If I were wanting to compare compute throughput (FP32 add throughput vs. bf16 add throughput), I would want to get memory considerations mostly out of, or minimized in, my test code.
At the moment I don’t have convenient access to an A100 or A10. I can conveniently get to an L4 GPU, cc8.9, and I note that it has the same throughput for bf16 and fp32. Therefore, I would want to do half as many bf16x2 operations as I do FP32 operations, and see if those time approximately equal. According to my test case, they do:
# cat t223.cu
#include <cuda_bf16.h>
const int al = 8;
template <typename T>
__global__ void k(T *d, int l){
T a[al];
for (int i = 0; i < al; i++) a[i] = d[i];
T r;
for (int i = 0; i < l; i++)
for (int j = 0; j < al; j++)
r += a[j];
d[threadIdx.x] = r;
using ft1 = float;
int main(){
ft1 *d;
const int bs = 256;
const int nb = 1024;
cudaMalloc(&d, bs * sizeof(ft1));
const int l=1000;
k<<<nb,bs>>>(d, l);
cudaDeviceSynchronize();
k<<<nb/2,bs>>>(reinterpret_cast<__nv_bfloat162 *>(d), l);
# nvcc -o t223 t223.cu -arch=sm_89
# nsys profile --stats=true ./t223
Generating '/tmp/nsys-report-d985.qdstrm'
[1/8] [========================100%] report48.nsys-rep
[2/8] [========================100%] report48.sqlite
[3/8] Executing 'nvtx_sum' stats report
SKIPPED: /root/bobc/report48.sqlite does not contain NV Tools Extension (NVTX) data.
[4/8] Executing 'osrt_sum' stats report
Time (%) Total Time (ns) Num Calls Avg (ns) Med (ns) Min (ns) Max (ns) StdDev (ns) Name
51.8 213,610,012 476 448,760.5 14,893.0 1,033 78,773,099 4,104,860.2 ioctl
41.5 170,863,015 11 15,533,001.4 3,030,461.0 4,832 100,130,001 29,513,044.4 poll
5.7 23,639,646 29 815,160.2 5,600.0 2,114 23,450,998 4,353,491.9 fopen
0.5 2,039,590 27 75,540.4 13,036.0 10,947 1,252,944 236,605.2 mmap64
0.2 789,453 44 17,942.1 16,729.5 7,052 31,456 4,501.9 open64
0.1 402,621 9 44,735.7 41,305.0 28,960 74,022 12,741.7 sem_timedwait
0.1 270,289 2 135,144.5 135,144.5 113,872 156,417 30,083.9 pthread_create
0.0 162,570 14 11,612.1 5,156.0 2,484 70,706 17,556.5 mmap
0.0 84,152 48 1,753.2 67.0 58 80,782 11,649.5 fgets
0.0 72,314 23 3,144.1 3,253.0 1,625 5,540 911.7 fclose
0.0 53,886 51 1,056.6 1,033.0 730 1,740 183.6 fcntl
0.0 40,425 6 6,737.5 6,219.5 2,922 10,447 2,908.5 open
0.0 32,301 13 2,484.7 2,047.0 1,271 6,013 1,297.8 read
0.0 30,735 5 6,147.0 5,975.0 4,644 7,361 1,081.0 munmap
0.0 28,165 10 2,816.5 2,739.0 1,400 4,747 877.8 write
0.0 17,115 2 8,557.5 8,557.5 5,540 11,575 4,267.4 socket
0.0 16,263 1 16,263.0 16,263.0 16,263 16,263 0.0 fread
0.0 14,185 1 14,185.0 14,185.0 14,185 14,185 0.0 connect
0.0 9,193 1 9,193.0 9,193.0 9,193 9,193 0.0 pipe2
0.0 6,395 7 913.6 911.0 844 987 56.0 dup
0.0 2,345 1 2,345.0 2,345.0 2,345 2,345 0.0 bind
0.0 1,417 1 1,417.0 1,417.0 1,417 1,417 0.0 listen
[5/8] Executing 'cuda_api_sum' stats report
99.7 188,588,879 1 188,588,879.0 188,588,879.0 188,588,879 188,588,879 0.0 cudaMalloc
0.2 311,180 2 155,590.0 155,590.0 147,560 163,620 11,356.1 cudaDeviceSynchronize
0.1 197,077 2 98,538.5 98,538.5 28,755 168,322 98,688.8 cudaLaunchKernel
0.0 1,365 1 1,365.0 1,365.0 1,365 1,365 0.0 cuModuleGetLoadingMode
[6/8] Executing 'cuda_gpu_kern_sum' stats report
Time (%) Total Time (ns) Instances Avg (ns) Med (ns) Min (ns) Max (ns) StdDev (ns) Name
52.9 164,352 1 164,352.0 164,352.0 164,352 164,352 0.0 void k<float>(T1 *, int)
47.1 146,048 1 146,048.0 146,048.0 146,048 146,048 0.0 void k<__nv_bfloat162>(T1 *, int)
[7/8] Executing 'cuda_gpu_mem_time_sum' stats report
SKIPPED: /root/bobc/report48.sqlite does not contain GPU memory data.
