Weird output with Nvidia Encoder SDK
I am trying to integrate the Nvidia Encoder SDK with the Nvidia FBC SDK. I am using cuda devices as my input buffers. For some reasons I am getting a weird output, that is, my encoded video is just a green screen screen.
Any help regarding this would be appreciated, thank you
Note- I am doing to by integrating the encoder SDK in the Cuda Asynchronous sample of the Nvidia Frame Buffer Capture SDK
 * \brief
 * Demonstrates how to use NvFBC to asynchronously grab frames to
 * video memory then save them to the disk.
 * \file
 * This sample demonstrates the following features:
 * - Capture to video memory using CUDA interop;
 * - Select an output (monitor) to track;
 * - Select and test buffer formats;
 * - Frame scaling;
 * - Asynchronous (non blocking) capture.
 * This copyright notice applies to this file only:
 * \copyright
 * Copyright (c) 2013-2017, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <dlfcn.h>
#include <string.h>
#include <getopt.h>
#include <unistd.h>
#include<dlfcn.h>
#include"nvEncodeAPI.h"
#include <NvFBC.h>
// If you have the CUDA Toolkit Installed, you can include the CUDA headers
// #include "cuda.h"
//#include "cuda_drvapi_dynlink_cuda.h"
#include"cuda.h"
#include "NvFBCUtils.h"
#define APP_VERSION 4
#define LIB_NVFBC_NAME "libnvidia-fbc.so.1"
#define LIB_CUDA_NAME  "libcuda.so.1"
#define N_FRAMES 10
 * CUDA entry points
typedef CUresult (* CUINITPROC) (unsigned int Flags);
typedef CUresult (* CUDEVICEGETPROC) (CUdevice *device, int ordinal);
typedef CUresult (* CUCTXCREATEV2PROC) (CUcontext *pctx, unsigned int flags, CUdevice dev);
typedef CUresult (* CUMEMCPYDTOHV2PROC) (void *dstHost, CUdeviceptr srcDevice, size_t ByteCount);
typedef CUresult (* CUGETDEVICEPTR) (CUdeviceptr *dptr, size_t bytesize);
static CUINITPROC cuInit_ptr = NULL;
static CUDEVICEGETPROC cuDeviceGet_ptr = NULL;
static CUCTXCREATEV2PROC cuCtxCreate_v2_ptr = NULL;
static CUMEMCPYDTOHV2PROC cuMemcpyDtoH_v2_ptr = NULL;
static CUGETDEVICEPTR cuGetDevicePtr=NULL;
typedef NVENCSTATUS (*PNVENCCREATEINSTANCE) (NV_ENCODE_API_FUNCTION_LIST* pFuncList);
 * Dynamically opens the CUDA library and resolves the symbols that are
 * needed for this application.
 * \param [out] libCUDA
 *   A pointer to the opened CUDA library.
 * \return
 *   NVFBC_TRUE in case of success, NVFBC_FALSE otherwise.
static NVFBC_BOOL cuda_load_library(void *libCUDA)
    libCUDA = dlopen(LIB_CUDA_NAME, RTLD_NOW);
    if (libCUDA == NULL) {
        fprintf(stderr, "Unable to open '%s'\n", LIB_CUDA_NAME);
        return NVFBC_FALSE;
    cuInit_ptr = (CUINITPROC) dlsym(libCUDA, "cuInit");
    if (cuInit_ptr == NULL) {
        fprintf(stderr, "Unable to resolve symbol 'cuInit'\n");
        return NVFBC_FALSE;
    cuDeviceGet_ptr = (CUDEVICEGETPROC) dlsym(libCUDA, "cuDeviceGet");
    if (cuDeviceGet_ptr == NULL) {
        fprintf(stderr, "Unable to resolve symbol 'cuDeviceGet'\n");
        return NVFBC_FALSE;
    cuCtxCreate_v2_ptr = (CUCTXCREATEV2PROC) dlsym(libCUDA, "cuCtxCreate_v2");
    if (cuCtxCreate_v2_ptr == NULL) {
        fprintf(stderr, "Unable to resolve symbol 'cuCtxCreate_v2'\n");
        return NVFBC_FALSE;
    cuMemcpyDtoH_v2_ptr = (CUMEMCPYDTOHV2PROC) dlsym(libCUDA, "cuMemcpyDtoH_v2");
    if (cuMemcpyDtoH_v2_ptr == NULL) {
        fprintf(stderr, "Unable to resolve symbol 'cuMemcpyDtoH_v2'\n");
        return NVFBC_FALSE;
    cuGetDevicePtr = (CUGETDEVICEPTR) dlsym(libCUDA,"cuMemAlloc");
    if(cuGetDevicePtr==NULL){
        fprintf(stderr, "Unable to resolve symbol 'cuMemAlloc'\n");
        return NVFBC_FALSE;
    return NVFBC_TRUE;
 * Initializes CUDA and creates a CUDA context.
