TX2 RT5639 on R32.1
I’m porting rt5639 on TX2 R32.1.
Please see the change I did as the following.
diff --git a/sources/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts b/sources/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts
index 015793e..d7a998f 100644
--- a/sources/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts
+++ b/sources/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts
@@ -366,6 +366,15 @@
 	i2c@c240000 {
 		clock-frequency = <400000>;
+// added by Yen for rt5639 audio codec
+		pcptx2_rt5639: rt5639.1-001c@1c {
+			status = "okay";
+			compatible = "realtek,rt5640";
+			reg = <0x1c>;
+			realtek,ldo1-en-gpios =	<&tegra_main_gpio TEGRA_MAIN_GPIO(J, 6) GPIO_ACTIVE_HIGH>;
+			sel_jd_source = <3>;
 	cpus {
@@ -442,6 +451,148 @@
+	tegra_sound: sound {
+		compatible = "nvidia,tegra-audio-t186ref-mobile-rt5639/40";
+		nvidia,model = "tegra-snd-t186ref-mobile-rt5639_40";
+		realtek,in1-differential = <1>;
+		nvidia,num-codec-link = <5>;
+		nvidia,num-clk = <8>;
+		nvidia,hp-det-gpios = <&tegra_main_gpio TEGRA_MAIN_GPIO(J, 5) GPIO_ACTIVE_HIGH>;
+		nvidia,clk-rates = < 270950400	/* PLLA_x11025_RATE */
+				     11289600	/* AUD_MCLK_x11025_RATE */
+				     45158400	/* PLLA_OUT0_x11025_RATE */
+				     45158400	/* AHUB_x11025_RATE */
+				     245760000  /* PLLA_x8000_RATE */
+				     12288000	/* AUD_MCLK_x8000_RATE */
+				     49152000	/* PLLA_OUT0_x8000_RATE */
+				     49152000 >;/* AHUB_x8000_RATE */
+		clocks = <&tegra_car TEGRA186_CLK_PLLP_OUT0>,
+			<&tegra_car TEGRA186_CLK_PLLA>,
+			<&tegra_car TEGRA186_CLK_PLL_A_OUT0>,
+			<&tegra_car TEGRA186_CLK_AHUB>,
+			<&tegra_car TEGRA186_CLK_CLK_M>,
+			<&tegra_car TEGRA186_CLK_AUD_MCLK>;
+		clock-names = "pll_p_out1", "pll_a", "pll_a_out0", "ahub",
+				"clk_m", "extern1";
+		resets = <&tegra_car TEGRA186_RESET_AUD_MCLK>;
+		reset-names = "extern1_rst";
+		status = "okay";
+		nvidia,audio-routing =
+			"x Headphone Jack", 	"x HP L Playback",
+			"x Headphone Jack", 	"x HP R Playback",
+			"x Int Spk", 	"x SPORP",
+			"x Int Spk", 	"x SPORN",
+			"x Int Spk", 	"x SPOLP",
+			"x Int Spk", 	"x SPOLN",
+			"x IN2P",		"x Mic Jack",
+			"x DMIC L1",	"x Int Mic",
+			"x DMIC L2",	"x Int Mic",
+			"x DMIC R1",	"x Int Mic",
+			"x DMIC R2",	"x Int Mic",
+			"y Headphone", 	"y OUT",
+			"y IN",		"y Mic",
+			"z Headphone", 	"z OUT",
+			"z IN",		"z Mic";
+		nvidia,xbar = <&tegra_axbar>;
+		rt5640_dai_link: nvidia,dai-link-1 {
+			link-name = "rt5640-playback";
+			cpu-dai = <&tegra_i2s1>;
+			codec-dai = <&pcptx2_rt5639>;
+			/* codec-dai = <&spdif_dit0>; */
+			cpu-dai-name = "I2S1";
+			codec-dai-name = "rt5640-aif1";
+			/* codec-dai-name = "dit-hifi"; */
+			format = "i2s";
+			bitclock-slave;
