Benchmark tensorrt model in UFF extension on jetson AGX Orin
I downloaded the ssd_mobilenet_v2_coco.uff from
https://nvidia.box.com/shared/static/jcdewxep8vamzm71zajcovza938lygre.gz, I’d like to benchmark this tensorrt model on Jetson AGX Orin.
Using model (unet-segmentation.uff) in jetson_benchmarks/benchmark_csv/orin-benchmarks.csv at master · NVIDIA-AI-IOT/jetson_benchmarks · GitHub as an example, I saved the ssd_mobilenet_v2_coco.uff under models dir, I updated orin-benchmarks.csv and benchmark.py to execute the ssd_mobilenet_v2_coco.uff, but it failed.
My question here: does the tensorrt model (ssd_mobilenet_v2_coco.uff) work on AGX Orin? if so, what might be the problem? I suspect the input (input,3,300, 300) and out (NMP) ) in orin_benchmark.csv, but run out of ideas.
Would you mind sharing the error log so we can know more about the issue?
/usr/src/tensorrt/bin/trtexec --uff=ssd_mobilenet.uff --output=NMP --uffInput=input_1,31,300,300 --verbose
[06/11/2024-16:01:33] [I] === Model Options ===
[06/11/2024-16:01:33] [I] Format: UFF
[06/11/2024-16:01:33] [I] Model: ssd_mobilenet.uff
[06/11/2024-16:01:33] [I] Uff Inputs Layout: NCHW
[06/11/2024-16:01:33] [I] Input: input_1,31,300,300
[06/11/2024-16:01:33] [I] Output: NMP
[06/11/2024-16:01:33] [I] === Build Options ===
[06/11/2024-16:01:33] [I] Max batch: 1
[06/11/2024-16:01:33] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[06/11/2024-16:01:33] [I] minTiming: 1
[06/11/2024-16:01:33] [I] avgTiming: 8
[06/11/2024-16:01:33] [I] Precision: FP32
[06/11/2024-16:01:33] [I] LayerPrecisions:
[06/11/2024-16:01:33] [I] Calibration:
[06/11/2024-16:01:33] [I] Refit: Disabled
[06/11/2024-16:01:33] [I] Sparsity: Disabled
[06/11/2024-16:01:33] [I] Safe mode: Disabled
[06/11/2024-16:01:33] [I] DirectIO mode: Disabled
[06/11/2024-16:01:33] [I] Restricted mode: Disabled
[06/11/2024-16:01:33] [I] Build only: Disabled
[06/11/2024-16:01:33] [I] Save engine:
[06/11/2024-16:01:33] [I] Load engine:
[06/11/2024-16:01:33] [I] Profiling verbosity: 0
[06/11/2024-16:01:33] [I] Tactic sources: Using default tactic sources
[06/11/2024-16:01:33] [I] timingCacheMode: local
[06/11/2024-16:01:33] [I] timingCacheFile:
[06/11/2024-16:01:33] [I] Heuristic: Disabled
[06/11/2024-16:01:33] [I] Preview Features: Use default preview flags.
[06/11/2024-16:01:33] [I] Input(s)s format: fp32:CHW
[06/11/2024-16:01:33] [I] Output(s)s format: fp32:CHW
[06/11/2024-16:01:33] [I] Input build shapes: model
[06/11/2024-16:01:33] [I] Input calibration shapes: model
[06/11/2024-16:01:33] [I] === System Options ===
[06/11/2024-16:01:33] [I] Device: 0
[06/11/2024-16:01:33] [I] DLACore:
[06/11/2024-16:01:33] [I] Plugins:
[06/11/2024-16:01:33] [I] === Inference Options ===
[06/11/2024-16:01:33] [I] Batch: 1
[06/11/2024-16:01:33] [I] Input inference shapes: model
[06/11/2024-16:01:33] [I] Iterations: 10
[06/11/2024-16:01:33] [I] Duration: 3s (+ 200ms warm up)
[06/11/2024-16:01:33] [I] Sleep time: 0ms
[06/11/2024-16:01:33] [I] Idle time: 0ms
[06/11/2024-16:01:33] [I] Streams: 1
[06/11/2024-16:01:33] [I] ExposeDMA: Disabled
[06/11/2024-16:01:33] [I] Data transfers: Enabled
[06/11/2024-16:01:33] [I] Spin-wait: Disabled
[06/11/2024-16:01:33] [I] Multithreading: Disabled
[06/11/2024-16:01:33] [I] CUDA Graph: Disabled
[06/11/2024-16:01:33] [I] Separate profiling: Disabled
[06/11/2024-16:01:33] [I] Time Deserialize: Disabled
[06/11/2024-16:01:33] [I] Time Refit: Disabled
[06/11/2024-16:01:33] [I] NVTX verbosity: 0
[06/11/2024-16:01:33] [I] Persistent Cache Ratio: 0
[06/11/2024-16:01:33] [I] Inputs:
[06/11/2024-16:01:33] [I] === Reporting Options ===
[06/11/2024-16:01:33] [I] Verbose: Enabled
[06/11/2024-16:01:33] [I] Averages: 10 inferences
[06/11/2024-16:01:33] [I] Percentiles: 90,95,99
[06/11/2024-16:01:33] [I] Dump refittable layers:Disabled
[06/11/2024-16:01:33] [I] Dump output: Disabled
[06/11/2024-16:01:33] [I] Profile: Disabled
[06/11/2024-16:01:33] [I] Export timing to JSON file:
[06/11/2024-16:01:33] [I] Export output to JSON file:
[06/11/2024-16:01:33] [I] Export profile to JSON file:
[06/11/2024-16:01:33] [I] === Device Information ===
[06/11/2024-16:01:33] [I] Selected Device: Orin
[06/11/2024-16:01:33] [I] Compute Capability: 8.7
[06/11/2024-16:01:33] [I] SMs: 16
[06/11/2024-16:01:33] [I] Compute Clock Rate: 1.3 GHz
[06/11/2024-16:01:33] [I] Device Global Memory: 30588 MiB
[06/11/2024-16:01:33] [I] Shared Memory per SM: 164 KiB
[06/11/2024-16:01:33] [I] Memory Bus Width: 128 bits (ECC disabled)
[06/11/2024-16:01:33] [I] Memory Clock Rate: 1.3 GHz
[06/11/2024-16:01:33] [I] TensorRT version: 8.5.2
