I don’t konw how to import uff model from a UFF File. I can not find the information in the user guide.
Please check this sample:
/usr/local/lib/python2.7/dist-packages/tensorrt/examples/uff_mnist.py
engine = trt.utils.uff_file_to_trt_engine(G_LOGGER,
MODEL,
parser,
MAX_BATCHSIZE,
MAX_WORKSPACE,
trt.infer.DataType.FLOAT)
I am trying to run the example of uff_mnist.py that is provided in the tensorrt package. I am running this on a x86 machine as the python apis are not available on the Jetson yet.
But I am getting the following error. Any idea what is wrong? I have not done any changes to the code.
$ python /usr/local/lib/python2.7/dist-packages/tensorrt/examples/uff_mnist.py /usr/src/tensorrt/data
[TensorRT] INFO: UFFParser: parsing Const_0
[TensorRT] INFO: UFFParser: parsing Const_1
[TensorRT] INFO: UFFParser: parsing Const_2
[TensorRT] INFO: UFFParser: parsing Const_3
[TensorRT] INFO: UFFParser: parsing Const_4
[TensorRT] INFO: UFFParser: parsing Const_5
[TensorRT] INFO: UFFParser: parsing Const_6
[TensorRT] INFO: UFFParser: parsing Const_7
[TensorRT] INFO: UFFParser: parsing Input_0
[TensorRT] INFO: UFFParser: parsing Conv_0
[TensorRT] INFO: UFFParser: parsing Binary_0
[TensorRT] INFO: UFFParser: parsing Activation_0
[TensorRT] INFO: UFFParser: parsing Pool_0
[TensorRT] INFO: UFFParser: parsing Conv_1
[TensorRT] INFO: UFFParser: parsing Binary_1
[TensorRT] INFO: UFFParser: parsing Activation_1
[TensorRT] INFO: UFFParser: parsing Pool_1
[TensorRT] INFO: UFFParser: parsing Const_8
[TensorRT] INFO: UFFParser: parsing Reshape_0
[TensorRT] INFO: UFFParser: parsing FullyConnected_0
[TensorRT] INFO: UFFParser: parsing Binary_2
[TensorRT] INFO: UFFParser: parsing Activation_2
[TensorRT] INFO: UFFParser: parsing FullyConnected_1
[TensorRT] INFO: UFFParser: parsing Binary_3
[TensorRT] INFO: UFFParser: parsing MarkOutput_0
[TensorRT] INFO: Original: 10 layers
[TensorRT] INFO: After dead-layer removal: 10 layers
[TensorRT] INFO: After scale fusion: 10 layers
[TensorRT] INFO: Fusing Binary_0 with activation Activation_0
[TensorRT] INFO: Fusing Binary_1 with activation Activation_1
[TensorRT] INFO: Fusing Binary_2 with activation Activation_2
[TensorRT] INFO: After conv-act fusion: 7 layers
[TensorRT] INFO: After tensor merging: 7 layers
[TensorRT] INFO: After concat removal: 7 layers
[TensorRT] ERROR: cudnnEngine.cpp (55) - Cuda Error in initializeCommonContext: 4
[TensorRT] ERROR: Failed to create engine
File “/usr/local/lib/python2.7/dist-packages/tensorrt/utils/_utils.py”, line 74, in uff_file_to_trt_engine
assert(engine)
File “/usr/local/lib/python2.7/dist-packages/tensorrt/examples/uff_mnist.py”, line 126, in
main()
File “/usr/local/lib/python2.7/dist-packages/tensorrt/examples/uff_mnist.py”, line 108, in main
File “/usr/local/lib/python2.7/dist-packages/tensorrt/utils/_utils.py”, line 82, in uff_file_to_trt_engine
raise AssertionError(‘UFF parsing failed on line {} in statement {}’.format(line, text))
AssertionError: UFF parsing failed on line 74 in statement assert(engine)
Do you have a GPU on the x86-machine?
Please also make sure the required driver and CUDA are well installed.
You can verify this via running CUDA sample code.
For example,
/usr/local/cuda-8.0/bin/cuda-install-samples-8.0.sh .
cd NVIDIA_CUDA-8.0_Samples/1_Utilities/deviceQuery
make
./deviceQuery
Yes there is a GPU. Below is the output of the command you suggested.
$ ./deviceQuery
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: “GeForce GTX 1080”
CUDA Driver Version / Runtime Version 8.0 / 8.0
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 8113 MBytes (8506769408 bytes)
(20) Multiprocessors, (128) CUDA Cores/MP: 2560 CUDA Cores
GPU Max Clock rate: 1848 MHz (1.85 GHz)
Memory Clock rate: 5005 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 2097152 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 8.0, CUDA Runtime Version = 8.0, NumDevs = 1, Device0 = GeForce GTX 1080
Result = PASS
Sorry for the inconvenience.
Could you check if it can be reproduced with TensorRT 3 GA package?
https://developer.nvidia.com/nvidia-tensorrt-download
Same result unfortunately.
$python uff_mnist.py TensorRT-3.0.1/python/data
[TensorRT] ERROR: cudnnEngine.cpp (56) - Cuda Error in initializeCommonContext: 4
File “/usr/lib/python2.7/dist-packages/tensorrt/utils/_utils.py”, line 133, in uff_file_to_trt_engine
assert(engine)
File “uff_mnist.py”, line 175, in
main()
File “uff_mnist.py”, line 157, in main
File “/usr/lib/python2.7/dist-packages/tensorrt/utils/_utils.py”, line 141, in uff_file_to_trt_engine
AssertionError: UFF parsing failed on line 133 in statement assert(engine)
Could you also share your driver and cuDNN version?
I have pasted the driver details above. Here are the cuDNN details.
$ nvcc --version
Copyright (c) 2005-2016 NVIDIA Corporation
Built on Tue_Jan_10_13:22:03_CST_2017
Cuda compilation tools, release 8.0, V8.0.61
nvcc is CUDA toolkit.
Please help to check cuDNN version via this command:
ll /usr/lib/aarch64-linux-gnu/libcudnn*
This is on a x86 machine so I don’t think there will be a aarach64 folder.
Anyways the problem got resolved. Looks like the new ga .deb creates the examples in /usr/lib/python instead of the /usr/local/lib/python. I was referring to the older files. It is working with the ga code. Thanks for your help.
-siddarth
Good to know it works now.
Thanks for your feedback.
Hi, I have the same error as you, but I do not understand what the ga code mean. My tensorRT was install at /usr/local/lib/python and my CUDA and cudnn version are described as below:
CUDA Driver Version / Runtime Version 9.0 / 9.0
lrwxrwxrwx 1 root root 17 13 14:14 libcudnn.so.7 → libcudnn.so.7.1.1
-rw-r–r-- 1 root root 306M 13 14:13 libcudnn.so.7.1.1
This issue is fixed in TensorRT v3.0.4.
Please install our latest TensorRT package to resolve this issue.
The problem is solved, you can run your program with super privilege, then you can pass the error
