Hi Jonathanh
According to your recommendation
DT
rt565x_dai_link: nvidia,dai-link-1 {
/*link-name = "rt565x-playback";*/
link-name = "rt5631-playback";
cpu-dai = <&tegra_i2s1>;
/*codec-dai = <&spdif_dit0>;*/
codec-dai = <&rt5631_codec>;
cpu-dai-name = "I2S1";
/*codec-dai-name = "dit-hifi";*/
codec-dai-name = "rt5631-hifi";
format = "i2s";
bitclock-slave;
frame-slave;
bitclock-noninversion;
frame-noninversion;
bit-format = "s16_le";
bclk_ratio = <0>;
srate = <48000>;
num-channel = <2>;
ignore_suspend;
name-prefix = "x";
status = "okay";
tegra_t186ref_mobile_rt565x.c
* tegra_t186ref_mobile_rt565x.c - Tegra t186ref Machine driver
* Copyright (c) 2015-2017 NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify it
* under the terms and conditions of the GNU General Public License,
* version 2, as published by the Free Software Foundation.
* This program is distributed in the hope it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <linux/module.h>
#include <linux/platform_device.h>
#include <linux/of_platform.h>
#include <linux/input.h>
#include <linux/slab.h>
#include <linux/gpio.h>
#include <linux/of_gpio.h>
#include <linux/i2c.h>
#include <linux/regulator/consumer.h>
#include <linux/delay.h>
#include <soc/tegra/pmc.h>
#ifdef CONFIG_SWITCH
#include <linux/switch.h>
#endif
#include <linux/pm_runtime.h>
#include <linux/version.h>
#if LINUX_VERSION_CODE >= KERNEL_VERSION(4, 2, 0)
#include <linux/platform_data/tegra_asoc_pdata.h>
#else
#include <mach/tegra_asoc_pdata.h>
#endif
#include <sound/core.h>
#include <sound/jack.h>
#include <sound/pcm.h>
#include <sound/pcm_params.h>
#include <sound/soc.h>
#include "../codecs/rt5659.h"
#include "tegra_asoc_utils_alt.h"
#include "tegra_asoc_machine_alt.h"
#include "tegra_asoc_machine_alt_t18x.h"
#include "tegra210_xbar_alt.h"
#include <dt-bindings/sound/tas2552.h>
#endif
#define DRV_NAME "tegra-snd-t186ref-mobile-rt565x"
#define GPIO_SPKR_EN BIT(0)
#define GPIO_HP_MUTE BIT(1)
#define GPIO_INT_MIC_EN BIT(2)
#define GPIO_EXT_MIC_EN BIT(3)
#define GPIO_HP_DET BIT(4)
#define PARAMS(sformat, channels) \
.formats = sformat, \
.rate_min = 48000, \
.rate_max = 48000, \
.channels_min = channels, \
.channels_max = channels, \
struct tegra_t186ref {
struct tegra_asoc_platform_data *pdata;
struct tegra_asoc_audio_clock_info audio_clock;
unsigned int num_codec_links;
int gpio_requested;
int jack_status;
#endif
struct regulator *digital_reg;
struct regulator *spk_reg;
struct regulator *dmic_reg;
struct snd_soc_card *pcard;
int rate_via_kcontrol;
int is_codec_dummy;
int fmt_via_kcontrol;
static const int tegra_t186ref_srate_values[] = {
0,
8000,
16000,
44100,
48000,
11025,
22050,
24000,
32000,
88200,
96000,
176400,
192000,
static struct snd_soc_jack tegra_t186ref_hp_jack;
static struct switch_dev tegra_t186ref_headset_switch = {
.name = "h2w",
static int tegra_t186ref_jack_notifier(struct notifier_block *self,
unsigned long action, void *dev)
struct snd_soc_jack *jack = dev;
#if LINUX_VERSION_CODE < KERNEL_VERSION(3, 19, 0)
struct snd_soc_codec *codec = jack->codec;
struct snd_soc_card *card = codec->component.card;
#else
struct snd_soc_card *card = jack->card;
#endif
struct tegra_t186ref *machine = snd_soc_card_get_drvdata(card);
enum headset_state state = BIT_NO_HEADSET;
int idx = 0;
static bool button_pressed = false;
if (machine->is_codec_dummy)
return NOTIFY_OK;
idx = tegra_machine_get_codec_dai_link_idx_t18x("rt565x-playback");
