So after looking through each of the routines in cuDNN, it’s not clear to me what datatypes are permitted per routine. The cudnnDataType_t type lists several such as float, half, and (u)int8. But are these datatypes supported for each routine?
Say I was trying to use batch normalization with int8 data. The cudnnBatchNormalizationForwardTraining() routine does not make it clear if int8 is supported, and I would rather not have to test it, along with every other routine, for each datatype to determine compatiblity. The ‘Scaling Parameters’ section talks about ‘float’, ‘half’, and ‘double’ - not int8.
It’s very difficult to get a feel for what data works with what routines. Hoping someone here can give me a few pointers to clarify this (not the host kind). Any help very much appreciated.
