Hi all,
We are developing AI box using Jetson nano eMMC card and customize carrier board but the audio is not working. Our design and configuration is described below:
We have modified some dts files. However there are some problems with I2C and I2S configuration.
tegra210-porg-super-module-e2614.dtsi
e2614_rt5658_a00: rt5659.1-001a@1a {
compatible = "realtek,rt5658";
reg = <0x1a>;
status = "okay";
/ gpio for jack detection /
gpios = <&gpio TEGRA_GPIO(B, 6) 0>;
/ refer include/sound/rt5659.h for the values to be used /
realtek,jd-src = <1>; / RT5659_JD3 /
realtek,dmic1-data-pin = <2>; / RT5659_DMIC1_DATA_GPIO5 /
tegra210-porg-p3448-common.dtsi
tegra_sound: sound {
status = "okay";
compatible = "nvidia,tegra-audio-t210ref-mobile-rt565x";
nvidia,model = "tegra-snd-t210ref-mobile-rt565x";
clocks = <&tegra_car TEGRA210_CLK_PLL_A>,
<&tegra_car TEGRA210_CLK_PLL_A_OUT0>,
<&tegra_car TEGRA210_CLK_EXTERN1>;
clock-names = "pll_a", "pll_a_out0", "extern1";
assigned-clocks = <&tegra_car TEGRA210_CLK_EXTERN1>;
assigned-clock-parents = <&tegra_car TEGRA210_CLK_PLL_A_OUT0>;
nvidia,num-codec-link = <4>;
nvidia,audio-routing =
"x Headphone", "x OUT",
"x IN", "x Mic",
"y Headphone", "y OUT",
"y IN", "y Mic",
"a IN", "a Mic",
"b IN", "b Mic";
nvidia,xbar = <&tegra_axbar>;
mclk-fs = <256>;
hdr40_snd_link_i2s: i2s_dai_link1: nvidia,dai-link-1 {
link-name = "spdif-dit-0";
cpu-dai = <&tegra_i2s4>;
codec-dai = <&spdif_dit0>;
cpu-dai-name = "I2S4";
codec-dai-name = "rt5659-aif1";
format = "i2s";
bitclock-slave;
frame-slave;
bitclock-noninversion;
frame-noninversion;
bit-format = "s16_le";
srate = <48000>;
num-channel = <2>;
ignore_suspend;
name-prefix = "x";
status = "okay";
tegra-platforms-audio-dai-links.dtsi
status = "okay";
nvidia,num-codec-link = <12>;
nvidia,num-clk = <8>;
nvidia,clk-rates = < 270950400 / PLLA_x11025_RATE /
11289600 / AUD_MCLK_x11025_RATE /
45158400 / PLLA_OUT0_x11025_RATE /
45158400 / AHUB_x11025_RATE /
245760000 / PLLA_x8000_RATE /
12288000 / AUD_MCLK_x8000_RATE /
49152000 / PLLA_OUT0_x8000_RATE /
49152000 >;/ AHUB_x8000_RATE /
nvidia,dai-link-1 {
cpu-dai = <&tegra_i2s1>;
format = "i2s";
srate = <48000>;
num-channel = <2>;
ignore_suspend;
name-prefix = "x";
status = "okay";
tegra210-porg-pinmux-p3448-0002-b00.dtsi
gen3_i2c_scl_pf0 {
nvidia,pins = "gen3_i2c_scl_pf0";
nvidia,function = "i2c3";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
gen3_i2c_sda_pf1 {
nvidia,pins = "gen3_i2c_sda_pf1";
dap4_din_pj5 {
nvidia,pins = "dap4_din_pj5";
nvidia,function = "i2s4b";
nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
dap4_dout_pj6 {
nvidia,pins = "dap4_dout_pj6";
dap4_fs_pj4 {
nvidia,pins = "dap4_fs_pj4";
dap4_sclk_pj7 {
nvidia,pins = "dap4_sclk_pj7";
Boot up log:
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4263) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SM0
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 1.099380] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.119968] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.126443] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[ 1.147514] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.153824] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.167158] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.173446] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.186777] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.193067] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.206416] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.212705] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.221003] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.262583] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.262611] imx219 7-0010: board setup failed
[ 1.286405] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.286435] imx219 8-0010: board setup failed
[ 1.342820] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.342823] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.347841] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.347844] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.357674] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.357677] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.362703] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.362706] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.362709] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.362713] hpd: edid read prepare failed
[ 1.672460] rt5659 1-001a: Device with ID register ffffff80 is not rt5659
[ 1.699746] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 1.706633] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 1.741467] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 1.748478] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 1.756870] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 1.763752] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 1.794773] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 1.801658] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.275373] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.445031] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 2.451945] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.487899] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 2.494781] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.655152] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 2.662505] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.672876] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 2.679795] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 3.520456] using random self ethernet address
[ 3.550005] using random host ethernet address
[ 4.024798] random: crng init done
[ 4.028230] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.341936] using random self ethernet address
[ 4.349612] using random host ethernet address
Do people have any suggestion for us ??
