Referring: https://bugs.launchpad.net/ubuntu/+source/nvidia-graphics-drivers-319/+bug/1241745
Kernel parameters: GRUB_CMDLINE_LINUX_DEFAULT=“splash acpi_osi= acpi_backlight=video video. use_native_backlight=1”
NVIDIA Driver v390 installed on Ubuntu 18.04
This is the only configuration where the function keys fn f5/f6 do something which strongly correspond to /sys/class/backlight/acpi_video0/brightness, but visually the brightness stays the same. If the laptop will turn the screen off after the minutes configured, the display stays black (but you could heavily recognize some letters on the display.
In all other kernel parameter configs I have tried , there was no reaction to the function keys nor to the sys class described above (i.e. acpi_backlight=vendor or none).
Changes to the xorg.conf in the way described here:
$sudo vim /usr/share/X11/xorg.conf.d/10-nvidia.conf =>
1 Section "OutputClass"
2 Identifier "nvidia"
3 MatchDriver "nvidia-drm"
4 Driver "nvidia"
5 Option "AllowEmptyInitialConfiguration"
6 ModulePath "/usr/lib/x86_64-linux-gnu/nvidia/xorg"
7 EndSection
8 Section "Device"
9 Identifier "PEGP"
10 Driver "nvidia"
11 VendorName "NVIDIA Corporation"
12 Option "Backlight" "acpi_video0"
13 BusID "PCI:0:1:0"
14 EndSection
or changes directly to the NVIDIA generated xorg.conf:
39 Section "Device"
40 Identifier "Device0"
41 Driver "nvidia"
42 VendorName "NVIDIA Corporation"
43 BoardName "GeForce GTX 1070 Mobile"
44 Option "RegistryDwords" "EnableBrightnessControl=1"
45 EndSection
did not take any effect, though I am not sure that the Option or the Bus Id was derived in the right way (the device name was changed from Device0 to PEGP, derived from:
$dmesg|grep 'ACPI: Video'
[ 1.173170] ACPI: Video Device [PEGP] (multi-head: yes rom: yes post: no)
$ lspci -D |grep VGA
0000:01:00.0 VGA compatible controller: NVIDIA Corporation GP104M [GeForce GTX 1070 Mobile] (rev a1)
I am running out of options, could it maybe be a bug?? Is there a solution out there??
Would be glad to hear from you!