+			frame-slave;
+			bitclock-noninversion;
+			frame-noninversion;
+			bit-format = "s16_le";
+			bclk_ratio = <0>;
+			srate = <48000>;
+			num-channel = <2>;
+			ignore_suspend;
+			name-prefix = "x";
+			status = "okay";
+		nvidia,dai-link-2 {
+			link-name = "spdif-dit-1";
+			cpu-dai = <&tegra_i2s2>;
+			codec-dai = <&spdif_dit1>;
+			cpu-dai-name = "I2S2";
+			codec-dai-name = "dit-hifi";
+			format = "dsp_a";
+			bitclock-slave;
+			frame-slave;
+			bitclock-inversion;
+			frame-inversion;
+			bclk_ratio = <4>;
+			srate = <8000>;
+			num-channel = <1>;
+			ignore_suspend;
+			name-prefix = "y";
+			status = "okay";
+		nvidia,dai-link-3 {
+			link-name = "spdif-dit-2";
+			cpu-dai = <&tegra_i2s3>;
+			codec-dai = <&spdif_dit2>;
+			cpu-dai-name = "I2S3";
+			format = "i2s";
+			bitclock-slave;
+			frame-slave;
+			bclk_ratio = <1>;
+			srate = <48000>;
+			ignore_suspend;
+			name-prefix = "z";
+			status = "okay";
+		dspk_dai_link_1: nvidia,dai-link-4 {
+			link-name = "dspk-playback-r";
+			cpu-dai = <&tegra_dspk1>;
+			codec-dai = <&spdif_dit3>;
+			cpu-dai-name = "DSPK1";
+			format = "i2s";
+			srate = <48000>;
+			ignore_suspend;
+			name-prefix = "d1";
+			status = "okay";
+		dspk_dai_link_2: nvidia,dai-link-5 {
+			link-name = "dspk-playback-l";
+			cpu-dai = <&tegra_dspk2>;
+			codec-dai = <&spdif_dit4>;
+			cpu-dai-name = "DSPK2";
+			format = "i2s";
+			srate = <48000>;
+			ignore_suspend;
+			name-prefix = "d2";
+			status = "okay";
 #if LINUX_VERSION >= 414
diff --git a/sources/kernel/kernel-4.9/arch/arm64/configs/tegra_defconfig b/sources/kernel/kernel-4.9/arch/arm64/configs/tegra_defconfig
index 9fc9760..3566a6d 100644
--- a/sources/kernel/kernel-4.9/arch/arm64/configs/tegra_defconfig
+++ b/sources/kernel/kernel-4.9/arch/arm64/configs/tegra_defconfig
@@ -1123,3 +1123,15 @@ CONFIG_CRYPTO_AES_ARM64_NEON_BLK=y
 CONFIG_ARCH_TEGRA_18x_SOC=y
 CONFIG_ARCH_TEGRA_19x_SOC=y
 CONFIG_ARCH_TEGRA_23x_SOC=y
+# added by Yen for enable rt5639 audio codec
+# CONFIG_EQOS_APE_HWDEP is not set
+CONFIG_SND_SOC_TEGRA210_ADSP_ALT=y
+CONFIG_TEGRA_NVADSP=y
+CONFIG_TEGRA_NVADSP_ON_SMMU=y
+# CONFIG_TEGRA_ADSP_DFS is not set
+# CONFIG_TEGRA_ADSP_CPUSTAT is not set
+CONFIG_TEGRA_ADSP_CONSOLE=y
+# CONFIG_MBOX_ACK_HANDLER is not set
+CONFIG_FIQ=y
diff --git a/sources/kernel/kernel-4.9/sound/soc/codecs/rt5640.c b/sources/kernel/kernel-4.9/sound/soc/codecs/rt5640.c
index 79d02c9..f53445c 100644
--- a/sources/kernel/kernel-4.9/sound/soc/codecs/rt5640.c
+++ b/sources/kernel/kernel-4.9/sound/soc/codecs/rt5640.c
@@ -133,8 +133,12 @@ static const struct reg_default rt5640_reg[] = {
 	{ 0x8b, 0x0600 },
 	{ 0x8c, 0x0228 },
 	{ 0x8d, 0xa000 },
-	{ 0x8e, 0x0004 },
-	{ 0x8f, 0x1100 },
