@Tonie
The correct i2c bus is i2c@c2400000, the message show the device no ack that could be the device didn’t power up or something with it. You may need help from the vendor to check the device side first.
@Tonie
I think you need to make the i2c working first. The gpio-to-sfio is about the i2s setting.
You could try the i2c-tools to access the device and probe the i2c signal to check.
root@tegra-ubuntu:/home/nvidia# i2cdetect -y -r 1
0 1 2 3 4 5 6 7 8 9 a b [ 381.089237] tegra-i2c c240000.i2c: no acknowledge from address 0x3
c d e f
00: – [ 381.099327] tegra-i2c c240000.i2c: no acknowledge from address 0x4
– [ 381.107974] tegra-i2c c240000.i2c: no acknowledge from address 0x5
– [ 381.114833] tegra-i2c c240000.i2c: no acknowledge from address 0x6
– [ 381.121685] tegra-i2c c240000.i2c: no acknowledge from address 0x7
– [ 381.128488] tegra-i2c c240000.i2c: no acknowledge from address 0x8
– [ 381.135361] tegra-i2c c240000.i2c: no acknowledge from address 0x9
– [ 381.142195] tegra-i2c c240000.i2c: no acknowledge from address 0xa
– [ 381.149024] tegra-i2c c240000.i2c: no acknowledge from address 0xb
– [ 381.155881] tegra-i2c c240000.i2c: no acknowledge from address 0xc
– [ 381.162716] tegra-i2c c240000.i2c: no acknowledge from address 0xd
– [ 381.169542] tegra-i2c c240000.i2c: no acknowledge from address 0xe
– [ 381.176349] tegra-i2c c240000.i2c: no acknowledge from address 0xf
10: [ 381.183197] tegra-i2c c240000.i2c: no acknowledge from address 0x10
– [ 381.190663] tegra-i2c c240000.i2c: no acknowledge from address 0x11
– [ 381.197557] tegra-i2c c240000.i2c: no acknowledge from address 0x12
– [ 381.204482] tegra-i2c c240000.i2c: no acknowledge from address 0x13
– [ 381.211388] tegra-i2c c240000.i2c: no acknowledge from address 0x14
– [ 381.218297] tegra-i2c c240000.i2c: no acknowledge from address 0x15
– [ 381.225170] tegra-i2c c240000.i2c: no acknowledge from address 0x16
– [ 381.232124] tegra-i2c c240000.i2c: no acknowledge from address 0x17
– [ 381.239042] tegra-i2c c240000.i2c: no acknowledge from address 0x18
– [ 381.245952] tegra-i2c c240000.i2c: no acknowledge from address 0x19
– [ 381.252902] tegra-i2c c240000.i2c: no acknowledge from address 0x1a
– [ 381.259828] tegra-i2c c240000.i2c: no acknowledge from address 0x1b
– [ 381.266719] tegra-i2c c240000.i2c: no acknowledge from address 0x1c
– [ 381.273710] tegra-i2c c240000.i2c: no acknowledge from address 0x1d
– [ 381.280637] tegra-i2c c240000.i2c: no acknowledge from address 0x1e
– [ 381.287597] tegra-i2c c240000.i2c: no acknowledge from address 0x1f
20: [ 381.294529] tegra-i2c c240000.i2c: no acknowledge from address 0x20
– [ 381.301907] tegra-i2c c240000.i2c: no acknowledge from address 0x21
– [ 381.308849] tegra-i2c c240000.i2c: no acknowledge from address 0x22
– [ 381.315739] tegra-i2c c240000.i2c: no acknowledge from address 0x23
– [ 381.322694] tegra-i2c c240000.i2c: no acknowledge from address 0x24
– [ 381.329602] tegra-i2c c240000.i2c: no acknowledge from address 0x25
– [ 381.336519] tegra-i2c c240000.i2c: no acknowledge from address 0x26
– [ 381.343418] tegra-i2c c240000.i2c: no acknowledge from address 0x27
– [ 381.350315] tegra-i2c c240000.i2c: no acknowledge from address 0x28
– [ 381.357237] tegra-i2c c240000.i2c: no acknowledge from address 0x29
