Unix graphics fails on boot - Ubuntu 21.10
Hi to all!
After grub, linux starts to load normally until ending up on a black screen and completely locked. I have read hundreds of posts with this problem but I can not find a solution for my case. In fact, this post may be my last hope of fixing this issue.
It could work with nouveau but I need the CUDA cores pushing my computations.
I start by thanking you for any selfless help on this problem.
The configuration of my pc is the following:
HP Z6200 Workstation
24GB RAM
2xIntel Xeon E2620
2xNvidia Quadro K5000 in sli mode.
Ubuntu 21.10
I have done many tests with different distros:
  • Ubuntu 18, 21, 22
    -Fedora 35/36
  • Pop Os 22
    -Debian 9
I have not been able to boot x with neither the 390 nor the 470 driver series.
I only had partial success with Pop Os 22 and the 340 series of drivers, but of course without CUDA.
I always test the drivers compiled for these distros. The result is always the same, black screen.
Next, I try the method described at https://www.if-not-true-then-false.com/ for the cited distros. The result is always the same, black screen.
The common result in all the tests that I can guess is the following:
hpz620 kernel: nvidia-modeset: WARNING: GPU:0: Lost display notification (0:0x00000000); continuing.
Nouveau is well locked in all tests.
In Windows 10 the graphic configuration works perfectly, so I rule out a hardware failure.
I upload the logs of my last test to see if an awake mind finds the configuration problem.
Thank you very much.
The nvidia-bug-report of last test:
nvidia-bug-report.zip (132.2 KB)
And the nvidia-installer log:
nvidia-installer.zip (1.6 KB)
Does it work if you remove the second gpu for testing purpose?
No, I didn’t this test but today I test it and I got the same result, Black screen.
My next test will be update bios if has update available.
Can you see some kind of clue in the logs?
Thanks a lot.
PD: In nvidia-bug-report has many boots, some of this are from past night when I had plugged 2 k5000 yet.
reports-only-1-k5000.zip (155.2 KB)
I have not many hope about bios update due to I had installed the newest version already. In any case I reupdated it.
Hello!
All tests were unsuccessful.
I test with other Linux distributions without a good result.
The last test was in Manjaro 42.2. After installing nvidia-drivers-470xx-> Black Screen still!
I upload the nvidia-bug-report.log file. I don’t understand what causes this error :(
Sorry, I cannot upload the bug report.
We can download from this link:
https://1drv.ms/u/s!AiYVIzwbr49ig5I3q7a0nGlWwiOAiQ?e=HoqqL5
A system bios update wouldn’t help anyway, rather a vbios update for the nvidia gpus but that’s hard to come by.
is a dreaded error, the display engine crashed. The K5000 seems to have two DVI and two DP connectors, you seem to be using hdmi monitors on it. Which connectors are you using? Please check if any of those is triggering this by disconnecting them before booting.
Ok, I will test it.
Some tested things (maybe give a clue about this case):
I tried to update k5000 bios but was impossible. I tested with all methods and neverthing worked. Always I got “no compatible devices found”.
Then, I changed slot security for two x16 slots (from enabled to disabled) and I got 6 long bips, red light and don’t boot.
Update:
Now in Manjaro with nouveau, always when I’m logged starts with 1 display working. After 2/3 minutes, this screen start to blink and start the 2nd screen.
That’s really odd, nouveau’s display code is usually very reliable, much better than the nvidia prop. driver’s one.
Hi, finally I came back from Manjaro to Pop Os due to I have more aknowledge about ubuntu based distros.
I had screen fails in one of my two monitors with Nouveau driver and I bought new cables but now, these cables was DVI-HDMI instead of DP-DVI olds.
Process:
  1. I connected one screen with one new cable DVI-HDMI.
  2. I installed nvidia-driver-470
  3. And Surprise, after reboot system booted without fail.
  4. I enabled OpenCL libraries and after that shutdown system.
  5. I Connected 2nd monitor with another one new cable.
  6. After that booted without problems.
I think that Black screen problem was due to Displayport connection or configuration.
This topic can be marked as Solved!
Thanks to all.
4th july update: I already have problems other time…
On 4th july boot already I have black screen.
