Hello NVIDIA Team,
I’m deploying Bright Cluster Manager 10.0 (BCM 10.0) on Ubuntu 24.04 (Noble) as part of a BasePOD installation.
During the Kubernetes setup (cm-kubernetes-setup), multiple stages fail due to missing or invalid package repositories.
❌ Error details
E: The repository 'http://updates-us-east.brightcomputing.com/deb/cm/10.0/amd64/ubuntu noble Release' does not have a Release file.
E: The repository 'http://updates-us-east.brightcomputing.com/deb/ml/10.0/amd64/ubuntu noble Release' does not have a Release file.
E: The repository 'https://pkgs.k8s.io/core:/stable:/v1.30/deb Release' does not have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu noble Release' does not have a Release file.
As a result, the Kubernetes setup fails to complete correctly:
The etcd module (
etcd/kube-default) is never created. -
etcd-serveris not installed on the control-plane image. -
The containerd package is missing and the service remains DOWN or “socket not ready.”
Each following stage (API server bootstrap, GPU operator, etc.) depends on these missing components and fails as well.
🧰 Temporary workarounds attempted
I tried several manual fixes to move the installation forward:
Installed
etcd-servermanually inside/cm/images/k8s-control-plane-image. -
Created
/cm/shared/modulefiles/etcd/kube-defaultand/cm/shared/apps/etcd/binmanually. -
Installed
containerdmanually and recreated/etc/containerd/config.toml. -
Added
module use /cm/shared/modulefilesto/etc/profile.d/modules.shin the control-plane image.
However, even with these manual steps, each stage of the setup continued to encounter errors related to missing packages or uninitialized services.
The installation never reached a stable or usable Kubernetes cluster state.
🧠 Questions
Are updated Bright 10.0 repositories for Ubuntu 24.04 (Noble) available or planned soon?
If not, is there an official workaround (alternate repo endpoint or HTTPS mirror) that provides required packages such as
etcd,containerd, andnvidia-gpu-operatordependencies? -
Or is Ubuntu 22.04 (Jammy) currently the only supported base OS for Bright 10.0?
Environment
BCM 10.0 (NVIDIA BasePOD reference deployment)
Nodes:
bcm10-headnode,master2,knode-01 -
Bright repositories:
updates-us-east.brightcomputing.com -
Internet access: working, but repo endpoints return “Release file missing” errors.
Thanks for confirming current repository support status for Ubuntu 24.04 and guidance on how to proceed with a clean Kubernetes installation.
Best regards,
