Air-gapped BCM + Kubernetes + Slurm installation workflow
we are trying to deploy Bright Cluster Manager, Kubernetes, and Slurm in a fully air-gapped environment. During the process we encountered several issues related to:
  • loading required BCM packages into our local APT repository,
  • missing Bright packages (e.g., cm-docker, cm-containerd, cm-nvidia-container-toolkit) when running cm-docker-setup,
  • containerd CRI not initializing correctly without the Bright-provided packages,
  • Kubernetes Setup failing during image pull and CRI validation even with air-gap registry + ChartMuseum configured.
We want to confirm the correct/official sequence for deploying Bright in an air-gapped installation that includes:
  1. Preparing local APT repository for all required BCM packages
  2. Loading Docker/Containerd configs for air-gap
  3. Loading Kubernetes images and Helm charts
  4. Running Slurm and the remaining workload managers
Is there an officially documented step-by-step workflow for BCM + Kubernetes + Slurm in air-gapped mode?
If yes, could you guide us to the correct documentation or recommended procedure?
Thanks in advance.