+// modified by Yen for hearing microphone's sound from headphone
+//	{ 0x8e, 0x0004 },
+//	{ 0x8f, 0x1100 },
+	{ 0x8e, 0x0005 },
+	{ 0x8f, 0x1140 },
 	{ 0x90, 0x0646 },
 	{ 0x91, 0x0c00 },
 	{ 0x92, 0x0000 },
@@ -942,8 +946,10 @@ static void hp_amp_power_on(struct snd_soc_codec *codec)
 	/* depop parameters */
 	regmap_update_bits(rt5640->regmap, RT5640_PR_BASE +
 		RT5640_CHPUMP_INT_REG1, 0x0700, 0x0200);
-	regmap_update_bits(rt5640->regmap, RT5640_DEPOP_M2,
-		RT5640_DEPOP_MASK, RT5640_DEPOP_MAN);
+// commented out for fixing hearing microphone's sound from headphone
+//	regmap_update_bits(rt5640->regmap, RT5640_DEPOP_M2,
+//		RT5640_DEPOP_MASK, RT5640_DEPOP_MAN);
 	regmap_update_bits(rt5640->regmap, RT5640_DEPOP_M1,
 		RT5640_HP_CP_MASK | RT5640_HP_SG_MASK | RT5640_HP_CB_MASK,
 		RT5640_HP_CP_PU | RT5640_HP_SG_DIS | RT5640_HP_CB_PU);
@@ -1232,6 +1238,12 @@ static const struct snd_soc_dapm_widget rt5640_dapm_widgets[] = {
 		RT5640_PWR_DAC_L1_BIT, 0, NULL, 0),
 	SND_SOC_DAPM_SUPPLY("DAC R1 Power", RT5640_PWR_DIG1,
 		RT5640_PWR_DAC_R1_BIT, 0, NULL, 0),
+// added by Yen for enable rt5639 audio codec
+        SND_SOC_DAPM_SUPPLY("DAC L2 Power", RT5640_PWR_DIG1,
+                RT5640_PWR_DAC_L2_BIT, 0, NULL, 0),
+        SND_SOC_DAPM_SUPPLY("DAC R2 Power", RT5640_PWR_DIG1,
+                RT5640_PWR_DAC_R2_BIT, 0, NULL, 0),
 	/* SPK/OUT Mixer */
 	SND_SOC_DAPM_MIXER("SPK MIXL", RT5640_PWR_MIXER, RT5640_PWR_SM_L_BIT,
 		0, rt5640_spk_l_mix, ARRAY_SIZE(rt5640_spk_l_mix)),
@@ -1327,10 +1339,12 @@ static const struct snd_soc_dapm_widget rt5640_specific_dapm_widgets[] = {
 		rt5640_mono_mix, ARRAY_SIZE(rt5640_mono_mix)),
 	SND_SOC_DAPM_SUPPLY("Improve MONO Amp Drv", RT5640_PWR_ANLG1,
 		RT5640_PWR_MA_BIT, 0, NULL, 0),
-	SND_SOC_DAPM_SUPPLY("DAC L2 Power", RT5640_PWR_DIG1,
-		RT5640_PWR_DAC_L2_BIT, 0, NULL, 0),
-	SND_SOC_DAPM_SUPPLY("DAC R2 Power", RT5640_PWR_DIG1,
-		RT5640_PWR_DAC_R2_BIT, 0, NULL, 0),
+// commented out by Yen for enable rt5639 audio codec
+//	SND_SOC_DAPM_SUPPLY("DAC L2 Power", RT5640_PWR_DIG1,
+//		RT5640_PWR_DAC_L2_BIT, 0, NULL, 0),
+//	SND_SOC_DAPM_SUPPLY("DAC R2 Power", RT5640_PWR_DIG1,
+//		RT5640_PWR_DAC_R2_BIT, 0, NULL, 0),
 	SND_SOC_DAPM_OUTPUT("MONOP"),
 	SND_SOC_DAPM_OUTPUT("MONON"),
@@ -2020,6 +2034,10 @@ static int rt5640_set_bias_level(struct snd_soc_codec *codec,
 	case SND_SOC_BIAS_STANDBY:
 		if (SND_SOC_BIAS_OFF == snd_soc_codec_get_bias_level(codec)) {
+//added by Yen for microphone
+			snd_soc_update_bits(codec, RT5640_PWR_ANLG2,
+				RT5640_PWR_MB1, RT5640_PWR_MB1);
 			snd_soc_update_bits(codec, RT5640_PWR_ANLG1,
 				RT5640_PWR_VREF1 | RT5640_PWR_MB |
 				RT5640_PWR_BG | RT5640_PWR_VREF2,
@@ -2033,12 +2051,18 @@ static int rt5640_set_bias_level(struct snd_soc_codec *codec,
