(2) GeForce 210, 4 displays, only first GPU recognized using nvidia proprietary drivers
Running Mint 17.1 64bit Cinnamon
lspci -vv shows both cards but second card does not function / does not show up in nvidia-xconfig
(hardware known to be working as I am able to get 3 displays working running nouveau drivers but unsatisfactory 3d - also works in Windows 7)
Currently running NVIDIA UNIX x86_64 Kernel Module 304.125 driver
nvidia log script results in “NVIDIA: could not open the device file /dev/nvidia1 (Input/output error).”
(Log file attached)
Have had this problem for about a year now (Ubuntu 13.x and now 14.04, trying mint 17.1 now, same results) - would be willing to try different distribution, kernel, etc - really would love to see this hardware perform - I can’t say how much you help is greatly appreciated.
Thank you and best wishes
X
[code]
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 18811463
Date: Mon Feb 16 10:54:53 PST 2015
uname: Linux Prefect 3.13.0-37-generic #64-Ubuntu SMP Mon Sep 22 21:28:38 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 30 2015-02-16 10:49:08.961548629 -0800 /etc/issue
Linux Mint 17.1 Rebecca \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 11 2014-02-19 18:43:56.000000000 -0800 /etc/debian_version
jessie/sid
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 10830 2015-02-14 13:06:55.178546110 -0800 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Sat Feb 14 13:06:45 2015
installer version: 340.76
PATH: /usr/local/sbin:/usr/local/bin:/usr/bin:/usr/sbin:/sbin:/bin
nvidia-installer command line:
/usr/bin/nvidia-uninstall
-s
Using built-in stream user interface
→ If you plan to no longer use the NVIDIA driver, you should make sure that no X screens are configured to use the NVIDIA X driver in your X configuration file. If you used nvidia-xconfig to configure X, it may have created a backup of your original configuration. Would you like to run nvidia-xconfig --restore-original-backup to attempt restoration of the original X configuration file? (Answer: No)
→ Parsing log file:
→ done.
→ Validating previous installation:
→ Unable to find installed file ‘/usr/lib/i386-linux-gnu/libOpenCL.so.1.0.0’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib/vdpau/libvdpau_nvidia.so.1’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib/libvdpau_nvidia.so’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib/i386-linux-gnu/libOpenCL.so.1.0’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib/i386-linux-gnu/libOpenCL.so.1’ (No such file or directory).
→ Unable to access previously installed symlink ‘/usr/lib/i386-linux-gnu/libOpenCL.so’ (No such file or directory).
→ done.
WARNING: Your driver installation has been altered since it was initially installed; this may happen, for example, if you have since installed the NVIDIA driver through a mechanism other than nvidia-installer (such as your distribution’s native package management system). nvidia-installer will attempt to uninstall as best it can. Please see the file ‘/var/log/nvidia-installer.log’ for details.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-34076 (340.76)):
→ DKMS module detected; removing…
→ Unable to restore symbolic link /usr/lib/nvidia-331/libGL.so → libGL.so.1 (No such file or directory).
→ Unable to restore symbolic link /usr/lib/nvidia-331/libGL.so.1 → libGL.so.331.113 (No such file or directory).
ERROR: Unable to create ‘/usr/lib/nvidia-331/libGL.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/libGL.so.331.113’.
ERROR: Unable to create ‘/usr/lib/nvidia-331/libnvidia-glcore.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/libnvidia-glcore.so.331.113’.
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libGL.so → libGL.so.1 (No such file or directory).
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libGL.so.1 → libGL.so.331.113 (No such file or directory).
ERROR: Unable to create ‘/usr/lib32/nvidia-331/libGL.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/libGL.so.331.113’.
ERROR: Unable to create ‘/usr/lib32/nvidia-331/libnvidia-glcore.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/libnvidia-glcore.so.331.113’.
ERROR: Unable to create ‘/usr/lib32/nvidia-331/libGL.la’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/libGL.la’.
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvidia-ml.so → libnvidia-ml.so.1 (No such file or directory).
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvidia-compiler.so.1 → libnvidia-compiler.so.331.113 (No such file or directory).
→ Unable to restore symbolic link /usr/lib/nvidia-331/vdpau/libvdpau_nvidia.so.1 → libvdpau_nvidia.so.331.113 (No such file or directory).
ERROR: Unable to create ‘/usr/lib/nvidia-331/vdpau/libvdpau_nvidia.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/vdpau/libvdpau_nvidia.so.331.113’.
→ Unable to restore symbolic link /usr/lib/nvidia-331/vdpau/libvdpau_nvidia.so → libvdpau_nvidia.so.1 (No such file or directory).