[8/8] Executing 'cuda_gpu_mem_size_sum' stats report
Generated:
/root/bobc/report48.nsys-rep
CUDA 12.2
For reference, here is the SASS. I haven’t studied it carefully, but there don’t appear to be obvious optimizations done by the compiler that would skew this:
# cuobjdump -sass ./t223
Fatbin elf code:
arch = sm_89
code version = [1,7]
host = linux
compile_size = 64bit
code for sm_89
Fatbin elf code:
arch = sm_89
host = linux
code for sm_89
Function : _Z1kI14__nv_bfloat162EvPT_i
.headerflags @"EF_CUDA_TEXMODE_UNIFIED EF_CUDA_64BIT_ADDRESS EF_CUDA_SM89 EF_CUDA_VIRTUAL_SM(EF_CUDA_SM89)"
/*0000*/ IMAD.MOV.U32 R1, RZ, RZ, c[0x0][0x28] ; /* 0x00000a00ff017624 */
/* 0x000fc400078e00ff */
/*0010*/ IMAD.MOV.U32 R8, RZ, RZ, c[0x0][0x168] ; /* 0x00005a00ff087624 */
/* 0x000fe200078e00ff */
/*0020*/ ULDC.64 UR4, c[0x0][0x118] ; /* 0x0000460000047ab9 */
/* 0x000fc80000000a00 */
/*0030*/ ISETP.GE.AND P0, PT, R8, 0x1, PT ; /* 0x000000010800780c */
/* 0x000fda0003f06270 */
/*0040*/ @!P0 BRA 0x440 ; /* 0x000003f000008947 */
/* 0x000fea0003800000 */
/*0050*/ IADD3 R12, R8, -0x1, RZ ; /* 0xffffffff080c7810 */
/* 0x000fe20007ffe0ff */
/*0060*/ IMAD.MOV.U32 R10, RZ, RZ, c[0x0][0x160] ; /* 0x00005800ff0a7624 */
/* 0x000fe400078e00ff */
/*0070*/ IMAD.MOV.U32 R11, RZ, RZ, c[0x0][0x164] ; /* 0x00005900ff0b7624 */
/*0080*/ ISETP.GE.U32.AND P1, PT, R12, 0x3, PT ; /* 0x000000030c00780c */
/* 0x000fe40003f26070 */
/*0090*/ LOP3.LUT R8, R8, 0x3, RZ, 0xc0, !PT ; /* 0x0000000308087812 */
/* 0x000fe400078ec0ff */
/*00a0*/ LDG.E R0, [R10.64] ; /* 0x000000040a007981 */
/* 0x000168000c1e1900 */
/*00b0*/ LDG.E R2, [R10.64+0x4] ; /* 0x000004040a027981 */
/* 0x000162000c1e1900 */
/*00c0*/ ISETP.NE.AND P0, PT, R8, RZ, PT ; /* 0x000000ff0800720c */
/* 0x000fc60003f05270 */
/*00d0*/ LDG.E R3, [R10.64+0x8] ; /* 0x000008040a037981 */
/*00e0*/ LDG.E R4, [R10.64+0xc] ; /* 0x00000c040a047981 */
/*00f0*/ LDG.E R5, [R10.64+0x10] ; /* 0x000010040a057981 */
/*0100*/ LDG.E R6, [R10.64+0x14] ; /* 0x000014040a067981 */
/*0110*/ LDG.E R7, [R10.64+0x18] ; /* 0x000018040a077981 */
/*0120*/ LDG.E R9, [R10.64+0x1c] ; /* 0x00001c040a097981 */
/*0130*/ @!P1 BRA 0x380 ; /* 0x0000024000009947 */
/*0140*/ IADD3 R10, -R8, c[0x0][0x168], RZ ; /* 0x00005a00080a7a10 */
/* 0x001fc60007ffe1ff */
/*0150*/ HFMA2.BF16_V2 R11, R11, 1, 1, R0 ; /* 0x3f803f800b0b7831 */
