I’m trying to install the latest Nvidia driver on linux, but on all of my tries the screen went black. I have tried to install the nvidia driver on Fedora 41, Nobara 41, PopOS _Nvidia, PopOS, Garuda, Bazzite(KDE and Gnome) and Bazzite(KDE and Gnome)_nvidia. On all of those, with differents kernels I keep getting the Black screen. My GPU is an RTX 3060.
One thing that I notice is that on Bazzite_nvidia, on my UWHD monitor the video works, but when I plug the GPU on my UWQHD monitor it does not work. I notice that the screen resolution above 2560x1440 the screen goes black and stop to work. Does Nvidia keeps old drivers releases? So I can try to install them and see if it works?
Currently I’m using Linux Mint 22.1 Cinnamon with the following config:
System:
Kernel: 6.8.0-53-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 clocksource: tsc
Desktop: Cinnamon v: 6.4.7 tk: GTK v: 3.24.41 wm: Muffin v: 6.4.1 vt: 7 dm: LightDM v: 1.30.0
Distro: Linux Mint 22.1 Xia base: Ubuntu 24.04 noble
Machine:
Type: Desktop Mobo: ASRock model: B450M Steel Legend serial:
uuid: UEFI: American Megatrends v: P10.20 date: 04/23/2024
CPU:
Info: 8-core model: AMD Ryzen 7 5700X bits: 64 type: MT MCP smt: enabled arch: Zen 3+ rev: 2
cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB
Speed (MHz): avg: 2291 high: 3017 min/max: 2200/4662 boost: enabled cores: 1: 2200 2: 2200
3: 2627 4: 2200 5: 2191 6: 2200 7: 2196 8: 2200 9: 2200 10: 2196 11: 2200 12: 3017 13: 2200
14: 2200 15: 2200 16: 2439 bogomips: 108596
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Gigabyte driver: nvidia
v: 550.120 arch: Ampere pcie: speed: 2.5 GT/s lanes: 8 ports: active: none off: HDMI-A-2
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: nouveau
unloaded: fbdev,modesetting,vesa failed: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0
screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.57x13.11") s-diag: 868mm (34.19")
Monitor-1: HDMI-1 res: 3440x1440 hz: 85 dpi: 109 size: 800x334mm (31.5x13.15")
diag: 867mm (34.13") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast
surfaceless: drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120 glx-v: 1.4 direct-render: yes
renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
Audio:
Device-1: NVIDIA GA106 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
pcie: speed: 8 GT/s lanes: 8 bus-ID: 07:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.8.0-53-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin
Swap:
Alert: No swap data was found.
Info:
Memory: total: 64 GiB note: est. available: 62.72 GiB used: 4.72 GiB (7.5%)
Processes: 405 Power: uptime: 11m states: freeze,mem,disk suspend: deep wakeups: 0
hibernate: platform Init: systemd v: 255 target: graphical (5) default: graphical
Compilers: gcc: 13.3.0 Client: Cinnamon v: 6.4.7 inxi: 3.3.34
I believe that I found my problem. Still did not test, but it is related to Wayland, because on Mint and Ubuntu that uses X11 the driver works fine.
I’ve the same problem. Also Mint 22.1.
So if I disable Wayland it should work?
Interesting, I have the same problem.
I also have Mint 22.1 Cinnamon, also a Ryzen 7 5700X and a RTX 3050 (with Kernel 6.8.0-59).
I used the 550 drivers without a problem.
My screen resolution is 3840x1600.
But after I installed the 570.133.07-0ubuntu0.24.04.1 drivers and did a reboot, I can see the Mint logo for a short moment, then the screen goes black.
No obvious errors in the syslog, I just don’t get a video output.
I had to roll back to the proprietary 550 drivers.
Update:
I can confirm that this bug is triggered by a high resolution (as gustavosaibroestudos’ posting suggested).
I did the following:
on the 550 drivers I switched from my native resolution (3840x1600) to HD (1920x1080)
I then installed the 570 drivers
reboot
screen goes black / no video output (because the login screen of Mint is displayed in the native resolution)
I blindly entered my password
the Cinnamon desktop loads and switches to HD - I get a video output!
I double checked it by:
Preferences → Display
selecting 3840x1600 → Apply
no video output
I wait ~15 seconds, Mint automatically switches back to HD, again a video ouput
So something is definitely wrong with the driver.
