I’m using Video_Codec_SDK_11.0.10 for hevc encoding
when app starts it always crashes at nvEncGetEncodePresetConfig lib func, context info as follows:
code: in CreateDefaultEncoderParams func:
NV_ENC_PRESET_CONFIG presetConfig = { NV_ENC_PRESET_CONFIG_VER, { NV_ENC_CONFIG_VER } };
LOG(INFO) << "nvEncGetEncodePresetConfig 1 " << m_hEncoder << " " << presetConfig.version << " " << presetConfig.presetCfg.version;
m_nvenc.nvEncGetEncodePresetConfig(m_hEncoder, codecGuid, presetGuid, &presetConfig);
LOG(INFO) << "nvEncGetEncodePresetConfig 2 " << m_hEncoder << " " << presetConfig.version << " " << presetConfig.presetCfg.version;
memcpy(pIntializeParams->encodeConfig, &presetConfig.presetCfg, sizeof(NV_ENC_CONFIG));
it crashes at nvEncGetEncodePresetConfig
the stack info is as follows:
#0 0x00007f6f8aa93438 in __GI_raise (sig=sig@entry=6) at …/sysdeps/unix/sysv/linux/raise.c:54
54 …/sysdeps/unix/sysv/linux/raise.c: No such file or directory.
[Current thread is 1 (Thread 0x7f6f1a7fc700 (LWP 44171))]
(gdb)
(gdb)
(gdb) bt
#1 0x00007f6f8aa9503a in __GI_abort () at abort.c:89
#2 0x00007f6f8f464897 in corelib::SignalHandler (signum=11, siginfo=0x7f6f1a7f8930, ucontext=0x7f6f1a7f8800) at corelib/src/signals.cc:234
#3
#4 0x00007f6f8cb0f995 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1
#5 0x00007f6f8cb1c7b2 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1
#6 0x00007f6f8f4925ac in NvEncoder::CreateDefaultEncoderParams (this=0x7f6e80217110, pIntializeParams=0x564e64a439b0, codecGuid=…, presetGuid=…, tuningInfo=NV_ENC_TUNING_INFO_ULTRA_LOW_LATENCY)
at s_loop/src/remote_interface/camera_pusher/nvcodec/NvEncoder.cpp:128
#7 0x0000564e62b7a19f in remote_interface::camera_pusher::CameraStreamPusher::InitNvEncoder (this=0x564e64a439a0, width=1200, height=1200) at s_loop/src/remote_interface/camera_pusher/main.cc:316
#8 0x0000564e62b6620b in remote_interface::camera_pusher::CameraStreamPusher::EncoderThread (this=0x564e64a439a0) at s_loop/src/remote_interface/camera_pusher/main.cc:453
#9 0x00007f6f8b111b30 in ?? () from /home/jingchi/car_data/weride_adv/781f69989b2ca44b93915e583a66d794b9530cf9/driving/lib/libstdc++.so.6
#10 0x00007f6f8da196ba in start_thread (arg=0x7f6f1a7fc700) at pthread_create.c:333
#11 0x00007f6f8ab654dd in clone () at …/sysdeps/unix/sysv/linux/x86_64/clone.S:109
(gdb) f 6
128 s_loop/src/remote_interface/camera_pusher/nvcodec/NvEncoder.cpp: No such file or directory.
(gdb) info locals
presetConfig = {version = 4026793995, presetCfg = {version = 4026990603, profileGUID = {Data1 = 0, Data2 = 0, Data3 = 0, Data4 = “\000\000\000\000\000\000\000”}, gopLength = 0, frameIntervalP = 0,
monoChromeEncoding = 0, frameFieldMode = 0, mvPrecision = NV_ENC_MV_PRECISION_DEFAULT, rcParams = {version = 0, rateControlMode = NV_ENC_PARAMS_RC_CONSTQP, constQP = {qpInterP = 0, qpInterB = 0,
qpIntra = 0}, averageBitRate = 0, maxBitRate = 0, vbvBufferSize = 0, vbvInitialDelay = 0, enableMinQP = 0, enableMaxQP = 0, enableInitialRCQP = 0, enableAQ = 0, reservedBitField1 = 0,
enableLookahead = 0, disableIadapt = 0, disableBadapt = 0, enableTemporalAQ = 0, zeroReorderDelay = 0, enableNonRefP = 0, strictGOPTarget = 0, aqStrength = 0, reservedBitFields = 0, minQP = {
qpInterP = 0, qpInterB = 0, qpIntra = 0}, maxQP = {qpInterP = 0, qpInterB = 0, qpIntra = 0}, initialRCQP = {qpInterP = 0, qpInterB = 0, qpIntra = 0}, temporallayerIdxMask = 0,
temporalLayerQP = “\000\000\000\000\000\000\000”, targetQuality = 0 ‘\000’, targetQualityLSB = 0 ‘\000’, lookaheadDepth = 0, lowDelayKeyFrameScale = 0 ‘\000’, reserved1 = “\000\000”,
qpMapMode = NV_ENC_QP_MAP_DISABLED, multiPass = NV_ENC_MULTI_PASS_DISABLED, alphaLayerBitrateRatio = 0, reserved = {0, 0, 0, 0, 0}}, encodeCodecConfig = {h264Config = {enableTemporalSVC = 0,
