Hello, I was able to make a small modification to ffmpeg which will demonstrate the crash. Start with the source code from ffmpeg tag name “n4.2.3”, and apply this diff to libavcodec/nvenc.c:
--- ./nvenc_orig.c 2020-07-07 08:55:32.105268303 -0700
+++ nvenc.c 2020-07-07 09:04:24.441360966 -0700
@@ -2110,6 +2110,7 @@
pic_params.inputTimeStamp = frame->pts;
if (ctx->a53_cc && av_frame_get_side_data(frame, AV_FRAME_DATA_A53_CC)) {
if (ff_alloc_a53_sei(frame, sizeof(NV_ENC_SEI_PAYLOAD), (void**)&sei_data, &sei_size) < 0) {
av_log(ctx, AV_LOG_ERROR, "Not enough memory for closed captions, skipping\n");
@@ -2121,6 +2122,18 @@
sei_data->payload = (uint8_t*)(sei_data + 1);
+ // attach a Filler SEI message, to only the first 100 frames
+ static int frame_count = 0;
+ if (frame_count++ < 100)
+ sei_size = 16;
+ sei_data = av_mallocz(sei_size + sizeof(NV_ENC_SEI_PAYLOAD));
+ sei_data->payloadSize = (uint32_t)sei_size;
+ sei_data->payloadType = 3;
+ sei_data->payload = (uint8_t*)(sei_data + 1);
+ memset(sei_data->payload, 0xff, sei_size);
nvenc_codec_specific_pic_params(avctx, &pic_params, sei_data);
} else {
I configured the source code with the following options:
./configure --enable-version3 --enable-cuda --enable-cuvid --enable-nvenc --enable-nonfree --enable-libnpp --enable-libvmaf --extra-cflags=-I/usr/local/cuda/include --extra-ldflags=-L/usr/local/cuda/lib64 --nvcc=/usr/local/cuda/bin/nvcc --enable-cuda-nvcc
I ran the transcoder with the following command:
./ffmpeg_g -y -loglevel verbose -f rawvideo -s:v 1920x1080 -pix_fmt yuv420p -r 30 -i /media/source_yuv/test_nvidia_rc_lookahead_crash_1920x1080_420.yuv -c:v h264_nvenc -preset medium -rc cbr -profile:v high -coder cabac -no-scenecut 1 -b_ref_mode disabled -bf 3 -spatial-aq 1 -b:v 4M -g 30 -rc-lookahead 15 /home/richard/test_nvidia_rc_lookahead_crash_1920x1080_420.mov
In this case I was using uncompressed YUV planar as an input format and quicktime as the output, but I’m sure the crash will be reproducible regardless of the input and output formats. The important settings are to use the h264_nvenc codec, CBR rate control, and enable rc-lookahead.
Here is the back trace from the crash:
Thread 1 "ffmpeg_g" received signal SIGSEGV, Segmentation fault.
__memmove_avx_unaligned () at ../sysdeps/x86_64/multiarch/memcpy-avx-unaligned.S:244
244 ../sysdeps/x86_64/multiarch/memcpy-avx-unaligned.S: No such file or directory.
(gdb) bt
#0 __memmove_avx_unaligned () at ../sysdeps/x86_64/multiarch/memcpy-avx-unaligned.S:244
#1 0x00007fffe91ed390 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1
#2 0x00007fffe91ee1c7 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1
#3 0x00007fffe91ea7b8 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1
#4 0x00007fffe91ea88e in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1
#5 0x00007fffe91eafed in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1
#6 0x00007fffe91e8407 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1
#7 0x00007fffe91f609b in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1
#8 0x0000000000fe0745 in ff_nvenc_send_frame (avctx=0x2126280, frame=0x2943d40) at libavcodec/nvenc.c:2148
#9 0x0000000000877c82 in avcodec_send_frame (avctx=avctx@entry=0x2126280, frame=frame@entry=0x2943d40)
at libavcodec/encode.c:403
#10 0x00000000004a6b2b in do_video_out (of=of@entry=0x2123840, ost=ost@entry=0x2126040,
next_picture=next_picture@entry=0x2943d40, sync_ipts=<optimized out>, sync_ipts@entry=15.000007629394531)
at fftools/ffmpeg.c:1288
#11 0x00000000004a7eb6 in reap_filters (flush=flush@entry=0) at fftools/ffmpeg.c:1505
