So I was curius about NVENC so I downloaded the NVENC SDK and tried the sample encoder that was precompiled.
I tried to encode a 40 second 1080p 30fps clip using this config
// H.264 encoder parameter file
// syntax: [parameter [=] value] [[#|//] comment]
// Profile, Level
profile = 0 // 66=Baseline, 77=Main, 100=High, 0=auto(=lowest possible profile)
level = 0 // 10,11,12,13,20,21,22,30,31,32,40,41,42,50,51=level_idc, 0=auto(=lowest possible level)
// sequence structure
gopLength = 30 // IDR frame distance
numBFrames = 4 // number of B frames between I and P frames
fieldMode = 0 // 0=prog frame, 1=field
bottomfieldFirst = 0 // 0=top field first, 1=bottom field first
numSlices = 4 // 0=auto, 1..PicHeightInMbs=number of slices per picture
// Input File Details
width = 1920 // Width of Input Frame
height = 1080 // Height of Input Frame
maxwidth = 1920 // Max Width for resource allocation. Max resoultion change during reconfiguration can not go beyond MaxWidth, MaxHeight
maxheight = 1080 // Max Width for resource allocation. Max resoultion change during reconfiguration can not go beyond MaxWidth, MaxHeight
inFile =video.yuv
// Driver COde Path property
preset = 5 // 0=NV_ENC_PRESET_DEFAULT, 1=NV_ENC_PRESET_LOW_LATENCY_DEFAULT, 2=NV_ENC_PRESET_HP, 3=NV_ENC_PRESET_HQ, 4=NV_ENC_PRESET_BD, 5=NV_ENC_PRESET_LOW_LATENCY_HQ, 6=NV_ENC_PRESET_LOW_LATENCY_HP
interfaceType = 2 // 0=DX9, 1=DX11, 2=CUDA, 3=DX10
syncMode = 1 // 0=AsyncMode, 1=SyncMode
// bitstream characteristics (Type I HRD)
maxbitrate = 10000000 // Peakbitrate, maximum bitrate (bits/sec), 0=use encoder defined default (level limit)
vbvBufferSize = 10000000 // vbvBufferSize, decoder buffer size (bits), 0=use encoder defined default (level limit)
vbvInitialDelay = 5000000 // vbvInitialDelay, initial decoder buffer fullness (bits), 0=use encoder defined default (50%)
// rate control
rcMode = 2 // 0=fixed QP, 1=VBR, 2=CBR, 4=VBR_MINQP, 8=CBR_TWOPASS
bitrate = 8000000 // average bit rate (bits/s) (ignored if RCMode != 1)
enableInitialRCQP = 1
initialQPI = 28 // If enableInitialRCQP set then It will be used as InitialQP value for I slices for RCMode !=0. constant QP value for I slices For RCMode =0.
initialQPP = 28 // If enableInitialRCQP set then It will be used as InitialQP value for P slices for RCMode !=0. constant QP value for P slices For RCMode =0.
initialQPB = 34 // If enableInitialRCQP set then It will be used as InitialQP value for B slices for RCMode !=0. constant QP value for B slices For RCMode =0.
frameRateNum = 30000
frameRateDen = 1001
// picture type decision
enablePtd = 1 // 1=picture type decision will be takane by Encoder driver. 0=picture type decision will be takane by application
This was the output from CMD
>> GetNumberEncoders() has detected 1 CUDA capable GPU device(s) <<
[ GPU #0 - < GeForce GTX 650 > has Compute SM 3.0, NVENC Available ]
>> InitCUDA() has detected 1 CUDA capable GPU device(s)<<
[ GPU #0 - < GeForce GTX 650 > has Compute SM 3.0, Available NVENC ]
>> Select GPU #0 - < GeForce GTX 650 > supports SM 3.0 and NVENC
> CNvEncoder::AllocateIOBuffers() = Size (1920x1080 @ 16 frames)
> System Memory with 16 buffers.
