A98
December 13, 2023, 5:30pm
1
Hello.I tried to launch resnet pose_estimation programm in the docker container.I got error:
[12/13/2023-11:01:18] [TRT] [E] 1: [stdArchiveReader.cpp::StdArchiveReader::35] Error Code 1: Serialization (Serialization assertion safeVersionRead == safeSerializationVersion failed.Version tag does not match. Note: Current Version: 0, Serialized Engine Version: 87)
[12/13/2023-11:01:19] [TRT] [E] 4: [runtime.cpp::deserializeCudaEngine::50] Error Code 4: Internal Error (Engine deserialization failed.)
File “pose_estimation_run.py”, line 166, in
pose_estimation = PoseEstimation()
File “pose_estimation_run.py”, line 29, in init
self.model_trt.load_state_dict(torch.load(OPTIMIZED_MODEL))
File “/usr/local/lib/python3.6/dist-packages/torch/nn/modules/module.py”, line 1468, in load_state_dict
load(self)
File “/usr/local/lib/python3.6/dist-packages/torch/nn/modules/module.py”, line 1463, in load
state_dict, prefix, local_metadata, True, missing_keys, unexpected_keys, error_msgs)
File “/usr/local/lib/python3.6/dist-packages/torch2trt/torch2trt.py”, line 591, in _load_from_state_dict
self.context = self.engine.create_execution_context()
AttributeError: ‘NoneType’ object has no attribute ‘create_execution_context’
Full log is here:
log11.txt (2.9 KB)
As far as i am concerned, i have wrong resnet18_baseline_att_224x224_A_epoch_249_trt.pth file, which was greated on a different tensorRT version.And i need to create resnet18_baseline_att_224x224_A_epoch_249_trt.pth file from a resnet18_baseline_att_224x224_A_epoch_249.pth file in the docker container on my current TensoRT version.
Could you explain me, please, how can i create resnet18_baseline_att_224x224_A_epoch_249_trt.pth file from a resnet18_baseline_att_224x224_A_epoch_249.pth file in the docker container ?
Do you use Orin series? It seems that your GPU architecture is 87 instead of 53.
Based on the above message, this is the compatibility issue.
Please create the TensorRT engine from the same device.
And please launch the container with --runtime nvidia to enable GPU access.
A98
December 14, 2023, 11:56am
4
Thanks fo the reply.
I know only, that my jetson model is P3450. (If this information is no enough, could you explain me, please, how can i get necessary information ?)
Could you ,please, give me an instruction of the TensorRT engine creation inside of the docker container ?
The engine is built for Orin (87) but your device is Nano (53).
So it’s incompatible.
The easiest way to build a TensorRT engine is trtexec .
For example:
/usr/src/tensorrt/bin/trtexec --onnx=[model] --saveEngine=[output]
A98
December 20, 2023, 5:22pm
6
Hello.Unfortuantelly i couldnt do that, because i dont have the onnx.
I tried to install it 2 times.In the container, which was launched by the command docker/run.sh -c trtpose2 --volume.Log is here:
log2.txt (9.4 KB)
And in the container, which waas launched by the command: sudo docker run -it --runtime nvidia trtpose2.Log is here:
log3.txt (7.1 KB)
How can i install it ?Maybe i need specific version or additional packages ?
You don’t need to install ONNX to feed a .onnx file into the trtexec .
Based on your log, you are trying to use jetson-inference.
Could you share which sample you are using?
Is your model “resnet18_baseline_att_224x224_A_epoch_249.pth”?
If yes, please convert the .pth model into .onnx with PyTorch.
Then you can feed the .onnx model to the trtexec directly.
A98
December 27, 2023, 9:06am
8
Hello. Yes, my model is resnet18_baseline_att_224x224_A_epoch_249_trt.pth.And my docker containers is : jetson-inference/docs/aux-docker.md at master · dusty-nv/jetson-inference · GitHub . (All other containers are based on it)
Could you give me an example of the convertion of the .pth to .onnx ?
The model can be converted to the TensorRT engine with below GitHub:
Do you meet any issues when trying it?
A98
January 4, 2024, 9:43am
10
Hello.I am working on it (Trying to solve problem with a space on my device, first).
A98
January 8, 2024, 5:20pm
12
Hello.I used this method for the conversion: Conversion of model weights for human pose estimation model to ONNX results in nonsensical pose estimation - #11 by AastaLLL
I got the error:
It seems i cant do this operation on jetson, because it is not powerful enough.
Maybe i can just download the .onnx file somewhere ?
If i cant download it i will try to do that on my pc.
Please try to generate the ONNX file with below command:
$ git clone https://github.com/NVIDIA-AI-IOT/trt_pose.git
$ sudo docker run -it --rm --runtime nvidia -v /home/nvidia/trt_pose:/home/nvidia/trt_pose --network host nvcr.io/nvidia/l4t-pytorch:r32.5.0-pth1.7-py3
$ cd /home/nvidia/trt_pose/
$ sudo python3 setup.py install
$ cd trt_pose/utils/
$ ./export_for_isaac.py --input_checkpoint resnet18_baseline_att_224x224_A_epoch_249.pth
A98
January 10, 2024, 10:31am
14
Hi.Sorry for the late reply. I followed the instruction and created ONNX file.
Could you explain me, please, how can i convert my .onnx file to the engine in my container ?I have tensorrt, but, unfortunatelly, i still dont get, that exactly shuold i do to create the engine.
Based on the log, you have converted the model to the ONNX successfully.
Then please try to deploy it with trtexec outside of the container.
$ /usr/src/tensorrt/bin/trtexec --onnx=[model] --saveEngine=[output]
system
Closed
February 14, 2024, 4:59am
17