This time I think that is due to I tried to enable sli configuration and something was wrong.
Sorry I cannot upload nvidia-bug-report.log due to his size is bigger than 500 kb.
The error parts:
jul 04 22:56:31 pop-os /usr/libexec/gdm-x-session[4378]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:5:0:0 is part of an active SLI
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(GPU-0):     information.
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE)  *** Aborting ***
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(0): Failing initialization of X screen
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(G0): Only one X screen is supported when SLI is enabled.  Disabling
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(G0):     this screen.
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) NVIDIA(G0): Failing initialization of X screen
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) Screen(s) found, but none have a usable configuration.
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) no screens found(EE)
jul 04 22:56:32 pop-os /usr/libexec/gdm-x-session[4378]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
jul 04 22:56:33 pop-os /usr/libexec/gdm-x-session[4378]: (EE) Server terminated with error (1). Closing log file.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:5:0:0 is part of an active SLI
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(GPU-0):     information.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE)  *** Aborting ***
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(0): Failing initialization of X screen
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(G0): Only one X screen is supported when SLI is enabled.  Disabling
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(G0):     this screen.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) NVIDIA(G0): Failing initialization of X screen
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) Screen(s) found, but none have a usable configuration.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) no screens found(EE)
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4655]: (EE) Server terminated with error (1). Closing log file.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:5:0:0 is part of an active SLI
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(GPU-0):     information.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE)  *** Aborting ***
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(0): Failing initialization of X screen
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(G0): Only one X screen is supported when SLI is enabled.  Disabling
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(G0):     this screen.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) NVIDIA(G0): Failing initialization of X screen
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) Screen(s) found, but none have a usable configuration.
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) no screens found(EE)
jul 04 22:56:44 pop-os /usr/libexec/gdm-x-session[4670]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4670]: (EE) Server terminated with error (1). Closing log file.
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:5:0:0 is part of an active SLI
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(GPU-0):     information.
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE)  *** Aborting ***
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(0): Failing initialization of X screen
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(G0): Only one X screen is supported when SLI is enabled.  Disabling
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(G0):     this screen.
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) NVIDIA(G0): Failing initialization of X screen
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) Screen(s) found, but none have a usable configuration.
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) no screens found(EE)
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
jul 04 22:56:45 pop-os /usr/libexec/gdm-x-session[4679]: (EE) Server terminated with error (1). Closing log file.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:5:0:0 is part of an active SLI
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(GPU-0):     information.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE)  *** Aborting ***
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(0): Failing initialization of X screen
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(G0): Only one X screen is supported when SLI is enabled.  Disabling
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(G0):     this screen.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) NVIDIA(G0): Failing initialization of X screen
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) Screen(s) found, but none have a usable configuration.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) no screens found(EE)
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4688]: (EE) Server terminated with error (1). Closing log file.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:5:0:0 is part of an active SLI
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(GPU-0):     information.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE)  *** Aborting ***
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(0): Failing initialization of X screen
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(G0): Only one X screen is supported when SLI is enabled.  Disabling
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(G0):     this screen.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) NVIDIA(G0): Failing initialization of X screen
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) Screen(s) found, but none have a usable configuration.
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) no screens found(EE)
jul 04 22:56:46 pop-os /usr/libexec/gdm-x-session[4697]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
jul 04 22:56:47 pop-os /usr/libexec/gdm-x-session[4697]: (EE) Server terminated with error (1). Closing log file.
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:5:0:0 is part of an active SLI
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(GPU-0):     information.
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE)  *** Aborting ***
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(0): Failing initialization of X screen
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(G0): Only one X screen is supported when SLI is enabled.  Disabling
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(G0):     this screen.
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) NVIDIA(G0): Failing initialization of X screen
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) Screen(s) found, but none have a usable configuration.