 						0x0301, 0x0301);
 			snd_soc_update_bits(codec, RT5640_MICBIAS,
 						0x0030, 0x0030);
+		snd_soc_write(codec, RT5640_DEPOP_M1, 0x0005);
+		snd_soc_write(codec, RT5640_DEPOP_M2, 0x1140);
 		break;
 	case SND_SOC_BIAS_OFF:
-		snd_soc_write(codec, RT5640_DEPOP_M1, 0x0004);
-		snd_soc_write(codec, RT5640_DEPOP_M2, 0x1100);
+//		snd_soc_write(codec, RT5640_DEPOP_M1, 0x0004);
+//		snd_soc_write(codec, RT5640_DEPOP_M2, 0x1100);
 		snd_soc_update_bits(codec, RT5640_DUMMY1, 0x1, 0);
 		snd_soc_write(codec, RT5640_PWR_DIG1, 0x0000);
 		snd_soc_write(codec, RT5640_PWR_DIG2, 0x0000);
diff --git a/sources/kernel/nvidia/sound/soc/tegra-alt/machine_drivers/tegra_machine_driver_mobile.c b/sources/kernel/nvidia/sound/soc/tegra-alt/machine_drivers/tegra_machine_driver_mobile.c
index e3428a6..1d7db10 100644
--- a/sources/kernel/nvidia/sound/soc/tegra-alt/machine_drivers/tegra_machine_driver_mobile.c
+++ b/sources/kernel/nvidia/sound/soc/tegra-alt/machine_drivers/tegra_machine_driver_mobile.c
@@ -32,11 +33,12 @@
 #include <sound/soc.h>
 #include <dt-bindings/sound/tas2552.h>
 #include "rt5659.h"
+#include "rt5640.h"
 #include "tegra_asoc_utils_alt.h"
 #include "tegra_asoc_machine_alt.h"
 #include "tegra210_xbar_alt.h"
@@ -97,7 +99,8 @@ static int tegra_machine_driver_probe(struct platform_device *);
 static void dai_link_setup(struct platform_device *);
 static void ignore_suspend(struct snd_soc_card *);
 static int tegra_machine_sfc_init(struct snd_soc_pcm_runtime *);
-static int tegra_machine_rt565x_init(struct snd_soc_pcm_runtime *);
+//static int tegra_machine_rt565x_init(struct snd_soc_pcm_runtime *);
+static int tegra_machine_rt5639_init(struct snd_soc_pcm_runtime *);
 #if IS_ENABLED(CONFIG_SND_SOC_TEGRA210_ADSP_ALT)
 static int tegra_machine_compr_set_params(struct snd_compr_stream *);
@@ -533,7 +536,7 @@ static int tegra_machine_dai_init(struct snd_soc_pcm_runtime *runtime,
 	if (err < 0)
 		return err;
-	rtd = snd_soc_get_pcm_runtime(card, "rt565x-playback");
+	rtd = snd_soc_get_pcm_runtime(card, "rt5640-playback");
 	if (rtd) {
 		dai_params =
 		(struct snd_soc_pcm_stream *)rtd->dai_link->params;
@@ -544,7 +547,7 @@ static int tegra_machine_dai_init(struct snd_soc_pcm_runtime *runtime,
 		if (machine->is_hs_supported) {
 			err = snd_soc_dai_set_sysclk(rtd->codec_dai,
-			RT5659_SCLK_S_MCLK, clk_out_rate, SND_SOC_CLOCK_IN);
+			RT5640_SCLK_S_MCLK, clk_out_rate, SND_SOC_CLOCK_IN);
 			if (err < 0) {
 				dev_err(card->dev, "codec_dai clock not set\n");
 				return err;
@@ -782,7 +785,57 @@ static int tegra_machine_compr_set_params(struct snd_compr_stream *cstream)
 #endif
-static int tegra_machine_rt565x_init(struct snd_soc_pcm_runtime *rtd)
