(s) in 6 object(s) allocated from:
Indirect leak of 288 byte(s) in 4 object(s) allocated from:
#1 0x7fd08a09bc12 (/usr/lib/libasan.so.8.0.0+0x7bbc12)
Indirect leak of 264 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0a18da (/usr/lib/libasan.so.8.0.0+0x7c18da)
Indirect leak of 240 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0c889c (<unknown module>)
#2 0x7ffffffff (<unknown module>)
Indirect leak of 232 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0bc8ee (<unknown module>)
Indirect leak of 184 byte(s) in 1 object(s) allocated from:
#2 0xd00000004 (<unknown module>)
Indirect leak of 176 byte(s) in 2 object(s) allocated from:
#1 0x7fd08a0b6b70 (/usr/lib/libasan.so.8.0.0+0x7d6b70)
Indirect leak of 160 byte(s) in 4 object(s) allocated from:
Indirect leak of 152 byte(s) in 7 object(s) allocated from:
#1 0x7fd08a0bfc08 (<unknown module>)
Indirect leak of 128 byte(s) in 2 object(s) allocated from:
#1 0x7fd08a0b564d (/usr/lib/libasan.so.8.0.0+0x7d564d)
Indirect leak of 112 byte(s) in 1 object(s) allocated from:
Indirect leak of 96 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0a9055 (/usr/lib/libasan.so.8.0.0+0x7c9055)
Indirect leak of 96 byte(s) in 2 object(s) allocated from:
#1 0x7fd08a0b6c57 (/usr/lib/libasan.so.8.0.0+0x7d6c57)
Indirect leak of 80 byte(s) in 2 object(s) allocated from:
#1 0x7fd08a0b6bf2 (/usr/lib/libasan.so.8.0.0+0x7d6bf2)
Indirect leak of 64 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0a9141 (/usr/lib/libasan.so.8.0.0+0x7c9141)
#1 0x7fd08a0c3b80 (<unknown module>)
Indirect leak of 48 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0a188a (/usr/lib/libasan.so.8.0.0+0x7c188a)
#1 0x7fd08a0a18a1 (/usr/lib/libasan.so.8.0.0+0x7c18a1)
Indirect leak of 48 byte(s) in 2 object(s) allocated from:
Indirect leak of 38 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0c002e (<unknown module>)
Indirect leak of 24 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0a1282 (/usr/lib/libasan.so.8.0.0+0x7c1282)
#1 0x7fd08a0a1b4a (/usr/lib/libasan.so.8.0.0+0x7c1b4a)
#1 0x7fd08a0b6a5c (/usr/lib/libasan.so.8.0.0+0x7d6a5c)
Indirect leak of 16 byte(s) in 1 object(s) allocated from:
#1 0x7fd08a0c3eb3 (<unknown module>)
Indirect leak of 7 byte(s) in 1 object(s) allocated from:
SUMMARY: AddressSanitizer: 171800 byte(s) leaked in 928 allocation(s).
How did you solve this issue? I am also running into it. However not with SDL2 but with the new drivers via CUDA.
EDIT: To clarify I’m still talking about the 515 drivers and not the 520.
And furthermore I’m only seeing the “unknown-module” leaks. But these “leaks” have only occured after upgrading the drivers. After having read around a bit, im assuming the issue has to do with shared library loading / closing. But I am not really an expert on that matter
I did not. Tried writing an empty-body dlclose, as the internet says. Tried many different writings of library names to blacklist the entries in LSAN. Didn’t work either. So I kinda gave up.
Also I’m not even sure how I can go around the <unknown module>. Even if blacklists in LSAN worked, I still don’t know the library name.
Oh well, good to know that its not just me who have no idea on how to solve it :) And yea, no matter what I try to put in the lsan_suppressions file it will not ignore the unknown modules.
this still happends with nvidia 525.60.11 , also happends when creating a simple vulkan and/or opengl instance.
amrits
December 20, 2022, 10:34am
7
I am able to reproduce issue on my local setup and filed a bug 3917145 internally for tracking purpose.