/* check if idx has valid number */
if (idx == -EINVAL)
return idx;
dev_dbg(card->dev, "jack status = %d", jack->status);
if (jack->status & (SND_JACK_BTN_0 | SND_JACK_BTN_1 |
SND_JACK_BTN_2 | SND_JACK_BTN_3)) {
button_pressed = true;
return NOTIFY_OK;
} else if ((jack->status & SND_JACK_HEADSET) && button_pressed) {
return NOTIFY_OK;
switch (jack->status) {
case SND_JACK_HEADPHONE:
state = BIT_HEADSET_NO_MIC;
break;
case SND_JACK_HEADSET:
state = BIT_HEADSET;
break;
case SND_JACK_MICROPHONE:
/* mic: would not report */
default:
dev_dbg(card->dev, "switch state to %x\n", state);
switch_set_state(&tegra_t186ref_headset_switch, state);
return NOTIFY_OK;
static struct notifier_block tegra_t186ref_jack_detect_nb = {
.notifier_call = tegra_t186ref_jack_notifier,
#else
static struct snd_soc_jack_pin tegra_t186ref_hp_jack_pins[] = {
.pin = "Headphone Jack",
.mask = SND_JACK_HEADPHONE,
#endif
static struct snd_soc_pcm_stream tegra_t186ref_asrc_link_params[] = {
PARAMS(SNDRV_PCM_FMTBIT_S32_LE, 8),
PARAMS(SNDRV_PCM_FMTBIT_S16_LE, 2),
static int tegra_t186ref_set_params(struct snd_soc_card *card,
struct tegra_t186ref *machine,
int rate,
int channels,
u64 formats)
unsigned int tx_mask = (1 << channels) - 1;
unsigned int rx_mask = (1 << channels) - 1;
int idx, err = 0;
u64 format_k;
int num_of_dai_links = TEGRA186_XBAR_DAI_LINKS +
machine->num_codec_links;
format_k = (machine->fmt_via_kcontrol == 2) ?
(1ULL << SNDRV_PCM_FORMAT_S32_LE) : formats;
/* update dai link hw_params */
for (idx = 0; idx < num_of_dai_links; idx++) {
if (card->rtd[idx].dai_link->params) {
struct snd_soc_pcm_stream *dai_params;
dai_params =
(struct snd_soc_pcm_stream *)
card->rtd[idx].dai_link->params;
dai_params->rate_min = rate;
dai_params->channels_min = channels;
dai_params->formats = format_k;
if (idx >= TEGRA186_XBAR_DAI_LINKS) {
unsigned int fmt;
int bclk_ratio;
err = 0;
dai_params->formats = formats;
fmt = card->rtd[idx].dai_link->dai_fmt;
bclk_ratio =
tegra_machine_get_bclk_ratio_t18x(
&card->rtd[idx]);
if (bclk_ratio >= 0) {
err = snd_soc_dai_set_bclk_ratio(
card->rtd[idx].cpu_dai,
bclk_ratio);
if (err < 0) {
dev_err(card->dev,
"Failed to set cpu dai bclk ratio for %s\n",
card->rtd[idx].dai_link->name);
/* set TDM slot mask */
if ((fmt & SND_SOC_DAIFMT_FORMAT_MASK) ==
SND_SOC_DAIFMT_DSP_A) {
err = snd_soc_dai_set_tdm_slot(
tx_mask, rx_mask, 0, 0);
if (err < 0) {
dev_err(card->dev,
"%s cpu DAI slot mask not set\n",
card->rtd[idx].cpu_dai->name);
return 0;
static int tegra_t186ref_dai_init(struct snd_soc_pcm_runtime *rtd,
int rate,
int channels,
u64 formats,
bool is_playback)
struct snd_soc_card *card = rtd->card;
unsigned int idx, clk_out_rate;
int err, codec_rate, clk_rate;
codec_rate = tegra_t186ref_srate_values[machine->rate_via_kcontrol];
clk_rate = (machine->rate_via_kcontrol) ? codec_rate : rate;
err = tegra_alt_asoc_utils_set_rate(&machine->audio_clock, clk_rate,
0, 0);
if (err < 0) {
dev_err(card->dev, "Can't configure clocks\n");
return err;
clk_out_rate = machine->audio_clock.clk_out_rate;
pr_debug("pll_a_out0 = %d Hz, aud_mclk = %d Hz, codec rate = %d Hz\n",
machine->audio_clock.set_mclk, clk_out_rate, clk_rate);
tegra_t186ref_set_params(card, machine, rate, channels, formats);
if (idx != -EINVAL) {
dai_params =
(struct snd_soc_pcm_stream *)card->rtd[idx].dai_link->params;
dai_params->rate_min = clk_rate;
dai_params->formats = (machine->fmt_via_kcontrol == 2) ?