/* 0x020fe20000200000 */
/*0160*/ IADD3 R10, R10, -0x4, RZ ; /* 0xfffffffc0a0a7810 */
/* 0x000fc60007ffe0ff */
/*0170*/ HFMA2.BF16_V2 R11, R11, 1, 1, R2 ; /* 0x3f803f800b0b7831 */
/* 0x000fe20000200002 */
/*0180*/ ISETP.NE.AND P1, PT, R10, RZ, PT ; /* 0x000000ff0a00720c */
/* 0x000fc60003f25270 */
/*0190*/ HFMA2.BF16_V2 R11, R11, 1, 1, R3 ; /* 0x3f803f800b0b7831 */
/* 0x000fc80000200003 */
/*01a0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R4 ; /* 0x3f803f800b0b7831 */
/* 0x000fc80000200004 */
/*01b0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R5 ; /* 0x3f803f800b0b7831 */
/* 0x000fc80000200005 */
/*01c0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R6 ; /* 0x3f803f800b0b7831 */
/* 0x000fc80000200006 */
/*01d0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R7 ; /* 0x3f803f800b0b7831 */
/* 0x000fc80000200007 */
/*01e0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R9 ; /* 0x3f803f800b0b7831 */
/* 0x000fc80000200009 */
/*01f0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R0 ; /* 0x3f803f800b0b7831 */
/* 0x000fc80000200000 */
/*0200*/ HFMA2.BF16_V2 R11, R11, 1, 1, R2 ; /* 0x3f803f800b0b7831 */
/* 0x000fc80000200002 */
/*0210*/ HFMA2.BF16_V2 R11, R11, 1, 1, R3 ; /* 0x3f803f800b0b7831 */
/*0220*/ HFMA2.BF16_V2 R11, R11, 1, 1, R4 ; /* 0x3f803f800b0b7831 */
/*0230*/ HFMA2.BF16_V2 R11, R11, 1, 1, R5 ; /* 0x3f803f800b0b7831 */
/*0240*/ HFMA2.BF16_V2 R11, R11, 1, 1, R6 ; /* 0x3f803f800b0b7831 */
/*0250*/ HFMA2.BF16_V2 R11, R11, 1, 1, R7 ; /* 0x3f803f800b0b7831 */
/*0260*/ HFMA2.BF16_V2 R11, R11, 1, 1, R9 ; /* 0x3f803f800b0b7831 */
/*0270*/ HFMA2.BF16_V2 R11, R11, 1, 1, R0 ; /* 0x3f803f800b0b7831 */
/*0280*/ HFMA2.BF16_V2 R11, R11, 1, 1, R2 ; /* 0x3f803f800b0b7831 */
/*0290*/ HFMA2.BF16_V2 R11, R11, 1, 1, R3 ; /* 0x3f803f800b0b7831 */
/*02a0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R4 ; /* 0x3f803f800b0b7831 */
/*02b0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R5 ; /* 0x3f803f800b0b7831 */
/*02c0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R6 ; /* 0x3f803f800b0b7831 */
/*02d0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R7 ; /* 0x3f803f800b0b7831 */
/*02e0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R9 ; /* 0x3f803f800b0b7831 */
/*02f0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R0 ; /* 0x3f803f800b0b7831 */
