Here I want to build a cuda engine from a deeplab tensorflow frozen graph for semantic segmentaion task. Here is how I make a UFF model:
OUTPUT_NAME = ["SemanticPredictions"]
forzen_tf_graph_file = 'frozen_inference_graph.pb'
# generate uff from frozen graph
uff_model = uff.from_tensorflow_frozen_model(
frozen_file=forzen_tf_graph_file,
output_nodes=OUTPUT_NAME,
output_filename='uff_tf_model.uff',
text=False,
and here is the result from the above code:
UFF Version 0.5.5
=== Automatically deduced input nodes ===
[name: "ImageTensor"
op: "Placeholder"
attr {
key: "_output_shapes"
value {
list {
shape {
dim {
dim {
dim {
dim {
attr {
key: "dtype"
value {
type: DT_UINT8
attr {
key: "shape"
value {
shape {
dim {
dim {
dim {
dim {
Using output node SemanticPredictions
Converting to UFF graph
Warning: No conversion function registered for layer: Slice yet.
Converting SemanticPredictions as custom op: Slice
Warning: No conversion function registered for layer: ArgMax yet.
Converting ArgMax as custom op: ArgMax
Warning: No conversion function registered for layer: ResizeBilinear yet.
Converting ResizeBilinear_3 as custom op: ResizeBilinear
Converting ResizeBilinear_2 as custom op: ResizeBilinear
Warning: No conversion function registered for layer: BatchToSpaceND yet.
Converting MobilenetV2/expanded_conv_16/depthwise/depthwise/BatchToSpaceND as custom op: BatchToSpaceND
Warning: No conversion function registered for layer: SpaceToBatchND yet.
Converting MobilenetV2/expanded_conv_16/depthwise/depthwise/SpaceToBatchND as custom op: SpaceToBatchND
Converting MobilenetV2/expanded_conv_15/depthwise/depthwise/BatchToSpaceND as custom op: BatchToSpaceND
Converting MobilenetV2/expanded_conv_15/depthwise/depthwise/SpaceToBatchND as custom op: SpaceToBatchND
Converting MobilenetV2/expanded_conv_14/depthwise/depthwise/BatchToSpaceND as custom op: BatchToSpaceND
Converting MobilenetV2/expanded_conv_14/depthwise/depthwise/SpaceToBatchND as custom op: SpaceToBatchND
Converting MobilenetV2/expanded_conv_13/depthwise/depthwise/BatchToSpaceND as custom op: BatchToSpaceND
Converting MobilenetV2/expanded_conv_13/depthwise/depthwise/SpaceToBatchND as custom op: SpaceToBatchND
Converting MobilenetV2/expanded_conv_12/depthwise/depthwise/BatchToSpaceND as custom op: BatchToSpaceND
Converting MobilenetV2/expanded_conv_12/depthwise/depthwise/SpaceToBatchND as custom op: SpaceToBatchND
Converting MobilenetV2/expanded_conv_11/depthwise/depthwise/BatchToSpaceND as custom op: BatchToSpaceND
Converting MobilenetV2/expanded_conv_11/depthwise/depthwise/SpaceToBatchND as custom op: SpaceToBatchND
Converting MobilenetV2/expanded_conv_10/depthwise/depthwise/BatchToSpaceND as custom op: BatchToSpaceND
Converting MobilenetV2/expanded_conv_10/depthwise/depthwise/SpaceToBatchND as custom op: SpaceToBatchND
Converting MobilenetV2/expanded_conv_9/depthwise/depthwise/BatchToSpaceND as custom op: BatchToSpaceND
Converting MobilenetV2/expanded_conv_9/depthwise/depthwise/SpaceToBatchND as custom op: SpaceToBatchND
Converting MobilenetV2/expanded_conv_8/depthwise/depthwise/BatchToSpaceND as custom op: BatchToSpaceND
Converting MobilenetV2/expanded_conv_8/depthwise/depthwise/SpaceToBatchND as custom op: SpaceToBatchND
Converting MobilenetV2/expanded_conv_7/depthwise/depthwise/BatchToSpaceND as custom op: BatchToSpaceND
Converting MobilenetV2/expanded_conv_7/depthwise/depthwise/SpaceToBatchND as custom op: SpaceToBatchND
Warning: No conversion function registered for layer: ExpandDims yet.
Converting ExpandDims_1 as custom op: ExpandDims
Converting ResizeBilinear as custom op: ResizeBilinear
Warning: No conversion function registered for layer: Cast yet.
Converting ToInt32 as custom op: Cast
Converting ToFloat_1 as custom op: Cast
Converting Cast as custom op: Cast
Converting ExpandDims as custom op: ExpandDims
Converting ResizeBilinear_1 as custom op: ResizeBilinear
No. nodes: 594
UFF Output written to uff_tf_model.uff
And here I am trying to build the engine:
TRT_LOGGER = tensorrt.Logger(tensorrt.Logger.WARNING)
# Loads a test case into the provided pagelocked_buffer.
def load_normalized_test_case(img_path, pagelocked_buffer):
# Flatten the image into a 1D array, normalize, and copy to pagelocked memory.
img = cv2.imread(img_path, 1)
np.copyto(pagelocked_buffer, img)
# For more information on TRT basics, refer to the introductory samples.
with tensorrt.Builder(TRT_LOGGER) as builder, builder.create_network() as network, tensorrt.UffParser() as parser:
builder.max_workspace_size = common.GiB(1)
# Parse the Uff Network
parser.register_input("Imagetensor", (513,289,3))
parser.register_output("SemanticPredictions")
parser.parse("uff_tf_model.uff", network)
# Build and return an engine.
engine = builder.build_cuda_engine(network)
# Build an engine, allocate buffers and create a stream.
# For more information on buffer allocation, refer to the introductory samples.
inputs, outputs, bindings, stream = common.allocate_buffers(engine)
with engine.create_execution_context() as context:
load_normalized_test_case(img_path='test.png', pagelocked_buffer=inputs[0].host)
# For more information on performing inference, refer to the introductory samples.
# The common.do_inference function will return a list of outputs - we only have one in this case.
seg_map = common.do_inference(context, bindings=bindings, inputs=inputs, outputs=outputs, stream=stream)
And here is the output from the last script when I run it:
[TensorRT] ERROR: UFFParser: Validator error: ResizeBilinear_3: Unsupported operation _ResizeBilinear
[TensorRT] ERROR: Network must have at least one output
File "/home/pedram/catkin-ws/src/seg_proj/scripts/test.py", line 323, in <module>
File "/home/pedram/catkin-ws/src/seg_proj/scripts/common.py", line 124, in allocate_buffers
for binding in engine:
TypeError: 'NoneType' object is not iterable
So because of these errors, after the parsing process, the ‘network’ object is empty and therefore builder.build_cuda_engine(network) returns None. I cannot figure out what is going wrong here.
P.S: I am using:
Ubuntu 16.04
GPU: Nvidia 1050ti
Nvidia driver version: 384.130
Cuda: 9.0
Cudnn: 7
Python: 2.7
Tensroflow version: 1.13.0rc
TensorRT version: 5.0.2.6
The Deeplab frozen graph: http://download.tensorflow.org/models/deeplabv3_mnv2_cityscapes_train_2018_02_05.tar.gz
The test image could be sth like this: https://i.ibb.co/rwRZMvq/rsz-louvl.png
