I did transfer learning with DetectNet v2.
Checking the results with tlt-infer was very good.
However, when I export to DeepStream and check, the BBox is slightly misaligned to the top left.
How can I make it as accurate as tlt-infer?
We use the following
TLT v1.0.1
DetectNet v2 (ResNet18)
DeepStream SDK 4.0.2
@m.kawakami
Could you please paste your finding with more details? Thanks.
BTW, do you have chance to check TLT 2.0_dp too?
I’m using the following configs.
I’ll try TLT2.0.
train config.
# Sample model config for to instantiate a resnet18 model with pretrained weights and freeze blocks 0, 1
# with all shortcuts having projection layers.
model_config {
pretrained_model_file: "/root/work/tlt_work/pretrained_models/tlt_resnet18_detectnet_v2_v1/resnet18.hdf5"
num_layers: 18
#load_graph: True
#freeze_blocks: 0
#freeze_blocks: 1
#freeze_blocks: 2
#freeze_blocks: 3
arch: "resnet"
use_batch_norm: True
activation {
activation_type: "relu"
dropout_rate: 0.1
objective_set: {
cov {}
bbox {
scale: 35.0
offset: 0.5
training_precision: {
backend_floatx: FLOAT32
# Sample rasterizer configs to instantiate a 1 class bbox rasterizer
bbox_rasterizer_config {
target_class_config {
key: "object"
value: {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4
cov_radius_y: 0.4
bbox_min_radius: 1.0
deadzone_radius: 0.67
postprocessing_config {
key: "object"
value: {
clustering_config {
coverage_threshold: 0.005
dbscan_eps: 0.15
#dbscan_eps: 1.00
dbscan_min_samples: 0.05
minimum_bounding_box_height: 20
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.05
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
enable_autoweighting: True
max_objective_weight: 0.9999
min_objective_weight: 0.0001
training_config {
batch_size_per_gpu: 16
num_epochs: 80
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-6
max_learning_rate: 5e-4
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-9
optimizer {
adam {
epsilon: 1e-08
beta1: 0.9
beta2: 0.999
cost_scaling {
enabled: False
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
# Sample augementation config for
augmentation_config {
preprocessing {
output_image_width: 512
output_image_height: 288
output_image_channel: 3
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
color_shift_stddev: 0.3
hue_rotation_max: 25.0
saturation_shift_max: 0.2
contrast_scale_max: 0.1
contrast_center: 0.5
# Sample evaluation config to run evaluation in integrate mode for the given 3 class model,
# at every 10th epoch starting from the epoch 1.
evaluation_config {
average_precision_mode: INTEGRATE
validation_period_during_training: 10
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: "object"
value: 0.5
evaluation_box_config {
key: "object"
value {
minimum_height: 4
maximum_height: 9999
minimum_width: 4
maximum_width: 9999
dataset_config {
data_sources: {
tfrecords_path: "/root/work/tlt_work/tf_records/*"
image_directory_path: "/root/work/tlt_work/resized"
image_extension: "png"
target_class_mapping {
key: "object"
value: "object"
validation_fold: 0
train config after prune
model_config {
pretrained_model_file: "/root/work/tlt_work/pruned_model/resnet18_nopool_bn_detectnet_v2_pruned.tlt"
num_layers: 18
load_graph: True
#freeze_blocks: 0
#freeze_blocks: 1
#freeze_blocks: 2
#freeze_blocks: 3
arch: "resnet"
activation {
dropout_rate: 0.1
objective_set: {
cov {}
bbox {
scale: 35.0
offset: 0.5
key: "object"
value: {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4
cov_radius_y: 0.4
key: "object"
value: {
clustering_config {
dbscan_eps: 0.15
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
training_config {
num_epochs: 80
learning_rate {
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-9
optimizer {
adam {
epsilon: 1e-08
beta1: 0.9
beta2: 0.999
cost_scaling {
enabled: False
increment: 0.005
decrement: 1.0
preprocessing {
min_bbox_width: 1.0
zoom_min: 1.0
zoom_max: 1.0
evaluation_config {
key: "object"
value: 0.5
key: "object"
value {
minimum_height: 4
minimum_width: 4
maximum_width: 9999
dataset_config {
data_sources: {
key: "object"
value: "object"
validation_fold: 0
inference config
"dbscan_criterion": "IOU",
"dbscan_eps": {
"object": 0.25,
"default": 0.15
"dbscan_min_samples": {
"object": 0.05,
"default": 0.0
"min_cov_to_cluster": {
"object": 0.075,
"default": 0.005
"min_obj_height": {
"object": 4,
"default": 2
"target_classes": ["object"],
"confidence_th": {
"object": 0.3
"confidence_model": {
"object": { "kind": "aggregate_cov"},
"default": { "kind": "aggregate_cov"}
"output_map": {
"object" : "object"
"color": {
"object": "green"
"postproc_classes": ["object"],
"image_height": 288,
"image_width": 512,
"stride": 16
DeepStream config
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-engine-file=object_detect_b1_fp16.engine
labelfile-path=labels.txt
#int8-calib-file=calibration.bin
uff-input-blob-name=input_1
batch-size=1
input-dims=3;288;512;0
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=1
interval=0
gie-unique-id=1
output-blob-names=output_cov/Sigmoid;output_bbox/BiasAdd
is-classifier=0
#maintain-aspect-ratio=1
[class-attrs-all]
eps=0.15
group-threshold=1
minBoxes=0
detected-min-w=80
detected-min-h=40
Incidentally, can the model created with TLT2.0 also work with DeepStream 4.0?
No, the model created with TLT2.0 is compatible with DS5.