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) no screens found(EE)
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
jul 04 22:57:07 pop-os /usr/libexec/gdm-x-session[6036]: (EE) Server terminated with error (1). Closing log file.
jul 03 19:23:58 pop-os /usr/libexec/gdm-x-session[3606]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
jul 03 19:24:37 pop-os /usr/libexec/gdm-x-session[4563]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
jul 03 19:24:39 pop-os /usr/libexec/gdm-x-session[4563]: (EE) systemd-logind: failed to release device: Device not taken
jul 03 19:32:07 pop-os /usr/libexec/gdm-x-session[4563]: (EE) event6  - Logitech Wireless Keyboard PID:4075: client bug: event processing lagging behind by 22ms, your system is too slow
jul 03 20:20:20 pop-os /usr/libexec/gdm-x-session[4563]: (EE) event6  - Logitech Wireless Keyboard PID:4075: client bug: event processing lagging behind by 34ms, your system is too slow
jul 03 21:59:58 pop-os /usr/libexec/gdm-x-session[4563]: (EE) event6  - Logitech Wireless Keyboard PID:4075: client bug: event processing lagging behind by 34ms, your system is too slow
jul 03 22:00:06 pop-os /usr/libexec/gdm-x-session[4563]: (EE) event6  - Logitech Wireless Keyboard PID:4075: client bug: event processing lagging behind by 34ms, your system is too slow
[    99.102] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[    99.102] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
[    99.102] (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:5:0:0 is part of an active SLI
[    99.102] (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
[    99.102] (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
[    99.102] (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
[    99.102] (EE) NVIDIA(GPU-0):     information.
[    99.102] (EE)  *** Aborting ***
[    99.102] (EE) NVIDIA(0): Failing initialization of X screen
[    99.103] (EE) NVIDIA(G0): Only one X screen is supported when SLI is enabled.  Disabling
[    99.103] (EE) NVIDIA(G0):     this screen.
[    99.103] (EE) NVIDIA(G0): Failing initialization of X screen
[    99.103] (EE) Screen(s) found, but none have a usable configuration.
[    99.103] (EE)
[    99.103] (EE) no screens found(EE)
[    99.103] (EE)
[    99.103] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    99.103] (EE)
[    99.298] (EE) Server terminated with error (1). Closing log file.
[    78.723] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[    78.723] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
[    78.723] (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:5:0:0 is part of an active SLI
[    78.723] (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
[    78.723] (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
[    78.723] (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
[    78.723] (EE) NVIDIA(GPU-0):     information.
[    78.723] (EE)  *** Aborting ***
[    78.723] (EE) NVIDIA(0): Failing initialization of X screen
[    78.724] (EE) NVIDIA(G0): Only one X screen is supported when SLI is enabled.  Disabling
[    78.724] (EE) NVIDIA(G0):     this screen.
[    78.724] (EE) NVIDIA(G0): Failing initialization of X screen
[    78.724] (EE) Screen(s) found, but none have a usable configuration.
[    78.724] (EE)
[    78.724] (EE) no screens found(EE)
[    78.724] (EE)
[    78.724] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    78.724] (EE)
[    78.919] (EE) Server terminated with error (1). Closing log file.
[   108.082] (EE) systemd-logind: failed to release device: Device not taken
[   556.139] (EE) event6  - Logitech Wireless Keyboard PID:4075: client bug: event processing lagging behind by 22ms, your system is too slow
[  3449.448] (EE) event6  - Logitech Wireless Keyboard PID:4075: client bug: event processing lagging behind by 34ms, your system is too slow
[  9427.564] (EE) event6  - Logitech Wireless Keyboard PID:4075: client bug: event processing lagging behind by 34ms, your system is too slow
[  9434.796] (EE) event6  - Logitech Wireless Keyboard PID:4075: client bug: event processing lagging behind by 34ms, your system is too slow
[    76.107] (EE) systemd-logind: failed to release device: Device not taken
[   107.088] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 45ms, your system is too slow
[  1267.897] (EE) event4  - Logitech Wireless Keyboard PID:4075: client bug: event processing lagging behind by 35ms, your system is too slow
After purge nvidia driver, reboot with nouveu and installed another time nvidia-470 driver the system was working already.
I think that I got crash trying set sli mode in on.
Can you say somebody if it’s correct?
Please post the output of
sudo cat /sys/module/nvidia_drm/parameters/modeset
Now, the output is:
N
Please try a xorg.conf only containing
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "Quadro K5000"
    BusID          "PCI:5:0:0"
    Option         "BaseMosaic" "true"
EndSection
The Xorg.conf content:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 470.103.01
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "SLI" "Mosaic"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