if (!machine->is_codec_dummy) {
err = snd_soc_dai_set_sysclk(card->rtd[idx].codec_dai,
RT5659_SCLK_S_MCLK, clk_out_rate, SND_SOC_CLOCK_IN);
if (err < 0) {
dev_err(card->dev, "codec_dai clock not set\n");
return err;
idx = tegra_machine_get_codec_dai_link_idx_t18x("rt5631-playback");
dai_params = (struct snd_soc_pcm_stream *)card->rtd[idx].dai_link->params;
err = snd_soc_dai_set_pll(card->rtd[idx].codec_dai, 0, 0, 0, 0);
if (err < 0) {
dev_err(card->dev, "failed to configure pll!\n");
return err;
err = snd_soc_dai_set_sysclk(card->rtd[idx].codec_dai, 0,
if (err < 0) {
dev_err(card->dev, "failed to set codec clock to %d\n",
clk_out_rate);
return err;
/* set clk rate for i2s3 dai link*/
idx = tegra_machine_get_codec_dai_link_idx_t18x("spdif-dit-2");
dai_params =
idx = tegra_machine_get_codec_dai_link_idx_t18x("dspk-playback-r");
dai_params =
#if LINUX_VERSION_CODE < KERNEL_VERSION(4, 2, 0)
0, clk_out_rate, SND_SOC_CLOCK_IN);
#else
TAS2552_PDM_CLK_IVCLKIN, clk_out_rate,
SND_SOC_CLOCK_IN);
#endif
if (err < 0) {
return err;
idx = tegra_machine_get_codec_dai_link_idx_t18x("dspk-playback-l");
dai_params =
#else
SND_SOC_CLOCK_IN);
#endif
if (err < 0) {
return err;
idx = tegra_machine_get_codec_dai_link_idx_t18x("spdif-playback");
if ((idx != -EINVAL) && (clk_rate >= 32000)) {
dai_params =
if (is_playback) {
err = snd_soc_dai_set_sysclk(card->rtd[idx].cpu_dai, 0,
clk_rate, SND_SOC_CLOCK_OUT);
if (err < 0) {
dev_err(card->dev, "cpu_dai out clock not set\n");
return err;
} else {
clk_rate, SND_SOC_CLOCK_IN);
if (err < 0) {
dev_err(card->dev, "cpu_dai in clock not set\n");
return err;
return 0;
static int tegra_t186ref_hw_params(struct snd_pcm_substream *substream,
struct snd_pcm_hw_params *params)
struct snd_soc_pcm_runtime *rtd = substream->private_data;
int err;
bool is_playback;
if (substream->stream == SNDRV_PCM_STREAM_PLAYBACK)
is_playback = true;
else
is_playback = false;
err = tegra_t186ref_dai_init(rtd, params_rate(params),
params_channels(params),
(1ULL << (params_format(params))),
is_playback);
if (err < 0) {
dev_err(card->dev, "Failed dai init\n");
return err;
return 0;
static int tegra_t186ref_compr_startup(struct snd_compr_stream *cstream)
struct snd_soc_pcm_runtime *rtd = cstream->private_data;
tegra_alt_asoc_utils_clk_enable(&machine->audio_clock);
return 0;
static void tegra_t186ref_compr_shutdown(struct snd_compr_stream *cstream)
tegra_alt_asoc_utils_clk_disable(&machine->audio_clock);
return;
static int tegra_t186ref_startup(struct snd_pcm_substream *substream)
struct tegra_t186ref *machine = snd_soc_card_get_drvdata(rtd->card);
return 0;
static void tegra_t186ref_shutdown(struct snd_pcm_substream *substream)
return;
static int tegra_t186ref_dspk_init(struct snd_soc_pcm_runtime *rtd)
struct snd_soc_dapm_context *dapm = &card->dapm;
int err;
err = tegra_alt_asoc_utils_set_extern_parent(&machine->audio_clock,
"pll_a_out0");
if (err < 0)
dev_err(card->dev, "Failed to set extern clk parent\n");
snd_soc_dapm_sync(dapm);
return err;
static int tegra_t186ref_compr_set_params(struct snd_compr_stream *cstream)
struct snd_soc_platform *platform = rtd->platform;
struct snd_codec codec_params;
int err;
bool is_playback;
if (platform->driver->compr_ops &&
platform->driver->compr_ops->get_params) {
err = platform->driver->compr_ops->get_params(cstream,
&codec_params);
if (err < 0) {
dev_err(card->dev, "Failed to get compr params\n");
return err;
} else {
dev_err(card->dev, "compr ops not set\n");
return -EINVAL;
if (cstream->direction == SND_COMPRESS_PLAYBACK)