But I wonder why more people don’t have this problem.
In the meantime I tested a lot of drivers. Result: Every driver above version 550 has this problem (e.g. 560, 565 or 570).
But I was able to fix the problem by using Display Port instead of HDMI.
Just signed up to thank you, @swift42
Same problem here. I had been trying for 2 days, changing all sorts of things that could’ve broken other stuff.
Rolled back to 550 like you said, and it worked! Lifesaver!
Hey folks,
I’m just joining the group of people for whom it doesn’t work.
I have a Dell Precision 5680, Ubuntu 24.04 (6.11.0-26-generic), RTX 4000 ADA Mobile, and a Samsung G9 with DQHD resolution. After upgrading to driver version 570.133.07, the external display connected via USB-C DP - DP went black.
Rolled back to 550 and everything works fine.
Not exactly the same but since a few nvidia driver updates some games just crash the whole thing it seems. I used to reliably be able to ALT+CTRL+1 out to another tty and kill Xorg at least. But these days not even that works most of the time. Only ssh or simply pressing the power button to shut down the machine works.
SOMETIMES i can still get a console but then my resolution is set to 640x480 and the text is so garbled up it’s almost unreadable. Not in a memory-is-broken kind of way but garbled more like really really fuzzy and blurry so you can barely make it out.
Also the startup console resolution is randomly changing from my native monitor resolution of 1440p to something like 720p each other restart. The first start of the day will ALWAYS result in no signal at all. Just like when it crashed.
These drivers were much more stable a few years ago.
nvidia-smi
Thu Jun 5 22:01:22 2025
| NVIDIA-SMI 570.153.02 Driver Version: 570.153.02 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3080 Ti Off | 00000000:0D:00.0 On | N/A |
| 0% 55C P8 27W / 350W | 756MiB / 12288MiB | 16% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 7487 G /usr/lib/Xorg 389MiB |
| 0 N/A N/A 10079 C+G ...share/Steam/ubuntu12_32/steam 293MiB |
System:
Kernel: 6.14.9-artix1-1 arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
clocksource: tsc
Desktop: awesome v: 4.3-1684-gf009815cb-dirty dm: startx Distro: Artix
base: Arch Linux
Machine:
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
serial: <superuser required> part-nu: SKU uuid: <superuser required>
UEFI: American Megatrends v: 4403 date: 04/28/2022
CPU:
Info: 8-core model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP smt: enabled
arch: Zen 3+ rev: 2 cache: L1: 512 KiB L2: 4 MiB L3: 96 MiB
Speed (MHz): avg: 3599 min/max: 550/4151 boost: enabled cores: 1: 3599
2: 3599 3: 3599 4: 3599 5: 3599 6: 3599 7: 3599 8: 3599 9: 3599 10: 3599
11: 3599 12: 3599 13: 3599 14: 3599 15: 3599 16: 3599 bogomips: 96005
Graphics:
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: Micro-Star MSI
driver: nvidia v: 570.153.02 arch: Ampere pcie: speed: 2.5 GT/s lanes: 16
ports: active: none off: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0d:00.0
chip-ID: 10de:2208 class-ID: 0300
Display: server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch
Monitor-1: DP-3 size-res: N/A modes: N/
larsan
June 9, 2025, 7:50am
10
Exactly this. The only way I was able to boot with the 570 driver was to use recovery mode with an earlier kernel, 6.8.0-59 vs 6.8.0-60.