/*0300*/ HFMA2.BF16_V2 R11, R11, 1, 1, R2 ; /* 0x3f803f800b0b7831 */
/*0310*/ HFMA2.BF16_V2 R11, R11, 1, 1, R3 ; /* 0x3f803f800b0b7831 */
/*0320*/ HFMA2.BF16_V2 R11, R11, 1, 1, R4 ; /* 0x3f803f800b0b7831 */
/*0330*/ HFMA2.BF16_V2 R11, R11, 1, 1, R5 ; /* 0x3f803f800b0b7831 */
/*0340*/ HFMA2.BF16_V2 R11, R11, 1, 1, R6 ; /* 0x3f803f800b0b7831 */
/*0350*/ HFMA2.BF16_V2 R11, R11, 1, 1, R7 ; /* 0x3f803f800b0b7831 */
/*0360*/ HFMA2.BF16_V2 R11, R11, 1, 1, R9 ; /* 0x3f803f800b0b7831 */
/* 0x000fe20000200009 */
/*0370*/ @P1 BRA 0x150 ; /* 0xfffffdd000001947 */
/* 0x000fea000383ffff */
/*0380*/ @!P0 BRA 0x440 ; /* 0x000000b000008947 */
/*0390*/ HFMA2.BF16_V2 R11, R11, 1, 1, R0 ; /* 0x3f803f800b0b7831 */
/* 0x021fe20000200000 */
/*03a0*/ IADD3 R8, R8, -0x1, RZ ; /* 0xffffffff08087810 */
/*03b0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R2 ; /* 0x3f803f800b0b7831 */
/*03c0*/ ISETP.NE.AND P0, PT, R8, RZ, PT ; /* 0x000000ff0800720c */
/*03d0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R3 ; /* 0x3f803f800b0b7831 */
/*03e0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R4 ; /* 0x3f803f800b0b7831 */
/*03f0*/ HFMA2.BF16_V2 R11, R11, 1, 1, R5 ; /* 0x3f803f800b0b7831 */
/*0400*/ HFMA2.BF16_V2 R11, R11, 1, 1, R6 ; /* 0x3f803f800b0b7831 */
/*0410*/ HFMA2.BF16_V2 R11, R11, 1, 1, R7 ; /* 0x3f803f800b0b7831 */
/*0420*/ HFMA2.BF16_V2 R11, R11, 1, 1, R9 ; /* 0x3f803f800b0b7831 */
/*0430*/ @P0 BRA 0x390 ; /* 0xffffff5000000947 */
/*0440*/ S2R R2, SR_TID.X ; /* 0x0000000000027919 */
/* 0x020e620000002100 */
/*0450*/ IMAD.MOV.U32 R3, RZ, RZ, 0x4 ; /* 0x00000004ff037424 */
/* 0x000fc800078e00ff */
/*0460*/ IMAD.WIDE.U32 R2, R2, R3, c[0x0][0x160] ; /* 0x0000580002027625 */
/* 0x002fca00078e0003 */
/*0470*/ STG.E [R2.64], R11 ; /* 0x0000000b02007986 */
/* 0x000fe2000c101904 */
/*0480*/ EXIT ; /* 0x000000000000794d */
/*0490*/ BRA 0x490; /* 0xfffffff000007947 */
/* 0x000fc0000383ffff */
/*04a0*/ NOP; /* 0x0000000000007918 */
/* 0x000fc00000000000 */
/*04b0*/ NOP; /* 0x0000000000007918 */
/*04c0*/ NOP; /* 0x0000000000007918 */
/*04d0*/ NOP; /* 0x0000000000007918 */
/*04e0*/ NOP; /* 0x0000000000007918 */
/*04f0*/ NOP; /* 0x0000000000007918 */
/*0500*/ NOP; /* 0x0000000000007918 */
/*0510*/ NOP; /* 0x0000000000007918 */
/*0520*/ NOP; /* 0x0000000000007918 */