 * \param [in] cuCtx
 *   A pointer to the created CUDA context.
 * \return
static NVFBC_BOOL cuda_init(CUcontext *cuCtx)
    CUresult cuRes;
    CUdevice cuDev;
    cuRes = cuInit_ptr(0);
    if (cuRes != CUDA_SUCCESS) {
        fprintf(stderr, "Unable to initialize CUDA (result: %d)\n", cuRes);
        return NVFBC_FALSE;
    cuRes = cuDeviceGet_ptr(&cuDev, 0);
        fprintf(stderr, "Unable to get CUDA device (result: %d)\n", cuRes);
        return NVFBC_FALSE;
    cuRes = cuCtxCreate_v2_ptr(cuCtx, CU_CTX_SCHED_AUTO, cuDev);
        fprintf(stderr, "Unable to create CUDA context (result: %d)\n", cuRes);
        return NVFBC_FALSE;
    return NVFBC_TRUE;
 * Prints usage information.
static void usage(const char *pname)
    printf("Usage: %s [options]\n", pname);
    printf("\n");
    printf("Options:\n");
    printf("  --help|-h         This message\n");
    printf("  --get-status|-g   Print status and exit\n");
    printf("  --track|-t <str>  Region of the screen to track.\n");
    printf("                    Can be 'default', 'screen' or '<output name>'\n");
    printf("                    as returned by --get-status\n");
    printf("  --frames|-f <n>   Number of frames to capture (default: %u)\n",
           N_FRAMES);
    printf("  --size|-s <w>x<h> Size of the captured frames\n");
    printf("                    (default: size of the framebuffer)\n");
    printf("  --format|-o <fmt> Buffer format to use.\n");
    printf("                    Can be 'rgb', 'argb', 'nv12' or 'yuv444p'\n");
    printf("                    Default: 'rgb'\n");
 * Initializes the NvFBC and CUDA libraries and creates an NvFBC instance.
 * Creates and sets up a capture session to video memory using the CUDA interop.
 * Captures a bunch of frames every second, converts them to BMP and saves them
 * to the disk.
int main(int argc, char *argv[])
    //handing the opening of the nvidia encoder library
    void* handle = dlopen("libnvidia-encode.so",RTLD_NOW);
    if(handle==NULL)
        printf("Unable to load the nvidia encoder library");
        return EXIT_FAILURE;
    PNVENCCREATEINSTANCE NvEncCreateInstance_ptr;
    NvEncCreateInstance_ptr = (PNVENCCREATEINSTANCE) dlsym(handle,"NvEncodeAPICreateInstance");
    if(NvEncCreateInstance_ptr==NULL)
        printf("Failure to load the nv encode lib");
static struct option longopts[] = {
        { "get-status", no_argument, NULL, 'g' },
        { "track", required_argument, NULL, 't' },
        { "frames", required_argument, NULL, 'f' },
        { "size", required_argument, NULL, 's' },
        { "format", required_argument, NULL, 'o' },
        { NULL, 0, NULL, 0 }
    int opt, ret;
    unsigned int i, nFrames = N_FRAMES;
    NVFBC_SIZE frameSize = { 0, 0 };
    NVFBC_BOOL printStatusOnly = NVFBC_FALSE;
    NVFBC_TRACKING_TYPE trackingType = NVFBC_TRACKING_DEFAULT;
    char outputName[NVFBC_OUTPUT_NAME_LEN];
    uint32_t outputId = 0;
    void *libNVFBC = NULL, *libCUDA = NULL;
    PNVFBCCREATEINSTANCE NvFBCCreateInstance_ptr = NULL;
    NVFBC_API_FUNCTION_LIST pFn;
    CUcontext cuCtx;
    NVFBCSTATUS fbcStatus;
    NVFBC_BOOL fbcBool;
    NVFBC_SESSION_HANDLE fbcHandle;
    NVFBC_CREATE_HANDLE_PARAMS createHandleParams;
    NVFBC_GET_STATUS_PARAMS statusParams;
    NVFBC_CREATE_CAPTURE_SESSION_PARAMS createCaptureParams;
    NVFBC_DESTROY_CAPTURE_SESSION_PARAMS destroyCaptureParams;
    NVFBC_DESTROY_HANDLE_PARAMS destroyHandleParams;
    NVFBC_TOCUDA_SETUP_PARAMS setupParams;
    NVFBC_BUFFER_FORMAT bufferFormat = NVFBC_BUFFER_FORMAT_NV12;
    char videoFile[64]="video.h264";
    FILE* fd;
     * Parse the command line.