is_playback = true;
else
err = tegra_t186ref_dai_init(rtd, codec_params.sample_rate,
codec_params.ch_out, SNDRV_PCM_FMTBIT_S16_LE,
is_playback);
if (err < 0) {
return err;
return 0;
static int tegra_t186ref_init(struct snd_soc_pcm_runtime *rtd)
int err;
struct snd_soc_dai *codec_dai = rtd->codec_dai;
struct snd_soc_codec *codec = codec_dai->codec;
#endif
"pll_a_out0");
if (err < 0) {
return err;
snd_soc_jack_new(codec, "Headphone Jack", SND_JACK_HEADPHONE,
&tegra_t186ref_hp_jack);
#else
err = snd_soc_card_jack_new(card, "Headphone Jack", SND_JACK_HEADPHONE,
&tegra_t186ref_hp_jack, NULL, 0);
if (err) {
dev_err(card->dev, "Headset Jack creation failed %d\n", err);
return err;
#endif
#ifndef CONFIG_SWITCH
err = snd_soc_jack_add_pins(&tegra_t186ref_hp_jack,
ARRAY_SIZE(tegra_t186ref_hp_jack_pins),
tegra_t186ref_hp_jack_pins);
if (err) {
dev_err(card->dev, "snd_soc_jack_add_pins failed %d\n", err);
return err;
#else
snd_soc_jack_notifier_register(&tegra_t186ref_hp_jack,
&tegra_t186ref_jack_detect_nb);
#endif
/* single button supporting play/pause */
snd_jack_set_key(tegra_t186ref_hp_jack.jack,
SND_JACK_BTN_0, KEY_MEDIA);
/* multiple buttons supporting play/pause and volume up/down */
SND_JACK_BTN_1, KEY_MEDIA);
SND_JACK_BTN_2, KEY_VOLUMEUP);
SND_JACK_BTN_3, KEY_VOLUMEDOWN);
snd_soc_dapm_sync(&card->dapm);
return 0;
static int tegra_t186ref_sfc_init(struct snd_soc_pcm_runtime *rtd)
unsigned int in_srate, out_srate;
int err;
in_srate = 48000;
out_srate = 8000;
err = snd_soc_dai_set_sysclk(codec_dai, 0, out_srate,
SND_SOC_CLOCK_OUT);
err = snd_soc_dai_set_sysclk(codec_dai, 0, in_srate,
SND_SOC_CLOCK_IN);
return err;
static int tegra_rt565x_event_int_spk(struct snd_soc_dapm_widget *w,
struct snd_kcontrol *k, int event)
struct snd_soc_dapm_context *dapm = w->dapm;
struct snd_soc_card *card = dapm->card;
struct tegra_asoc_platform_data *pdata = machine->pdata;
int err;
if (machine->spk_reg) {
if (SND_SOC_DAPM_EVENT_ON(event))
err = regulator_enable(machine->spk_reg);
else
regulator_disable(machine->spk_reg);
if (!(machine->gpio_requested & GPIO_SPKR_EN))
return 0;
gpio_set_value_cansleep(pdata->gpio_spkr_en,
!!SND_SOC_DAPM_EVENT_ON(event));
return 0;
static int tegra_rt565x_event_hp(struct snd_soc_dapm_widget *w,
if (!(machine->gpio_requested & GPIO_HP_MUTE))
return 0;
gpio_set_value_cansleep(pdata->gpio_hp_mute,
return 0;
static int tegra_rt565x_event_int_mic(struct snd_soc_dapm_widget *w,
int ret = 0;
if (machine->dmic_reg) {
ret = regulator_enable(machine->dmic_reg);
else
regulator_disable(machine->dmic_reg);
if (!(machine->gpio_requested & GPIO_INT_MIC_EN))
return 0;
gpio_set_value_cansleep(pdata->gpio_int_mic_en,
return 0;
static int tegra_rt565x_event_ext_mic(struct snd_soc_dapm_widget *w,
if (!(machine->gpio_requested & GPIO_EXT_MIC_EN))
return 0;
gpio_set_value_cansleep(pdata->gpio_ext_mic_en,
return 0;
static struct snd_soc_ops tegra_t186ref_ops = {
.hw_params = tegra_t186ref_hw_params,
.startup = tegra_t186ref_startup,
.shutdown = tegra_t186ref_shutdown,
static struct snd_soc_compr_ops tegra_t186ref_compr_ops = {
.set_params = tegra_t186ref_compr_set_params,
.startup = tegra_t186ref_compr_startup,
.shutdown = tegra_t186ref_compr_shutdown,
static const struct snd_soc_dapm_widget tegra_t186ref_dapm_widgets[] = {
SND_SOC_DAPM_HP("x Headphone Jack", tegra_rt565x_event_hp),
SND_SOC_DAPM_SPK("x Int Spk", tegra_rt565x_event_int_spk),
SND_SOC_DAPM_MIC("x Int Mic", tegra_rt565x_event_int_mic),
SND_SOC_DAPM_MIC("x Mic Jack", tegra_rt565x_event_ext_mic),