+//static int tegra_machine_rt565x_init(struct snd_soc_pcm_runtime *rtd)
+//	struct snd_soc_card *card = rtd->card;
+//	struct tegra_machine *machine = snd_soc_card_get_drvdata(card);
+//	struct snd_soc_jack *jack;
+//	int err;
+//	err = tegra_alt_asoc_utils_set_extern_parent(&machine->audio_clock,
+//							"pll_a_out0");
+//	if (err < 0) {
+//		dev_err(card->dev, "Failed to set extern clk parent\n");
+//		return err;
+//	jack = devm_kzalloc(card->dev, sizeof(struct snd_soc_jack), GFP_KERNEL);
+//	if (!jack)
+//		return -ENOMEM;
+//	err = snd_soc_card_jack_new(card, "Headset Jack", SND_JACK_HEADSET,
+//				    jack, NULL, 0);
+//	if (err) {
+//		dev_err(card->dev, "Headset Jack creation failed %d\n", err);
+//		return err;
+//	err = tegra_machine_add_codec_jack_control(card, rtd, jack);
+//	if (err) {
+//		dev_err(card->dev, "Failed to add jack control: %d\n", err);
+//		return err;
+//	err = rt5659_set_jack_detect(rtd->codec, jack);
+//	if (err) {
+//		dev_err(card->dev, "Failed to set jack for RT565x: %d\n", err);
+//		return err;
+//	/* single button supporting play/pause */
+//	snd_jack_set_key(jack->jack, SND_JACK_BTN_0, KEY_MEDIA);
+//	/* multiple buttons supporting play/pause and volume up/down */
+//	snd_jack_set_key(jack->jack, SND_JACK_BTN_1, KEY_MEDIA);
+//	snd_jack_set_key(jack->jack, SND_JACK_BTN_2, KEY_VOLUMEUP);
+//	snd_jack_set_key(jack->jack, SND_JACK_BTN_3, KEY_VOLUMEDOWN);
+//	snd_soc_dapm_sync(&card->dapm);
+//	return 0;
+static int tegra_machine_rt5639_init(struct snd_soc_pcm_runtime *rtd)
@@ -871,7 +924,7 @@ static void dai_link_setup(struct platform_device *pdev)
 	for (i = 0; i < machine->num_codec_links; i++) {
 		if (tegra_machine_codec_links[i].name) {
 			if (strstr(tegra_machine_codec_links[i].name,
-				"rt565x-playback") ||
+				"rt5640-playback") ||
 				"rt565x-codec-sysclk-bclk1")) {
 				codec_dai_name =
@@ -882,7 +935,7 @@ static void dai_link_setup(struct platform_device *pdev)
 				} else {
 					machine->is_hs_supported = true;
 					tegra_machine_codec_links[i].init =
-						tegra_machine_rt565x_init;
+						tegra_machine_rt5639_init;
 			} else if (strstr(tegra_machine_codec_links[i].name,
 				"dspk-playback-r"))
@@ -966,11 +1019,7 @@ err_alloc_dai_link:
 /* structure to match device tree node */
 static const struct of_device_id tegra_machine_of_match[] = {
-	{ .compatible = "nvidia,tegra-audio-t186ref-mobile-rt565x",
-		.data = &soc_data_tegra186 },
-	{ .compatible = "nvidia,tegra-audio-t210ref-mobile-rt565x",
-		.data = &soc_data_tegra210 },
-	{ .compatible = "nvidia,tegra-audio-mystique",
+	{ .compatible = "nvidia,tegra-audio-t186ref-mobile-rt5639/40",
I also change Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
