Avoiding Bank Conflicts in convolution
Bank conflicts are avoidable in most CUDA computations if care is taken accessing shared memory arrays.
In convolution, for example this is just a matter of padding the 2D array to a width that is not evenly divisible by the number of shared memory banks.
I am unable to understand this padding funda related to avoiding bank conflicts.
Any pointers here ??
Thanks in advance
consider shared A[16][16],
A[i][j] belongs to bank-j for any i = 0:15
suppose you use 16 threads, then
A[threadIdx.x][0] is bank-conflict since A[0][0], A[1][0], … A[15][0] fall into bank-0
and cannnot be broadcasted.
however if you declare shared A[16][16+1]
then A[threadIdx.x][0] is not bank-conflict since
A[0][0] is bank-0
A[1][0] is bank-1
A[15][0] is bank-15
General speaking, under shared A[16][16+1], row-major index of A[i][j] is (i * 17 + j)
(i * 17 + j) = 16 * k + bank_id
or say bank_id = (i * 17 + j) mod 16
for j = 0, bank_id = (i * 17) mod 16
gcd(17,16) = 1, so A[i][0], i=0:15 is distributed into 16 bank.
Thanks for your reply!
A[1][0] is bank 1 but the statement:
Says that A[1][0] is bank 0… as you said : A[ i ][ j ] belongs to bank-j for any i = 0:15
I am little bit confused!
sorry, I correct my setting, define type of matrix A is “float”,
shared float A[16][16]
and relationship between bank id and A[i][j] is shown in the following
bank 0	bank 1	bank 2	bank 3   ....   bank 15
A[0][0]   A[0][1]   A[0][2]   A[0][3]  ....   A[0][15]
A[1][0]   A[1][1]   A[1][2]   A[1][3]  ....   A[1][15]
A[2][0]   A[2][1]   A[2][2]   A[2][3]  ....   A[2][15]
A[15][0]  A[15][1]  A[15][2]  A[15][3]  ....  A[15][15]
that’s why I say A[i][j] belongs to bank-j for any i = 0:15