We will debug it now and keep you posted on the same.
C0rn3j
June 2, 2023, 10:07am
8
This issue is mentioned as fixed in the beta driver - 535.43.02
@C0rn3j I’ll keep the update in mind but hopefully what @gulafaran said about Vulkan wasn’t ignored
C0rn3j
June 14, 2023, 10:09pm
10
OP here.
I re-ran this example on Fedora 39, X11, xorg-x11-drv-nvidia 545.29.06.
Here is the output:
==81543==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 2464 byte(s) in 44 object(s) allocated from:
#0 0x7f7ebe4d8cc7 in calloc (/lib64/libasan.so.8+0xd8cc7) (BuildId: 7fcb7759bc17ef47f9682414b6d99732d6a6ab0c)
#1 0x7f7eabfe500d (/lib64/libnvidia-glcore.so.545.29.06+0x9e500d) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#0 0x7f7ebe4d92ef in malloc (/lib64/libasan.so.8+0xd92ef) (BuildId: 7fcb7759bc17ef47f9682414b6d99732d6a6ab0c)
#1 0x7f7ebd84da4b (<unknown module>)
#2 0x7f7ebd8416f4 (/usr/lib64/libasan.so.8.0.0+0x106f4)
#3 0x7f7ebe3564f3 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c4f3) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#4 0x7f7ebe25ad2e in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30d2e) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#5 0x4013f8 in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x4013f8) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#6 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#7 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#8 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
Direct leak of 184 byte(s) in 1 object(s) allocated from:
#1 0x7f7ebd83bb9f (<unknown module>)
#2 0x7f7ebd83db2d (<unknown module>)
#3 0x7f7ebd84669b (/usr/lib64/libasan.so.8.0.0+0x1569b)
#4 0x7f7ebd84686f (/usr/lib64/libasan.so.8.0.0+0x1586f)
#5 0x7f7ebd8479a0 (/usr/lib64/libasan.so.8.0.0+0x169a0)
#6 0x7f7ebd847f8f (/usr/lib64/libasan.so.8.0.0+0x16f8f)
#7 0x7f7ebd82d151 (<unknown module>)
#8 0x7f7ebd841e0c (/usr/lib64/libasan.so.8.0.0+0x10e0c)
#9 0x7f7ebd82ef5d (<unknown module>)
#10 0x7f7ebd82f1fb (<unknown module>)
#11 0x7f7ebd82f4c7 (<unknown module>)
#12 0x7f7ebe356513 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c513) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#13 0x7f7ebe25ad2e in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30d2e) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#14 0x4013f8 in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x4013f8) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#15 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#16 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#17 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#12 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#1 0x7f7ebd84a1e1 (/usr/lib64/libasan.so.8.0.0+0x191e1)
#2 0x7f7ebd82e21f (<unknown module>)
#3 0x7f7ebd82f572 (<unknown module>)
#4 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#1 0x7f7ebd84a179 (/usr/lib64/libasan.so.8.0.0+0x19179)
#2 0x7f7ebd851256 (<unknown module>)
#3 0x7f7ebd8512d7 (<unknown module>)
#4 0x7f7ebd851344 (<unknown module>)
#5 0x7f7ebd826a28 (<unknown module>)
#6 0x7f7ebd82dfed (<unknown module>)
#7 0x7f7ebd82f4b0 (<unknown module>)
