Hi!
When I upgrade from NVIDIA driver 470 I get blackscreen after MOBO logo splash. I am able to SSH into my computer from my laptop. I have been running the 470 driver for months as upgrading to 535 or 545 also yields blackscreen after MOBO logo splash. Before that I ran the 525 driver but then it got removed from the repo :(
My system is encrypted using LUKS so I have to type in my password “blindly” (not that it is much more of a hassle) but I don’t think the encryption would affect it. I have tried a blank install of Linux Mint (without encryption) on a separate SSD in my system however it also blackscreens after installing the 550 driver. I haven’t SSH:ed into that system to debug.
The BIOS is the latest version (not including betas). I am running Mint 21.3.
I think I saw a brief flash of character-esque white on the screen once. The general behavior is that the logo splash happens and then the screen returns to black (when it should ask for a decryption key). It doesn’t go into sleep mode.
Generating nvidia-bug-report.log:
$ startx -- -logverbose 6
/usr/lib/xorg/Xorg.wrap: Only console users are allowed to run the X server
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
Couldn't get a file descriptor referring to the console.
Running nvidia-bug-report.sh works and I have attached the log.
nvidia-bug-report.log (157.6 KB)
Running nvidia-smi:
$ nvidia-smi
Sun Sep 15 12:39:13 2024
| NVIDIA-SMI 550.107.02 Driver Version: 550.107.02 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 1060 3GB Off | 00000000:0A:00.0 On | N/A |
| 0% 28C P8 6W / 120W | 141MiB / 3072MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1339 G /usr/lib/xorg/Xorg 137MiB |
Running dkms status. Before I installed dkms for the 5.15 kernel I could boot using 5.15 however the driver (obviously) did not work.
$ dkms status
nvidia/550.107.02, 5.15.0-121-generic, x86_64: installed
nvidia/550.107.02, 6.8.0-40-generic, x86_64: installed
These are the packages containing NVIDIA:
$ dpkg -l | grep nvidia
ii libnvidia-cfg1-550:amd64 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-550 550.107.02-0ubuntu0.22.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-550:amd64 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-550:i386 550.107.02-0ubuntu0.22.04.1 i386 NVIDIA libcompute package
ii libnvidia-decode-550:amd64 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-550:i386 550.107.02-0ubuntu0.22.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.9-1.1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-egl-wayland1:i386 1:1.1.9-1.1 i386 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-550:amd64 550.107.02-0ubuntu0.22.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-550:i386 550.107.02-0ubuntu0.22.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-550:amd64 550.107.02-0ubuntu0.22.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-550:amd64 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-550:i386 550.107.02-0ubuntu0.22.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-550:amd64 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-550:i386 550.107.02-0ubuntu0.22.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-550 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-dkms-550 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-550 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA driver metapackage
ii nvidia-firmware-550-550.107.02 550.107.02-0ubuntu0.22.04.1 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-550 550.107.02-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-550 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-550 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-550 550.107.02-0ubuntu0.22.04.1 amd64 NVIDIA binary Xorg driver
One thing I notice is the version for nvidia-settings is 510, that sticks out to me however sudo apt update && sudo apt upgrade doesn’t upgrade any package. Also the version number for nvidia-firmware, 550-550 looks a bit odd to me.
Anyway. One thing I’ll try later today is to use a HDMI cable instead of a displayport cable. I can always revert back to the 470 driver but it would be nice to get 550 working. Thanks!
