fp16 vs fp32
Hello All,
I did some micro-benchmarking on addition operation for both fp16 and fp32 on gtx 1080 ti, with -Xptxas -O0 to turn off the optimization.
kernel for half_add()
__global__ void kern_hadd (half *my_array, uint *start_t, uint *end_t)
    unsigned int start_time1;
    unsigned int start_time2;
    unsigned int start_time3;
    unsigned int end_time1;
    unsigned int end_time2;
    unsigned int end_time3;
    half a = my_array[0];
    half b = my_array[1];
    half c;
    __syncthreads();
    start_time1 = clock();
    end_time1 = clock();
    __syncthreads();
    start_time2 = clock();
    c= __hadd(a, b);
    end_time2 = clock();
    __syncthreads();
    start_time3 = clock();
    end_time3 = clock();
    start_t[0] = start_time1;
    start_t[1] = start_time2;
    start_t[2] = start_time3;
    end_t[0] = end_time1;
    end_t[1] = end_time2;
    end_t[2] = end_time3;
    my_array[2] = c;
Sass for half_add
/*0228*/                   MOV R8, R8;                       	/* 0x5c98078000870008 */
        /*0230*/                   BAR.SYNC 0x0;                     	/* 0xf0a81b8000070000 */
        /*0238*/                   CS2R R10, SR_CLOCKLO;             /* 0x50c800000507000a */
        /* 0x00643c03fde01fef */
        /*0248*/                   MOV R10, R10;                     	/* 0x5c98078000a7000a */
        /*0250*/                   MOV R11, R10;                     	/* 0x5c98078000a7000b */
        /*0258*/                   HADD2 R4, R4.H0_H0, R9.H0_H0; 	/* 0x5d11000020970404 */
        /* 0x007fbc03fde01fef */
        /*0268*/                   CS2R R9, SR_CLOCKLO;              /* 0x50c8000005070009 */
        /*0270*/                   MOV R9, R9;                       	/* 0x5c98078000970009 */
        /*0278*/                   MOV R10, R9;                      	/* 0x5c9807800097000a */
        /* 0x007fbc03fde019ef */
        /*0288*/                   BAR.SYNC 0x0;                     	/* 0xf0a81b8000070000 */
        /*0290*/                   CS2R R9, SR_CLOCKLO;              /* 0x50c8000005070009 */
        /*0298*/                   MOV R9, R9;                       	/* 0x5c98078000970009 */
syn1 45 (clk/warp) :2mov
syn2 131 (clk/warp) 2mov + hadd2
syn3 45 (clk/warp) : 2mov
__hadd() consume around 131 - 45 = 86 clocks
kernel for float_add()
__global__ void kern_fadd (float *my_array, uint *start_t, uint *end_t)
    float a = my_array[0];
    float b = my_array[1];
    float c;
    __syncthreads();
    __syncthreads();
    c = a + b;
    __syncthreads();
    my_array[2] = c;
Sass for float_add()
        /*0258*/                   FADD R7, R7, R9;          		/* 0x5c58000000970707 */
        /*0268*/                   MOV R7, R7;               		/* 0x5c98078000770007 */
        /*0270*/                   CS2R R9, SR_CLOCKLO;      	/* 0x50c8000005070009 */
        /*0278*/                   MOV R9, R9;               		/* 0x5c98078000970009 */
        /* 0x007fbc033de01fef */
        /*0288*/                   MOV R10, R9;              		/* 0x5c9807800097000a */
        /*0290*/                   BAR.SYNC 0x0;             		/* 0xf0a81b8000070000 */
        /*0298*/                   CS2R R9, SR_CLOCKLO;      	/* 0x50c8000005070009 */
syn1 45 (clk/warp) 2mov
syn2 75 (clk/warp) 2mov + fadd + mov
syn3 45 (clk/warp) 2mov
Float addition consume around 15 clocks
It appears that fp16 is not as fast as fp32. Is it true? Can we say that the benefit of using fp16 is majorly from reducing the memory bandwidth?
This is true for the architecture of your GPU, which is sm_61 (= compute capability 6.1). Only architectures sm_60, sm_70, and possibly sm_62 (not sure about the last one) are designed for high FP16 computational throughput.
For all other architectures, FP16 makes a lot of sense as a storage format (a lot of sensor data only requires FP16 due to the use of 10-bit ADCs, for example) while doing all computation with high-throughput FP32 computation, optimizing use of memory bandwidth in this way. By the way, reading from an FP16 texture automatically converts the data to FP32, so that may be a something to take into consideration.
Hello njuffa,
Thanks for your reply.
I did some profiling on the P100. Below are some results.
fp32 seems comparable to fp16, in terms of clock cycles.
Besides bandwidth reduction, how to use fp16 efficiently? Do I need to use half2 to vectorize the computation?
It’s all right there in the Pascal whitepaper:
https://images.nvidia.com/content/pdf/tesla/whitepaper/pascal-architecture-whitepaper.pdf
So yeah, you need to use half2 computation to get the doubled FLOPS rate compared to FP32.