    while ((opt = getopt_long(argc, argv, "hgt:f:s:o:", longopts, NULL)) != -1) {
        switch (opt) {
            case 'g':
                printStatusOnly = NVFBC_TRUE;
                break;
            case 't':
                NvFBCUtilsParseTrackingType(optarg, &trackingType, outputName);
                break;
            case 'f':
                nFrames = (unsigned int) atoi(optarg);
                break;
            case 's':
                ret = sscanf(optarg, "%ux%u", &frameSize.w, &frameSize.h);
                if (ret != 2) {
                    fprintf(stderr, "Invalid size format: '%s'\n", optarg);
                break;
            case 'o':
                if (!strcasecmp(optarg, "rgb")) {
                    bufferFormat = NVFBC_BUFFER_FORMAT_RGB;
                } else if (!strcasecmp(optarg, "argb")) {
                    bufferFormat = NVFBC_BUFFER_FORMAT_ARGB;
                } else if (!strcasecmp(optarg, "nv12")) {
                } else if (!strcasecmp(optarg, "yuv444p")) {
                    bufferFormat = NVFBC_BUFFER_FORMAT_YUV444P;
                } else {
                    fprintf(stderr, "Unknown buffer format: '%s'\n", optarg);
                break;
            case 'h':
            default:
                usage(argv[0]);
                return EXIT_SUCCESS;
    NvFBCUtilsPrintVersions(APP_VERSION);
     * Dynamically load the NvFBC library.
    libNVFBC = dlopen(LIB_NVFBC_NAME, RTLD_NOW);
    if (libNVFBC == NULL) {
        fprintf(stderr, "Unable to open '%s'\n", LIB_NVFBC_NAME);
    fbcBool = cuda_load_library(libCUDA);
    if (fbcBool != NVFBC_TRUE) {
    fbcBool = cuda_init(&cuCtx);
         //input output buffer the contains all the pointers to the functions for the api
    NV_ENCODE_API_FUNCTION_LIST nvencFunctionList;
    nvencFunctionList.version=NV_ENCODE_API_FUNCTION_LIST_VER;
    //this function call populates the passed pointer to the nvidia api function list with
    //the function pointers to the routines implemented by the encoder api
    NVENCSTATUS status = NvEncCreateInstance_ptr(&nvencFunctionList);//NvEncodeAPICreateInstance(&nvencFunctionList);
    //exit code if failed to create instance of the api
    if(status!=NV_ENC_SUCCESS)
        printf("The nvidia encoder could not be initialized");
        EXIT_FAILURE;
    //creating the encode session params
    NV_ENC_OPEN_ENCODE_SESSION_EX_PARAMS openSessionExParams;
    //initializing them and then adding the values
    // memset(&openSessionExParams,0,sizeof(openSessionExParams));
    //setting the version
    openSessionExParams.version = NV_ENC_OPEN_ENCODE_SESSION_EX_PARAMS_VER;
    openSessionExParams.deviceType = NV_ENC_DEVICE_TYPE_CUDA;
    //Note -  Maybe change the next line
    //ading the device pointer which in this case will be a cuda context
    openSessionExParams.device = (void*)cuCtx;
    openSessionExParams.reserved = NULL;
    openSessionExParams.apiVersion = NVENCAPI_VERSION;
    //setting all values of the reserved 1 array to 0
    //Note - check the next two lines
    memset(openSessionExParams.reserved1,0,253*sizeof(uint32_t));//sizeof(openSessionExParams.reserved1)/sizeof(openSessionExParams.reserved1[0]));
    memset(openSessionExParams.reserved2,NULL,64*sizeof(void*));//sizeof(openSessionExParams.reserved2)/sizeof(openSessionExParams.reserved2[0]));
    //handle for the encoder
    void* encoder;
    //Note- Seg fault
    status = nvencFunctionList.nvEncOpenEncodeSessionEx(&openSessionExParams,&encoder);
    //NvEncOpenEncodeSessionEx(&openSessionExParams,encoder);
        printf("Failure opening encoding session: %u\n",status);
    //getting the count of the available encoder settings