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvcuvid.so → libnvcuvid.so.1 (No such file or directory).
ERROR: Unable to create ‘/usr/lib/nvidia-331/libnvidia-ml.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/libnvidia-ml.so.331.113’.
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvidia-cfg.so.1 → libnvidia-cfg.so.331.113 (No such file or directory).
ERROR: Unable to create ‘/usr/lib/nvidia-331/libnvidia-ifr.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/libnvidia-ifr.so.331.113’.
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvidia-ifr.so → libnvidia-ifr.so.1 (No such file or directory).
ERROR: Unable to create ‘/usr/lib/nvidia-331/libnvidia-compiler.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/libnvidia-compiler.so.331.113’.
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvidia-ifr.so.1 → libnvidia-ifr.so.331.113 (No such file or directory).
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvidia-compiler.so → libnvidia-compiler.so.1 (No such file or directory).
ERROR: Unable to create ‘/usr/lib/nvidia-331/libnvcuvid.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/libnvcuvid.so.331.113’.
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvidia-ml.so.1 → libnvidia-ml.so.331.113 (No such file or directory).
ERROR: Unable to create ‘/usr/lib/nvidia-331/libnvidia-cfg.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/libnvidia-cfg.so.331.113’.
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvcuvid.so.1 → libnvcuvid.so.331.113 (No such file or directory).
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvidia-encode.so.1 → libnvidia-encode.so.331.113 (No such file or directory).
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvidia-encode.so → libnvidia-encode.so.1 (No such file or directory).
→ Unable to restore symbolic link /usr/lib/nvidia-331/libnvidia-cfg.so → libnvidia-cfg.so.1 (No such file or directory).
ERROR: Unable to create ‘/usr/lib/nvidia-331/libnvidia-encode.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/libnvidia-encode.so.331.113’.
→ Unable to restore symbolic link /usr/lib32/vdpau/libvdpau_nvidia.so.1 → /etc/alternatives/x86_64-linux-gnu_libvdpau_nvidia.so.1_lib32 (No such file or directory).
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvidia-ml.so → libnvidia-ml.so.1 (No such file or directory).
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvidia-compiler.so.1 → libnvidia-compiler.so.331.113 (No such file or directory).
→ Unable to restore symbolic link /usr/lib32/nvidia-331/vdpau/libvdpau_nvidia.so.1 → libvdpau_nvidia.so.331.113 (No such file or directory).
ERROR: Unable to create ‘/usr/lib32/nvidia-331/vdpau/libvdpau_nvidia.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/vdpau/libvdpau_nvidia.so.331.113’.
→ Unable to restore symbolic link /usr/lib32/nvidia-331/vdpau/libvdpau_nvidia.so → libvdpau_nvidia.so.1 (No such file or directory).
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvcuvid.so → libnvcuvid.so.1 (No such file or directory).
ERROR: Unable to create ‘/usr/lib32/nvidia-331/libnvidia-ml.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/libnvidia-ml.so.331.113’.
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvidia-cfg.so.1 → libnvidia-cfg.so.331.113 (No such file or directory).
ERROR: Unable to create ‘/usr/lib32/nvidia-331/libnvidia-ifr.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/libnvidia-ifr.so.331.113’.
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvidia-ifr.so → libnvidia-ifr.so.1 (No such file or directory).
ERROR: Unable to create ‘/usr/lib32/nvidia-331/libnvidia-compiler.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/libnvidia-compiler.so.331.113’.
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvidia-ifr.so.1 → libnvidia-ifr.so.331.113 (No such file or directory).
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvidia-compiler.so → libnvidia-compiler.so.1 (No such file or directory).
ERROR: Unable to create ‘/usr/lib32/nvidia-331/libnvcuvid.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/libnvcuvid.so.331.113’.
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvidia-ml.so.1 → libnvidia-ml.so.331.113 (No such file or directory).
ERROR: Unable to create ‘/usr/lib32/nvidia-331/libnvidia-cfg.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/libnvidia-cfg.so.331.113’.
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvcuvid.so.1 → libnvcuvid.so.331.113 (No such file or directory).
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvidia-encode.so.1 → libnvidia-encode.so.331.113 (No such file or directory).
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvidia-encode.so → libnvidia-encode.so.1 (No such file or directory).
→ Unable to restore symbolic link /usr/lib32/nvidia-331/libnvidia-cfg.so → libnvidia-cfg.so.1 (No such file or directory).