– [ 381.364146] tegra-i2c c240000.i2c: no acknowledge from address 0x2a
– [ 381.371072] tegra-i2c c240000.i2c: no acknowledge from address 0x2b
– [ 381.377965] tegra-i2c c240000.i2c: no acknowledge from address 0x2c
– [ 381.384909] tegra-i2c c240000.i2c: no acknowledge from address 0x2d
– [ 381.391803] tegra-i2c c240000.i2c: no acknowledge from address 0x2e
– [ 381.398705] tegra-i2c c240000.i2c: no acknowledge from address 0x2f
30: [ 381.405644] tegra-i2c c240000.i2c: no acknowledge from address 0x30
– [ 381.413047] tegra-i2c c240000.i2c: no acknowledge from address 0x31
– [ 381.419943] tegra-i2c c240000.i2c: no acknowledge from address 0x32
– [ 381.426834] tegra-i2c c240000.i2c: no acknowledge from address 0x33
– [ 381.433747] tegra-i2c c240000.i2c: no acknowledge from address 0x34
– [ 381.440664] tegra-i2c c240000.i2c: no acknowledge from address 0x35
– [ 381.447558] tegra-i2c c240000.i2c: no acknowledge from address 0x36
– [ 381.454471] tegra-i2c c240000.i2c: no acknowledge from address 0x37
– [ 381.461388] tegra-i2c c240000.i2c: no acknowledge from address 0x38
– [ 381.468268] tegra-i2c c240000.i2c: no acknowledge from address 0x39
– [ 381.475174] tegra-i2c c240000.i2c: no acknowledge from address 0x3a
– [ 381.482078] tegra-i2c c240000.i2c: no acknowledge from address 0x3b
– [ 381.489046] tegra-i2c c240000.i2c: no acknowledge from address 0x3c
– [ 381.495971] tegra-i2c c240000.i2c: no acknowledge from address 0x3d
– [ 381.502878] tegra-i2c c240000.i2c: no acknowledge from address 0x3e
– [ 381.509821] tegra-i2c c240000.i2c: no acknowledge from address 0x3f
40: [ 381.516754] tegra-i2c c240000.i2c: no acknowledge from address 0x40
– [ 381.524182] tegra-i2c c240000.i2c: no acknowledge from address 0x41
– [ 381.531095] tegra-i2c c240000.i2c: no acknowledge from address 0x42
– [ 381.538021] tegra-i2c c240000.i2c: no acknowledge from address 0x43
– [ 381.544919] tegra-i2c c240000.i2c: no acknowledge from address 0x44
– [ 381.551810] tegra-i2c c240000.i2c: no acknowledge from address 0x45
– [ 381.558716] tegra-i2c c240000.i2c: no acknowledge from address 0x46
– [ 381.565628] tegra-i2c c240000.i2c: no acknowledge from address 0x47
– [ 381.572531] tegra-i2c c240000.i2c: no acknowledge from address 0x48
– [ 381.579431] tegra-i2c c240000.i2c: no acknowledge from address 0x49
– [ 381.586366] tegra-i2c c240000.i2c: no acknowledge from address 0x4a
– [ 381.593262] tegra-i2c c240000.i2c: no acknowledge from address 0x4b
– [ 381.600170] tegra-i2c c240000.i2c: no acknowledge from address 0x4c
– [ 381.607095] tegra-i2c c240000.i2c: no acknowledge from address 0x4d
– [ 381.614004] tegra-i2c c240000.i2c: no acknowledge from address 0x4e
– [ 381.620921] tegra-i2c c240000.i2c: no acknowledge from address 0x4f
50: [ 381.627823] tegra-i2c c240000.i2c: no acknowledge from address 0x50
– [ 381.635257] tegra-i2c c240000.i2c: no acknowledge from address 0x51
– [ 381.642157] tegra-i2c c240000.i2c: no acknowledge from address 0x52
– [ 381.649051] tegra-i2c c240000.i2c: no acknowledge from address 0x53
– [ 381.655994] tegra-i2c c240000.i2c: no acknowledge from address 0x54
– [ 381.662943] tegra-i2c c240000.i2c: no acknowledge from address 0x55
– [ 381.669897] tegra-i2c c240000.i2c: no acknowledge from address 0x56