enableStereoMVC = 0, hierarchicalPFrames = 0, hierarchicalBFrames = 0, outputBufferingPeriodSEI = 0, outputPictureTimingSEI = 0, outputAUD = 0, disableSPSPPS = 0, outputFramePackingSEI = 0,
outputRecoveryPointSEI = 0, enableIntraRefresh = 0, enableConstrainedEncoding = 0, repeatSPSPPS = 0, enableVFR = 0, enableLTR = 0, qpPrimeYZeroTransformBypassFlag = 0, useConstrainedIntraPred = 0,
enableFillerDataInsertion = 0, disableSVCPrefixNalu = 0, enableScalabilityInfoSEI = 0, reservedBitFields = 0, level = 0, idrPeriod = 0, separateColourPlaneFlag = 0, disableDeblockingFilterIDC = 0,
numTemporalLayers = 0, spsId = 0, ppsId = 0, adaptiveTransformMode = NV_ENC_H264_ADAPTIVE_TRANSFORM_AUTOSELECT, fmoMode = NV_ENC_H264_FMO_AUTOSELECT,
bdirectMode = NV_ENC_H264_BDIRECT_MODE_AUTOSELECT, entropyCodingMode = NV_ENC_H264_ENTROPY_CODING_MODE_AUTOSELECT, stereoMode = NV_ENC_STEREO_PACKING_MODE_NONE, intraRefreshPeriod = 0,
intraRefreshCnt = 0, maxNumRefFrames = 0, sliceMode = 0, sliceModeData = 0, h264VUIParameters = {overscanInfoPresentFlag = 0, overscanInfo = 0, videoSignalTypePresentFlag = 0, videoFormat = 0,
videoFullRangeFlag = 0, colourDescriptionPresentFlag = 0, colourPrimaries = 0, transferCharacteristics = 0, colourMatrix = 0, chromaSampleLocationFlag = 0, chromaSampleLocationTop = 0,
chromaSampleLocationBot = 0, bitstreamRestrictionFlag = 0, reserved = {0 <repeats 15 times>}}, ltrNumFrames = 0, ltrTrustMode = 0, chromaFormatIDC = 0, maxTemporalLayers = 0,
useBFramesAsRef = NV_ENC_BFRAME_REF_MODE_DISABLED, numRefL0 = NV_ENC_NUM_REF_FRAMES_AUTOSELECT, numRefL1 = NV_ENC_NUM_REF_FRAMES_AUTOSELECT, reserved1 = {0 <repeats 267 times>}, reserved2 = {
0x0 <repeats 64 times>}}, hevcConfig = {level = 0, tier = 0, minCUSize = NV_ENC_HEVC_CUSIZE_AUTOSELECT, maxCUSize = NV_ENC_HEVC_CUSIZE_AUTOSELECT, useConstrainedIntraPred = 0,
disableDeblockAcrossSliceBoundary = 0, outputBufferingPeriodSEI = 0, outputPictureTimingSEI = 0, outputAUD = 0, enableLTR = 0, disableSPSPPS = 0, repeatSPSPPS = 0, enableIntraRefresh = 0,
chromaFormatIDC = 0, pixelBitDepthMinus8 = 0, enableFillerDataInsertion = 0, enableConstrainedEncoding = 0, enableAlphaLayerEncoding = 0, reserved = 0, idrPeriod = 0, intraRefreshPeriod = 0,
intraRefreshCnt = 0, maxNumRefFramesInDPB = 0, ltrNumFrames = 0, vpsId = 0, spsId = 0, ppsId = 0, sliceMode = 0, sliceModeData = 0, maxTemporalLayersMinus1 = 0, hevcVUIParameters = {
overscanInfoPresentFlag = 0, overscanInfo = 0, videoSignalTypePresentFlag = 0, videoFormat = 0, videoFullRangeFlag = 0, colourDescriptionPresentFlag = 0, colourPrimaries = 0,
transferCharacteristics = 0, colourMatrix = 0, chromaSampleLocationFlag = 0, chromaSampleLocationTop = 0, chromaSampleLocationBot = 0, bitstreamRestrictionFlag = 0, reserved = {
0 <repeats 15 times>}}, ltrTrustMode = 0, useBFramesAsRef = NV_ENC_BFRAME_REF_MODE_DISABLED, numRefL0 = NV_ENC_NUM_REF_FRAMES_AUTOSELECT, numRefL1 = NV_ENC_NUM_REF_FRAMES_AUTOSELECT,
reserved1 = {0 <repeats 214 times>}, reserved2 = {0x0 <repeats 64 times>}}, h264MeOnlyConfig = {disablePartition16x16 = 0, disablePartition8x16 = 0, disablePartition16x8 = 0,
disablePartition8x8 = 0, disableIntraSearch = 0, bStereoEnable = 0, reserved = 0, reserved1 = {0 <repeats 255 times>}, reserved2 = {0x0 <repeats 64 times>}}, hevcMeOnlyConfig = {reserved = {
0 <repeats 256 times>}, reserved1 = {0x0 <repeats 64 times>}}, reserved = {0 <repeats 320 times>}}, reserved = {0 <repeats 278 times>}, reserved2 = {0x0 <repeats 64 times>}}, reserved1 = {
nv_mutex = {std::__mutex_base = {_M_mutex = {__data = {__lock = 2, __count = 0, __owner = 44171, __nusers = 1, __kind = 0, __spins = 0, __elision = 0, __list = {__prev = 0x0, __next = 0x0}},
__size = “\002\000\000\000\000\000\000\000\213\254\000\000\001”, ‘\000’ <repeats 26 times>, __align = 2}}, }
pEncodeConfig =
(gdb)
system info:
ubuntu 16.04 nvidia driver: libnvidia-encode.so.460.32.03
2 GPUs: GeForce RTX 2080 TI
can anyone help me out?