#12 0x00000000004abfe9 in transcode_step () at fftools/ffmpeg.c:4650
#13 transcode () at fftools/ffmpeg.c:4694
#14 0x00000000004896b2 in main (argc=<optimized out>, argv=0x7fffffffd148) at fftools/ffmpeg.c:4896
(gdb)
And the process memory mappings:
(gdb) info proc mappings
process 32659
Mapped address spaces:
Start Addr End Addr Size Offset objfile
0x400000 0x167e000 0x127e000 0x0 /home/richard/Software/ffmpeg/ffmpeg_g
0x187d000 0x187e000 0x1000 0x127d000 /home/richard/Software/ffmpeg/ffmpeg_g
0x187e000 0x18cc000 0x4e000 0x127e000 /home/richard/Software/ffmpeg/ffmpeg_g
0x18cc000 0x324b000 0x197f000 0x0 [heap]
0x200000000 0x200200000 0x200000 0x0
0x200200000 0x200400000 0x200000 0x0 /dev/nvidiactl
0x200400000 0x200600000 0x200000 0x0 /dev/nvidia0
0x200600000 0x203e00000 0x3800000 0x0 /dev/nvidiactl
0x203e00000 0x204000000 0x200000 0x0 /dev/nvidia0
0x204000000 0x205000000 0x1000000 0x0
0x205000000 0x205200000 0x200000 0x0 /dev/nvidiactl
0x205200000 0x205400000 0x200000 0x0 /dev/nvidiactl
0x205400000 0x205600000 0x200000 0x205400000 /dev/nvidia-uvm
0x205600000 0x205800000 0x200000 0x0 /dev/nvidiactl
0x205800000 0x205a00000 0x200000 0x0
0x205a00000 0x205c00000 0x200000 0x0 /dev/nvidiactl
0x205c00000 0x300200000 0xfa600000 0x0
0x10000000000 0x10004000000 0x4000000 0x0
0x7fffb30a3000 0x7fffb59e8000 0x2945000 0x0
0x7fffb59e8000 0x7fffb5cf4000 0x30c000 0x0 /dev/nvidiactl
0x7fffb5cf4000 0x7fffb6000000 0x30c000 0x0 /dev/nvidiactl
0x7fffb6000000 0x7fffb632a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffb632a000 0x7fffb6400000 0xd6000 0x0
0x7fffb6400000 0x7fffb672a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffb672a000 0x7fffb6800000 0xd6000 0x0
0x7fffb6800000 0x7fffb6b2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffb6b2a000 0x7fffb6c00000 0xd6000 0x0
0x7fffb6c00000 0x7fffb6f2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffb6f2a000 0x7fffb7000000 0xd6000 0x0
0x7fffb7000000 0x7fffb732a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffb732a000 0x7fffb7400000 0xd6000 0x0
0x7fffb7400000 0x7fffb772a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffb772a000 0x7fffb8000000 0x8d6000 0x0
0x7fffb8004000 0x7fffb8310000 0x30c000 0x0 /dev/nvidiactl
0x7fffb8310000 0x7fffb861c000 0x30c000 0x0 /dev/nvidiactl
0x7fffb861c000 0x7fffb8928000 0x30c000 0x0 /dev/nvidiactl
0x7fffb8928000 0x7fffb8c34000 0x30c000 0x0 /dev/nvidiactl
0x7fffb8c34000 0x7fffb8f40000 0x30c000 0x0 /dev/nvidiactl
0x7fffb8f40000 0x7fffb924c000 0x30c000 0x0 /dev/nvidiactl
0x7fffb924c000 0x7fffb9558000 0x30c000 0x0 /dev/nvidiactl
0x7fffb9558000 0x7fffb9864000 0x30c000 0x0 /dev/nvidiactl
0x7fffb9864000 0x7fffb9b70000 0x30c000 0x0 /dev/nvidiactl
0x7fffb9b70000 0x7fffb9e7c000 0x30c000 0x0 /dev/nvidiactl
0x7fffb9e7c000 0x7fffba188000 0x30c000 0x0 /dev/nvidiactl
0x7fffba188000 0x7fffba494000 0x30c000 0x0 /dev/nvidiactl
0x7fffba494000 0x7fffba7a0000 0x30c000 0x0 /dev/nvidiactl
0x7fffba7a0000 0x7fffbaaac000 0x30c000 0x0 /dev/nvidiactl
0x7fffbaaac000 0x7fffbadb8000 0x30c000 0x0 /dev/nvidiactl
0x7fffbadb8000 0x7fffbb0c4000 0x30c000 0x0 /dev/nvidiactl
0x7fffbb0c4000 0x7fffbb3d0000 0x30c000 0x0 /dev/nvidiactl
0x7fffbb3d0000 0x7fffbb6dc000 0x30c000 0x0 /dev/nvidiactl
0x7fffbb6dc000 0x7fffbb9e8000 0x30c000 0x0 /dev/nvidiactl
0x7fffbb9e8000 0x7fffbbcf4000 0x30c000 0x0 /dev/nvidiactl
0x7fffbbcf4000 0x7fffbc000000 0x30c000 0x0 /dev/nvidiactl
0x7fffbc000000 0x7fffbc32a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffbc32a000 0x7fffbc400000 0xd6000 0x0