> NVENC Encoder[0] configuration parameters for configuration #0
> GPU Device ID = 0
> Frames = 0 frames
> ConfigFile = config.txt
> Frame at which 0th configuration will happen = 0
> maxWidth,maxHeight = [1920,1080]
> Width,Height = [1920,1080]
> Video Output Codec = 4 - H.264 Codec
> Average Bitrate = 8000000 (bps/sec)
> Peak Bitrate = 10000000 (bps/sec)
> Rate Control Mode = 1 - VBR (Variable Bitrate)
> Frame Rate (Num/Denom) = (30000/1001) 29.9700 fps
> GOP Length = 30
> Set Initial RC QP = 1
> Initial RC QP (I,P,B) = I(28), P(28), B(34)
> Number of B Frames = 0
> Display Aspect Ratio X = 1920
> Display Aspect Ratio Y = 1080
> Video codec profile = 100
> Video codec Level = 0
> FieldEncoding = 0
> Number slices per Frame = 4
> Encoder Preset = 5 - Low Latancy High Quality (HQ) Preset
> Asynchronous Mode = No
> NVENC API Interface = 2 - CUDA
[ Input Filesize] : -749111296 bytes
[ Source Input File ] = "video.yuv"
[ # of Input Frames ] = 1140
** Start Encode <video.yuv>, Frames [0,1140] **
Loading Frames [0,239] into system memory queue (240 frames)
Encoding Frames [0,239]
0. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. 121. 122. 123. 124. 125. 126. 127. 128. 129. 130. 131. 132. 133. 134. 135. 136. 137. 138. 139. 140. 141. 142. 143. 144. 145. 146. 147. 148. 149. 150. 151. 152. 153. 154. 155. 156. 157. 158. 159. 160. 161. 162. 163. 164. 165. 166. 167. 168. 169. 170. 171. 172. 173. 174. 175. 176. 177. 178. 179. 180. 181. 182. 183. 184. 185. 186. 187. 188. 189. 190. 191. 192. 193. 194. 195. 196. 197. 198. 199. 200. 201. 202. 203. 204. 205. 206. 207. 208. 209. 210. 211. 212. 213. 214. 215. 216. 217. 218. 219. 220. 221. 222. 223. 224. 225. 226. 227. 228. 229. 230. 231. 232. 233. 234. 235. 236. 237. 238. 239.
encodeID[0], Frames [0,239] Encode Time = 4988.28 (ms)
Loading Frames [240,479] into system memory queue (240 frames)
Encoding Frames [240,479]
240. 241. 242. 243. 244. 245. 246. 247. 248. 249. 250. 251. 252. 253. 254. 255. 256. 257. 258. 259. 260. 261. 262. 263. 264. 265. 266. 267. 268. 269. 270. 271. 272. 273. 274. 275. 276. 277. 278. 279. 280. 281. 282. 283. 284. 285. 286. 287. 288. 289. 290. 291. 292. 293. 294. 295. 296. 297. 298. 299. 300. 301. 302. 303. 304. 305. 306. 307. 308. 309. 310. 311. 312. 313. 314. 315. 316. 317. 318. 319. 320. 321. 322. 323. 324. 325. 326. 327. 328. 329. 330. 331. 332. 333. 334. 335. 336. 337. 338. 339. 340. 341. 342. 343. 344. 345. 346. 347. 348. 349. 350. 351. 352. 353. 354. 355. 356. 357. 358. 359. 360. 361. 362. 363. 364. 365. 366. 367. 368. 369. 370. 371. 372. 373. 374. 375. 376. 377. 378. 379. 380. 381. 382. 383. 384. 385. 386. 387. 388. 389. 390. 391. 392. 393. 394. 395. 396. 397. 398. 399. 400. 401. 402. 403. 404. 405. 406. 407. 408. 409. 410. 411. 412. 413. 414. 415. 416. 417. 418. 419. 420. 421. 422. 423. 424. 425. 426. 427. 428. 429. 430. 431. 432. 433. 434. 435. 436. 437. 438. 439. 440. 441. 442. 443. 444. 445. 446. 447. 448. 449. 450. 451. 452. 453. 454. 455. 456. 457. 458. 459. 460. 461. 462. 463. 464. 465. 466. 467. 468. 469. 470. 471. 472. 473. 474. 475. 476. 477. 478. 479.
encodeID[0], Frames [240,479] Encode Time = 9888.45 (ms)
Loading Frames [480,719] into system memory queue (240 frames)
Encoding Frames [480,719]
480. 481. 482. 483. 484. 485. 486. 487. 488. 489. 490. 491. 492. 493. 494. 495. 496. 497. 498. 499. 500. 501. 502. 503. 504. 505. 506. 507. 508. 509. 510. 511. 512. 513. 514. 515. 516. 517. 518. 519. 520. 521. 522. 523. 524. 525. 526. 527. 528. 529. 530. 531. 532. 533. 534. 535. 536. 537. 538. 539. 540. 541. 542. 543. 544. 545. 546. 547. 548. 549. 550. 551. 552. 553. 554. 555. 556. 557. 558. 559. 560. 561. 562. 563. 564. 565. 566. 567. 568. 569. 570. 571. 572. 573. 574. 575. 576. 577. 578. 579. 580. 581. 582. 583. 584. 585. 586. 587. 588. 589. 590. 591. 592. 593. 594. 595. 596. 597. 598. 599. 600. 601. 602. 603. 604. 605. 606. 607. 608. 609. 610. 611. 612. 613. 614. 615. 616. 617. 618. 619. 620. 621. 622. 623. 624. 625. 626. 627. 628. 629. 630. 631. 632. 633. 634. 635. 636. 637. 638. 639. 640. 641. 642. 643. 644. 645. 646. 647. 648. 649. 650. 651. 652. 653. 654. 655. 656. 657. 658. 659. 660. 661. 662. 663. 664. 665. 666. 667. 668. 669. 670. 671. 672. 673. 674. 675. 676. 677. 678. 679. 680. 681. 682. 683. 684. 685. 686. 687. 688. 689. 690. 691. 692. 693. 694. 695. 696. 697. 698. 699. 700. 701. 702. 703. 704. 705. 706. 707. 708. 709. 710. 711. 712. 713. 714. 715. 716. 717. 718. 719.
