AVC/H.264 parser/decoder 12.1.14 hoards heap memory filled with SEI messages when pfnGetSEIMsg is nullptr
Hello.
I upgraded NVIDIA codec SDK from 11.1.5 to 12.1.14 (the latest I believe) recently and I think I found a “Memory hoarding” problem in SDK 12.1.14.
My application is an AVC/H.264 video player based on NVIDIA codec SDK and it has “loop play mode” feature.
When it reaches the end of a video clip, it seeks back to the first frame of the clip and continues playing infinitely.
After the upgrade, I’ve been having steady and limitless increase of memory size (RSS/RES: residential memory area) with my application in “loop play” mode.
Before the upgrade, the application’s memory size increases for a while, then hits a ceiling and stops increasing.
After having a hard time with debugging, I found the following facts.
  • The increased memory area contains a huge array of SEI message data. In my case, they were repeated chunks of human-readable texts that describe encoding parameters, which are embedded at the top of AVC/H.264 stream data.
  • The number of text chunks increase in proportion with “loop count”.
  • With SDK 12.1.14, users can set a callback-function-pointer to pfnGetSEIMsg in set-up parameter structure CUVIDPARSERPARAMS given to cuvidCreateVideoParser().
  • With SDK 11.1.5, fpnGetSEIMsg was not defined. It seems to be a new feature added in SDK 12.
  • When a callback-function-pointer is set to pfnGetSEIMsg, the callback-function is called when the parser comes across SEI Messages or Metadata OBUs in a AVC/H.264 stream.
  • The sample code in “Samples/NvCodec/NvDecoder/NvDecoder.cpp” specifies NULL for pfnGetSEIMsg if SEI messages are not necessary. Therefore, pfnGetSEIMsg is not a mandatory parameter and it can be left unspecified as NULL.
  • When I specify a pointer to an empty function (which does nothing but returning 1) for pfnGetSEIMsg, the increase of memory size stops after hitting a ceiling, as it used to with SDK 11.1.5.
  • When I set NULL to pfnGetSEIMsg, the size of memory increases without limit in “loop play mode”.
I suspect that the AVC/H.264 parser/decoder hoards SEI message data on heap memory without limit when it can’t call a callback-function (because pfnGetSEIMsg is NULL), let the function handle the messages, then free the memory area for the data on return from the function.
I think the parser should ignore all SEI messages and Metadata OBUs from the start when NULL is given to CUVIDPARSERPARAMS.pfnGetSEIMsg on cuvidCreateVideoParser().
The amount of hoarded memory is small (less than 1 KB per loop), but it can accumulate up to 100 MB when a short clip is kept loop-playing for several days (this is a typical use-case of my product).
This problem can be avoided by assigning a pointer to an empty function to pfnGetSEIMsg,
but fixing the problem will save future users from unexpected increase of memory size.
It would be nice if I could provide you a modified version of NVIDIA SDK sample code for easy reproduction, but I can’t install ffmpeg on my development environment for some reasons.
I believe you can easily reproduce the problem with AVC/H.264 MP4 files with some SEI messages embedded in the content or you can identify the cause of the problem if you have access to the source code of codec SDK 12.1.14.
I think this is a problem with AVC/H.264 parser and GPU has nothing to do with the problem,
but the following is my GPU information.
OS : Linux (Rocky 8)
Driver Version : 535.54.03
CUDA Version : 12.2
Product Name : Quadro RTX 4000 or RTX A4500
Thank you for reading this report.
Hello, again.
I’d like to make it sure that the following are true:
  • Setting NULL to pfnGetSEIMsg is allowed by the specification.
  • The memory hoarding is an unexpected behavior.
  • My temporary fix by setting a pointer to an empty callback function to pfnGetSEIMsg is the best way to avoid the problem and it has no side effect.
I need to prove that I have figured out the real cause of growing memory size and I have implemented a right way to avoid the problem.
To fellow users who may be interested in this topic,
I reported this problem through the bug report form, which I came across yesterday, and I received a prompt reply (thanks).
  • Setting NULL to pfnGetSEIMsg is legal and it should disable processing of SEI messages.
  • The memory hoarding was a problem with the driver. It has already been fixed in 545.29.02 NFB(=New Feature Branch).
  • Giving a pointer to an empty function is an effective workaround and has no drawbacks.
bug report 4406959
Hello @masaki.nishikawa, a belated welcome to the NVIDIA developer forums!
In case of suspected software bugs and if there is a more direct form or route available to report them, it is very welcome to use that route to let us know of possible issues.
Thank you very much to share the current status here for others who might have encountered the same problem, the community appreciates it.
Lastly, the bug reference link you posted is only visible to partner program accounts, not publicly here on the developer forums. I disabled it to void confusion.
I conducted a test with R545.29.06 (the latest NFB) and verified that the problem I had reported didn’t reproduce.
I believe that the bug has been fixed in R545.29.06 and it was fixed in R545.29.02.
P.S.
Markus, Thank you for taking care of the inaccessible link.