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::BatchTilePlugin_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::Clip_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::CoordConvAC version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::CropAndResizeDynamic version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::CropAndResize version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::DecodeBbox3DPlugin version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::EfficientNMS_Explicit_TF_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::EfficientNMS_Implicit_TF_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::EfficientNMS_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::FlattenConcat_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::GenerateDetection_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::GridAnchorRect_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::GroupNorm version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 2
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::LayerNorm version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::LReLU_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::MultilevelCropAndResize_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::MultilevelProposeROI_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::MultiscaleDeformableAttnPlugin_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::NMSDynamic_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::NMS_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::Normalize_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::PillarScatterPlugin version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::PriorBox_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::ProposalDynamic version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::Proposal version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::Region_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::Reorg_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::ROIAlign_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::RPROI_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::ScatterND version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::SeqLen2Spatial version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::SplitGeLU version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::Split version 1
[06/11/2024-16:01:33] [V] [TRT] Registered plugin creator - ::VoxelGeneratorPlugin version 1
[06/11/2024-16:01:33] [I] [TRT] [MemUsageChange] Init CUDA: CPU +220, GPU +0, now: CPU 246, GPU 12021 (MiB)
[06/11/2024-16:01:33] [V] [TRT] Trying to load shared library libnvinfer_builder_resource.so.8.5.2
[06/11/2024-16:01:33] [V] [TRT] Loaded shared library libnvinfer_builder_resource.so.8.5.2
[06/11/2024-16:01:35] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +302, GPU +282, now: CPU 571, GPU 12323 (MiB)
[06/11/2024-16:01:35] [W] [TRT] The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
[06/11/2024-16:01:35] [I] Start parsing network model
[06/11/2024-16:01:35] [V] [TRT] UFFParser: Parsing Input[Op: Input].
[06/11/2024-16:01:35] [V] [TRT] UFFParser: Input → [1,3,300,300]
[06/11/2024-16:01:35] [V] [TRT] UFFParser: Applying order forwarding to: Input
[06/11/2024-16:01:35] [V] [TRT] UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/weights[Op: Const].
[06/11/2024-16:01:35] [V] [TRT] UFFParser: FeatureExtractor/MobilenetV2/Conv/weights → [3,3,3,32]
[06/11/2024-16:01:35] [V] [TRT] UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/weights
[06/11/2024-16:01:35] [V] [TRT] UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/Conv2D[Op: Conv]. Inputs: Input, FeatureExtractor/MobilenetV2/Conv/weights
[06/11/2024-16:01:35] [V] [TRT] UFFParser: Inserting transposes for FeatureExtractor/MobilenetV2/Conv/Conv2D
[06/11/2024-16:01:35] [E] [TRT] UffParser: Parser error: FeatureExtractor/MobilenetV2/Conv/Conv2D: Order size is not matching the number dimensions of TensorRT
[06/11/2024-16:01:35] [E] Failed to parse uff file
[06/11/2024-16:01:35] [I] Finish parsing network model
[06/11/2024-16:01:35] [E] Parsing model failed
[06/11/2024-16:01:35] [E] Failed to create engine from model or file.
[06/11/2024-16:01:35] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8502] # /usr/src/tensorrt/bin/trtexec --uff=ssd_mobilenet.uff --output=NMP --uffInput=input_1,31,300,300 --verbose
Based on this, it looks like the uff model doesn’t define correctly.
Could you also share the log that converts the TensorFlow model into the uff file?
I used this model from https://nvidia.box.com/shared/static/jcdewxep8vamzm71zajcovza938lygre.gz
Could you share the log you converted the model into the uff.
So we can know more about if any issues with the process.