– [ 381.676767] tegra-i2c c240000.i2c: no acknowledge from address 0x57
– [ 381.683744] tegra-i2c c240000.i2c: no acknowledge from address 0x58
– [ 381.690704] tegra-i2c c240000.i2c: no acknowledge from address 0x59
– [ 381.697637] tegra-i2c c240000.i2c: no acknowledge from address 0x5a
– [ 381.704533] tegra-i2c c240000.i2c: no acknowledge from address 0x5b
– [ 381.711439] tegra-i2c c240000.i2c: no acknowledge from address 0x5c
– [ 381.718344] tegra-i2c c240000.i2c: no acknowledge from address 0x5d
– [ 381.725243] tegra-i2c c240000.i2c: no acknowledge from address 0x5e
– [ 381.732154] tegra-i2c c240000.i2c: no acknowledge from address 0x5f
60: [ 381.739070] tegra-i2c c240000.i2c: no acknowledge from address 0x60
– [ 381.746479] tegra-i2c c240000.i2c: no acknowledge from address 0x61
– [ 381.753403] tegra-i2c c240000.i2c: no acknowledge from address 0x62
– [ 381.760315] tegra-i2c c240000.i2c: no acknowledge from address 0x63
– [ 381.767243] tegra-i2c c240000.i2c: no acknowledge from address 0x64
– [ 381.774190] tegra-i2c c240000.i2c: no acknowledge from address 0x65
– [ 381.781077] tegra-i2c c240000.i2c: no acknowledge from address 0x66
– [ 381.788018] tegra-i2c c240000.i2c: no acknowledge from address 0x67
– [ 381.794925] tegra-i2c c240000.i2c: no acknowledge from address 0x68
– [ 381.801847] tegra-i2c c240000.i2c: no acknowledge from address 0x69
– [ 381.808783] tegra-i2c c240000.i2c: no acknowledge from address 0x6a
– [ 381.815738] tegra-i2c c240000.i2c: no acknowledge from address 0x6b
– [ 381.822672] tegra-i2c c240000.i2c: no acknowledge from address 0x6c
– [ 381.829523] tegra-i2c c240000.i2c: no acknowledge from address 0x6d
– [ 381.836423] tegra-i2c c240000.i2c: no acknowledge from address 0x6e
– [ 381.843330] tegra-i2c c240000.i2c: no acknowledge from address 0x6f
70: [ 381.850297] tegra-i2c c240000.i2c: no acknowledge from address 0x70
– [ 381.857713] tegra-i2c c240000.i2c: no acknowledge from address 0x71
– [ 381.864623] tegra-i2c c240000.i2c: no acknowledge from address 0x72
– [ 381.871610] tegra-i2c c240000.i2c: no acknowledge from address 0x73
– [ 381.878520] tegra-i2c c240000.i2c: no acknowledge from address 0x74
– [ 381.885432] tegra-i2c c240000.i2c: no acknowledge from address 0x75
– [ 381.892333] tegra-i2c c240000.i2c: no acknowledge from address 0x76
– [ 381.899259] tegra-i2c c240000.i2c: no acknowledge from address 0x77
It looks like i2c doesn’t work.
Please help to advise what I can do more ?
@Tonie
It’s predictable due to there is no any device devices connect to this bus. However I can tell there’s no problem for this bus, we have an internal camera board is connected to this bus and working well.
What you need to do is use i2cget to access your device and probe the signal to debug why no ack from your device.
@Tonie
That’s interesting, What I can promise is this bus is no problem. And I see the CLK/DATA of this i2c bus is working to send command while I scan this bus from the waveform. BTW I am use the JetPack 3.1 but I believe there’s should be no different for this.
@Tonie
So you are using customize carrier board instead of Jetson CVM? I guess it’s could be the pin miss match.
Could you try to scan all bus and check the waveform to make sure this pin is connect to which bus.