    uint32_t guidCount;
    status =nvencFunctionList.nvEncGetEncodeGUIDCount(encoder,&guidCount);
        printf("Failure getting GUID count");
    //allocating a buffer that holds that count
    GUID* GUIDs = malloc(guidCount*sizeof(GUID));
    //number of supported guid
    uint32_t supportedGUID;
    //adding all the guids to the previously allocated buffer
    status =nvencFunctionList.nvEncGetEncodeGUIDs(encoder,GUIDs,guidCount,&supportedGUID);
        printf("Failure filling the guid buffer");
    //setting the encode guid
    GUID encodeGuid = NV_ENC_CODEC_H264_GUID;
    //settin up the presets
    uint32_t encodePresetCount;
    status =nvencFunctionList.nvEncGetEncodePresetCount(encoder,encodeGuid,&encodePresetCount);
        printf("Failure getting the encoder preset count");
    //allocating a buffer to hold the suppoting preset guid
    GUID *presetGUIDs = malloc(encodePresetCount*sizeof(GUID));
    uint32_t supportedPresetGUIDs;
status =nvencFunctionList.nvEncGetEncodePresetGUIDs(encoder,encodeGuid,presetGUIDs,encodePresetCount,&supportedPresetGUIDs);
        printf("Failure filling up the preset buffer");
    //getting a preset guid Note - check this line later
    GUID presetGuid = NV_ENC_PRESET_LOW_LATENCY_HQ_GUID;
    //setting up a preset congif Note - check this
    NV_ENC_PRESET_CONFIG encPresetConfig;
    encPresetConfig.version = NV_ENC_PRESET_CONFIG_VER;
    encPresetConfig.presetCfg.version=NV_ENC_CONFIG_VER;
    status =  nvencFunctionList.nvEncGetEncodePresetConfig(encoder,encodeGuid,presetGuid,&encPresetConfig);
   /* encPresetConfig.presetCfg.rcParams.averageBitRate = 5 * 1024 * 1024;
    encPresetConfig.presetCfg.rcParams.maxBitRate = 8 * 1024 * 1024;
    encPresetConfig.presetCfg.rcParams.vbvBufferSize = 87382;  single frame
        printf("Error getting the preset configuration");
    //getting the input format which is YUV for our solution
    //retrieving the input formats
    uint32_t inputFormatCount;
    status = nvencFunctionList.nvEncGetInputFormatCount(encoder,encodeGuid,&inputFormatCount);
        printf("Error getting the input buffer format count");
    //allocating a buffer for the input formats
    NV_ENC_BUFFER_FORMAT* encodeBufferFormats = malloc(inputFormatCount*sizeof(encodeBufferFormats));
    //holding the size of the supported formats
    uint32_t supportedInputFormats;
    //filling up the above buffer
    status = nvencFunctionList.nvEncGetInputFormats(encoder,encodeGuid, encodeBufferFormats,inputFormatCount,&supportedInputFormats);
        printf("Error getting the supported input formats");
    //selecting a buffer format
    //NV_ENC_BUFFER_FORMAT bufferFormat = NV_ENC_BUFFER_FORMAT_IYUV;
    //querying the underlying hardware encoder capabilities can be done using the API
    //initializing the hardware encoder
    NV_ENC_INITIALIZE_PARAMS initializationParams;
/* NV_ENC_PRESET_CONFIG presetConfig;
    presetConfig.version = NV_ENC_PRESET_CONFIG_VER;
NV_ENC_CONFIG encoderConfig;
    encoderConfig.version = NV_ENC_CONFIG_VER;
    encoderConfig.profileGUID=NV_ENC_CODEC_PROFILE_AUTOSELECT_GUID;
presetConfig.presetCfg=encoderConfig;
    status = nvencFunctionList.nvEncGetEncodePresetConfig(encoder,encodeGuid,presetGuid,&presetConfig);*/
        printf("\nUnable to get preset config %u",status);
//initializing the encoder params
    initializationParams.version = NV_ENC_INITIALIZE_PARAMS_VER;
    initializationParams.encodeConfig = &encPresetConfig.presetCfg;
    initializationParams.encodeGUID = encodeGuid;
    initializationParams.presetGUID=presetGuid;
    initializationParams.encodeWidth = 600;
    initializationParams.encodeHeight = 600;
    initializationParams.frameRateNum = 60;
