Deepstream on Jetson Nano
For installing deepstream on Jetson nano with JetPack 4.6 do I just need to pull the docker image by this command?
docker pull nvcr.io/nvidia/deepstream-l4t:6.0.1-base
Or do I need the 6.0.1 -IOT or 6.0.1-examples image from the link below?
And after pulling image what should I do next?
We are moving this post to the DeepStream SDK forum to get better help on setup related.
Hi @dhairyasachdeva11 ,
It depends on your purpose, you can find the difference between the different container here: Docker Containers — DeepStream 6.2 Release documentation (nvidia.com)
