Hallo cuda fans,
I need a function to add two unsigned short values atomically. The atomicAdd function is only for a 32Bit integer but I use an unsigned short value.
Hallo cuda fans,
Is there a particular reason you cannot simply substitute a 32-bit integer? Rule of thumb based on experience: Every integer wants to be an int unless there is a compelling reason for it to be some other integer type.
You can do atomic operations on one byte and two byte quantities, using a 4-byte atomic operation plus some extra processing. this thread may be of interest.
with unsigned short support available in atomicCAS you can directly combine that with the custom atomic example given in the programming guide to create a 16-bit atomic op. Any of these methods that I have mentioned will be less performant than doing a native 32-bit atomic op, so as hinted by njuffa that realization may be preferred for performance.
