I use the tlv320aic3109 decoder
reference https://devtalk.nvidia.com/default/topic/1036139/jetson-tx2/tx2-asoc-with-tlv320aic32x4/1
However, the following error occurred
3.732085] Release 3.2.0 from 19.12.2014 [ 3.732284] net can1: mttcan device registered (regs=ffffff8000fda000, irq=428) [ 3.737469] cpuidle: Initializing cpuidle driver init for Denver cluster [ 3.737595] cpuidle: Initializing cpuidle driver init for A57 cluster [ 3.738543] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered [ 3.738546] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2 [ 3.740899] usbcore: registered new interface driver snd-usb-audio [ 3.742617] tegra210_adsp_audio_platform_probe: platform probe started [ 3.743791] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1 [ 3.748523] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0 [ 3.748773] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1 [ 3.749091] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot [ 3.749816] tegra210-adsp adsp_audio: Default param-type to BYTE for src [ 3.750215] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1 [ 3.750598] tegra210-adsp adsp_audio: Default param-type to BYTE for aec [ 3.750603] tegra210-adsp adsp_audio: adma channel page address dt entry not found [ 3.750606] tegra210-adsp adsp_audio: using adma channel page 0 [ 3.762049] tegra210_adsp_audio_platform_probe probe successfull. [ 3.762050] OPE platform probe [ 3.762133] OPE platform probe successful [ 3.777920] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec [ 3.780190] tegra-snd-t186ref-mobile-rt565x sound: ASoC: CODEC DAI tlv320aic31xx-hifi not registered [ 3.780196] tegra-snd-t186ref-mobile-rt565x sound: snd_soc_register_card failed (-517) [ 3.780839] GACT probability NOT on [ 3.780848] Mirror/redirect action on [ 3.780861] u32 classifier [ 3.780862] Actions configured
This is because of what?
