Hi Team,
I have problems with mounting an NFS to my BCM cluster. My cluster uses topology 1, and the NFS is located in the externalnet. I have successfully mounted the NFS to my head node:
When I enter the relevant directory, i can see the files in my NFS.
Then, I exported this directory:
And mounted it on my default category
When I check the /etc/fstab in node03, I see that the directory should be mounted:
However, when I try to mount all the volumes in the fstab file, I get an error saying that there is no such directory. But when I follow the same steps again with a regular directory in the head node (I mean I am not using the NFS in the extarnalnet this time), It successfully mounts the directory which can be seen below:
Here is the files and folder shared in the head node:
I am not sure whether this problem is related to using an NFS in the externalnet.
Besides, when I toggle on the auto button in the File System Export page, the line is removed from the list. Hence, I cannot export a file system automatically:
I use just one head node and one regular node in my cluster and both are workstations.
Thank you in advance.