encodeID[0], Frames [480,719] Encode Time = 14750.28 (ms)
Loading Frames [720,959] into system memory queue (240 frames)
Encoding Frames [720,959]
720. 721. 722. 723. 724. 725. 726. 727. 728. 729. 730. 731. 732. 733. 734. 735. 736. 737. 738. 739. 740. 741. 742. 743. 744. 745. 746. 747. 748. 749. 750. 751. 752. 753. 754. 755. 756. 757. 758. 759. 760. 761. 762. 763. 764. 765. 766. 767. 768. 769. 770. 771. 772. 773. 774. 775. 776. 777. 778. 779. 780. 781. 782. 783. 784. 785. 786. 787. 788. 789. 790. 791. 792. 793. 794. 795. 796. 797. 798. 799. 800. 801. 802. 803. 804. 805. 806. 807. 808. 809. 810. 811. 812. 813. 814. 815. 816. 817. 818. 819. 820. 821. 822. 823. 824. 825. 826. 827. 828. 829. 830. 831. 832. 833. 834. 835. 836. 837. 838. 839. 840. 841. 842. 843. 844. 845. 846. 847. 848. 849. 850. 851. 852. 853. 854. 855. 856. 857. 858. 859. 860. 861. 862. 863. 864. 865. 866. 867. 868. 869. 870. 871. 872. 873. 874. 875. 876. 877. 878. 879. 880. 881. 882. 883. 884. 885. 886. 887. 888. 889. 890. 891. 892. 893. 894. 895. 896. 897. 898. 899. 900. 901. 902. 903. 904. 905. 906. 907. 908. 909. 910. 911. 912. 913. 914. 915. 916. 917. 918. 919. 920. 921. 922. 923. 924. 925. 926. 927. 928. 929. 930. 931. 932. 933. 934. 935. 936. 937. 938. 939. 940. 941. 942. 943. 944. 945. 946. 947. 948. 949. 950. 951. 952. 953. 954. 955. 956. 957. 958. 959.
encodeID[0], Frames [720,959] Encode Time = 19647.19 (ms)
Loading Frames [960,1139] into system memory queue (180 frames)
Encoding Frames [960,1139]
960. 961. 962. 963. 964. 965. 966. 967. 968. 969. 970. 971. 972. 973. 974. 975. 976. 977. 978. 979. 980. 981. 982. 983. 984. 985. 986. 987. 988. 989. 990. 991. 992. 993. 994. 995. 996. 997. 998. 999. 1000. 1001. 1002. 1003. 1004. 1005. 1006. 1007. 1008. 1009. 1010. 1011. 1012. 1013. 1014. 1015. 1016. 1017. 1018. 1019. 1020. 1021. 1022. 1023. 1024. 1025. 1026. 1027. 1028. 1029. 1030. 1031. 1032. 1033. 1034. 1035. 1036. 1037. 1038. 1039. 1040. 1041. 1042. 1043. 1044. 1045. 1046. 1047. 1048. 1049. 1050. 1051. 1052. 1053. 1054. 1055. 1056. 1057. 1058. 1059. 1060. 1061. 1062. 1063. 1064. 1065. 1066. 1067. 1068. 1069. 1070. 1071. 1072. 1073. 1074. 1075. 1076. 1077. 1078. 1079. 1080. 1081. 1082. 1083. 1084. 1085. 1086. 1087. 1088. 1089. 1090. 1091. 1092. 1093. 1094. 1095. 1096. 1097. 1098. 1099. 1100. 1101. 1102. 1103. 1104. 1105. 1106. 1107. 1108. 1109. 1110. 1111. 1112. 1113. 1114. 1115. 1116. 1117. 1118. 1119. 1120. 1121. 1122. 1123. 1124. 1125. 1126. 1127. 1128. 1129. 1130. 1131. 1132. 1133. 1134. 1135. 1136. 1137. 1138. 1139.
>> Last Encoded Frame completed <<
encodeID[0], Frames [960,1139] Encode Time = 23284.50 (ms)
CNvEncoder::ReleaseEncoderResources() m_RefCount == 0, releasing resources
Frames Encoded : 1140
Total Encode Time : 72.56 (sec)
Average Time/Frame : 63.65 (ms)
Average Frame Rate : 15.71 (fps)
OutputFile[0] = test.gpu0.264
Filesize[0] = 38190216
Average Bitrate[0] (38.04 seconds) 8032013.500 (bps)
It looked like it encoded, but I opened the clip and it only played the first 8 seconds in a loop.
Help would be apreciated
heres the output file and the original
original http://youtu.be/G18bFxayRnE
output http://youtu.be/0zar_Ref53g
“for some odd reason YouTube made the videos look really crappy”
