Hi. I’m having trouble running Autodesk Fusion 360 on wine. Newest wine version from arch repo (wine, not wine-staging but it doesn’t change anything in my particular case). OS is ArchLinux.
Sketch objects are really laggy, after selecting and unselecting them they stay highlighted until i click once again somewhere else.
New users can only include 3 links, so here are the photos and issue described:
[url]https://github.com/cryinkfly/Fusion-360---Linux-Wine-Version-/issues/73[/url]
This problem is exclusive to nvidia proprietary drivers, it works almost fine on nouveau/igpu drivers. Doesn’t matter if I run the app in OpenGL or DX9 mode, with or without DXVK.
When using DXVK I apply following overrides:
[HKEY_CURRENT_USER\Software\Wine\DllOverrides]
"*d3d10core"=""
"*d3d11"="native"
"*d3d9"="builtin"
"*dxgi"="native"
Wine environment set with
winetricks -q corefonts cjkfonts msxml4 msxml6 vcrun2017 fontsmooth=rgb win8
I’ve noticed this when running Fusion from the terminal:
043c:fixme:d3d_shader:print_glsl_info_log Info log received from GLSL shader #10:
043c:fixme:d3d_shader:print_glsl_info_log Vertex info
043c:fixme:d3d_shader:print_glsl_info_log -----------
043c:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[2].zw" might be used before being initialized
043c:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[3]" might be used before being initialized
043c:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[4]" might be used before being initialized
043c:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[5]" might be used before being initialized
043c:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[6]" might be used before being initialized
043c:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[7]" might be used before being initialized
043c:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[8]" might be used before being initialized
043c:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[9]" might be used before being initialized
043c:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[10]" might be used before being initialized
043c:fixme:d3d_shader:print_glsl_info_log 0(25) : warning C7050: "vs_out[11]" might be used before being initialized
Here’s my glxinfo -B
name of display: :0
display: :0 screen: 0
direct rendering: Yes
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 4096 MB
Total available memory: 4096 MB
Currently available dedicated video memory: 3736 MB
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce GTX 980/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 470.63.01
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6.0 NVIDIA 470.63.01
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 470.63.01
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
Here’s whole logfile of running fusion from the terminal:
[url]https://pastebin.com/8XSf9e16[/url]
Any help would be appreciated :)
Happy to provide additional info if needed.
