Hi all,
I trained detectnet-v2-darknet-53 on the helmet dataset with GPU 1080 ti and batch-size=4. The trained map result reach to 80%, and that shows the model fine trained, but when I want to get inference test on some tests images, the bounding box of output are incorrected and shifted. Note that this problem only occurred with detectnet-v2-darknet-53, I get correct result with yolov3/ssd/darknet-v1.
I used TLT docker version v2-py3.
Why this problem happen? How to I can solve the problem? This related to config file or bug in the TLT version.
Morganh
September 24, 2020, 2:18am
3
Do you run with tlt-infer or deepstream?
Please share the command and config file too.
@Morganh ,
I run tlt-infer.
tlt-infer detectnet_v2 -e /workspace/tmp2/detectnet_v2/specs/detectnet_v2_inference_kitti_etlt.txt \
-o /workspace/tmp2/output \
-i /workspace/tmp2/trainval/image \
-k key
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: "/workspace/tf_records/*"
image_directory_path: "/workspace/dataset/training"
image_extension: "jpg"
target_class_mapping {
key: "hat"
value: "hat"
key: "head"
value: "head"
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 1248
output_image_height: 384
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298023224
contrast_scale_max: 0.10000000149011612
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: "hat"
value {
clustering_config {
coverage_threshold: 0.004999999888241291
dbscan_eps: 0.15000000596046448
dbscan_min_samples: 0.05000000074505806
minimum_bounding_box_height: 1
key: "head"
value {
clustering_config {
dbscan_eps: 0.12999999523162842
model_config {
pretrained_model_file: "/workspace/pretrained_model/darknet53.hdf5"
num_layers: 53
use_batch_norm: true
dropout_rate: 0.10000000149011612
activation {
activation_type: "relu"
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
freeze_blocks: 0.0
arch: "darknet"
all_projections: true
evaluation_config {
validation_period_during_training: 1
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: "hat"
value: 0.5
key: "head"
value: 0.699999988079071
evaluation_box_config {
key: "hat"
value {
minimum_height: 4
maximum_height: 9999
minimum_width: 4
maximum_width: 9999
key: "head"
value {
minimum_height: 4
minimum_width: 4
maximum_width: 9999
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.05000000074505806
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.9998999834060669
min_objective_weight: 9.999999747378752e-05
training_config {
batch_size_per_gpu: 4
num_epochs: 90
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 4.999999873689376e-06
max_learning_rate: 0.0005000000237487257
soft_start: 0.009999999776482582
annealing: 0.30000001192092896
regularizer {
type: L1
weight: 3.000000026176508e-09
optimizer {
adam {
epsilon: 9.99999993922529e-09
beta1: 0.8999999761581421
beta2: 0.9990000128746033
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 1
bbox_rasterizer_config {
key: "hat"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4000000059604645
cov_radius_y: 0.4000000059604645
bbox_min_radius: 1.0
key: "head"
value {
cov_center_x: 0.5
cov_center_y: 0.5
deadzone_radius: 0.6700000166893005
Morganh
September 25, 2020, 2:24am
5
Could you share the tlt infer config file too? Thanks.
Morganh
September 26, 2020, 4:16am
7
Hi @LoveNvidia ,
Your attachment is training spec. I mean could you share the tlt infer spec file here?
For example, the detectnet_v2_inference_kitti_tlt.txt or detectnet_v2_inference_kitti_etlt.txt.
Also, please share your full command and full log when you run tlt-infer. Thanks.
@Morganh ,
infer_detectnetv2_z.txt (1.7 KB)
tlt-infer detectnet_v2 -e /workspace/spec_files/infer_detectnetv2_z.txt -o /workspace/inferred_images/test_detectnet2 -i /workspace/dataset/testing/images -k key
infer_detectnetv2_log.txt (7.0 KB)
Q- I trained the detectnet-2/ssd/yolo with same backbone, and their map of both ssd/yolo are reached to 80% but detectnet2 achieved 63%, I want to know this problem related to model detector or process of training? My mean is that really the detectnet2 has poor performance against ssd/yolo?
I’m sorry, I made a mistake here. That model reached to 63%
Morganh
September 28, 2020, 6:07am
9
What is darknet-v1? Could you provide more details?
Can you share the training spec of yolo_v3 and ssd?
Could you please share the helmet dataset? Is it public dataset? I want to check on my side too.
For the “the bounding box of output are incorrected and shifted”, is it 100% reproduced on all the test images?
kayccc
October 6, 2020, 4:38am
10
Hi LoveNvidia,
Is this still an issue to support? Any update?
@kayccc ,
No thanks, the problem is solved with training again.