0x7fffbc400000 0x7fffbc72a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffbc72a000 0x7fffbc800000 0xd6000 0x0
0x7fffbc800000 0x7fffbcb2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffbcb2a000 0x7fffbcc00000 0xd6000 0x0
0x7fffbcc00000 0x7fffbcf2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffbcf2a000 0x7fffbd000000 0xd6000 0x0
0x7fffbd000000 0x7fffbd32a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffbd32a000 0x7fffbd400000 0xd6000 0x0
0x7fffbd400000 0x7fffbd72a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffbd72a000 0x7fffbd800000 0xd6000 0x0
0x7fffbd800000 0x7fffbdb2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffbdb2a000 0x7fffbdc00000 0xd6000 0x0
0x7fffbdc00000 0x7fffbdf2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffbdf2a000 0x7fffbe000000 0xd6000 0x0
0x7fffbe188000 0x7fffbe494000 0x30c000 0x0 /dev/nvidiactl
0x7fffbe494000 0x7fffbe7a0000 0x30c000 0x0 /dev/nvidiactl
0x7fffbe7a0000 0x7fffbeaac000 0x30c000 0x0 /dev/nvidiactl
0x7fffbeaac000 0x7fffbedb8000 0x30c000 0x0 /dev/nvidiactl
0x7fffbedb8000 0x7fffbf0c4000 0x30c000 0x0 /dev/nvidiactl
0x7fffbf0c4000 0x7fffbf3d0000 0x30c000 0x0 /dev/nvidiactl
0x7fffbf3d0000 0x7fffbf6dc000 0x30c000 0x0 /dev/nvidiactl
0x7fffbf6dc000 0x7fffbf9e8000 0x30c000 0x0 /dev/nvidiactl
0x7fffbf9e8000 0x7fffbfcf4000 0x30c000 0x0 /dev/nvidiactl
0x7fffbfcf4000 0x7fffc0000000 0x30c000 0x0 /dev/nvidiactl
0x7fffc0000000 0x7fffc4c00000 0x4c00000 0x0
0x7fffc4c00000 0x7fffc4f2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffc4f2a000 0x7fffc5000000 0xd6000 0x0
0x7fffc5000000 0x7fffc532a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffc532a000 0x7fffc5400000 0xd6000 0x0
0x7fffc5400000 0x7fffc572a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffc572a000 0x7fffc5800000 0xd6000 0x0
0x7fffc5800000 0x7fffc5b2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffc5b2a000 0x7fffc5c00000 0xd6000 0x0
0x7fffc5c00000 0x7fffc5f2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffc5f2a000 0x7fffc7200000 0x12d6000 0x0
0x7fffc7200000 0x7fffc752a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffc752a000 0x7fffc7600000 0xd6000 0x0
0x7fffc7600000 0x7fffc792a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffc792a000 0x7fffc7a00000 0xd6000 0x0
0x7fffc7a00000 0x7fffc7d2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffc7d2a000 0x7fffc8000000 0x2d6000 0x0
0x7fffc8000000 0x7fffc8021000 0x21000 0x0
0x7fffc8021000 0x7fffcc000000 0x3fdf000 0x0
0x7fffcc188000 0x7fffcc494000 0x30c000 0x0 /dev/nvidiactl
0x7fffcc494000 0x7fffcc7a0000 0x30c000 0x0 /dev/nvidiactl
0x7fffcc7a0000 0x7fffccaac000 0x30c000 0x0 /dev/nvidiactl
0x7fffccaac000 0x7fffccdb8000 0x30c000 0x0 /dev/nvidiactl
0x7fffccdb8000 0x7fffcd0c4000 0x30c000 0x0 /dev/nvidiactl
0x7fffcd0c4000 0x7fffcd3d0000 0x30c000 0x0 /dev/nvidiactl
0x7fffcd3d0000 0x7fffcd6dc000 0x30c000 0x0 /dev/nvidiactl
0x7fffcd6dc000 0x7fffcd9e8000 0x30c000 0x0 /dev/nvidiactl
0x7fffcd9e8000 0x7fffcdcf4000 0x30c000 0x0 /dev/nvidiactl
0x7fffcdcf4000 0x7fffce000000 0x30c000 0x0 /dev/nvidiactl
0x7fffce000000 0x7fffce400000 0x400000 0x0
0x7fffce400000 0x7fffce600000 0x200000 0x0 /dev/zero (deleted)
0x7fffce600000 0x7fffce800000 0x200000 0x0 /dev/nvidiactl
0x7fffce800000 0x7fffcea00000 0x200000 0x0 /dev/zero (deleted)
0x7fffcea00000 0x7fffcee00000 0x400000 0x0
0x7fffcee00000 0x7fffcf000000 0x200000 0x0 /dev/nvidiactl
0x7fffcf000000 0x7fffcf200000 0x200000 0x0
0x7fffcf200000 0x7fffcf400000 0x200000 0x0 /dev/zero (deleted)
0x7fffcf400000 0x7fffcf4e7000 0xe7000 0x0 /dev/nvidiactl
0x7fffcf4e7000 0x7fffcf600000 0x119000 0x0