SND_SOC_DAPM_MIC("Int Mic", NULL),
SND_SOC_DAPM_HP("x Headphone", NULL),
SND_SOC_DAPM_MIC("x Mic", NULL),
SND_SOC_DAPM_HP("y Headphone", NULL),
SND_SOC_DAPM_MIC("y Mic", NULL),
SND_SOC_DAPM_HP("z Headphone", NULL),
SND_SOC_DAPM_MIC("z Mic", NULL),
SND_SOC_DAPM_HP("m Headphone", NULL),
SND_SOC_DAPM_MIC("m Mic", NULL),
SND_SOC_DAPM_HP("n Headphone", NULL),
SND_SOC_DAPM_MIC("n Mic", NULL),
SND_SOC_DAPM_HP("o Headphone", NULL),
SND_SOC_DAPM_MIC("o Mic", NULL),
SND_SOC_DAPM_MIC("a Mic", NULL),
SND_SOC_DAPM_MIC("b Mic", NULL),
SND_SOC_DAPM_MIC("c Mic", NULL),
SND_SOC_DAPM_MIC("d Mic", NULL),
SND_SOC_DAPM_HP("e Headphone", NULL),
SND_SOC_DAPM_MIC("e Mic", NULL),
SND_SOC_DAPM_SPK("d1 Headphone", NULL),
SND_SOC_DAPM_SPK("d2 Headphone", NULL),
static int tegra_t186ref_suspend_pre(struct snd_soc_card *card)
unsigned int idx;
/* DAPM dai link stream work for non pcm links */
for (idx = 0; idx < card->num_rtd; idx++) {
INIT_DELAYED_WORK(&card->rtd[idx].delayed_work, NULL);
return 0;
static int tegra_t186ref_suspend_post(struct snd_soc_card *card)
if (machine->digital_reg)
regulator_disable(machine->digital_reg);
return 0;
static int tegra_t186ref_resume_pre(struct snd_soc_card *card)
int ret;
ret = regulator_enable(machine->digital_reg);
return 0;
static int tegra_t186ref_remove(struct snd_soc_card *card)
return 0;
static const char * const tegra_t186ref_srate_text[] = {
"None",
"8kHz",
"16kHz",
"44kHz",
"48kHz",
"11kHz",
"22kHz",
"24kHz",
"32kHz",
"88kHz",
"96kHz",
"176kHz",
"192kHz",
static int tegra_t186ref_codec_get_rate(struct snd_kcontrol *kcontrol,
struct snd_ctl_elem_value *ucontrol)
struct snd_soc_card *card = snd_kcontrol_chip(kcontrol);
ucontrol->value.integer.value[0] = machine->rate_via_kcontrol;
return 0;
static int tegra_t186ref_codec_put_rate(struct snd_kcontrol *kcontrol,
/* set the rate control flag */
machine->rate_via_kcontrol = ucontrol->value.integer.value[0];
return 0;
static const char * const tegra_t186ref_format_text[] = {
"None",
"16",
"32",
static int tegra_t186ref_codec_get_format(struct snd_kcontrol *kcontrol,
ucontrol->value.integer.value[0] = machine->fmt_via_kcontrol;
return 0;
static int tegra_t186ref_codec_put_format(struct snd_kcontrol *kcontrol,
/* set the format control flag */
machine->fmt_via_kcontrol = ucontrol->value.integer.value[0];
return 0;
static const char * const tegra_t186ref_jack_state_text[] = {
"None",
"HS",
"HP",
static int tegra_t186ref_codec_get_jack_state(struct snd_kcontrol *kcontrol,
ucontrol->value.integer.value[0] = tegra_t186ref_headset_switch.state;
return 0;
static int tegra_t186ref_codec_put_jack_state(struct snd_kcontrol *kcontrol,
if (ucontrol->value.integer.value[0] == 0)
switch_set_state(&tegra_t186ref_headset_switch, BIT_NO_HEADSET);
else if (ucontrol->value.integer.value[0] == 1)
switch_set_state(&tegra_t186ref_headset_switch, BIT_HEADSET);
else if (ucontrol->value.integer.value[0] == 2)
BIT_HEADSET_NO_MIC);
return 0;
static const struct soc_enum tegra_t186ref_codec_rate =
SOC_ENUM_SINGLE_EXT(ARRAY_SIZE(tegra_t186ref_srate_text),
tegra_t186ref_srate_text);
static const struct soc_enum tegra_t186ref_codec_format =
SOC_ENUM_SINGLE_EXT(ARRAY_SIZE(tegra_t186ref_format_text),
tegra_t186ref_format_text);
static const struct soc_enum tegra_t186ref_jack_state =
SOC_ENUM_SINGLE_EXT(ARRAY_SIZE(tegra_t186ref_jack_state_text),
tegra_t186ref_jack_state_text);
static const struct snd_soc_dapm_route tegra_t186ref_audio_map[] = {
static const struct snd_kcontrol_new tegra_t186ref_controls[] = {
