OK I think I found some kind of answer: The GTX 960 supports encoding at up to 4096x4096. Sadly, the NVEncoder sample doesn’t check the device capabilities, and it appears that the driver doesn’t validate its inputs properly either.
Here’s a snippet to print the device capabilities - call this after m_pNvHWEncoder->Initialize:
void PrintCapabilities(CNvHWEncoder * pNvHWEncoder)
if (!pNvHWEncoder) return;
unsigned int encodeGUIDCount = 0;
NVENCSTATUS nvStatus = pNvHWEncoder->NvEncGetEncodeGUIDCount(&encodeGUIDCount);
if (nvStatus != NV_ENC_SUCCESS) {
printf("Failed to get count of encode GUIDs. Status=%d\n", nvStatus);
return;
GUID * encodeGUIDArray = new GUID[encodeGUIDCount];
memset(encodeGUIDArray, 0, sizeof(GUID)* encodeGUIDCount);
unsigned int encodeGUIDArraySize = 0;
nvStatus = pNvHWEncoder->NvEncGetEncodeGUIDs(encodeGUIDArray, encodeGUIDCount, &encodeGUIDArraySize);
printf("Failed to get encode GUIDs. Status=%d\n", nvStatus);
delete[] encodeGUIDArray;
return;
assert(encodeGUIDArraySize <= encodeGUIDCount);
for (size_t i=0; i<encodeGUIDCount; i++) {
wchar_t strGuid[_MAX_PATH];
StringFromGUID2(encodeGUIDArray[i], &strGuid[0], sizeof(strGuid));
printf("Capabilities for GUID %u: %S\n", i, strGuid);
struct CapabilityDescription
NV_ENC_CAPS capability;
char const * name;
static CapabilityDescription allCapabilities[] =
NV_ENC_CAPS_NUM_MAX_BFRAMES, "Maximum number of B-Frames supported",
NV_ENC_CAPS_SUPPORTED_RATECONTROL_MODES, "Rate control modes supported",
NV_ENC_CAPS_SUPPORT_FIELD_ENCODING, "HW support for field mode encoding",
NV_ENC_CAPS_SUPPORT_MONOCHROME, "HW support for monochrome mode encoding",
NV_ENC_CAPS_SUPPORT_FMO, "HW support for FMO",
NV_ENC_CAPS_SUPPORT_QPELMV, "HW capability for Quarter pel motion estimation",
NV_ENC_CAPS_SUPPORT_BDIRECT_MODE, "H.264 specific. HW support for BDirect modes",
NV_ENC_CAPS_SUPPORT_CABAC, "H264 specific. HW support for CABAC entropy coding mode",
NV_ENC_CAPS_SUPPORT_ADAPTIVE_TRANSFORM, "HW support for Adaptive Transform",
NV_ENC_CAPS_SUPPORT_RESERVED, "Reserved enum field",
NV_ENC_CAPS_NUM_MAX_TEMPORAL_LAYERS, "HW support for encoding Temporal layers",
NV_ENC_CAPS_SUPPORT_HIERARCHICAL_PFRAMES, "HW support for Hierarchical P frames",
NV_ENC_CAPS_SUPPORT_HIERARCHICAL_BFRAMES, "HW support for Hierarchical B frames",
NV_ENC_CAPS_LEVEL_MAX, "Maximum Encoding level supported ",
NV_ENC_CAPS_LEVEL_MIN, "Minimum Encoding level supported",
NV_ENC_CAPS_SEPARATE_COLOUR_PLANE, "HW support for separate colour plane encoding",
NV_ENC_CAPS_WIDTH_MAX, "Maximum output width supported",
NV_ENC_CAPS_HEIGHT_MAX, "Maximum output height supported",
NV_ENC_CAPS_SUPPORT_TEMPORAL_SVC, "Temporal Scalability Support",
NV_ENC_CAPS_SUPPORT_DYN_RES_CHANGE, "Dynamic Encode Resolution Change Support",
NV_ENC_CAPS_SUPPORT_DYN_BITRATE_CHANGE, "Dynamic Encode Bitrate Change Support",
NV_ENC_CAPS_SUPPORT_DYN_FORCE_CONSTQP, "Forcing Constant QP On The Fly Support",
NV_ENC_CAPS_SUPPORT_DYN_RCMODE_CHANGE, "Dynamic rate control mode Change Support. ",
NV_ENC_CAPS_SUPPORT_SUBFRAME_READBACK, "Subframe readback support for slice-based encoding",