0x7fffcf600000 0x7fffcf92a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffcf92a000 0x7fffcfa00000 0xd6000 0x0
0x7fffcfa00000 0x7fffcfd2a000 0x32a000 0x0 /dev/zero (deleted)
0x7fffcfd2a000 0x7fffe0000000 0x102d6000 0x0
0x7fffe00ce000 0x7fffe00d3000 0x5000 0x0 /dev/nvidiactl
0x7fffe00d3000 0x7fffe00d4000 0x1000 0x0 /dev/nvidiactl
0x7fffe00d4000 0x7fffe00d9000 0x5000 0x0 /dev/nvidiactl
0x7fffe00d9000 0x7fffe00da000 0x1000 0x0 /dev/nvidiactl
0x7fffe00da000 0x7fffe00df000 0x5000 0x0 /dev/nvidiactl
0x7fffe00df000 0x7fffe00e0000 0x1000 0x0 /dev/nvidiactl
0x7fffe00e0000 0x7fffe00e5000 0x5000 0x0 /dev/nvidiactl
0x7fffe00e5000 0x7fffe00e6000 0x1000 0x0 /dev/nvidiactl
0x7fffe00e6000 0x7fffe00eb000 0x5000 0x0 /dev/nvidiactl
0x7fffe00eb000 0x7fffe00ec000 0x1000 0x0 /dev/nvidiactl
0x7fffe00ec000 0x7fffe00f1000 0x5000 0x0 /dev/nvidiactl
0x7fffe00f1000 0x7fffe00f2000 0x1000 0x0 /dev/nvidiactl
0x7fffe00f2000 0x7fffe00f7000 0x5000 0x0 /dev/nvidiactl
0x7fffe00f7000 0x7fffe00f8000 0x1000 0x0 /dev/nvidiactl
0x7fffe00f8000 0x7fffe00fd000 0x5000 0x0 /dev/nvidiactl
0x7fffe00fd000 0x7fffe00fe000 0x1000 0x0 /dev/nvidiactl
0x7fffe00fe000 0x7fffe0103000 0x5000 0x0 /dev/nvidiactl
0x7fffe0103000 0x7fffe0104000 0x1000 0x0 /dev/nvidiactl
0x7fffe0104000 0x7fffe0109000 0x5000 0x0 /dev/nvidiactl
0x7fffe0109000 0x7fffe010a000 0x1000 0x0 /dev/nvidiactl
0x7fffe010a000 0x7fffe010f000 0x5000 0x0 /dev/nvidiactl
0x7fffe010f000 0x7fffe0110000 0x1000 0x0 /dev/nvidiactl
0x7fffe0110000 0x7fffe0115000 0x5000 0x0 /dev/nvidiactl
0x7fffe0115000 0x7fffe0116000 0x1000 0x0 /dev/nvidiactl
0x7fffe0116000 0x7fffe011b000 0x5000 0x0 /dev/nvidiactl
0x7fffe011b000 0x7fffe011c000 0x1000 0x0 /dev/nvidiactl
0x7fffe011c000 0x7fffe0121000 0x5000 0x0 /dev/nvidiactl
0x7fffe0121000 0x7fffe0122000 0x1000 0x0 /dev/nvidiactl
0x7fffe0122000 0x7fffe0127000 0x5000 0x0 /dev/nvidiactl
0x7fffe0127000 0x7fffe0128000 0x1000 0x0 /dev/nvidiactl
0x7fffe0128000 0x7fffe012d000 0x5000 0x0 /dev/nvidiactl
0x7fffe012d000 0x7fffe012e000 0x1000 0x0 /dev/nvidiactl
0x7fffe012e000 0x7fffe0133000 0x5000 0x0 /dev/nvidiactl
0x7fffe0133000 0x7fffe0134000 0x1000 0x0 /dev/nvidiactl
0x7fffe0134000 0x7fffe0139000 0x5000 0x0 /dev/nvidiactl
0x7fffe0139000 0x7fffe013a000 0x1000 0x0 /dev/nvidiactl
0x7fffe013a000 0x7fffe013f000 0x5000 0x0 /dev/nvidiactl
0x7fffe013f000 0x7fffe0140000 0x1000 0x0 /dev/nvidiactl
0x7fffe0140000 0x7fffe0145000 0x5000 0x0 /dev/nvidiactl
0x7fffe0145000 0x7fffe0146000 0x1000 0x0 /dev/nvidiactl
0x7fffe0146000 0x7fffe014b000 0x5000 0x0 /dev/nvidiactl
0x7fffe014b000 0x7fffe014c000 0x1000 0x0 /dev/nvidiactl
0x7fffe014c000 0x7fffe0151000 0x5000 0x0 /dev/nvidiactl
0x7fffe0151000 0x7fffe0152000 0x1000 0x0 /dev/nvidiactl
0x7fffe0152000 0x7fffe045e000 0x30c000 0x0 /dev/nvidiactl
0x7fffe045e000 0x7fffe0463000 0x5000 0x0 /dev/nvidiactl
0x7fffe0463000 0x7fffe0464000 0x1000 0x0 /dev/nvidiactl
0x7fffe0464000 0x7fffe0770000 0x30c000 0x0 /dev/nvidiactl
0x7fffe0770000 0x7fffe0a7c000 0x30c000 0x0 /dev/nvidiactl
0x7fffe0a7c000 0x7fffe0a81000 0x5000 0x0 /dev/nvidiactl
0x7fffe0a81000 0x7fffe0a82000 0x1000 0x0 /dev/nvidiactl
0x7fffe0a82000 0x7fffe0d8e000 0x30c000 0x0 /dev/nvidiactl
0x7fffe0d8e000 0x7fffe109a000 0x30c000 0x0 /dev/nvidiactl
0x7fffe109a000 0x7fffe109b000 0x1000 0x0 /dev/nvidiactl
0x7fffe109b000 0x7fffe109c000 0x1000 0x0 /dev/nvidiactl
0x7fffe109c000 0x7fffe109d000 0x1000 0x0 /dev/nvidiactl
0x7fffe109d000 0x7fffe109e000 0x1000 0x0 /dev/nvidiactl
0x7fffe109e000 0x7fffe109f000 0x1000 0x0 /dev/nvidiactl
0x7fffe109f000 0x7fffe10a0000 0x1000 0x0 /dev/nvidiactl
0x7fffe10a0000 0x7fffe10a1000 0x1000 0x0 /dev/nvidiactl