/*0530*/ NOP; /* 0x0000000000007918 */
/*0540*/ NOP; /* 0x0000000000007918 */
/*0550*/ NOP; /* 0x0000000000007918 */
/*0560*/ NOP; /* 0x0000000000007918 */
/*0570*/ NOP; /* 0x0000000000007918 */
Function : _Z1kIfEvPT_i
/*0000*/ MOV R1, c[0x0][0x28] ; /* 0x00000a0000017a02 */
/* 0x000fc40000000f00 */
/*0010*/ MOV R8, c[0x0][0x168] ; /* 0x00005a0000087a02 */
/* 0x000fe20000000f00 */
/* 0x000fc60000000a00 */
/* 0x000fe40007ffe0ff */
/*0060*/ MOV R10, c[0x0][0x160] ; /* 0x00005800000a7a02 */
/* 0x000fe40000000f00 */
/*0070*/ ISETP.GE.U32.AND P1, PT, R12, 0x3, PT ; /* 0x000000030c00780c */
/*0080*/ MOV R11, c[0x0][0x164] ; /* 0x00005900000b7a02 */
/* 0x000fc600078ec0ff */
/*00b0*/ ISETP.NE.AND P0, PT, R8, RZ, PT ; /* 0x000000ff0800720c */
/*00c0*/ LDG.E R2, [R10.64+0x4] ; /* 0x000004040a027981 */
/*0140*/ IADD3 R12, -R8, c[0x0][0x168], RZ ; /* 0x00005a00080c7a10 */
/* 0x000fc60007ffe1ff */
/*0150*/ FADD R11, R0, R11 ; /* 0x0000000b000b7221 */
/* 0x021fe20000000000 */
/*0160*/ IADD3 R12, R12, -0x4, RZ ; /* 0xfffffffc0c0c7810 */
/*0170*/ FADD R10, R2, R11 ; /* 0x0000000b020a7221 */
/* 0x000fe20000000000 */
/*0180*/ ISETP.NE.AND P1, PT, R12, RZ, PT ; /* 0x000000ff0c00720c */
/*0190*/ FADD R11, R3, R10 ; /* 0x0000000a030b7221 */
/* 0x000fc80000000000 */
/*01a0*/ FADD R10, R4, R11 ; /* 0x0000000b040a7221 */
/*01b0*/ FADD R11, R5, R10 ; /* 0x0000000a050b7221 */
/*01c0*/ FADD R10, R6, R11 ; /* 0x0000000b060a7221 */
/*01d0*/ FADD R10, R7, R10 ; /* 0x0000000a070a7221 */
/*01e0*/ FADD R11, R9, R10 ; /* 0x0000000a090b7221 */
/*01f0*/ FADD R11, R0, R11 ; /* 0x0000000b000b7221 */
/*0200*/ FADD R10, R2, R11 ; /* 0x0000000b020a7221 */
/*0210*/ FADD R11, R3, R10 ; /* 0x0000000a030b7221 */
/*0220*/ FADD R10, R4, R11 ; /* 0x0000000b040a7221 */
/*0230*/ FADD R11, R5, R10 ; /* 0x0000000a050b7221 */
/*0240*/ FADD R10, R6, R11 ; /* 0x0000000b060a7221 */
/*0250*/ FADD R10, R7, R10 ; /* 0x0000000a070a7221 */
/*0260*/ FADD R11, R9, R10 ; /* 0x0000000a090b7221 */
/*0270*/ FADD R11, R0, R11 ; /* 0x0000000b000b7221 */
/*0280*/ FADD R10, R2, R11 ; /* 0x0000000b020a7221 */
/*0290*/ FADD R11, R3, R10 ; /* 0x0000000a030b7221 */
/*02a0*/ FADD R10, R4, R11 ; /* 0x0000000b040a7221 */
/*02b0*/ FADD R11, R5, R10 ; /* 0x0000000a050b7221 */
/*02c0*/ FADD R10, R6, R11 ; /* 0x0000000b060a7221 */