    initializationParams.frameRateDen = 1;
    initializationParams.enablePTD=1;
    initializationParams.reservedBitFields=0;
    initializationParams.privDataSize=0;
    initializationParams.privData=NULL;
    initializationParams.encodeConfig= NULL;
    memset(initializationParams.reserved,0,289*sizeof(uint32_t));
    memset(initializationParams.reserved2,NULL,64*sizeof(void*));
    initializationParams.enableEncodeAsync =0;
    initializationParams.enableOutputInVidmem=0;
    status = nvencFunctionList.nvEncInitializeEncoder(encoder,&initializationParams);
        printf("Error initializing encoder, %u",status);
    //allocating the nvidia input output buffers
    int num_macroblocks = ((600 + 15) / 16) * ((600 + 15) / 16);
    int max_surfaces = (num_macroblocks >= 8160) ? 16 : 32;
    NV_ENC_INPUT_PTR* inputBuffers = (NV_ENC_INPUT_PTR*) malloc(max_surfaces * sizeof(NV_ENC_INPUT_PTR));
    NV_ENC_OUTPUT_PTR* outputBuffers = (NV_ENC_OUTPUT_PTR*) malloc(max_surfaces * sizeof(NV_ENC_OUTPUT_PTR));
    //CUdeviceptr* cudaDevicePtrs = (CUdeviceptr*) malloc(max_surfaces*sizeof(CUdeviceptr));
for(int i=0;i<max_surfaces;i++)
    //creating the input buffer
        NV_ENC_CREATE_INPUT_BUFFER inputBufferParams;
        inputBufferParams.version = NV_ENC_CREATE_INPUT_BUFFER_VER;
        inputBufferParams.width =(600 + 31) & ~31;
        inputBufferParams.height=(600 + 31) & ~31;
        inputBufferParams.bufferFmt = NV_ENC_BUFFER_FORMAT_IYUV;
        inputBufferParams.reserved=0;
        memset(inputBufferParams.reserved1,0,57*sizeof(uint32_t));
        memset(inputBufferParams.reserved2,NULL,63*sizeof(void*));
        status = nvencFunctionList.nvEncCreateInputBuffer(encoder,&inputBufferParams);
            printf("Input buffer could not be created");
        //creating the output buffer
        NV_ENC_CREATE_BITSTREAM_BUFFER bitstreamBufferParams;
        bitstreamBufferParams.version = NV_ENC_CREATE_BITSTREAM_BUFFER_VER;
         bitstreamBufferParams.reserved=0;
        memset(bitstreamBufferParams.reserved1,0,58*sizeof(uint32_t));
        memset(bitstreamBufferParams.reserved2,NULL,64*sizeof(void*));
//This line is giving me the error, NV_ENC_ERR_UNIMPLEMENTED
        status = nvencFunctionList.nvEncCreateBitstreamBuffer(encoder,&bitstreamBufferParams);
            printf("Bitstream could not be created %i",status);
        /* CUresult cuResult = cuGetDevicePtr(&cudaDevicePtrs[i],600);
        if(cuResult!=CUDA_SUCCESS)
            printf("Could not allocate cuda device pointer, %u\n",cuResult);
        inputBuffers[i]=inputBufferParams.inputBuffer;
        outputBuffers[i]=bitstreamBufferParams.bitstreamBuffer;
     * Resolve the 'NvFBCCreateInstance' symbol that will allow us to get
     * the API function pointers.
        (PNVFBCCREATEINSTANCE) dlsym(libNVFBC, "NvFBCCreateInstance");
    if (NvFBCCreateInstance_ptr == NULL) {
        fprintf(stderr, "Unable to resolve symbol 'NvFBCCreateInstance'\n");
     * Create an NvFBC instance.
     * API function pointers are accessible through pFn.
    memset(&pFn, 0, sizeof(pFn));
    pFn.dwVersion = NVFBC_VERSION;
    fbcStatus = NvFBCCreateInstance_ptr(&pFn);
    if (fbcStatus != NVFBC_SUCCESS) {
        fprintf(stderr, "Unable to create NvFBC instance (status: %d)\n",
                fbcStatus);
     * Create a session handle that is used to identify the client.
    memset(&createHandleParams, 0, sizeof(createHandleParams));
    createHandleParams.dwVersion = NVFBC_CREATE_HANDLE_PARAMS_VER;
    fbcStatus = pFn.nvFBCCreateHandle(&fbcHandle, &createHandleParams);
        fprintf(stderr, "%s\n", pFn.nvFBCGetLastErrorStr(fbcHandle));
     * Get information about the state of the display driver.