NV_ENC_CAPS_SUPPORT_CONSTRAINED_ENCODING, "Constrained Encoding mode support",
NV_ENC_CAPS_SUPPORT_INTRA_REFRESH, "Intra Refresh Mode Support",
NV_ENC_CAPS_SUPPORT_CUSTOM_VBV_BUF_SIZE, "Custom VBV Buffer Size support",
NV_ENC_CAPS_SUPPORT_DYNAMIC_SLICE_MODE, "Dynamic Slice Mode Support",
NV_ENC_CAPS_SUPPORT_REF_PIC_INVALIDATION, "Reference Picture Invalidation Support",
NV_ENC_CAPS_PREPROC_SUPPORT, "Support for PreProcessing",
NV_ENC_CAPS_ASYNC_ENCODE_SUPPORT, "Support Async mode",
NV_ENC_CAPS_MB_NUM_MAX, "Maximum MBs per frame supported",
NV_ENC_CAPS_MB_PER_SEC_MAX, "Maximum aggregate throughput in MBs per sec",
NV_ENC_CAPS_SUPPORT_YUV444_ENCODE, "HW support for YUV444 mode encoding",
NV_ENC_CAPS_SUPPORT_LOSSLESS_ENCODE, "HW support for lossless encoding",
int countOfAllCapabilities = sizeof(allCapabilities) / sizeof(allCapabilities[0]);
for (int c=0; c<countOfAllCapabilities; c++) {
CapabilityDescription desc = allCapabilities[c];
NV_ENC_CAPS_PARAM caps;
ZeroMemory(&caps, sizeof(caps));
caps.version = NV_ENC_CAPS_PARAM_VER;
caps.capsToQuery = desc.capability;
int capabilityValue = 0;
nvStatus = pNvHWEncoder->NvEncGetEncodeCaps(encodeGUIDArray[i], &caps, &capabilityValue);
if (nvStatus == NV_ENC_SUCCESS) {
printf("\t%s: %d\n", desc.name, capabilityValue);
delete [] encodeGUIDArray;
Here are the capabilities reported for a GTX 960:
Capabilities for GUID 0: {6BC82762-4E63-4CA4-AA85-1E50F321F6BF}
Maximum number of B-Frames supported: 4
Rate control modes supported: 63
HW support for field mode encoding: 1
HW support for monochrome mode encoding: 0
HW support for FMO: 0
HW capability for Quarter pel motion estimation: 1
H.264 specific. HW support for BDirect modes: 1
H264 specific. HW support for CABAC entropy coding mode: 1
HW support for Adaptive Transform: 1
Reserved enum field: 0
HW support for encoding Temporal layers: 0
HW support for Hierarchical P frames: 0
HW support for Hierarchical B frames: 0
Maximum Encoding level supported : 51
Minimum Encoding level supported: 1
HW support for separate colour plane encoding: 0
Maximum output width supported: 4096
Maximum output height supported: 4096
Temporal Scalability Support: 0
Dynamic Encode Resolution Change Support: 1
Dynamic Encode Bitrate Change Support: 1
Forcing Constant QP On The Fly Support: 1
Dynamic rate control mode Change Support. : 0
Subframe readback support for slice-based encoding: 0
Constrained Encoding mode support: 1
Intra Refresh Mode Support: 1
Custom VBV Buffer Size support: 1
Dynamic Slice Mode Support: 1
Reference Picture Invalidation Support: 1
Support for PreProcessing: 0
Support Async mode: 1
Maximum MBs per frame supported: 65536
Maximum aggregate throughput in MBs per sec: 983040
HW support for YUV444 mode encoding: 1
HW support for lossless encoding: 1
Capabilities for GUID 1: {790CDC88-4522-4D7B-9425-BDA9975F7603}
Maximum number of B-Frames supported: 0
HW support for field mode encoding: 0
H.264 specific. HW support for BDirect modes: 0
HW support for Adaptive Transform: 0
Maximum Encoding level supported : 62
Support Async mode: 0
HW support for YUV444 mode encoding: 0