| NVIDIA-SMI 550.144.03 Driver Version: 550.144.03 CUDA Version: 12.4 |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4070 Off | 00000000:2B:00.0 On | N/A |
| 0% 35C P8 10W / 200W | 1240MiB / 12282MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2054 G /usr/lib/xorg/Xorg 486MiB |
| 0 N/A N/A 2554 G cinnamon 49MiB
System:
Host: fungrim-ws Kernel: 6.8.0-60-generic arch: x86_64 bits: 64
Desktop: Cinnamon v: 6.4.8 Distro: Linux Mint 22.1 Xia
Machine:
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.50
date: 01/14/2021
CPU:
Info: 8-core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+
rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB
Speed (MHz): avg: 2408 high: 2879 min/max: 2200/4850 boost: enabled cores:
1: 2547 2: 2200 3: 2421 4: 2879 5: 2200 6: 2500 7: 2200 8: 2200 9: 2246
10: 2200 11: 2196 12: 2878 13: 2196 14: 2200 15: 2721 16: 2748
bogomips: 121590
Graphics:
Device-1: NVIDIA AD104 [GeForce RTX 4070] vendor: ASUSTeK driver: nvidia
v: 550.144.03 arch: Lovelace bus-ID: 2b:00.0
Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB bus-ID: 3-1.3.2.4.2:13
loaded: nouveau unloaded: fbdev,modesetting,vesa failed: nvidia
gpu: nvidia,nvidia-nvswitch resolution: 3440x1440~60Hz
API: EGL v: 1.5 drivers: nvidia,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.144.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070/PCIe/SSE2
API: Vulkan v: 1.3.275 drivers: N/A surfaces: xcb,xlib devices: 2
Same here. I am a Manjaro user. I’ve tried Cachy, Garuda and Endeavour and all have them result in a black / “stuck” display on my external monitors connected via HDMI and USB-C.
I use XFCE but have also tried Hyprland and KDE which also have issues.
It does seem that this only occurs when the desktop is extended over multiple screens. Mirrored displays seems to work.
But I’ve rolled back to an older kernel and the 550 Nvidia driver and excluded both from system updates since March.
System:
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: tsc avail: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64
root=UUID=c102c97f-7aa1-42b9-a154-2a93cf4b32d4 rw rootflags=subvol=@
quiet splash resume=UUID=8c869f2b-0c0a-4126-b852-3b60d5f68cef
udev.log_priority=3
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: ulauncher,xfce4-panel tools: xfce4-screensaver avail: i3lock vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Machine:
Type: Laptop System: LENOVO product: 81SY v: Legion Y540-15IRH-PG0
serial: <superuser required> Chassis: type: 10 v: Legion Y540-15IRH-PG0
Mobo: LENOVO model: LNVNB161216 v: SDK0J40697 WIN
part-nu: LENOVO_MT_81SY_BU_idea_FM_Legion Y540-15IRH-PG0
uuid: <superuser required> UEFI: LENOVO v: BHCN42WW date: 05/21/2021
Battery:
ID-1: BAT0 charge: 43.7 Wh (100.0%) condition: 43.7/52.5 Wh (83.3%)
volts: 12.6 min: 11.3 model: LGC L17L3PG1 type: Li-poly serial: <filter>
status: full cycles: 642
Memory:
System RAM: total: 32 GiB available: 31.22 GiB used: 4.13 GiB (13.2%)
Message: For most reliable report, use superuser + dmidecode.
Array-1: capacity: 32 GiB slots: 2 modules: 2 EC: None
max-module-size: 16 GiB note: est.
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
speed: 2667 MT/s volts: curr: 1 min: 1.25 max: 2 width (bits): data: 64
total: 64 manufacturer: 0898 part-no: KD4AGSA8M-26N1900 serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
PCI Slots:
Permissions: Unable to run dmidecode. Root privileges required.
CPU:
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: performance cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida
intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr
mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities:
Type: gather_data_sampling mitigation: Microcode
Type: itlb_multihit status: KVM: Split huge pages
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
vulnerable
Type: mds mitigation: Clear CPU buffers; SMT vulnerable
Type: meltdown mitigation: PTI
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: reg_file_data_sampling status: Not affected
Type: retbleed mitigation: IBRS
Type: spec_rstack_overflow status: Not affected
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
sanitization
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: conditional;
RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Type: srbds mitigation: Microcode
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:5 chip-ID: 04f2:b6d9
class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.16 compositors: 1: Picom v: 12.5
2: xfwm4 v: 4.20.0 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: LG Display 0x05e5 built: 2018 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.369
green: x: 0.349 y: 0.557 blue: x: 0.153 y: 0.110 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau drv: nvidia
platforms: device: 0 drv: nvidia device: 1 drv: iris device: 2 drv: nouveau
device: 3 drv: swrast gbm: drv: iris surfaceless: drv: nvidia x11:
drv: iris inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e9b memory: 15.25 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings
gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
Audio:
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsactl,alsamixer,amixer
Server-1: JACK v: 1.9.22 status: off tools: N/A
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
tools: pactl,pw-cat,pw-cli,wpctl
Network:
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlp0s20f3 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
WAN IP: <filter>
Bluetooth:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:13
chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: up address: see --recommends
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Drives:
Local Storage: total: 1.84 TiB used: 617.67 GiB (32.8%)
SMART Message: Unable to run smartctl. Root privileges required.