SOC_DAPM_PIN_SWITCH("x Int Spk"),
SOC_DAPM_PIN_SWITCH("x Headphone Jack"),
SOC_DAPM_PIN_SWITCH("x Mic Jack"),
SOC_DAPM_PIN_SWITCH("x Int Mic"),
SOC_ENUM_EXT("codec-x rate", tegra_t186ref_codec_rate,
tegra_t186ref_codec_get_rate, tegra_t186ref_codec_put_rate),
SOC_ENUM_EXT("codec-x format", tegra_t186ref_codec_format,
tegra_t186ref_codec_get_format, tegra_t186ref_codec_put_format),
SOC_ENUM_EXT("Jack-state", tegra_t186ref_jack_state,
tegra_t186ref_codec_get_jack_state,
tegra_t186ref_codec_put_jack_state),
static struct snd_soc_card snd_soc_tegra_t186ref = {
.name = "tegra-t186ref",
.owner = THIS_MODULE,
.remove = tegra_t186ref_remove,
.suspend_post = tegra_t186ref_suspend_post,
.suspend_pre = tegra_t186ref_suspend_pre,
.resume_pre = tegra_t186ref_resume_pre,
.controls = tegra_t186ref_controls,
.num_controls = ARRAY_SIZE(tegra_t186ref_controls),
.dapm_widgets = tegra_t186ref_dapm_widgets,
.num_dapm_widgets = ARRAY_SIZE(tegra_t186ref_dapm_widgets),
.fully_routed = true,
static void dai_link_setup(struct platform_device *pdev)
struct snd_soc_card *card = platform_get_drvdata(pdev);
struct snd_soc_codec_conf *tegra_machine_codec_conf = NULL;
struct snd_soc_codec_conf *tegra_t186ref_codec_conf = NULL;
struct snd_soc_dai_link *tegra_machine_dai_links = NULL;
struct snd_soc_dai_link *tegra_t186ref_codec_links = NULL;
int i;
/* set new codec links and conf */
tegra_t186ref_codec_links = tegra_machine_new_codec_links(pdev,
tegra_t186ref_codec_links,
&machine->num_codec_links);
if (!tegra_t186ref_codec_links)
goto err_alloc_dai_link;
/* set codec init */
for (i = 0; i < machine->num_codec_links; i++) {
if (tegra_t186ref_codec_links[i].name) {
if (strstr(tegra_t186ref_codec_links[i].name,
"rt565x-playback"))
tegra_t186ref_codec_links[i].init = tegra_t186ref_init;
else if (strstr(tegra_t186ref_codec_links[i].name,
"rt5631-playback"))
"dspk-playback-r"))
tegra_t186ref_codec_links[i].init = tegra_t186ref_dspk_init;
"dspk-playback-l"))
tegra_t186ref_codec_conf = tegra_machine_new_codec_conf(pdev,
tegra_t186ref_codec_conf,
if (!tegra_t186ref_codec_conf)
/* get the xbar dai link/codec conf structure */
tegra_machine_dai_links = tegra_machine_get_dai_link_t18x();
if (!tegra_machine_dai_links)
tegra_machine_codec_conf = tegra_machine_get_codec_conf_t18x();
if (!tegra_machine_codec_conf)
/* set ADMAIF dai_ops */
for (i = TEGRA186_DAI_LINK_ADMAIF1;
i <= TEGRA186_DAI_LINK_ADMAIF20; i++)
tegra_machine_set_dai_ops(i, &tegra_t186ref_ops);
/* set sfc dai_init */
tegra_machine_set_dai_init(TEGRA186_DAI_LINK_SFC1_RX,
&tegra_t186ref_sfc_init);
#if defined(CONFIG_SND_SOC_TEGRA210_ADSP_ALT)
/* set ADSP PCM/COMPR */
for (i = TEGRA186_DAI_LINK_ADSP_PCM1;
i <= TEGRA186_DAI_LINK_ADSP_PCM2; i++) {
/* set ADSP COMPR */
for (i = TEGRA186_DAI_LINK_ADSP_COMPR1;
i <= TEGRA186_DAI_LINK_ADSP_COMPR2; i++) {
tegra_machine_set_dai_compr_ops(i,
&tegra_t186ref_compr_ops);
#endif
/* set ASRC params. The default is 2 channels */
for (i = 0; i < 6; i++) {
tegra_machine_set_dai_params(TEGRA186_DAI_LINK_ASRC1_TX1 + i,
&tegra_t186ref_asrc_link_params[i]);
tegra_machine_set_dai_params(TEGRA186_DAI_LINK_ASRC1_RX1 + i,
/* append t186ref specific dai_links */
card->num_links =
tegra_machine_append_dai_link_t18x(tegra_t186ref_codec_links,
2 * machine->num_codec_links);
card->dai_link = tegra_machine_dai_links;
/* append t186ref specific codec_conf */
card->num_configs =
tegra_machine_append_codec_conf_t18x(tegra_t186ref_codec_conf,
card->codec_conf = tegra_machine_codec_conf;
return;
err_alloc_dai_link:
tegra_machine_remove_dai_link();