     * This call is optional but helps the application decide what it should
     * do.
    memset(&statusParams, 0, sizeof(statusParams));
    statusParams.dwVersion = NVFBC_GET_STATUS_PARAMS_VER;
    fbcStatus = pFn.nvFBCGetStatus(fbcHandle, &statusParams);
    if (printStatusOnly) {
        NvFBCUtilsPrintStatus(&statusParams);
    if (statusParams.bCanCreateNow == NVFBC_FALSE) {
        fprintf(stderr, "It is not possible to create a capture session "
                        "on this system.\n");
    if (trackingType == NVFBC_TRACKING_OUTPUT) {
        if (!statusParams.bXRandRAvailable) {
            fprintf(stderr, "The XRandR extension is not available.\n");
            fprintf(stderr, "It is therefore not possible to track an RandR output.\n");
        outputId = NvFBCUtilsGetOutputId(statusParams.outputs,
                                         statusParams.dwOutputNum,
                                         outputName);
        if (outputId == 0) {
            fprintf(stderr, "RandR output '%s' not found.\n", outputName);
     * Create a capture session.
    printf("Creating an asynchronous capture session of %u frames with 1 "
           "second internal between captures.\n", nFrames);
    memset(&createCaptureParams, 0, sizeof(createCaptureParams));
    createCaptureParams.dwVersion     = NVFBC_CREATE_CAPTURE_SESSION_PARAMS_VER;
    createCaptureParams.eCaptureType  = NVFBC_CAPTURE_SHARED_CUDA;
    createCaptureParams.bWithCursor   = NVFBC_TRUE;
    createCaptureParams.frameSize     = frameSize;
    createCaptureParams.eTrackingType = trackingType;
        createCaptureParams.dwOutputId = outputId;
    fbcStatus = pFn.nvFBCCreateCaptureSession(fbcHandle, &createCaptureParams);
     * Set up the capture session.
    memset(&setupParams, 0, sizeof(setupParams));
    setupParams.dwVersion     = NVFBC_TOCUDA_SETUP_PARAMS_VER;
    setupParams.eBufferFormat = bufferFormat;
    fbcStatus = pFn.nvFBCToCudaSetUp(fbcHandle, &setupParams);
     * We are now ready to start grabbing frames.
    fd = fopen(videoFile, "wb");
    if (fd == NULL)
        fprintf(stderr,"Unable to create '%s'\n", videoFile);
//configuring the per frame encode parameters
    NV_ENC_PIC_PARAMS encoderPicParams;
    //Codec specific params
    /* NV_ENC_CODEC_PIC_PARAMS h264Params;
    h264Params.h264PicParams.reserved3=0;
    h264Params.h264PicParams.reservedBitFields=0;
    h264Params.h264PicParams.ltrUsageMode=0;
    memset(h264Params.h264PicParams.reserved,0,242*sizeof(uint32_t));
    memset(h264Params.h264PicParams.reserved2,NULL,61*sizeof(void*));*/
    encoderPicParams.version = NV_ENC_PIC_PARAMS_VER;
    //encoderPicParams.codecPicParams=h264Params;
    encoderPicParams.inputWidth=(600+ 31) & ~31;
    encoderPicParams.inputHeight=(600+ 31) & ~31;
    encoderPicParams.inputPitch = (600+ 31) & ~31;
    //encoderPicParams.encodePicFlags=NV_ENC_PIC_FLAG_FORCEIDR;
    //encoderPicParams.bufferFmt=NV_ENC_BUFFER_FORMAT_IYUV;
    encoderPicParams.pictureStruct=NV_ENC_PIC_STRUCT_FRAME;
    for (i = 0; i < 60; i++) {
        static CUdeviceptr cuDevicePtr;
        static unsigned char *frame = NULL;
        static uint32_t lastByteSize = 0;
        //char filename[64];
        int index=i;
        if(i>=max_surfaces)
            index=i%max_surfaces;
        int res;
        uint64_t t1, t2, t1_total, t2_total, t_delta, wait_time_ms;
        CUresult cuRes;
        NVFBC_TOCUDA_GRAB_FRAME_PARAMS grabParams;
        NVFBC_FRAME_GRAB_INFO frameInfo;
        t1 = NvFBCUtilsGetTimeInMillis();
        t1_total = t1;
        memset(&grabParams, 0, sizeof(grabParams));
        memset(&frameInfo, 0, sizeof(frameInfo));
        grabParams.dwVersion = NVFBC_TOCUDA_GRAB_FRAME_PARAMS_VER;
         * Use asynchronous calls.
