So it says the size is the memory in Bytes for the texture,
but if I want to use a 2D texture, how can I specify the dimention of the array ?
so here is my code :
float *data;
uint32_t data_size;
CUDA_SAFE_CALL(cudaMalloc((void**) &(data), data_size));
CUDA_SAFE_CALL(cudaMemcpy(data, host_data,data_size,
cudaMemcpyHostToDevice) );
texture<float4, 2, cudaReadModeElementType> texRef;
// set texture parameters
texRef.addressMode[0] = cudaAddressModeClamp;
texRef.addressMode[1] = cudaAddressModeClamp;
texRef.filterMode = cudaFilterModePoint;
texRef.normalized = false; // access with normalized texture coordinates or not
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc(32, 32,32, 32, cudaChannelFormatKindFloat);
CUDA_SAFE_CALL(cudaBindTexture(texRef,(void *)data,channelDesc,data_size,0));
__global__ void
myKer(float* in,float* out)
float4 fetch = texfetch(texRef, x,y); <- this doesn't work !
out[(threadIdx.y*blockDim.x+threadIdx.x)*4] = fetch.x;
out[(threadIdx.y*blockDim.x+threadIdx.x)*4+1] = fetch.y;
out[(threadIdx.y*blockDim.x+threadIdx.x)*4+2] = fetch.z;
out[(threadIdx.y*blockDim.x+threadIdx.x)*4+3] = fetch.w;
when I do a fetch in the kernel I can only get the first element no matter what x & y values are. I’m guessing it’s because it doesn’t know what is the size of each dimension.
So If I want to use a 2D texture do I have to use a cudaArray with necessarily ? or could I tell to the texture what is my array shape ?
