elhe
July 14, 2021, 1:41pm
#1
I would like to capture an image, debayer it, postprocess it and then run TensorRT with the result.
My current plan is to use gstreamer to capture it, then opencv to postprocess TensorRT for the inference. That should use the ISP with gstreamer and the cuda cores with TensorRT. But is there a better option, with more hardware acceleration on the jetson nano?
The optimal solution is DeepStream SDK. Please check
NVIDIA Metropolis Documentation
You can install the package through SDKManager, and then start with deepstream-app by running the command:
/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app$ deepstream-app -c source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
elhe
July 15, 2021, 3:27am
#4
Thanks I will have a look into Deepstream SDK
elhe
July 15, 2021, 2:52pm
#5
When I try to execute
/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-app$ sudo deepstream-app -c ../../../../samples/configs/deepstream-app/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
I get the following error message:
** ERROR: <create_multi_source_bin:1320>: Failed to create element 'src_bin_muxer'
** ERROR: <create_multi_source_bin:1411>: create_multi_source_bin failed
** ERROR: <create_pipeline:1294>: create_pipeline failed
** ERROR: <main:636>: Failed to create pipeline
Quitting
App run failed
Please try to go to the same folder and run the command. See if this works.
And may try without sudo .
elhe
July 16, 2021, 4:33am
#7
I tried:
I tried it with and without sudo and had the same result as mentioned above.
Please remove cache for a try:
$ rm .cache/gstreamer-1.0/registry.aarch64.bin
If it still does not work, would suggest do clean re-flash. The command should work by default.
elhe
July 16, 2021, 1:38pm
#9
Ok thanks that helped.
I now only face the problem described in Is there a way to execute deepstream-test1 with X11 forwarding
system
closed
September 19, 2021, 7:58am
#11
