Benchmarks Targeted for Jetson TX2
I’m studying about ‘the Autonomous landing of small UAV’ using jetson nano.
I built using SSD MobileNet v2 for it and done it.
But FPS is too low as 0.5~0.8 using SSD-MobileNet v2.
So I’ve changed the board to TX2 but it’s same.
Then, I’ve tried to using TensorRT, Benchmars etc.
I’ve just found the git-hub as below,
GitHub - NVIDIA-AI-IOT/jetson_benchmarks: Jetson Benchmark.
But I got the error msg as below, but I have no idea how to solve it.
Please help me.
============error=========================
kookmin-uav@ubuntu:~/jetson_benchmarks$ sudo python3 benchmark.py --all --csv_file_path /home/kookmin-uav/jetson_benchmarks/benchmark_csv/tx2-nano-benchmarks.csv \
                        --model_dir /home/kookmin-uav/jetson_benchmarks/models \
                        --jetson_devkit tx2 \
                        --gpu_freq 1122000000 --power_mode 3 --precision fp16
Please close all other applications and Press Enter to continue…
Setting Jetson tx2 in max performance mode
File “benchmark.py”, line 130, in
main()
File “benchmark.py”, line 28, in main
system_check.run_set_clocks_withDVFS()
File “/home/kookmin-uav/jetson_benchmarks/utils/utilities.py”, line 34, in run_set_clocks_withDVFS
self.set_clocks_withDVFS(frequency=self.gpu_freq, device=‘gpu’)
File “/home/kookmin-uav/jetson_benchmarks/utils/utilities.py”, line 74, in set_clocks_withDVFS
from_freq = self.read_internal_register(register=freq_register_, device=device)
File “/home/kookmin-uav/jetson_benchmarks/utils/utilities.py”, line 100, in read_internal_register
reg_read = open(register, “r”)
FileNotFoundError: [Errno 2] No such file or directory: ‘/sys/devices/gpu.0/devfreq/17000000.gp10bnafll_gpc0/rate’
Please add --jetson_clocks to enable the clock with jetson_clocks instead.
For example:
$ sudo python3 benchmark.py --all --csv_file_path /home/nvidia/topic_232954/jetson_benchmarks/benchmark_csv/tx2-nano-benchmarks.csv --jetson_clocks
Thank you so much your help!
I’ve just make it run!
By the way, I have one more question.
I’d like to ask you this benchmark can use with pre-trained model by tf2?
Actually I trained SSD-MobileNet v2 by tf2 for UAV’s autonomous landing.
This model can detect helipad BUT FPS is appx. 0.5 with Jetson nano.
So I would love to make it higher but have no idea.
I’m trying to use Jetson-inference, too but I don’t know how to use my pre-trained model.
Not using benchmark is okay, If I can make FPS higher.
Please help me how to solve this problem.
Thank you so much!
You can use trtexec for the benchmark.
Below is a tutorial that converts a TF2 model into TensorRT for your reference:
