How to convert to uff from frozen graph pb
I found the script convert_to_uff.py (in dist-packages), but when I try to use it:
python3 convert_to_uff.py frozen_inference_graph.pb -o output.uff
It tells me:
File “convert_to_uff.py”, line 96, in
main()
File “convert_to_uff.py”, line 92, in main
debug_mode=args.debug
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py”, line 229, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py”, line 178, in from_tensorflow
debug_mode=debug_mode)
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py”, line 94, in convert_tf2uff_graph
uff_graph, input_replacements, debug_mode=debug_mode)
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py”, line 79, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes, debug_mode=debug_mode)
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py”, line 41, in convert_layer
fields = cls.parse_tf_attrs(tf_node.attr)
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py”, line 222, in parse_tf_attrs
return {key: cls.parse_tf_attr_value(val) for key, val in attrs.items() if val is not None and val.WhichOneof(‘value’) is not None}
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py”, line 218, in parse_tf_attr_value
return cls.convert_tf2uff_field(code, val)
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py”, line 190, in convert_tf2uff_field
return TensorFlowToUFFConverter.convert_tf2numpy_dtype(val)
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py”, line 103, in convert_tf2numpy_dtype
return tf.as_dtype(dtype).as_numpy_dtype
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py”, line 126, in as_numpy_dtype
return _TF_TO_NP[self._type_enum]
KeyError: 20
any ideas? am I using the wrong syntax?
I understand some operations are not yet convertible from tensorflow to trt, but I am converting an ssd_inception_v2 network to trt, which I know exists since it is one of the networks in the examples
It looks like there are some missing argument in your command:
Please use the similar like this:
$ sudo python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py [your/pb/file] -o [output/uff/name]] -O [output/layer/name] -p /usr/src/tensorrt/samples/sampleUffSSD/config.py
Or you can check this tutorial for ssd_inception_v2 network directly:
https://github.com/AastaNV/TRT_object_detection
Using output node /home/neural-networks/models/convertToTRT/testTRT.layer
Converting to UFF graph
File “/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py”, line 96, in
main()
File “/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py”, line 92, in main
File “/usr/lib/python3.6/dist-packages/uff/bin/…/…/uff/converters/tensorflow/conversion_helpers.py”, line 229, in from_tensorflow_frozen_model
File “/usr/lib/python3.6/dist-packages/uff/bin/…/…/uff/converters/tensorflow/conversion_helpers.py”, line 178, in from_tensorflow
File “/usr/lib/python3.6/dist-packages/uff/bin/…/…/uff/converters/tensorflow/converter.py”, line 94, in convert_tf2uff_graph
File “/usr/lib/python3.6/dist-packages/uff/bin/…/…/uff/converters/tensorflow/converter.py”, line 62, in convert_tf2uff_node
raise UffException(str(name) + " was not found in the graph. Please use the -l option to list nodes in the graph.")
uff.model.exceptions.UffException: /home/neural-networks/models/convertToTRT/testTRT.layer was not found in the graph. Please use the -l option to list nodes in the graph.
I am confused… It sounds like it is looking for the file it is supposed to be outputting, testTRT.layer.
this was my input:
sudo python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py frozen_inference_graph.pb -o /home/neural-networks/models/convertToTRT/testTRT.uff -O /home/neural-networks/models/convertToTRT/testTRT.layer -p /home/TensorRT-7.0.0.11/samples/sampleUffSSD/config.py
If I skip the layer part:
sudo python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py frozen_inference_graph.pb -o /home/neural-networks/models/convertToTRT/testTRT.uff -p /home/TensorRT-7.0.0.11/samples/sampleUffSSD/config.py
it gives me a .uff file.
Unfortunately running this using the detect-net example gives me:
:~/jetson-inference/python/examples$ ./detectnet-camera.py --camera /dev/video0 --network=raccoonnet
jetson.inference.__init__.py
jetson.inference -- initializing Python 2.7 bindings...
jetson.inference -- registering module types...
jetson.inference -- done registering module types
jetson.inference -- done Python 2.7 binding initialization
jetson.utils.__init__.py
jetson.utils -- initializing Python 2.7 bindings...
jetson.utils -- registering module functions...
jetson.utils -- done registering module functions
jetson.utils -- registering module types...
jetson.utils -- done registering module types
jetson.utils -- done Python 2.7 binding initialization
jetson.inference -- PyTensorNet_New()
jetson.inference -- PyDetectNet_Init()
jetson.inference -- detectNet loading network using argv command line params
jetson.inference -- detectNet.__init__() argv[0] = './detectnet-camera.py'
jetson.inference -- detectNet.__init__() argv[1] = '--camera'
jetson.inference -- detectNet.__init__() argv[2] = '/dev/video0'
jetson.inference -- detectNet.__init__() argv[3] = '--network=raccoonnet'
detectNet -- loading detection network model from:
          -- model        networks/SSD-Raccoonnet/ssd_raccoon.uff
          -- input_blob   'Input'
          -- output_blob  'NMS'
          -- output_count 'NMS_1'
          -- class_labels networks/SSD-Raccoonnet/ssd_raccoon_labels.txt
          -- threshold    0.500000
          -- batch_size   1
[TRT]   TensorRT version 6.0.1
[TRT]   loading NVIDIA plugins...
[TRT]   Plugin Creator registration succeeded - GridAnchor_TRT
[TRT]   Plugin Creator registration succeeded - GridAnchorRect_TRT
[TRT]   Plugin Creator registration succeeded - NMS_TRT
[TRT]   Plugin Creator registration succeeded - Reorg_TRT
[TRT]   Plugin Creator registration succeeded - Region_TRT
[TRT]   Plugin Creator registration succeeded - Clip_TRT
[TRT]   Plugin Creator registration succeeded - LReLU_TRT
[TRT]   Plugin Creator registration succeeded - PriorBox_TRT
[TRT]   Plugin Creator registration succeeded - Normalize_TRT
[TRT]   Plugin Creator registration succeeded - RPROI_TRT
[TRT]   Plugin Creator registration succeeded - BatchedNMS_TRT
[TRT]   Could not register plugin creator:  FlattenConcat_TRT in namespace:
[TRT]   completed loading NVIDIA plugins.
[TRT]   detected model format - UFF  (extension '.uff')
[TRT]   desired precision specified for GPU: FASTEST
[TRT]   requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT]   native precisions detected for GPU:  FP32, FP16, INT8
[TRT]   selecting fastest native precision for GPU:  FP16
[TRT]   attempting to open engine cache file /usr/local/bin/networks/SSD-Raccoonnet/ssd_raccoon.uff.1.1.GPU.FP16.engine
[TRT]   cache file not found, profiling network model on device GPU
[TRT]   device GPU, loading /usr/bin/ /usr/local/bin/networks/SSD-Raccoonnet/ssd_raccoon.uff
[TRT]   UffParser: Validator error: FeatureExtractor/MobilenetV2/layer_19_2_Conv2d_4_3x3_s2_256/BatchNorm/FusedBatchNormV3: Unsupported operation _FusedBatchNormV3
[TRT]   failed to parse UFF model '/usr/local/bin/networks/SSD-Raccoonnet/ssd_raccoon.uff'
[TRT]   device GPU, failed to load networks/SSD-Raccoonnet/ssd_raccoon.uff
detectNet -- failed to initialize.
jetson.inference -- detectNet failed to load built-in network 'raccoonnet'
PyTensorNet_Dealloc()
  File "./detectnet-camera.py", line 49, in <module>
    net = jetson.inference.detectNet(opt.network, sys.argv, opt.threshold)
Exception: jetson.inference -- detectNet failed to load network
If I take the “.engine” file from a the mobilenet network and put it into my network’s /data/networks/SSD-NETWORK/ folder, then the program starts, but does not use my network, instead using mobilenet’s. But when I generated my uff, it did not produce a .engine file
Is it possible that the issue is at line 54( Unsupported operation _FusedBatchNormV3)? If so, it is odd that only that one had problems, considering there are also FusedBatchNormV1 ,2 ,and 4 operations in the graph.pbtxt file
The error in comment#4 shows that the output layer is not specified or incorrectly passed.
For ssd_inception_v2 model, the output layer name should be NMS.
Ex.
sudo python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py frozen_inference_graph.pb -O NMS -p config.py
You can also check our README for more information:
/usr/src/tensorrt/samples/sampleUffSSD/README.md
thanks, Unfortunately there are still 2 problems. First, the converter still complains about the network:
~/convertToTRT$ sudo python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py frozen_inference_graph.pb -O NMS -p /usr/src/tensorrt/samples/sampleUffSSD/config.py
2020-01-17 07:53:40.140960: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
Loading frozen_inference_graph.pb
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/bin/../../uff/converters/tensorflow/conversion_helpers.py:227: The name tf.gfile.GFile is deprecated. Please use tf.io.gfile.GFile instead.
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
WARNING: To create TensorRT plugin nodes, please use the `create_plugin_node` function instead.
UFF Version 0.6.5
=== Automatically deduced input nodes ===
[name: "Input"
op: "Placeholder"
input: "Cast"
attr {
  key: "dtype"
  value {
    type: DT_FLOAT
attr {
  key: "shape"
  value {
    shape {
      dim {
      dim {
      dim {
      dim {
Using output node NMS
Warning: No conversion function registered for layer: NMS_TRT yet.
Converting NMS as custom op: NMS_TRT
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/bin/../../uff/converters/tensorflow/converter.py:179: The name tf.AttrValue is deprecated. Please use tf.compat.v1.AttrValue instead.
Warning: No conversion function registered for layer: Cast yet.
Converting Cast as custom op: Cast
Warning: No conversion function registered for layer: FlattenConcat_TRT yet.
Converting concat_box_loc as custom op: FlattenConcat_TRT
Warning: No conversion function registered for layer: FusedBatchNormV3 yet.
Converting FeatureExtractor/MobilenetV2/layer_19_2_Conv2d_5_3x3_s2_128/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
Converting FeatureExtractor/MobilenetV2/layer_19_1_Conv2d_5_1x1_64/BatchNorm/FusedBatchNormV3 as custom op: FusedBatchNormV3
etc…
The second is that the inference code also still has that problem:
Also it seems to be weird that the convert code is complaining about tf1.14 when tf2 doesn’t seem to be officially supported on xavier (at least I was unable to find an official installation guide). Installing tf2 via:
sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v43 tensorflow-gpu==2
causes problems right away:
2020-01-17 11:19:57.588473: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
  File "/usr/lib/python3.6/dist-packages/uff/bin/../../uff/converters/tensorflow/conversion_helpers.py", line 18, in <module>
    from tensorflow import GraphDef
ImportError: cannot import name 'GraphDef'
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py", line 18, in <module>
    import uff
  File "/usr/lib/python3.6/dist-packages/uff/bin/../../uff/__init__.py", line 2, in <module>
    from uff.converters.tensorflow.conversion_helpers import from_tensorflow  # noqa
  File "/usr/lib/python3.6/dist-packages/uff/bin/../../uff/converters/tensorflow/conversion_helpers.py", line 23, in <module>
    https://www.tensorflow.org/install/""".format(err))
ImportError: ERROR: Failed to import module (cannot import name 'GraphDef')
Please make sure you have TensorFlow installed.
For installation instructions, see:
ok so the problem isnt tf1.14. it seems to have something to do with the converter not knowing what a batch normalization is…
FusedBatchNormV3 is a new operation in TensorFlow and doesn’t have TensorRT support yet.
A possible workaround is to convert the model into onnx format first.
Could you check if this comment works for you?
https://devtalk.nvidia.com/default/topic/1066445/tensorrt/tensorrt-6-0-1-tensorflow-1-14-no-conversion-function-registered-for-layer-fusedbatchnormv3-yet/post/5403567/#5403567
CLEI/HECI codes are 10 character alpha numeric codes that have a 1:1 relationship to a product identifier (part number).
there are some other codes that are used for shopping as covenant eyes promo code and also other promo codes and discount codes
