• Hardware Platform (Jetson / GPU) Nano
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4
• TensorRT Version NA
I intend to use gst-dsexample in jetson nano , however I cannot build it directly from docker version of deepstream-samples. Same problem was there in dGpu but there was deepstream-devel which could be used successfully there. Now there is no specific deepstream-devel docker image. Do you recommend in downloading deepstream and go about it , instead of using docker