tegra_machine_remove_codec_conf();
return;
static int tegra_t186ref_driver_probe(struct platform_device *pdev)
struct device_node *np = pdev->dev.of_node;
struct snd_soc_card *card = &snd_soc_tegra_t186ref;
struct tegra_t186ref *machine;
struct tegra_asoc_platform_data *pdata = NULL;
struct snd_soc_codec *codec = NULL;
int idx = 0;
int ret = 0;
const char *codec_dai_name;
if (!np) {
dev_err(&pdev->dev, "No device tree node for t186ref driver");
return -ENODEV;
machine = devm_kzalloc(&pdev->dev, sizeof(struct tegra_t186ref),
GFP_KERNEL);
if (!machine) {
dev_err(&pdev->dev, "Can't allocate t186ref struct\n");
ret = -ENOMEM;
goto err;
card->dev = &pdev->dev;
platform_set_drvdata(pdev, card);
snd_soc_card_set_drvdata(card, machine);
machine->is_codec_dummy = 0;
machine->audio_clock.clk_cdev1_state = 0;
machine->digital_reg = NULL;
machine->spk_reg = NULL;
machine->dmic_reg = NULL;
card->dapm.idle_bias_off = true;
ret = snd_soc_of_parse_card_name(card, "nvidia,model");
if (ret)
goto err;
ret = snd_soc_of_parse_audio_routing(card,
"nvidia,audio-routing");
if (ret)
goto err;
if (of_property_read_u32(np, "nvidia,num-clk",
&machine->audio_clock.num_clk) < 0) {
dev_err(&pdev->dev,
"Missing property nvidia,num-clk\n");
ret = -ENODEV;
goto err;
if (of_property_read_u32_array(np, "nvidia,clk-rates",
(u32 *)&machine->audio_clock.clk_rates,
dev_err(&pdev->dev,
"Missing property nvidia,clk-rates\n");
ret = -ENODEV;
goto err;
dai_link_setup(pdev);
/* Addd h2w swith class support */
ret = tegra_alt_asoc_switch_register(&tegra_t186ref_headset_switch);
if (ret < 0)
#endif
pdata = devm_kzalloc(&pdev->dev,
sizeof(struct tegra_asoc_platform_data),
GFP_KERNEL);
if (!pdata) {
dev_err(&pdev->dev,
"Can't allocate tegra_asoc_platform_data struct\n");
return -ENOMEM;
pdata->gpio_codec1 = pdata->gpio_codec2 = pdata->gpio_codec3 =
pdata->gpio_spkr_en = pdata->gpio_hp_mute =
pdata->gpio_int_mic_en = pdata->gpio_ext_mic_en = -1;
machine->pdata = pdata;
machine->pcard = card;
ret = tegra_alt_asoc_utils_init(&machine->audio_clock,
&pdev->dev,
card);
if (ret)
ret = snd_soc_register_card(card);
if (ret) {
dev_err(&pdev->dev, "snd_soc_register_card failed (%d)\n",
ret);
goto err_fini_utils;
if (idx == -EINVAL)
dev_warn(&pdev->dev, "codec link not defined - codec not part of sound card");
else {
codec = card->rtd[idx].codec;
codec_dai_name = card->rtd[idx].dai_link->codec_dai_name;
dev_info(&pdev->dev,
"codec-dai \"%s\" registered\n", codec_dai_name);
if (!strcmp("dit-hifi", codec_dai_name)) {
dev_info(&pdev->dev, "This is a dummy codec\n");
machine->is_codec_dummy = 1;
printk ("[VuNguyen] : %s %d !!!!!!!!!!!!!!!\r\n", __func__, __LINE__);
/* setup for jack detection only in non-dummy case */
rt5659_set_jack_detect(codec, &tegra_t186ref_hp_jack);
return 0;
err_fini_utils:
tegra_alt_asoc_utils_fini(&machine->audio_clock);
err_alloc_dai_link:
err:
return ret;
static int tegra_t186ref_driver_remove(struct platform_device *pdev)
snd_soc_unregister_card(card);
return 0;
static const struct of_device_id tegra_t186ref_of_match[] = {
{ .compatible = "nvidia,tegra-audio-t186ref-mobile-rt565x", },
static struct platform_driver tegra_t186ref_driver = {
.driver = {
.name = DRV_NAME,
.pm = &snd_soc_pm_ops,
.of_match_table = tegra_t186ref_of_match,
.probe = tegra_t186ref_driver_probe,
.remove = tegra_t186ref_driver_remove,
module_platform_driver(tegra_t186ref_driver);
MODULE_AUTHOR("Mohan Kumar <mkumard@nvidia.com>");
MODULE_DESCRIPTION("Tegra+t186ref machine ASoC driver");