ERROR: Unable to create ‘/usr/lib32/nvidia-331/libnvidia-encode.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/libnvidia-encode.so.331.113’.
ERROR: Unable to create ‘/usr/lib/nvidia-331/libnvidia-tls.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/libnvidia-tls.so.331.113’.
ERROR: Unable to create ‘/usr/lib/nvidia-331/tls/libnvidia-tls.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib/nvidia-331/tls/libnvidia-tls.so.331.113’.
ERROR: Unable to create ‘/usr/lib32/nvidia-331/libnvidia-tls.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/libnvidia-tls.so.331.113’.
ERROR: Unable to create ‘/usr/lib32/nvidia-331/tls/libnvidia-tls.so.331.113’ for copying (No such file or directory)
→ Unable to restore file ‘/usr/lib32/nvidia-331/tls/libnvidia-tls.so.331.113’.
WARNING: Failed to restore some backed up files/symlinks, and/or their attributes. See /var/log/nvidia-installer.log for details
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (340.76) is complete.
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 26038 2015-02-16 10:50:01.208923240 -0800 /var/log/Xorg.0.log
[ 35.783]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[ 35.783] X Protocol Version 11, Revision 0
[ 35.783] Build Operating System: Linux 3.2.0-61-generic x86_64 Ubuntu
[ 35.783] Current Operating System: Linux Prefect 3.13.0-37-generic #64-Ubuntu SMP Mon Sep 22 21:28:38 UTC 2014 x86_64
[ 35.783] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.13.0-37-generic root=UUID=61d21e23-cedb-4561-8318-d8008a482b00 ro quiet splash text
[ 35.783] Build Date: 30 July 2014 12:21:54AM
[ 35.783] xorg-server 2:1.15.1-0ubuntu2.1 (For technical support please see Enterprise open source support | Ubuntu)
[ 35.783] Current version of pixman: 0.30.2
[ 35.783] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 35.783] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 35.783] (==) Log file: “/var/log/Xorg.0.log”, Time: Mon Feb 16 10:49:26 2015
[ 35.800] (==) Using config file: “/etc/X11/xorg.conf”
[ 35.800] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 35.811] (==) ServerLayout “Layout0”
[ 35.811] (
) |–>Screen “Screen0” (0)
[ 35.811] () | |–>Monitor “Monitor0”
[ 35.812] (
) | |–>Device “Device0”
[ 35.812] () |–>Input Device “Keyboard0”
[ 35.812] (
) |–>Input Device “Mouse0”
[ 35.812] (==) Automatically adding devices
[ 35.812] (==) Automatically enabling devices
[ 35.812] (==) Automatically adding GPU devices
[ 35.812] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 35.812] Entry deleted from font path.
[ 35.812] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 35.812] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 35.812] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 35.812] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 35.812] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 35.812] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 35.812] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 35.812] (WW) Disabling Keyboard0
[ 35.812] (WW) Disabling Mouse0
[ 35.812] (II) Loader magic: 0x7fdc7241cd40
[ 35.812] (II) Module ABI versions:
[ 35.812] X.Org ANSI C Emulation: 0.4
[ 35.812] X.Org Video Driver: 15.0
[ 35.812] X.Org XInput driver : 20.0
[ 35.812] X.Org Server Extension : 8.0
[ 35.812] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 35.812] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 35.813] (–) PCI:*(0:1:0:0) 10de:0a23:1462:8a93 rev 161, Mem @ 0xf3000000/16777216, 0xc0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000ac00/128, BIOS @ 0x???/131072
[ 35.813] (–) PCI: (0:2:0:0) 10de:0a23:1462:8a93 rev 161, Mem @ 0xf6000000/16777216, 0xd0000000/268435456, 0xf4000000/33554432, I/O @ 0x0000bc00/128, BIOS @ 0x???/131072
[ 35.813] Initializing built-in extension Generic Event Extension
[ 35.813] Initializing built-in extension SHAPE
[ 35.813] Initializing built-in extension MIT-SHM
[ 35.813] Initializing built-in extension XInputExtension
[ 35.813] Initializing built-in extension XTEST
[ 35.813] Initializing built-in extension BIG-REQUESTS
[ 35.813] Initializing built-in extension SYNC
[ 35.813] Initializing built-in extension XKEYBOARD
[ 35.813] Initializing built-in extension XC-MISC
[ 35.813] Initializing built-in extension SECURITY
[ 35.813] Initializing built-in extension XINERAMA
[ 35.813] Initializing built-in extension XFIXES
[ 35.813] Initializing built-in extension RENDER
[ 35.813] Initializing built-in extension RANDR
[ 35.813] Initializing built-in extension COMPOSITE
[ 35.813] Initializing built-in extension DAMAGE
[ 35.813] Initializing built-in extension MIT-SCREEN-SAVER
[ 35.813] Initializing built-in extension DOUBLE-BUFFER
[ 35.814] Initializing built-in extension RECORD
[ 35.814] Initializing built-in extension DPMS
[ 35.814] Initializing built-in extension Present
[ 35.814] Initializing built-in extension DRI3
[ 35.814] Initializing built-in extension X-Resource
[ 35.814] Initializing built-in extension XVideo
[ 35.814] Initializing built-in extension XVideo-MotionCompensation
[ 35.814] Initializing built-in extension SELinux
[ 35.814] Initializing built-in extension XFree86-VidModeExtension
[ 35.814] Initializing built-in extension XFree86-DGA
[ 35.814] Initializing built-in extension XFree86-DRI
[ 35.814] Initializing built-in extension DRI2
[ 35.814] (WW) “glamoregl” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 35.814] (II) “glx” will be loaded by default.