0x7fffe10a1000 0x7fffe10a2000 0x1000 0x0 /dev/nvidiactl
0x7fffe10a2000 0x7fffe10a3000 0x1000 0x0 /dev/nvidiactl
0x7fffe10a3000 0x7fffe10a4000 0x1000 0x0 /dev/nvidiactl
0x7fffe10a4000 0x7fffe10a5000 0x1000 0x0 /dev/nvidiactl
0x7fffe10a5000 0x7fffe10a6000 0x1000 0x0 /dev/nvidiactl
0x7fffe10a6000 0x7fffe10a7000 0x1000 0x0 /dev/nvidiactl
0x7fffe10a7000 0x7fffe10a8000 0x1000 0x0 /dev/nvidiactl
0x7fffe10a8000 0x7fffe10a9000 0x1000 0x0 /dev/nvidiactl
0x7fffe10a9000 0x7fffe10aa000 0x1000 0x0 /dev/nvidiactl
0x7fffe10aa000 0x7fffe10ad000 0x3000 0x0 /dev/nvidiactl
0x7fffe10ad000 0x7fffe10b0000 0x3000 0x0 /dev/nvidiactl
0x7fffe10b0000 0x7fffe10b3000 0x3000 0x0 /dev/nvidiactl
0x7fffe10b3000 0x7fffe10b6000 0x3000 0x0 /dev/nvidiactl
0x7fffe10b6000 0x7fffe10b9000 0x3000 0x0 /dev/nvidiactl
0x7fffe10b9000 0x7fffe10bc000 0x3000 0x0 /dev/nvidiactl
0x7fffe10bc000 0x7fffe10bf000 0x3000 0x0 /dev/nvidiactl
0x7fffe10bf000 0x7fffe10c2000 0x3000 0x0 /dev/nvidiactl
0x7fffe10c2000 0x7fffe10c5000 0x3000 0x0 /dev/nvidiactl
0x7fffe10c5000 0x7fffe10c8000 0x3000 0x0 /dev/nvidiactl
0x7fffe10c8000 0x7fffe10cb000 0x3000 0x0 /dev/nvidiactl
0x7fffe10cb000 0x7fffe10ce000 0x3000 0x0 /dev/nvidiactl
0x7fffe10ce000 0x7fffe10d1000 0x3000 0x0 /dev/nvidiactl
0x7fffe10d1000 0x7fffe10d4000 0x3000 0x0 /dev/nvidiactl
0x7fffe10d4000 0x7fffe10d7000 0x3000 0x0 /dev/nvidiactl
0x7fffe10d7000 0x7fffe10da000 0x3000 0x0 /dev/nvidiactl
0x7fffe10da000 0x7fffe1103000 0x29000 0x0 /dev/nvidiactl
0x7fffe1103000 0x7fffe112c000 0x29000 0x0 /dev/nvidiactl
0x7fffe112c000 0x7fffe1154000 0x28000 0x0 /dev/nvidiactl
0x7fffe1154000 0x7fffe124c000 0xf8000 0x0
0x7fffe124c000 0x7fffe144c000 0x200000 0x0 /dev/zero (deleted)
0x7fffe144c000 0x7fffe144d000 0x1000 0x0
0x7fffe144d000 0x7fffe1cce000 0x881000 0x0
0x7fffe1cce000 0x7fffe1ccf000 0x1000 0x0
0x7fffe1ccf000 0x7fffe24cf000 0x800000 0x0
0x7fffe24cf000 0x7fffe24d0000 0x1000 0x0
0x7fffe24d0000 0x7fffe2cd0000 0x800000 0x0
0x7fffe2cd0000 0x7fffe8cd0000 0x6000000 0x0
0x7fffe8cd0000 0x7fffe8fc8000 0x2f8000 0x0 /usr/lib/x86_64-linux-gnu/libnvcuvid.so.440.82
0x7fffe8fc8000 0x7fffe91c7000 0x1ff000 0x2f8000 /usr/lib/x86_64-linux-gnu/libnvcuvid.so.440.82
0x7fffe91c7000 0x7fffe91e2000 0x1b000 0x2f7000 /usr/lib/x86_64-linux-gnu/libnvcuvid.so.440.82
0x7fffe91e2000 0x7fffe91e4000 0x2000 0x0
0x7fffe91e4000 0x7fffe91fa000 0x16000 0x0 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.440.82
0x7fffe91fa000 0x7fffe93fa000 0x200000 0x16000 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.440.82
0x7fffe93fa000 0x7fffe93fd000 0x3000 0x16000 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.440.82
0x7fffe93fd000 0x7fffea2d7000 0xeda000 0x0 /usr/lib/x86_64-linux-gnu/libcuda.so.440.82
0x7fffea2d7000 0x7fffea4d6000 0x1ff000 0xeda000 /usr/lib/x86_64-linux-gnu/libcuda.so.440.82
0x7fffea4d6000 0x7fffea5f1000 0x11b000 0xed9000 /usr/lib/x86_64-linux-gnu/libcuda.so.440.82
0x7fffea5f1000 0x7fffea607000 0x16000 0x0
0x7fffea607000 0x7fffea608000 0x1000 0x0
0x7fffea608000 0x7fffeae08000 0x800000 0x0
0x7fffeae08000 0x7fffeae09000 0x1000 0x0
0x7fffeae09000 0x7fffeb609000 0x800000 0x0
0x7fffeb609000 0x7fffeb60a000 0x1000 0x0
0x7fffeb60a000 0x7fffebe0a000 0x800000 0x0
0x7fffebe0a000 0x7fffebe0b000 0x1000 0x0
0x7fffebe0b000 0x7fffec60b000 0x800000 0x0
0x7fffec60b000 0x7fffec60c000 0x1000 0x0
0x7fffec60c000 0x7fffece0c000 0x800000 0x0
0x7fffece0c000 0x7fffece0d000 0x1000 0x0
0x7fffece0d000 0x7fffed60d000 0x800000 0x0
0x7fffed60d000 0x7fffed60e000 0x1000 0x0
0x7fffed60e000 0x7fffede0e000 0x800000 0x0
0x7fffede0e000 0x7fffede0f000 0x1000 0x0
