mkumard
23
May be some permission issues with your image which was flashed. Try run with sudo
The dts file “compatible = “fsl,sgtl5000,tegra-audio-sgtl5000”;” seems wrong.
It should be “compatible = fsl,sgtl5000”; for codec driver from sound/soc/codecs/sgtl5000.c
“nvidia,tegra-audio-sgtl5000” string was related to machine driver compatible. Please check the drivers for reference.
HM_Tech
24
I have tried this as well, later changed to have a try. thanks for that.
for the amixer - I have tried as root user as well.
mkumard
25
Is your sound card registered?. # cat /proc/asound/cards
HM_Tech
26
Not right? see this log:
nvidia@nvidia-desktop:~$ cat /proc/asound/cards
0 [tegrahdagalent1]: tegra-hda-galen - tegra-hda-galen-t194
tegra-hda-galen-t194 at 0x3518000 irq 73
1 [tegrasndt19xmob]: tegra-snd-t19x- - tegra-snd-t19x-mobile-rt565x
mkumard
27
This is APE sound card.
So you should access mixer controls with card = 1
I could not use amixer, but when I check the register value it shows 024: 0132 after playback, but no sound.
Any idea on why very first time immediate after flashing BSP I can hear the sound until I reboot/power cycle?
mkumard
29
That’s strange behavior that after reboot audio not working. We need to do few things here to check the behavior of codec.
- Compare the codec register dumps for working and non-working case during playback.
- Probe if I2S signals which are going to codec.
system
Closed
31