/*02d0*/ FADD R10, R7, R10 ; /* 0x0000000a070a7221 */
/*02e0*/ FADD R11, R9, R10 ; /* 0x0000000a090b7221 */
/*02f0*/ FADD R11, R0, R11 ; /* 0x0000000b000b7221 */
/*0300*/ FADD R10, R2, R11 ; /* 0x0000000b020a7221 */
/*0310*/ FADD R11, R3, R10 ; /* 0x0000000a030b7221 */
/*0320*/ FADD R10, R4, R11 ; /* 0x0000000b040a7221 */
/*0330*/ FADD R11, R5, R10 ; /* 0x0000000a050b7221 */
/*0340*/ FADD R10, R6, R11 ; /* 0x0000000b060a7221 */
/*0350*/ FADD R10, R7, R10 ; /* 0x0000000a070a7221 */
/*0360*/ FADD R11, R9, R10 ; /* 0x0000000a090b7221 */
/*0390*/ FADD R11, R0, R11 ; /* 0x0000000b000b7221 */
/*03b0*/ FADD R10, R2, R11 ; /* 0x0000000b020a7221 */
/*03d0*/ FADD R11, R3, R10 ; /* 0x0000000a030b7221 */
/*03e0*/ FADD R10, R4, R11 ; /* 0x0000000b040a7221 */
/*03f0*/ FADD R11, R5, R10 ; /* 0x0000000a050b7221 */
/*0400*/ FADD R10, R6, R11 ; /* 0x0000000b060a7221 */
/*0410*/ FADD R10, R7, R10 ; /* 0x0000000a070a7221 */
/*0420*/ FADD R11, R9, R10 ; /* 0x0000000a090b7221 */
/*0450*/ MOV R3, 0x4 ; /* 0x0000000400037802 */
/* 0x000fca0000000f00 */
Fatbin ptx code:
arch = sm_89
code version = [8,2]
host = linux
compressed
If we stay with your original formulation which adds two arrays in memory, I would expect this to be an entirely memory-bound problem. In that case, I would expect the equality point to be having the same number of FP32 adds as bf16x2 adds (not half as previously). Once again, I see approximate equality in that case:
# cat t224.cu
__global__ void k(const T * __restrict__ a, const T * __restrict__ b, T * __restrict__ c, int l){
int idx = threadIdx.x+blockDim.x*blockIdx.x;
if (idx < l)
c[idx] = a[idx]+b[idx];
using ft1 = float;
const int sz = 1048576*32;
int main(){
ft1 *a, *b, *c;
const int bs = 256;
const int nb = (sz+bs-1)/bs;
cudaMalloc(&a, sz * sizeof(ft1));
cudaMalloc(&b, sz * sizeof(ft1));
cudaMalloc(&c, sz * sizeof(ft1));
k<<<nb,bs>>>(a, b, c, sz);
k<<<nb,bs>>>(reinterpret_cast<__nv_bfloat162 *>(a), reinterpret_cast<__nv_bfloat162 *>(b), reinterpret_cast<__nv_bfloat162 *>(c), sz);
# nvcc -o t224 t224.cu -arch=sm_89
# nsys profile --stats=true ./t224
Generating '/tmp/nsys-report-8d17.qdstrm'
[1/8] [========================100%] report50.nsys-rep
[2/8] [========================100%] report50.sqlite
SKIPPED: /root/bobc/report50.sqlite does not contain NV Tools Extension (NVTX) data.