0x7fffede0f000 0x7fffee60f000 0x800000 0x0
0x7fffee60f000 0x7fffee610000 0x1000 0x0
0x7fffee610000 0x7fffeee10000 0x800000 0x0
0x7fffeee10000 0x7fffeee11000 0x1000 0x0
0x7fffeee11000 0x7fffef611000 0x800000 0x0
0x7fffef611000 0x7fffef612000 0x1000 0x0
0x7fffef612000 0x7fffefe12000 0x800000 0x0
0x7fffefe12000 0x7fffefe13000 0x1000 0x0
0x7fffefe13000 0x7ffff0613000 0x800000 0x0
0x7ffff0613000 0x7ffff0614000 0x1000 0x0
0x7ffff0614000 0x7ffff0e14000 0x800000 0x0
0x7ffff0e14000 0x7ffff0e15000 0x1000 0x0
0x7ffff0e15000 0x7ffff1615000 0x800000 0x0
0x7ffff1615000 0x7ffff1616000 0x1000 0x0
0x7ffff1616000 0x7ffff1e16000 0x800000 0x0
0x7ffff1e16000 0x7ffff1e17000 0x1000 0x0
0x7ffff1e17000 0x7ffff2617000 0x800000 0x0
0x7ffff290f000 0x7ffff2985000 0x76000 0x0 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppc.so.10.2.0.243
0x7ffff2985000 0x7ffff2b84000 0x1ff000 0x76000 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppc.so.10.2.0.243
0x7ffff2b84000 0x7ffff2b88000 0x4000 0x75000 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppc.so.10.2.0.243
0x7ffff2b88000 0x7ffff2b8a000 0x2000 0x0
0x7ffff2b8a000 0x7ffff2ba0000 0x16000 0x0 /lib/x86_64-linux-gnu/libgcc_s.so.1
0x7ffff2ba0000 0x7ffff2d9f000 0x1ff000 0x16000 /lib/x86_64-linux-gnu/libgcc_s.so.1
0x7ffff2d9f000 0x7ffff2da0000 0x1000 0x15000 /lib/x86_64-linux-gnu/libgcc_s.so.1
0x7ffff2da0000 0x7ffff2f12000 0x172000 0x0 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
0x7ffff2f12000 0x7ffff3112000 0x200000 0x172000 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
0x7ffff3112000 0x7ffff311c000 0xa000 0x172000 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
0x7ffff311c000 0x7ffff311e000 0x2000 0x17c000 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
0x7ffff311e000 0x7ffff3122000 0x4000 0x0
0x7ffff3122000 0x7ffff3129000 0x7000 0x0 /lib/x86_64-linux-gnu/librt-2.23.so
0x7ffff3129000 0x7ffff3328000 0x1ff000 0x7000 /lib/x86_64-linux-gnu/librt-2.23.so
0x7ffff3328000 0x7ffff3329000 0x1000 0x6000 /lib/x86_64-linux-gnu/librt-2.23.so
0x7ffff3329000 0x7ffff332a000 0x1000 0x7000 /lib/x86_64-linux-gnu/librt-2.23.so
0x7ffff332a000 0x7ffff332f000 0x5000 0x0 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
0x7ffff332f000 0x7ffff352e000 0x1ff000 0x5000 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
0x7ffff352e000 0x7ffff352f000 0x1000 0x4000 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
0x7ffff352f000 0x7ffff3530000 0x1000 0x5000 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
0x7ffff3530000 0x7ffff3532000 0x2000 0x0 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
0x7ffff3532000 0x7ffff3732000 0x200000 0x2000 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
0x7ffff3732000 0x7ffff3733000 0x1000 0x2000 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
0x7ffff3733000 0x7ffff3734000 0x1000 0x3000 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
0x7ffff3734000 0x7ffff38f4000 0x1c0000 0x0 /lib/x86_64-linux-gnu/libc-2.23.so
0x7ffff38f4000 0x7ffff3af4000 0x200000 0x1c0000 /lib/x86_64-linux-gnu/libc-2.23.so
0x7ffff3af4000 0x7ffff3af8000 0x4000 0x1c0000 /lib/x86_64-linux-gnu/libc-2.23.so
0x7ffff3af8000 0x7ffff3afa000 0x2000 0x1c4000 /lib/x86_64-linux-gnu/libc-2.23.so
0x7ffff3afa000 0x7ffff3afe000 0x4000 0x0
0x7ffff3afe000 0x7ffff3b16000 0x18000 0x0 /lib/x86_64-linux-gnu/libpthread-2.23.so
0x7ffff3b16000 0x7ffff3d15000 0x1ff000 0x18000 /lib/x86_64-linux-gnu/libpthread-2.23.so
0x7ffff3d15000 0x7ffff3d16000 0x1000 0x17000 /lib/x86_64-linux-gnu/libpthread-2.23.so
0x7ffff3d16000 0x7ffff3d17000 0x1000 0x18000 /lib/x86_64-linux-gnu/libpthread-2.23.so