- pinmux.0x02431040 = 0x00000055; # dap1_sclk_pj0: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
- pinmux.0x02431038 = 0x00000055; # dap1_dout_pj1: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
- pinmux.0x02431030 = 0x00000055; # dap1_din_pj2: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
- pinmux.0x02431028 = 0x00000055; # dap1_fs_pj3: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
- pinmux.0x02431020 = 0x00000059; # aud_mclk_pj4: rsvd1, pull-up, tristate-enable, input-enable, lpdr-disable
+ pinmux.0x02431040 = 0x00000440; # dap1_sclk_pj0: i2s1, tristate-disable, input-enable
+ pinmux.0x02431038 = 0x00000440; # dap1_dout_pj1: i2s1, tristate-disable, input-enable
+ pinmux.0x02431030 = 0x00000450; # dap1_din_pj2: i2s1, tristate-enable, input-enable
+ pinmux.0x02431028 = 0x00000440; # dap1_fs_pj3: i2s1, tristate-disable, input-enable
+ pinmux.0x02431020 = 0x00000400; # aud_mclk_pj4: aud, tristate-disable, input-disable
Now, I can see rt5639 in dmesg(see attachment), but I can’t play sound via rt5639
[ 5.334918] ALSA device list:
[ 5.334921] #0: tegra-hda at 0x3518000 irq 385
[ 5.334923] #1: tegra-snd-t186ref-mobile-rt5639_40
I tried to copy amixer_settings which I used on R28.3 to rootfs/etc, but it doesn’t work too.
Does anyone know how to let it work?
Thx
Yen
dmesg.txt (97 KB)
Hello!
The changes appear to be fine as far as I can see. When you say …
Do you mean that settings the amixer controls does not work or audio playback/capture does not work?
Can you try …
$ echo 0 | sudo tee /sys/kernel/debug/tracing/trace
$ echo 0 | sudo tee /sys/kernel/debug/tracing/events/enable
$ echo 1 | sudo tee /sys/kernel/debug/tracing/tracing_on
$ echo 1 | sudo tee /sys/kernel/debug/tracing/events/asoc/snd_soc_dapm_widget_power/enable
$ aplay <args>
$ sudo cat /sys/kernel/debug/tracing/trace
And see the output from the trace?
Regards,
Jon
Hi jonathanh,
pcp@pcp-desktop:~$ echo 0 | sudo tee /sys/kernel/debug/tracing/trace
0
pcp@pcp-desktop:~$ echo 0 | sudo tee /sys/kernel/debug/tracing/events/enable
0
pcp@pcp-desktop:~$ echo 1 | sudo tee /sys/kernel/debug/tracing/tracing_on
1
oc_dapm_widget_power/enable sudo tee /sys/kernel/debug/tracing/events/asoc/snd_so
1
pcp@pcp-desktop:~$ aplay -D plughw:1,0 /usr/share/sounds/alsa/Front_Left.wav
Playing WAVE '/usr/share/sounds/alsa/Front_Left.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
pcp@pcp-desktop:~$ sudo cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 0/0   #P:4
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
pcp@pcp-desktop:~$
When I run “aplay -D plughw:1,0 /usr/share/sounds/alsa/Front_Left.wav”, no sound output from rt5639
It seems like this verion of Ubuntu doesn’t have amixer_settings, right?
Thx
Yen
Hello!