#8 0x7f7ebe356513 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c513) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#9 0x7f7ebe25ad2e in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30d2e) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#10 0x4013f8 in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x4013f8) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#11 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#12 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#13 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
Direct leak of 38 byte(s) in 1 object(s) allocated from:
#1 0x7f7ebd849d53 (/usr/lib64/libasan.so.8.0.0+0x18d53)
#2 0x7f7ebd82f699 (<unknown module>)
#3 0x7f7ebe356513 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c513) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
Direct leak of 29 byte(s) in 1 object(s) allocated from:
#2 0x7f7ebd82f8a7 (<unknown module>)
#2 0x7f7ebd82f86a (<unknown module>)
#1 0x7f7ebd851b95 (<unknown module>)
#2 0x7f7ebd82e239 (<unknown module>)
#0 0x7f7ebe4d81e5 (/lib64/libasan.so.8+0xd81e5) (BuildId: 7fcb7759bc17ef47f9682414b6d99732d6a6ab0c)
#1 0x7f7ebd842381 (/usr/lib64/libasan.so.8.0.0+0x11381)
#2 0x7f7ebd82bb4c (<unknown module>)
#3 0x7f7ebd82f150 (<unknown module>)
#4 0x7f7ebd82f4c7 (<unknown module>)
#5 0x7f7ebe356513 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c513) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#6 0x7f7ebe25ad2e in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30d2e) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#7 0x4013f8 in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x4013f8) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#8 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#9 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#10 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
Indirect leak of 4224 byte(s) in 44 object(s) allocated from:
Indirect leak of 2089 byte(s) in 1 object(s) allocated from:
#1 0x7f7ebd849e35 (/usr/lib64/libasan.so.8.0.0+0x18e35)
#2 0x7f7ebd849ec4 (/usr/lib64/libasan.so.8.0.0+0x18ec4)
#3 0x7f7ebd84b93b (/usr/lib64/libasan.so.8.0.0+0x1a93b)
#4 0x7f7ebd83dcda (<unknown module>)
#5 0x7f7ebd84669b (/usr/lib64/libasan.so.8.0.0+0x1569b)
#6 0x7f7ebd84686f (/usr/lib64/libasan.so.8.0.0+0x1586f)
#7 0x7f7ebd8479a0 (/usr/lib64/libasan.so.8.0.0+0x169a0)
#8 0x7f7ebd847f8f (/usr/lib64/libasan.so.8.0.0+0x16f8f)
#9 0x7f7ebd82d151 (<unknown module>)
#10 0x7f7ebd841e0c (/usr/lib64/libasan.so.8.0.0+0x10e0c)
#11 0x7f7ebd82ef5d (<unknown module>)
#12 0x7f7eac06ddab (/lib64/libnvidia-glcore.so.545.29.06+0xa6ddab) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
Indirect leak of 2056 byte(s) in 1 object(s) allocated from:
#1 0x7f7ebd84b08c (/usr/lib64/libasan.so.8.0.0+0x1a08c)
#2 0x7f7ebd84cebb (<unknown module>)
#3 0x7f7ebd846d91 (/usr/lib64/libasan.so.8.0.0+0x15d91)
#4 0x7f7ebd847f51 (/usr/lib64/libasan.so.8.0.0+0x16f51)
#5 0x7f7ebd82d151 (<unknown module>)
#6 0x7f7ebd841d93 (/usr/lib64/libasan.so.8.0.0+0x10d93)
#7 0x7f7ebd82ef5d (<unknown module>)
#8 0x7f7ebd82f1fb (<unknown module>)
#9 0x7f7ebd82f4c7 (<unknown module>)
#10 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
Indirect leak of 2024 byte(s) in 94 object(s) allocated from:
#1 0x7f7eabfe4d51 (/lib64/libnvidia-glcore.so.545.29.06+0x9e4d51) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