0x7ffff3d17000 0x7ffff3d1b000 0x4000 0x0
0x7ffff3d1b000 0x7ffff3d34000 0x19000 0x0 /lib/x86_64-linux-gnu/libz.so.1.2.8
0x7ffff3d34000 0x7ffff3f33000 0x1ff000 0x19000 /lib/x86_64-linux-gnu/libz.so.1.2.8
0x7ffff3f33000 0x7ffff3f34000 0x1000 0x18000 /lib/x86_64-linux-gnu/libz.so.1.2.8
0x7ffff3f34000 0x7ffff3f35000 0x1000 0x19000 /lib/x86_64-linux-gnu/libz.so.1.2.8
0x7ffff3f35000 0x7ffff3f38000 0x3000 0x0 /lib/x86_64-linux-gnu/libdl-2.23.so
0x7ffff3f38000 0x7ffff4137000 0x1ff000 0x3000 /lib/x86_64-linux-gnu/libdl-2.23.so
0x7ffff4137000 0x7ffff4138000 0x1000 0x2000 /lib/x86_64-linux-gnu/libdl-2.23.so
0x7ffff4138000 0x7ffff4139000 0x1000 0x3000 /lib/x86_64-linux-gnu/libdl-2.23.so
0x7ffff4139000 0x7ffff4902000 0x7c9000 0x0 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppidei.so.10.2.0.243
0x7ffff4902000 0x7ffff4b01000 0x1ff000 0x7c9000 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppidei.so.10.2.0.243
0x7ffff4b01000 0x7ffff4b06000 0x5000 0x7c8000 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppidei.so.10.2.0.243
0x7ffff4b06000 0x7ffff4b29000 0x23000 0x0
0x7ffff4b29000 0x7ffff4f5d000 0x434000 0x0 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppicc.so.10.2.0.243
0x7ffff4f5d000 0x7ffff515d000 0x200000 0x434000 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppicc.so.10.2.0.243
0x7ffff515d000 0x7ffff5162000 0x5000 0x434000 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppicc.so.10.2.0.243
0x7ffff5162000 0x7ffff5166000 0x4000 0x0
0x7ffff5166000 0x7ffff6a2b000 0x18c5000 0x0 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppig.so.10.2.0.243
0x7ffff6a2b000 0x7ffff6c2a000 0x1ff000 0x18c5000 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppig.so.10.2.0.243
0x7ffff6c2a000 0x7ffff6c30000 0x6000 0x18c4000 /usr/local/cuda-10.1/targets/x86_64-linux/lib/libnppig.so.10.2.0.243
0x7ffff6c30000 0x7ffff6c38000 0x8000 0x0
0x7ffff6c38000 0x7ffff6d98000 0x160000 0x0 /usr/local/lib/x86_64-linux-gnu/libvmaf.so.0.0.0
0x7ffff6d98000 0x7ffff6f98000 0x200000 0x160000 /usr/local/lib/x86_64-linux-gnu/libvmaf.so.0.0.0
0x7ffff6f98000 0x7ffff6f99000 0x1000 0x160000 /usr/local/lib/x86_64-linux-gnu/libvmaf.so.0.0.0
0x7ffff6f99000 0x7ffff6f9c000 0x3000 0x161000 /usr/local/lib/x86_64-linux-gnu/libvmaf.so.0.0.0
0x7ffff6f9c000 0x7ffff7095000 0xf9000 0x0 /usr/lib/x86_64-linux-gnu/libasound.so.2.0.0
0x7ffff7095000 0x7ffff7294000 0x1ff000 0xf9000 /usr/lib/x86_64-linux-gnu/libasound.so.2.0.0
0x7ffff7294000 0x7ffff729b000 0x7000 0xf8000 /usr/lib/x86_64-linux-gnu/libasound.so.2.0.0
0x7ffff729b000 0x7ffff729c000 0x1000 0xff000 /usr/lib/x86_64-linux-gnu/libasound.so.2.0.0
0x7ffff729c000 0x7ffff72a2000 0x6000 0x0 /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0.0.0
0x7ffff72a2000 0x7ffff74a2000 0x200000 0x6000 /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0.0.0
0x7ffff74a2000 0x7ffff74a3000 0x1000 0x6000 /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0.0.0
0x7ffff74a3000 0x7ffff74a4000 0x1000 0x7000 /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0.0.0
0x7ffff74a4000 0x7ffff74a7000 0x3000 0x0 /usr/lib/x86_64-linux-gnu/libxcb-shape.so.0.0.0
0x7ffff74a7000 0x7ffff76a6000 0x1ff000 0x3000 /usr/lib/x86_64-linux-gnu/libxcb-shape.so.0.0.0
0x7ffff76a6000 0x7ffff76a7000 0x1000 0x2000 /usr/lib/x86_64-linux-gnu/libxcb-shape.so.0.0.0
0x7ffff76a7000 0x7ffff76a8000 0x1000 0x3000 /usr/lib/x86_64-linux-gnu/libxcb-shape.so.0.0.0
0x7ffff76a8000 0x7ffff76aa000 0x2000 0x0 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
