[Beginner] Math operations giving incorrect answers
Hey guys,
New to CUDA C, running into a few problems. Whenever I executed any expressions on the device using numbers, the answers I get back are always incorrect.
For example this code (which is just directly copied from Nvidia) adds two vectors together to a third vector and prints out the results.
#include<iostream>
const int N = 10;
__global__ void add(int *a, int *b, int *c) {
	int index = blockIdx.x;
	if(index < N) {
		c[index] = a[index] + b[index];
int main() {
	int a[N], b[N], c[N];
	int *dev_a, *dev_b, *dev_c;
	cudaMalloc((void**)&dev_a, N * sizeof(int));
	cudaMalloc((void**)&dev_b, N * sizeof(int));
	cudaMalloc((void**)&dev_c, N * sizeof(int));
	for(int i = 0; i < N; i++) {
		a[i] = i;
		b[i] = i*i;
	cudaMemcpy(dev_a, a, N * sizeof(int), cudaMemcpyHostToDevice);
	cudaMemcpy(dev_b, b, N * sizeof(int), cudaMemcpyHostToDevice);
	add<<<N,1>>>(dev_a, dev_b, dev_c);
	cudaMemcpy(&c, dev_c, N * sizeof(int), cudaMemcpyDeviceToHost);
		std::cout << a[i] << " + " << b[i] << " = " << c[i] << "\n";
	cudaFree(dev_a);
	cudaFree(dev_b);
	cudaFree(dev_c);
	return 0;
But the results I get are:
0 + 0 = 4207985
1 + 1 = 0
2 + 4 = 4203010
3 + 9 = 0
4 + 16 = 928020192
5 + 25 = 32767
6 + 36 = 6307276
7 + 49 = 0
8 + 64 = 1
9 + 81 = 0
So I figured, let’s try an even simpler one, this code adds two integers and displays the result;
#include<iostream>
using namespace std;
__global__ void integerSum(int, int, int*);
int main() {
	int a, b, c = 0;
	int *dev_c;
	cudaMalloc((void**)&dev_c, sizeof(int));
	cout << "Enter 1st int: ";
	cin >> a;
	cout << "Enter second int: ";
	cin >> b;
	integerSum<<<1,1>>>(a, b, dev_c);
	cudaMemcpy(&c, dev_c, sizeof(int), cudaMemcpyDeviceToHost);
	cout << a << " + " << b << " = " << c << endl;
	cudaFree(dev_c);
	return 0;
__global__ void integerSum(int a, int b, int *dev_c) {
	*dev_c = a + b;
to which I get answers such as:
Enter 1st int: 5
Enter second int: 6
5 + 6 = 0
I get no errors when compiling.
If it makes any difference, I am running Linux Ubuntu 10.10 with CUDA 3.2 RC.
Hey guys,
#include<iostream>
const int N = 10;
	if(index < N) {
int main() {
		a[i] = i;
		b[i] = i*i;
	cudaFree(dev_a);
	cudaFree(dev_b);
	cudaFree(dev_c);
	return 0;
0 + 0 = 4207985
1 + 1 = 0
2 + 4 = 4203010
3 + 9 = 0
4 + 16 = 928020192
5 + 25 = 32767
6 + 36 = 6307276
7 + 49 = 0
8 + 64 = 1
9 + 81 = 0
#include<iostream>
int main() {
	int a, b, c = 0;
	int *dev_c;
	cin >> a;
	cin >> b;
	cudaFree(dev_c);
	return 0;
	*dev_c = a + b;
Enter 1st int: 5
Enter second int: 6
5 + 6 = 0
You need to do:
cudaMemcpy(c, dev_c, N * sizeof(int), cudaMemcpyDeviceToHost);
Hope this helps.
You need to do:
Hope this helps.