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX900 Pro 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 52A8T27A temp: 33.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A05 scheme: GPT
Message: No optical or floppy data found.
Partition:
ID-1: / raw-size: 400 GiB size: 400 GiB (100.00%) used: 69.54 GiB (17.4%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7 label: ROOT
uuid: c102c97f-7aa1-42b9-a154-2a93cf4b32d4
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: EFI
uuid: E11C-230E
ID-3: /data01 raw-size: 120.87 GiB size: 120.87 GiB (100.00%)
used: 2.3 GiB (1.9%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
label: DATA01 uuid: acc84cff-14fc-47b2-bb3f-66483bae9cc1
ID-4: /data02 raw-size: 531.51 GiB size: 531.51 GiB (100.00%)
used: 108.84 GiB (20.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: DATA02
uuid: e0b7b82b-08d5-4565-9adc-e6f5a0f49786
ID-5: /home raw-size: 400 GiB size: 400 GiB (100.00%)
used: 69.54 GiB (17.4%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
label: ROOT uuid: c102c97f-7aa1-42b9-a154-2a93cf4b32d4
ID-6: /var/cache raw-size: 400 GiB size: 400 GiB (100.00%)
ID-7: /var/log raw-size: 400 GiB size: 400 GiB (100.00%)
ID-8: /windows/c raw-size: 399.19 GiB size: 399.19 GiB (100.00%)
used: 318.94 GiB (79.9%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: Root uuid: FE1018F01018B21F
ID-9: /windows/d raw-size: 400 GiB size: 400 GiB (100.00%)
used: 118.04 GiB (29.5%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: Data
uuid: 3CA4410AA440C7DA
Swap:
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p5 maj-min: 259:5 label: SWAP
uuid: 8c869f2b-0c0a-4126-b852-3b60d5f68cef
Unmounted:
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 5CFB-D5D8
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 715 MiB fs: ntfs label: N/A
uuid: 408E5C608E5C5090
USB:
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 16 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002
class-ID: 0900
Device-1: 1-6:5 info: Chicony Integrated Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b6d9 class-ID: 0e02
serial: <filter>
Device-2: 1-9:8 info: Integrated Express ITE Device(8910) type: keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c100 class-ID: 0301
Device-3: 1-14:13 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 1d6b:0003
class-ID: 0900
Sensors:
System Temperatures: cpu: 57.0 C pch: 51.0 C mobo: N/A
Fan Speeds (rpm): N/A
Repos:
Packages: pm: pacman pkgs: 1285 libs: 352 tools: pamac,yay
Active pacman repo servers in: /etc/pacman.d/mirrorlist
1: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
Processes:
CPU top: 5 of 373
1: cpu: 10.5% command: zen-bin pid: 181851 mem: 828.6 MiB (2.5%)
2: cpu: 6.1% command: zen-bin pid: 185260 mem: 471.1 MiB (1.4%)
3: cpu: 5.2% command: zen-bin pid: 182046 mem: 608.2 MiB (1.9%)
4: cpu: 2.7% command: Xorg pid: 1036 mem: 242.3 MiB (0.7%)
5: cpu: 2.5% command: zen-bin pid: 185263 mem: 296.8 MiB (0.9%)
Memory top: 5 of 373
1: mem: 828.6 MiB (2.5%) command: zen-bin pid: 181851 cpu: 10.5%
2: mem: 608.2 MiB (1.9%) command: zen-bin pid: 182046 cpu: 5.2%
3: mem: 536.3 MiB (1.6%) command: zen-bin pid: 183588 cpu: 2.3%
4: mem: 471.1 MiB (1.4%) command: zen-bin pid: 185260 cpu: 6.1%
5: mem: 332.9 MiB (1.0%) command: zen-bin pid: 182146 cpu: 0.4%
Info:
Processes: 373 Power: uptime: 1d 11h 39m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.42 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 257
default: graphical tool: systemctl
Compilers: gcc: 15.1.1 alt: 14 Shell: Bash v: 5.2.37
running-in: terminator inxi: 3.3.38