Indirect leak of 788 byte(s) in 1 object(s) allocated from:
#1 0x7f7ebd84a4ac (/usr/lib64/libasan.so.8.0.0+0x194ac)
#2 0x7f7ebd851221 (<unknown module>)
#3 0x7f7ebd82c3c8 (<unknown module>)
#4 0x7f7ebd82eda9 (<unknown module>)
#5 0x7f7ebd82ef43 (<unknown module>)
#6 0x7f7ebd82f1fb (<unknown module>)
#7 0x7f7ebd82f4c7 (<unknown module>)
#8 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
Indirect leak of 404 byte(s) in 1 object(s) allocated from:
#2 0x7f7ebd84a9d4 (/usr/lib64/libasan.so.8.0.0+0x199d4)
#3 0x7f7ebd84aad0 (/usr/lib64/libasan.so.8.0.0+0x19ad0)
#4 0x7f7ebd849627 (/usr/lib64/libasan.so.8.0.0+0x18627)
#5 0x7f7ebd82ec6d (<unknown module>)
#6 0x7f7ebd82ef43 (<unknown module>)
#7 0x7f7ebd82f1fb (<unknown module>)
#8 0x7f7ebd82f4c7 (<unknown module>)
#9 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#2 0x7f7ebd85126a (<unknown module>)
Indirect leak of 368 byte(s) in 2 object(s) allocated from:
#12 0x7f7ebe356544 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c544) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
Indirect leak of 352 byte(s) in 1 object(s) allocated from:
#2 0x7f7ebd8384d3 (<unknown module>)
#3 0x7f7ebd838881 (<unknown module>)
#4 0x7f7ebd838c9a (<unknown module>)
#5 0x7f7ebd83919c (<unknown module>)
#6 0x7f7ebd839313 (<unknown module>)
#7 0x7f7ebd83c384 (<unknown module>)
#8 0x7f7ebd83d7b7 (<unknown module>)
#9 0x7f7ebe353956 in SDL_DBus_CallMethodInternal (/lib64/libSDL2-2.0.so.0+0x129956) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#10 0x7f7ebe353b6a in SDL_DBus_CallMethod (/lib64/libSDL2-2.0.so.0+0x129b6a) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#11 0x7f7ebe35a343 in SDL_DBus_ScreensaverInhibit (/lib64/libSDL2-2.0.so.0+0x130343) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#12 0x7f7ebe32e162 in X11_SuspendScreenSaver (/lib64/libSDL2-2.0.so.0+0x104162) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#13 0x7f7ebe303959 in SDL_VideoInit_REAL (/lib64/libSDL2-2.0.so.0+0xd9959) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#14 0x7f7ebe25adb8 in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30db8) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#15 0x4013f8 in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x4013f8) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#16 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#17 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#18 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#2 0x7f7ebd84f25e (<unknown module>)
#4 0x7f7ebd838be9 (<unknown module>)
#9 0x7f7ebe351c25 in SDL_DBus_CallVoidMethodInternal (/lib64/libSDL2-2.0.so.0+0x127c25) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#10 0x7f7ebe353cca in SDL_DBus_CallVoidMethod (/lib64/libSDL2-2.0.so.0+0x129cca) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#11 0x7f7ebe359fe9 in SDL_DBus_ScreensaverInhibit (/lib64/libSDL2-2.0.so.0+0x12ffe9) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#13 0x7f7ebe310e22 in SDL_VideoQuit_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0xe6e22) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#14 0x7f7ebe259e64 in SDL_QuitSubSystem_REAL (/lib64/libSDL2-2.0.so.0+0x2fe64) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#15 0x7f7ebe25a3e8 in SDL_Quit_REAL (/lib64/libSDL2-2.0.so.0+0x303e8) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#16 0x7f7ebdc5efd5 in __run_exit_handlers (/lib64/libc.so.6+0x40fd5) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#17 0x7f7ebdc5f11d in __GI_exit /usr/src/debug/glibc-2.38-14.fc39.x86_64/stdlib/exit.c:141