         * The application will not wait for a new frame to be ready.  It will
         * capture a frame that is already available.  This might result in
         * capturing several times the same frame.  This can be detected by
         * checking the frameInfo.bIsNewFrame structure member.
        grabParams.dwFlags = NVFBC_TOCUDA_GRAB_FLAGS_NOWAIT;
         * This structure will contain information about the captured frame.
        grabParams.pFrameGrabInfo = &frameInfo;
         * The frame will be mapped in video memory through this CUDA
         * device pointer.
        grabParams.pCUDADeviceBuffer = &cuDevicePtr;
         * Capture a frame.
        fbcStatus = pFn.nvFBCToCudaGrabFrame(fbcHandle, &grabParams);
t2 = NvFBCUtilsGetTimeInMillis();
         * Allocate or re-allocate the destination buffer in system memory
         * when necessary.
         * This is to handle change of resolution.
        if (lastByteSize < frameInfo.dwByteSize) {
            frame = (unsigned char *)realloc(frame, frameInfo.dwByteSize);
            if (frame == NULL) {
                fprintf(stderr, "Unable to allocate system memory\n");
            printf("Reallocated %u KB of system memory\n",
                   frameInfo.dwByteSize / 1024);
            lastByteSize = frameInfo.dwByteSize;
        printf("%s id %u grabbed in %llu ms",
               (frameInfo.bIsNewFrame ? "New frame" : "Frame"),
               frameInfo.dwCurrentFrame,
               (unsigned long long) (t2 - t1));
         * Download frame from video memory to system memory.
        cuRes = cuMemcpyDtoH_v2_ptr((void *) frame, cuDevicePtr,
            fprintf(stderr, "CUDA memcpy failure (result: %d)\n", cuRes);
        //creating the params for the nv enc lock input buffer
        //inputBufferParams.pSysMemBuffer=(void*) frame;
        //status = nvencFunctionList.nvEncCreateInputBuffer(encoder,&inputBufferParams);
        //setting up the input params
        NV_ENC_REGISTER_RESOURCE registerResource;
        registerResource.version=NV_ENC_REGISTER_RESOURCE_VER;
        registerResource.resourceType = NV_ENC_INPUT_RESOURCE_TYPE_CUDADEVICEPTR;
        registerResource.width = (600+31)&~31;
        registerResource.height=(600+31)&~31;
        registerResource.pitch=(600+31)&~31;
        registerResource.resourceToRegister = (void*)cuDevicePtr;
        registerResource.bufferFormat = NV_ENC_BUFFER_FORMAT_NV12;
        status = nvencFunctionList.nvEncRegisterResource(encoder,&registerResource);
            printf("Failed to register resource, %u",status);
        //mapping these resources
        NV_ENC_MAP_INPUT_RESOURCE mappedResource;
        mappedResource.version = NV_ENC_MAP_INPUT_RESOURCE_VER;
        mappedResource.registeredResource=registerResource.registeredResource;
        status = nvencFunctionList.nvEncMapInputResource(encoder,&mappedResource);
            printf("Could not map resource: %u,",status);
/* NV_ENC_LOCK_INPUT_BUFFER lockInputParams;
        lockInputParams.version = NV_ENC_LOCK_INPUT_BUFFER_VER;
        lockInputParams.doNotWait=0;
        lockInputParams.reservedBitFields=0;
        //lockInputParams.inputBuffer=inputBufferParams.inputBuffer;
        lockInputParams.inputBuffer=inputBuffers[0];
        memset(lockInputParams.reserved1,0,251*sizeof(uint32_t));
        memset(lockInputParams.reserved2,NULL,64*sizeof(void*));
        status = nvencFunctionList.nvEncLockInputBuffer(encoder,&lockInputParams);
        lockInputParams.bufferDataPtr = (void*)frame;
            printf("Failed to lock input buffer: %u",status);
        status = nvencFunctionList.nvEncUnlockInputBuffer(encoder,inputBuffers[0]);
            printf("Input buffer could not be unlocked");
        encoderPicParams.outputBitstream=outputBuffers[index];
        encoderPicParams.inputBuffer=mappedResource.mappedResource;