[ 35.814] (WW) “xmir” is not to be loaded by default. Skipping.
[ 35.814] (II) LoadModule: “glx”
[ 35.814] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 35.899] (II) Module glx: vendor=“NVIDIA Corporation”
[ 35.899] compiled for 4.0.2, module version = 1.0.0
[ 35.899] Module class: X.Org Server Extension
[ 35.900] (II) NVIDIA GLX Module 304.125 Mon Dec 1 20:22:48 PST 2014
[ 35.900] Loading extension GLX
[ 35.900] (II) LoadModule: “nvidia”
[ 35.900] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 35.900] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 35.900] compiled for 4.0.2, module version = 1.0.0
[ 35.900] Module class: X.Org Video Driver
[ 35.900] (II) NVIDIA dlloader X Driver 304.125 Mon Dec 1 20:00:30 PST 2014
[ 35.900] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 35.902] (++) using VT number 7
[ 35.904] (II) Loading sub module “fb”
[ 35.905] (II) LoadModule: “fb”
[ 35.905] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 35.905] (II) Module fb: vendor=“X.Org Foundation”
[ 35.905] compiled for 1.15.1, module version = 1.0.0
[ 35.905] ABI class: X.Org ANSI C Emulation, version 0.4
[ 35.905] (II) Loading sub module “wfb”
[ 35.905] (II) LoadModule: “wfb”
[ 35.906] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 35.920] (II) Module wfb: vendor=“X.Org Foundation”
[ 35.920] compiled for 1.15.1, module version = 1.0.0
[ 35.920] ABI class: X.Org ANSI C Emulation, version 0.4
[ 35.920] (II) Loading sub module “ramdac”
[ 35.920] (II) LoadModule: “ramdac”
[ 35.920] (II) Module “ramdac” already built-in
[ 35.933] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 35.933] (==) NVIDIA(0): RGB weight 888
[ 35.933] (==) NVIDIA(0): Default visual is TrueColor
[ 35.933] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 35.933] (
) NVIDIA(0): Option “SLI” “On”
[ 35.943] () NVIDIA(0): NVIDIA SLI auto-select rendering option.
[ 35.943] (
) NVIDIA(0): Enabling 2D acceleration
[ 37.745] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:2:0:0. Please
[ 37.745] (EE) NVIDIA(0): check your system’s kernel log for additional error
[ 37.745] (EE) NVIDIA(0): messages and refer to Chapter 8: Common Problems in the
[ 37.745] (EE) NVIDIA(0): README for additional information.
[ 37.745] (EE) NVIDIA(0): Failed to initialize one NVIDIA graphics device!
[ 37.745] (WW) NVIDIA(0): Failed to initialize SLI configuration. Reason: One GPU
[ 37.745] (WW) NVIDIA(0): failed to initialize; Only one GPU will be used for this X
[ 37.746] (WW) NVIDIA(0): screen.
[ 38.468] (II) NVIDIA(GPU-0): Display (DELL 1503FP (CRT-0)) does not support NVIDIA 3D
[ 38.468] (II) NVIDIA(GPU-0): Vision stereo.
[ 38.524] (II) NVIDIA(GPU-0): Display (AOC 2236 (DFP-1)) does not support NVIDIA 3D Vision
[ 38.524] (II) NVIDIA(GPU-0): stereo.
