I trained a Resnet152 using the Tensorflow Object Detection API. Then, I converted it to onnx and later, when trying to build an engine using trtexec, this error whoed up:
ERROR: /home/deep/TensorRT/parsers/onnx/builtin_op_importers.cpp:4292 In function importTopK:
[8] Assertion failed: (inputs.at(1).is_weights()) && “This version of TensorRT only supports input K as an initializer.”
Environment
TensorRT Version : 8.0.1.6 GPU Type : Nvidia RTX 2060 Nvidia Driver Version : 470.42.01 CUDA Version : 11.3 CUDNN Version : 8.2.1 Operating System + Version : Ubuntu 20.04 LTS Python Version (if applicable) : 3.8.10 TensorFlow Version (if applicable) : 2.5 Cmake version: 3.13
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