57.1 233,819,715 484 483,098.6 15,671.0 1,040 78,880,360 4,659,663.1 ioctl
41.9 171,538,278 11 15,594,388.9 3,023,216.0 5,090 100,133,742 29,536,232.8 poll
0.5 1,994,332 27 73,864.1 12,252.0 10,272 1,225,290 231,472.8 mmap64
0.2 803,951 44 18,271.6 17,396.5 5,687 36,437 5,027.3 open64
0.1 420,760 9 46,751.1 41,900.0 35,794 79,454 13,318.9 sem_timedwait
0.1 281,937 2 140,968.5 140,968.5 119,296 162,641 30,649.5 pthread_create
0.0 193,250 29 6,663.8 5,789.0 2,095 19,080 3,868.0 fopen
0.0 177,396 17 10,435.1 4,874.0 2,633 71,145 16,163.0 mmap
0.0 84,441 48 1,759.2 66.5 58 81,104 11,696.1 fgets
0.0 82,168 8 10,271.0 6,322.5 3,720 40,943 12,452.9 munmap
0.0 72,407 23 3,148.1 3,228.0 1,662 4,850 831.4 fclose
0.0 55,639 51 1,091.0 1,045.0 728 1,961 210.5 fcntl
0.0 42,516 6 7,086.0 6,955.0 2,776 11,437 3,179.5 open
0.0 31,910 13 2,454.6 1,890.0 1,262 5,194 1,153.8 read
0.0 29,565 10 2,956.5 2,797.0 1,507 5,392 1,057.6 write
0.0 18,435 2 9,217.5 9,217.5 4,968 13,467 6,009.7 socket
0.0 17,510 1 17,510.0 17,510.0 17,510 17,510 0.0 fread
0.0 16,528 1 16,528.0 16,528.0 16,528 16,528 0.0 connect
0.0 9,361 1 9,361.0 9,361.0 9,361 9,361 0.0 pipe2
0.0 6,536 7 933.7 912.0 841 1,048 81.1 dup
0.0 2,567 1 2,567.0 2,567.0 2,567 2,567 0.0 bind
0.0 1,801 1 1,801.0 1,801.0 1,801 1,801 0.0 listen
98.2 185,911,202 3 61,970,400.7 331,931.0 328,182 185,251,089 106,764,207.9 cudaMalloc
1.7 3,261,579 2 1,630,789.5 1,630,789.5 1,550,148 1,711,431 114,044.3 cudaDeviceSynchronize
0.1 223,756 2 111,878.0 111,878.0 36,570 187,186 106,501.6 cudaLaunchKernel
0.0 2,437 1 2,437.0 2,437.0 2,437 2,437 0.0 cuModuleGetLoadingMode
52.4 1,709,411 1 1,709,411.0 1,709,411.0 1,709,411 1,709,411 0.0 void k<__nv_bfloat162>(const T1 *, const T1 *, T1 *, int)
47.6 1,550,915 1 1,550,915.0 1,550,915.0 1,550,915 1,550,915 0.0 void k<float>(const T1 *, const T1 *, T1 *, int)
SKIPPED: /root/bobc/report50.sqlite does not contain GPU memory data.
Generated:
/root/bobc/report50.nsys-rep
Those kernels are achieving ~250GB/s bandwidth. That strikes me as reasonable/plausible for a GPU with an advertised peak theoretical bandwidth of 300GB/s
There’s quite a few things missing from your post, in my view:
- compile command
- CUDA version
- how you are timing things
- exact runnable code, without having to add anything or change anything
You’ll note I’ve provided those things in my answer. Sorry, I don’t wish to wade through your github site. It seems unnecessary to me, I believe I have demonstrated that concise and complete claims can be made within the confines of the forum here, and if you should take down that github repo for any reason, your demonstrators disappear or become useless for future readers.
I would almost never recommend trying to understand things from PTX analysis. SASS, on the other hand, is quite reliable, albeit perhaps harder to work with. PTX goes through a compilation stage before it becomes runnable code (ie. it gets converted to SASS). This compilation stage is not an “assembler” in the traditional meaning of that term e.g. from the 80’s and 90’s, but rather a highly optimizing compiler.