#18 0x40165d in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x40165d) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#19 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#20 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#21 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#1 0x7f7ebd82c519 (<unknown module>)
#2 0x7f7ebd82e065 (<unknown module>)
Indirect leak of 256 byte(s) in 2 object(s) allocated from:
#4 0x7f7ebd852fe6 (<unknown module>)
#5 0x7f7ebd83db71 (<unknown module>)
#6 0x7f7ebd84669b (/usr/lib64/libasan.so.8.0.0+0x1569b)
#7 0x7f7ebd84686f (/usr/lib64/libasan.so.8.0.0+0x1586f)
#8 0x7f7ebd8479a0 (/usr/lib64/libasan.so.8.0.0+0x169a0)
#9 0x7f7ebd847f8f (/usr/lib64/libasan.so.8.0.0+0x16f8f)
#10 0x7f7ebd82d151 (<unknown module>)
#11 0x7f7ebd841e0c (/usr/lib64/libasan.so.8.0.0+0x10e0c)
#12 0x7f7ebd82ef5d (<unknown module>)
#13 0x7f7ebd82f1fb (<unknown module>)
#14 0x7f7ebd82f4c7 (<unknown module>)
#15 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#1 0x7f7ebd85390e (<unknown module>)
#2 0x7f7ebd828ae2 (<unknown module>)
#3 0x7f7ebd848344 (/usr/lib64/libasan.so.8.0.0+0x17344)
#4 0x7f7ebd850387 (<unknown module>)
#5 0x7f7ebd85269d (<unknown module>)
#6 0x7f7ebd842632 (/usr/lib64/libasan.so.8.0.0+0x11632)
#7 0x7f7ebd82e04d (<unknown module>)
#8 0x7f7ebd82f572 (<unknown module>)
#1 0x7f7ebd847ff2 (/usr/lib64/libasan.so.8.0.0+0x16ff2)
#2 0x7f7ebd850387 (<unknown module>)
#3 0x7f7ebd85269d (<unknown module>)
#4 0x7f7ebd842632 (/usr/lib64/libasan.so.8.0.0+0x11632)
#5 0x7f7ebd82e04d (<unknown module>)
#6 0x7f7ebd82f572 (<unknown module>)
#7 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
Indirect leak of 223 byte(s) in 1 object(s) allocated from:
#4 0x7f7ebd84de56 (<unknown module>)
#5 0x7f7ebd838a63 (<unknown module>)
#6 0x7f7ebd83c379 (<unknown module>)
#7 0x7f7ebd83cf20 (<unknown module>)
#8 0x7f7ebd82eb7c (<unknown module>)
#9 0x7f7ebd82ef43 (<unknown module>)
#10 0x7f7eac06ddab (/lib64/libnvidia-glcore.so.545.29.06+0xa6ddab) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#10 0x7f7ebe353971 in SDL_DBus_CallMethodInternal (/lib64/libSDL2-2.0.so.0+0x129971) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#11 0x7f7ebe353b6a in SDL_DBus_CallMethod (/lib64/libSDL2-2.0.so.0+0x129b6a) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#12 0x7f7ebe35a343 in SDL_DBus_ScreensaverInhibit (/lib64/libSDL2-2.0.so.0+0x130343) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#13 0x7f7ebe32e162 in X11_SuspendScreenSaver (/lib64/libSDL2-2.0.so.0+0x104162) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#14 0x7f7ebe303959 in SDL_VideoInit_REAL (/lib64/libSDL2-2.0.so.0+0xd9959) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#15 0x7f7ebe25adb8 in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30db8) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#16 0x4013f8 in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x4013f8) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#17 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#18 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#19 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#2 0x7f7ebd83c9b4 (<unknown module>)