What does the following show …
amixer -c 1 cget name="I2S1 Mux"
Jon
Hi jonathanh,
pcp@pcp-desktop:~$ amixer -c 1 cget name="I2S1 Mux"
numid=1040,iface=MIXER,name='I2S1 Mux'
  ; type=ENUMERATED,access=rw------,values=1,items=81
  ; Item #0 'None'
  ; Item #1 'ADMAIF1'
  ; Item #2 'ADMAIF2'
  ; Item #3 'ADMAIF3'
  ; Item #4 'ADMAIF4'
  ; Item #5 'ADMAIF5'
  ; Item #6 'ADMAIF6'
  ; Item #7 'ADMAIF7'
  ; Item #8 'ADMAIF8'
  ; Item #9 'ADMAIF9'
  ; Item #10 'ADMAIF10'
  ; Item #11 'ADMAIF11'
  ; Item #12 'ADMAIF12'
  ; Item #13 'ADMAIF13'
  ; Item #14 'ADMAIF14'
  ; Item #15 'ADMAIF15'
  ; Item #16 'ADMAIF16'
  ; Item #17 'I2S1'
  ; Item #18 'I2S2'
  ; Item #19 'I2S3'
  ; Item #20 'I2S4'
  ; Item #21 'I2S5'
  ; Item #22 'I2S6'
  ; Item #23 'SFC1'
  ; Item #24 'SFC2'
  ; Item #25 'SFC3'
  ; Item #26 'SFC4'
  ; Item #27 'MIXER1-1'
  ; Item #28 'MIXER1-2'
  ; Item #29 'MIXER1-3'
  ; Item #30 'MIXER1-4'
  ; Item #31 'MIXER1-5'
  ; Item #32 'AMX1'
  ; Item #33 'AMX2'
  ; Item #34 'AMX3'
  ; Item #35 'AMX4'
  ; Item #36 'ARAD1'
  ; Item #37 'AFC1'
  ; Item #38 'AFC2'
  ; Item #39 'AFC3'
  ; Item #40 'AFC4'
  ; Item #41 'AFC5'
  ; Item #42 'AFC6'
  ; Item #43 'OPE1'
  ; Item #44 'SPKPROT1'
  ; Item #45 'MVC1'
  ; Item #46 'MVC2'
  ; Item #47 'IQC1-1'
  ; Item #48 'IQC1-2'
  ; Item #49 'IQC2-1'
  ; Item #50 'IQC2-2'
  ; Item #51 'DMIC1'
  ; Item #52 'DMIC2'
  ; Item #53 'DMIC3'
  ; Item #54 'DMIC4'
  ; Item #55 'ADX1-1'
  ; Item #56 'ADX1-2'
  ; Item #57 'ADX1-3'
  ; Item #58 'ADX1-4'
  ; Item #59 'ADX2-1'
  ; Item #60 'ADX2-2'
  ; Item #61 'ADX2-3'
  ; Item #62 'ADX2-4'
  ; Item #63 'ADX3-1'
  ; Item #64 'ADX3-2'
  ; Item #65 'ADX3-3'
  ; Item #66 'ADX3-4'
  ; Item #67 'ADX4-1'
  ; Item #68 'ADX4-2'
  ; Item #69 'ADX4-3'
  ; Item #70 'ADX4-4'
  ; Item #71 'ADMAIF17'
  ; Item #72 'ADMAIF18'
  ; Item #73 'ADMAIF19'
  ; Item #74 'ADMAIF20'
  ; Item #75 'ASRC1-1'
  ; Item #76 'ASRC1-2'
  ; Item #77 'ASRC1-3'
  ; Item #78 'ASRC1-4'
  ; Item #79 'ASRC1-5'
  ; Item #80 'ASRC1-6'
  : values=1
pcp@pcp-desktop:~$
Thx
Yen
Hello!