0x7ffff76aa000 0x7ffff78aa000 0x200000 0x2000 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
0x7ffff78aa000 0x7ffff78ab000 0x1000 0x2000 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
0x7ffff78ab000 0x7ffff78ac000 0x1000 0x3000 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
0x7ffff78ac000 0x7ffff78cd000 0x21000 0x0 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
0x7ffff78cd000 0x7ffff7acc000 0x1ff000 0x21000 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
0x7ffff7acc000 0x7ffff7acd000 0x1000 0x20000 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
0x7ffff7acd000 0x7ffff7ace000 0x1000 0x21000 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
0x7ffff7ace000 0x7ffff7bd6000 0x108000 0x0 /lib/x86_64-linux-gnu/libm-2.23.so
0x7ffff7bd6000 0x7ffff7dd5000 0x1ff000 0x108000 /lib/x86_64-linux-gnu/libm-2.23.so
0x7ffff7dd5000 0x7ffff7dd6000 0x1000 0x107000 /lib/x86_64-linux-gnu/libm-2.23.so
0x7ffff7dd6000 0x7ffff7dd7000 0x1000 0x108000 /lib/x86_64-linux-gnu/libm-2.23.so
0x7ffff7dd7000 0x7ffff7dfd000 0x26000 0x0 /lib/x86_64-linux-gnu/ld-2.23.so
0x7ffff7dfd000 0x7ffff7dfe000 0x1000 0x0 /dev/nvidiactl
0x7ffff7dfe000 0x7ffff7dff000 0x1000 0x0 /dev/nvidiactl
0x7ffff7dff000 0x7ffff7e00000 0x1000 0x0 /dev/nvidiactl
0x7ffff7e00000 0x7ffff7e01000 0x1000 0x0 /dev/nvidia0
0x7ffff7e01000 0x7ffff7e02000 0x1000 0x0 /dev/nvidiactl
0x7ffff7e02000 0x7ffff7e03000 0x1000 0x0 /dev/nvidiactl
0x7ffff7e03000 0x7ffff7e04000 0x1000 0x0 /dev/nvidia0
0x7ffff7e04000 0x7ffff7e05000 0x1000 0x0 /dev/nvidiactl
0x7ffff7e05000 0x7ffff7e15000 0x10000 0x0 /dev/nvidia0
0x7ffff7e15000 0x7ffff7fd2000 0x1bd000 0x0
0x7ffff7fd2000 0x7ffff7fd3000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fd3000 0x7ffff7fd4000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fd4000 0x7ffff7fd5000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fd5000 0x7ffff7fd6000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fd6000 0x7ffff7fd7000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fd7000 0x7ffff7fd8000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fd8000 0x7ffff7fd9000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fd9000 0x7ffff7fda000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fda000 0x7ffff7fdb000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fdb000 0x7ffff7fdc000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fdc000 0x7ffff7fdd000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fdd000 0x7ffff7fde000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fde000 0x7ffff7fdf000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fdf000 0x7ffff7fe0000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fe0000 0x7ffff7fe1000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fe1000 0x7ffff7fe2000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fe2000 0x7ffff7fe3000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fe3000 0x7ffff7fe4000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fe4000 0x7ffff7fe5000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fe5000 0x7ffff7fe6000 0x1000 0x0 /dev/nvidiactl
0x7ffff7fe6000 0x7ffff7ff6000 0x10000 0x0 /dev/nvidia0
0x7ffff7ff6000 0x7ffff7ff7000 0x1000 0x0
0x7ffff7ff7000 0x7ffff7ffa000 0x3000 0x0 [vvar]
0x7ffff7ffa000 0x7ffff7ffc000 0x2000 0x0 [vdso]
0x7ffff7ffc000 0x7ffff7ffd000 0x1000 0x25000 /lib/x86_64-linux-gnu/ld-2.23.so
0x7ffff7ffd000 0x7ffff7ffe000 0x1000 0x26000 /lib/x86_64-linux-gnu/ld-2.23.so
0x7ffff7ffe000 0x7ffff7fff000 0x1000 0x0
0x7ffffffdd000 0x7ffffffff000 0x22000 0x0 [stack]
0xffffffffff600000 0xffffffffff601000 0x1000 0x0 [vsyscall]
Regards,
Richard