#3 0x7f7ebd82f1dc (<unknown module>)
#2 0x7f7ebd83cea3 (<unknown module>)
#3 0x7f7ebd82eb7c (<unknown module>)
#4 0x7f7ebd82ef43 (<unknown module>)
#5 0x7f7ebd82f1fb (<unknown module>)
#6 0x7f7ebd82f4c7 (<unknown module>)
#7 0x7f7ebe356513 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c513) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#8 0x7f7ebe25ad2e in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30d2e) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#9 0x4013f8 in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x4013f8) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#10 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#11 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#12 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
Indirect leak of 168 byte(s) in 1 object(s) allocated from:
#15 0x7f7ebe356513 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c513) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#16 0x7f7ebe25ad2e in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30d2e) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#17 0x4013f8 in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x4013f8) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#18 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#19 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#20 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#15 0x7f7ebe356544 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c544) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
Indirect leak of 160 byte(s) in 1 object(s) allocated from:
#6 0x7f7ebd838cb7 (<unknown module>)
#7 0x7f7ebd8537d1 (<unknown module>)
#8 0x7f7ebd83c9dc (<unknown module>)
#9 0x7f7ebd82f1dc (<unknown module>)
#10 0x7f7ebd82f4c7 (<unknown module>)
#11 0x7f7ebe356513 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c513) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#12 0x7f7ebe25ad2e in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30d2e) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#13 0x4013f8 in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x4013f8) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#14 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#15 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#16 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#6 0x7f7ebd839227 (<unknown module>)
#7 0x7f7ebd83cef3 (<unknown module>)
#2 0x7f7ebd82c502 (<unknown module>)
#3 0x7f7ebd82e065 (<unknown module>)
#4 0x7f7ebd82f572 (<unknown module>)
#5 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#1 0x7f7ebd834524 (<unknown module>)
#2 0x7f7ebd8480a9 (/usr/lib64/libasan.so.8.0.0+0x170a9)
#3 0x7f7ebd850387 (<unknown module>)
#4 0x7f7ebd85269d (<unknown module>)
#5 0x7f7ebd842632 (/usr/lib64/libasan.so.8.0.0+0x11632)
#6 0x7f7ebd82e04d (<unknown module>)
#7 0x7f7ebd82f572 (<unknown module>)
Indirect leak of 88 byte(s) in 1 object(s) allocated from:
#1 0x7f7ebd841846 (/usr/lib64/libasan.so.8.0.0+0x10846)
#2 0x7f7ebd8480e4 (/usr/lib64/libasan.so.8.0.0+0x170e4)
#2 0x7f7ebd82c745 (<unknown module>)
Indirect leak of 72 byte(s) in 1 object(s) allocated from:
#1 0x7f7ebd826931 (<unknown module>)
#2 0x7f7ebd8480f9 (/usr/lib64/libasan.so.8.0.0+0x170f9)
#2 0x7f7ebd8539cf (<unknown module>)
#3 0x7f7ebd828ae2 (<unknown module>)
#4 0x7f7ebd848344 (/usr/lib64/libasan.so.8.0.0+0x17344)
#5 0x7f7ebd850387 (<unknown module>)
#6 0x7f7ebd85269d (<unknown module>)
#7 0x7f7ebd842632 (/usr/lib64/libasan.so.8.0.0+0x11632)
#8 0x7f7ebd82e04d (<unknown module>)
#9 0x7f7ebd82f572 (<unknown module>)
#2 0x7f7ebd8539c1 (<unknown module>)
#2 0x7f7ebd8539b3 (<unknown module>)
#1 0x7f7ebd833790 (<unknown module>)
#2 0x7f7ebd847b23 (/usr/lib64/libasan.so.8.0.0+0x16b23)
#3 0x7f7ebd847f8f (/usr/lib64/libasan.so.8.0.0+0x16f8f)
#4 0x7f7ebd82d151 (<unknown module>)
#5 0x7f7ebd841e0c (/usr/lib64/libasan.so.8.0.0+0x10e0c)
#6 0x7f7ebd82ef5d (<unknown module>)
#3 0x7f7ebd84b7df (/usr/lib64/libasan.so.8.0.0+0x1a7df)
#4 0x7f7ebd828926 (<unknown module>)
#5 0x7f7ebd828e3b (<unknown module>)
#6 0x7f7ebd8460d8 (/usr/lib64/libasan.so.8.0.0+0x150d8)
#7 0x7f7ebd846beb (/usr/lib64/libasan.so.8.0.0+0x15beb)
#8 0x7f7ebd847f51 (/usr/lib64/libasan.so.8.0.0+0x16f51)
#10 0x7f7ebd841d93 (/usr/lib64/libasan.so.8.0.0+0x10d93)
#12 0x7f7ebd82f1fb (<unknown module>)
#13 0x7f7ebd82f4c7 (<unknown module>)
#14 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#1 0x7f7ebd84ecd4 (<unknown module>)
#2 0x7f7ebd82c77d (<unknown module>)
#1 0x7f7ebd83ffd0 (<unknown module>)
#2 0x7f7ebd848094 (/usr/lib64/libasan.so.8.0.0+0x17094)
#2 0x7f7ebd84806e (/usr/lib64/libasan.so.8.0.0+0x1706e)
#1 0x7f7ebd841939 (/usr/lib64/libasan.so.8.0.0+0x10939)
#2 0x7f7ebd82c66e (<unknown module>)
#2 0x7f7ebd82c680 (<unknown module>)
#1 0x7f7ebd82c4cc (<unknown module>)
#1 0x7f7ebd82c4e2 (<unknown module>)
Indirect leak of 40 byte(s) in 1 object(s) allocated from:
#1 0x7f7ebd8418c9 (/usr/lib64/libasan.so.8.0.0+0x108c9)
#2 0x7f7ebd82c65c (<unknown module>)
#2 0x7f7ebd82c6f4 (<unknown module>)
#2 0x7f7ebd84187c (/usr/lib64/libasan.so.8.0.0+0x1087c)
#3 0x7f7ebd82c745 (<unknown module>)
#4 0x7f7ebd82e065 (<unknown module>)
#5 0x7f7ebd82f572 (<unknown module>)
#6 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#1 0x7f7ebd84abc9 (/usr/lib64/libasan.so.8.0.0+0x19bc9)
#2 0x7f7ebd83bd34 (<unknown module>)
#3 0x7f7ebd83db2d (<unknown module>)
#4 0x7f7ebd84669b (/usr/lib64/libasan.so.8.0.0+0x1569b)
#5 0x7f7ebd84686f (/usr/lib64/libasan.so.8.0.0+0x1586f)
#6 0x7f7ebd8479a0 (/usr/lib64/libasan.so.8.0.0+0x169a0)
#7 0x7f7ebd847f8f (/usr/lib64/libasan.so.8.0.0+0x16f8f)
#8 0x7f7ebd82d151 (<unknown module>)
#9 0x7f7ebd841e0c (/usr/lib64/libasan.so.8.0.0+0x10e0c)
#10 0x7f7ebd82ef5d (<unknown module>)
#11 0x7f7ebd82f1fb (<unknown module>)
#12 0x7f7ebd82f4c7 (<unknown module>)
#13 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#2 0x7f7ebd84a1fc (/usr/lib64/libasan.so.8.0.0+0x191fc)
#3 0x7f7ebd82c502 (<unknown module>)
#13 0x7f7ebe356544 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c544) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#14 0x7f7ebe25ad2e in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30d2e) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#13 0x7f7ebe356513 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c513) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#3 0x7f7ebd82e21f (<unknown module>)