        encoderPicParams.bufferFmt=mappedResource.mappedBufferFmt;
        memset(encoderPicParams.reserved1,0,6*sizeof(uint32_t));
        memset(encoderPicParams.reserved2,NULL,2*sizeof(void*));
        memset(encoderPicParams.reserved3,0,286*sizeof(uint32_t));
        memset(encoderPicParams.reserved4,0,60*sizeof(void*));
        //sending the picture to be encoded
        status=nvencFunctionList.nvEncEncodePicture(encoder,&encoderPicParams);
            printf("\n Unable to encode video, Error code: %u",status);
//setting up the lock bitstream params
        //sending the data to the output stream
        NV_ENC_LOCK_BITSTREAM lockBitstreamParams;
        lockBitstreamParams.version=NV_ENC_LOCK_BITSTREAM_VER;
        lockBitstreamParams.doNotWait=0;
        lockBitstreamParams.outputBitstream=outputBuffers[index];
        lockBitstreamParams.reservedBitFields=0;
        memset(lockBitstreamParams.reserved,0,219*sizeof(uint32_t));
        memset(lockBitstreamParams.reserved1,0,13*sizeof(uint32_t));
        memset(lockBitstreamParams.reserved2,NULL,64*sizeof(uint32_t));
        status = nvencFunctionList.nvEncLockBitstream(encoder,&lockBitstreamParams);
            printf("error locking bitstream");
//writing the video data to the file
        int bytes = fwrite(lockBitstreamParams.bitstreamBufferPtr,1,lockBitstreamParams.bitstreamSizeInBytes ,fd);
printf("\nNumber of bytes: %u\n",bytes);
        if(bytes==0)
            fprintf(stderr, "Unable to write to '%s'\n", videoFile);
        status = nvencFunctionList.nvEncUnlockBitstream(encoder,outputBuffers[index]);
status = nvencFunctionList.nvEncUnmapInputResource(encoder,mappedResource.mappedResource);
            printf("failure to map resource, %u",status);
        //printf(", downloaded in %llu ms", (unsigned long long) (t2 - t1));
         * Convert RGB frame to BMP and save it on the disk.
         * This operation can be quite slow.
        /* t1 = NvFBCUtilsGetTimeInMillis();
        sprintf(filename, "frame%u.bmp", frameInfo.dwCurrentFrame);
        res = NvFBCUtilsSaveFrame(bufferFormat, filename, frame,
                                  frameInfo.dwWidth, frameInfo.dwHeight);
        if (res > 0) {
            fprintf(stderr, "Unable to save frame\n");
        t2_total = t2;*/
        /* printf(", saved in %llu ms", (unsigned long long) (t2 - t1));
         * Compute how much time to sleep before capturing the next frame.
        t_delta = t2_total - t1_total;
        wait_time_ms = t_delta < 1000 ? 1000 - t_delta : 0;
        printf(", now sleeping for %llu ms\n",
               (unsigned long long) wait_time_ms);
        usleep(wait_time_ms * 1000);*/
     * Destroy capture session, tear down resources.
    memset(&destroyCaptureParams, 0, sizeof(destroyCaptureParams));
    destroyCaptureParams.dwVersion = NVFBC_DESTROY_CAPTURE_SESSION_PARAMS_VER;
    fbcStatus = pFn.nvFBCDestroyCaptureSession(fbcHandle, &destroyCaptureParams);
     * Destroy session handle, tear down more resources.
    memset(&destroyHandleParams, 0, sizeof(destroyHandleParams));
    destroyHandleParams.dwVersion = NVFBC_DESTROY_HANDLE_PARAMS_VER;
    fbcStatus = pFn.nvFBCDestroyHandle(fbcHandle, &destroyHandleParams);
         //nvencFunctionList.nvEncUnlockInputBuffer(encoder,inputBuffers[i]);
        //nvencFunctionList.nvEncDestroyInputBuffer(encoder,inputBuffers[i]);
        nvencFunctionList.nvEncUnlockBitstream(encoder,outputBuffers[i]);
        nvencFunctionList.nvEncDestroyBitstreamBuffer(encoder,outputBuffers[i]);
    nvencFunctionList.nvEncDestroyEncoder(encoder);
    fclose(fd);
    free(GUIDs);
    free(presetGUIDs);
    free(encodeBufferFormats);
    free(inputBuffers);
    free(outputBuffers);
    //free(cudaDevicePtrs);
Bumping this, I’m dealing with an identical issue by doing the same as OP.
My code: nvfbc-rs/main.rs at master · gitautas/nvfbc-rs · GitHub