MODULE_LICENSE("GPL");
MODULE_ALIAS("platform:" DRV_NAME);
MODULE_DEVICE_TABLE(of, tegra_t186ref_of_match);
And console result
[ 9.766879] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 9.766953] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 9.767020] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 9.767094] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 9.767166] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 9.767232] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 9.767303] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 9.767371] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 9.767443] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 9.767511] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 9.767582] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 9.767648] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 9.767718] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 9.767786] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 9.767853] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 9.767927] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 9.767996] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 9.768065] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 9.768131] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 9.768197] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 9.771135] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 9.771211] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 9.771233] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 9.771253] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 9.781921] tegra-snd-t186ref-mobile-rt565x sound: ASoC: no source widget found for x OUT
[ 9.781924] tegra-snd-t186ref-mobile-rt565x sound: ASoC: Failed to add route x OUT -> direct -> x Headphone
[ 9.781958] tegra-snd-t186ref-mobile-rt565x sound: ASoC: no sink widget found for x IN
[ 9.781960] tegra-snd-t186ref-mobile-rt565x sound: ASoC: Failed to add route x Mic -> direct -> x IN
[ 9.799606] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 9.800065] tegra-snd-t186ref-mobile-rt565x sound: codec link not defined - codec not part of sound card
[ 9.800067] [VuNguyen] : tegra_t186ref_driver_probe 1123 !!!!!!!!!!!!!!!
[ 18.096618] tegra-snd-t186ref-mobile-rt565x sound: Failed dai init
[ 18.096619] tegra-snd-t186ref-mobile-rt565x sound: ASoC: machine hw_params failed: -524
[ 18.096717] tegra-snd-t186ref-mobile-rt565x sound: codec_dai clock not set
[ 18.096718] tegra-snd-t186ref-mobile-rt565x sound: Failed dai init
[ 18.096720] tegra-snd-t186ref-mobile-rt565x sound: ASoC: machine hw_params failed: -524
** 5 printk messages dropped ** [ 18.099495] tegra-snd-t186ref-mobile-rt565x sound: ASoC: machine hw_params failed: -524
** 59 printk messages dropped ** [ 18.110012] tegra-snd-t186ref-mobile-rt565x sound: ASoC: machine hw_params failed: -524
** 44 printk messages dropped ** [ 18.114710] tegra-snd-t186ref-mobile-rt565x sound: ASoC: machine hw_params failed: -524
** 59 printk messages dropped ** [ 18.120928] tegra-snd-t186ref-mobile-rt565x sound: ASoC: machine hw_params failed: -524
** 29 printk messages dropped ** [ 18.129810] tegra-snd-t186ref-mobile-rt565x sound: ASoC: machine hw_params failed: -524
** 59 printk messages dropped ** [ 18.135584] tegra-snd-t186ref-mobile-rt565x sound: ASoC: machine hw_params failed: -524
** 61 printk messages dropped ** [ 18.169242] tegra-snd-t186ref-mobile-rt565x sound: Failed dai init
Thanks and Best Regards,
Vu Nguyen