#3 0x7f7ebd8480e4 (/usr/lib64/libasan.so.8.0.0+0x170e4)
#2 0x7f7ebd82c634 (<unknown module>)
#2 0x7f7ebd82c64a (<unknown module>)
#1 0x7f7ebd84af97 (/usr/lib64/libasan.so.8.0.0+0x19f97)
#2 0x7f7ebd84839a (/usr/lib64/libasan.so.8.0.0+0x1739a)
Indirect leak of 32 byte(s) in 1 object(s) allocated from:
#4 0x7f7ebd8271a1 (<unknown module>)
#5 0x7f7ebd828b26 (<unknown module>)
#6 0x7f7ebd848344 (/usr/lib64/libasan.so.8.0.0+0x17344)
#7 0x7f7ebd850387 (<unknown module>)
#8 0x7f7ebd85269d (<unknown module>)
#9 0x7f7ebd842632 (/usr/lib64/libasan.so.8.0.0+0x11632)
#10 0x7f7ebd82e04d (<unknown module>)
#11 0x7f7ebd82f572 (<unknown module>)
Indirect leak of 31 byte(s) in 1 object(s) allocated from:
#2 0x7f7ebd84b38f (/usr/lib64/libasan.so.8.0.0+0x1a38f)
#3 0x7f7ebd8539aa (<unknown module>)
#4 0x7f7ebd828ae2 (<unknown module>)
#5 0x7f7ebd848344 (/usr/lib64/libasan.so.8.0.0+0x17344)
#6 0x7f7ebd850387 (<unknown module>)
#7 0x7f7ebd85269d (<unknown module>)
#8 0x7f7ebd842632 (/usr/lib64/libasan.so.8.0.0+0x11632)
#9 0x7f7ebd82e04d (<unknown module>)
#10 0x7f7ebd82f572 (<unknown module>)
#11 0x7f7eac05a0de (/lib64/libnvidia-glcore.so.545.29.06+0xa5a0de) (BuildId: 7c0c1563fc651a625e402ad40c7289972e2e063f)
#2 0x7f7ebd83c805 (<unknown module>)
#3 0x7f7ebd841b2e (/usr/lib64/libasan.so.8.0.0+0x10b2e)
#4 0x7f7ebd82ef72 (<unknown module>)
#2 0x7f7ebd82f46d (<unknown module>)
#1 0x7f7ebd841722 (/usr/lib64/libasan.so.8.0.0+0x10722)
#2 0x7f7ebe3564f3 in SDL_DBus_Init_Spinlocked.lto_priv.0 (/lib64/libSDL2-2.0.so.0+0x12c4f3) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#3 0x7f7ebe25ad2e in SDL_InitSubSystem_REAL.part.0 (/lib64/libSDL2-2.0.so.0+0x30d2e) (BuildId: 52b9526e652001ecfae08b5bcfe8921ea24f8410)
#4 0x4013f8 in main (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x4013f8) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#5 0x7f7ebdc46149 in __libc_start_call_main (/lib64/libc.so.6+0x28149) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#6 0x7f7ebdc4620a in __libc_start_main_impl (/lib64/libc.so.6+0x2820a) (BuildId: 788cdd41a15985bf8e0a48d213a46e07d58822df)
#7 0x401214 in _start (/home/ave/Documents/qt/build-usp2-Desktop_Qt_6_6_1_GCC_64bit-RelWithDebInfo/leak+0x401214) (BuildId: 1e259da54f59bed5f88ce77b0bf822a985821f48)
#1 0x7f7ebd82bb89 (<unknown module>)
#2 0x7f7ebd82f150 (<unknown module>)
#3 0x7f7ebd82f4c7 (<unknown module>)
#1 0x7f7ebd82c75b (<unknown module>)
#1 0x7f7ebd84eff5 (<unknown module>)
#2 0x7f7ebd82b9c3 (<unknown module>)
#3 0x7f7ebd82bbaf (<unknown module>)
#4 0x7f7ebd82f150 (<unknown module>)
#5 0x7f7ebd82f4c7 (<unknown module>)
Indirect leak of 8 byte(s) in 1 object(s) allocated from:
#2 0x7f7ebd848050 (/usr/lib64/libasan.so.8.0.0+0x17050)
#2 0x7f7ebd848040 (/usr/lib64/libasan.so.8.0.0+0x17040)
#2 0x7f7ebd853997 (<unknown module>)
#1 0x7f7ebd84ad7a (/usr/lib64/libasan.so.8.0.0+0x19d7a)
#2 0x7f7ebd83dd01 (<unknown module>)
#2 0x7f7ebd853969 (<unknown module>)
#2 0x7f7ebd82f2f7 (<unknown module>)
SUMMARY: AddressSanitizer: 21877 byte(s) leaked in 273 allocation(s).
