• Hardware Platform (Jetson / GPU) V100-SXM2 • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version 7.0.0 • NVIDIA GPU Driver Version (valid for GPU only) 510.47.03 • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
I am trying to convert http://download.tensorflow.org/models/object_detection/ssd_mobilenet_v2_coco_2018_03_29.tar.gz to tensorRT. Following the path tensorflow → onnx → tensorRT
I ran this command
./trtexec --onnx=/home/sahilwa/workplace/onnx-models/ssd_mobilenet_v2_coco_2018_03_115.onnx --explicitBatch --workspace=4096 --minTiming=10 --fp16 --saveEngine=ssd_mobilenet_v2_coco_2018_03_115.trt --verbose
But I get this error
[8] Assertion failed: convertOnnxWeights(initializer, &weights, ctx)
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