Correct. The default mixer settings are now set by the ALSA init scripts. See /usr/share/alsa/init/postinit/00-tegra.conf and /usr/share/alsa/init/postinit/01-tegra-rt565x.conf. When the following command is executed these files are parsed to see if there are any mixer settings that need to be set …
alsactl init <soundcardname>
Where soundcardname is the name of your soundcard which should be ‘tegrasndt186ref’. Please note that ‘alsactl init’ automatically run on the first boot after flashing because there is no ALSA restore file in /var/lib/alsa/.
So if you have previously made changes to the /etc/amixer_settings file, then now you need to add a
/usr/share/alsa/init/postinit/01-tegra-rt5639.conf with your mixers settings. Use the 01-tegra-rt565x.conf as an example.
This change has been made because previously ALSA save/restore did not work and this is aligned with how most Ubuntu machines work.
I assume that you have manually set the mixer controls for the codec now that the amixer_settings is not present, correct?
What does ‘aplay -v -D plughw:1,0 /usr/share/sounds/alsa/Front_Left.wav’ show?
Regards,
Jon
Hi Jon,
After adding 01-tegra-rt5639.conf,
I can hear sound by rt5639, but only from the “Front Left” speaker, “Front Right” speaker doesn’t have any sound and microphone is not working too.
(Test steps:Ubuntu->System Settings->Sound->Analog Stereo Output & Test Sound)
Attachments are the amixer_settings file I used on R28.3 and the 01-tegra-rt5639.conf I made.
Could you help us to check if 01-tegra-rt5639.conf file is correct?
Thx
Yen
01-tegra-rt5639.conf.txt (3.46 KB)
amixer_settings.txt (3.22 KB)
Hi jonathanh,
Any update?
Thx
Yen
Hello!
So the amixer_settings.txt are the setting you are using from rel28.3, correct?
The only difference I can see between the amixer_settings.txt and 01-tegra-rt5639.conf file is …
The amixer_setting.txt has …
amixer cset -c tegrasndt186ref name="x RECMIXL BST2 Switch" 1
amixer cset -c tegrasndt186ref name="x RECMIXR BST2 Switch" 1
But 01-tegra-rt5639.conf has …
CTL{name}="x RECMIXL BST2 Switch", CTL{value}="off"
CTL{name}="x RECMIXR BST2 Switch", CTL{value}="off"
This may explain why the microphone is not working, but does not explain why the right channel is not working for playback. What I would recommend is that you …
  1. Flash the working rel28.3 release and save all the mixer settings by …
$ alsactl store -f alsa-rel28.state
  1. Flash the non-working rel-32.1 release and save all the mixer settings by …
$ alsactl store -f alsa-rel32.state
  1. Compare the above files and look for any differences.
Regards,
Jon
Hi jonathanh,
My microphone is working after changing these values to “on”.
I have also compared 2 mixer settings(see attachments), but still have no ideal how to analyze it.
Could you help to analyze these 2 files to see why my right channel is not working?
Thx
Yen
alsa-rel28.state.txt (412 KB)
alsa-rel32.state.txt (762 KB)
Hello!
Thanks for the files. Yes there are quite a lot of differences between rel28 and rel32 and so diff’ing these files may appear quite overwhelming indeed. However, looking at the diff one thing I did see is …
-       control.601 {
+       control.981 {
                iface MIXER
                name 'x HP Playback Volume'
                value.0 31
-               value.1 31
+               value.1 1
                comment {
                        access 'read write'
                        type INTEGER
It appears like the volume for the right channel is 1 and not 31, can you try …
amixer -c tegrasndt186ref cset name="x HP Playback Volume" 31,31
Or in the 01-tegra-rt5639.conf …
CTL{name}="x HP Playback Volume", CTL{value}="31,31"
You can check the value set by …
amixer -c tegrasndt186ref cget name="x HP Playback Volume"
Regards,
Jon
Hi jonathanh,
I changed the following values and it works now.
CTL{name}="x Speaker Playback Volume", CTL{value}="32,32"
CTL{name}="x Headphone Playback Volume", CTL{value}="31,31"
CTL{name}="x DAC1 Playback Volume", CTL{value}="175,175"
Thanks for your help!!
Thx
Yen