[ 38.528] (II) NVIDIA(0): NVIDIA GPU GeForce 210 (GT216) at PCI:1:0:0 (GPU-0)
[ 38.528] (–) NVIDIA(0): Memory: 1048576 kBytes
[ 38.528] (–) NVIDIA(0): VideoBIOS: 70.18.88.00.19
[ 38.528] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 38.528] (–) NVIDIA(0): Interlaced video modes are supported on this GPU
[ 38.534] (–) NVIDIA(0): Valid display device(s) on GeForce 210 at PCI:1:0:0
[ 38.534] (–) NVIDIA(0): DELL 1503FP (CRT-0) (connected)
[ 38.534] (–) NVIDIA(0): CRT-1
[ 38.534] (–) NVIDIA(0): DFP-0
[ 38.534] (–) NVIDIA(0): AOC 2236 (DFP-1) (connected)
[ 38.534] (–) NVIDIA(0): DELL 1503FP (CRT-0): 400.0 MHz maximum pixel clock
[ 38.534] (–) NVIDIA(0): CRT-1: 400.0 MHz maximum pixel clock
[ 38.534] (–) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 38.534] (–) NVIDIA(0): DFP-0: Internal Single Link TMDS
[ 38.534] (–) NVIDIA(0): AOC 2236 (DFP-1): 330.0 MHz maximum pixel clock
[ 38.534] (–) NVIDIA(0): AOC 2236 (DFP-1): Internal Dual Link TMDS
[ 38.534] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 38.534] (
) NVIDIA(0): device DELL 1503FP (CRT-0) (Using EDID frequencies has
[ 38.534] () NVIDIA(0): been enabled on all display devices.)
[ 38.536] (
[ 38.536] () NVIDIA(0): device AOC 2236 (DFP-1) (Using EDID frequencies has been
[ 38.536] (
) NVIDIA(0): enabled on all display devices.)
[ 38.541] (==) NVIDIA(0):
[ 38.541] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 38.541] (==) NVIDIA(0): will be used as the requested mode.
[ 38.541] (II) NVIDIA(0): Validated MetaModes:
[ 38.541] (II) NVIDIA(0): “CRT-0:nvidia-auto-select,DFP-1:nvidia-auto-select”
[ 38.541] (II) NVIDIA(0): Virtual screen size determined to be 2944 x 1080
[ 38.571] (–) NVIDIA(0): DPI set to (86, 88); computed from “UseEdidDpi” X config
[ 38.571] (–) NVIDIA(0): option
[ 38.571] (–) Depth 24 pixmap format is 32 bpp
[ 38.587] (EE) NVIDIA(GPU-1): Failed to initialize the NVIDIA GPU at PCI:2:0:0. Please
[ 38.587] (EE) NVIDIA(GPU-1): check your system’s kernel log for additional error
[ 38.587] (EE) NVIDIA(GPU-1): messages and refer to Chapter 8: Common Problems in the
[ 38.587] (EE) NVIDIA(GPU-1): README for additional information.
[ 38.587] (EE) NVIDIA(GPU-1): Failed to initialize the NVIDIA graphics device!
[ 38.587] (II) NVIDIA: Using 768.00 MB of virtual memory for indirect memory access.
[ 38.598] (II) NVIDIA(0): Setting mode “CRT-0:nvidia-auto-select,DFP-1:nvidia-auto-select”
[ 38.663] Loading extension NV-GLX
[ 38.699] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 38.699] (==) NVIDIA(0): Backing store enabled
[ 38.699] (==) NVIDIA(0): Silken mouse enabled
[ 38.700] () NVIDIA(0): DPMS enabled
[ 38.700] Loading extension NV-CONTROL
[ 38.700] Loading extension XINERAMA
[ 38.700] (II) Loading sub module “dri2”
[ 38.700] (II) LoadModule: “dri2”
[ 38.700] (II) Module “dri2” already built-in
[ 38.700] (II) NVIDIA(0): [DRI2] Setup complete
[ 38.700] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 38.700] (–) RandR disabled
[ 38.704] (II) SELinux: Disabled on system
[ 38.704] (II) Initializing extension GLX
[ 38.731] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 38.733] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 38.733] (
) Power Button: Applying InputClass “evdev keyboard catchall”
[ 38.733] (II) LoadModule: “evdev”
[ 38.733] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 38.745] (II) Module evdev: vendor=“X.Org Foundation”
[ 38.745] compiled for 1.15.0, module version = 2.8.2
[ 38.745] Module class: X.Org XInput Driver
[ 38.745] ABI class: X.Org XInput driver, version 20.0
[ 38.745] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 38.745] () Power Button: always reports core events
[ 38.745] (
) evdev: Power Button: Device: “/dev/input/event1”
[ 38.745] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 38.745] (–) evdev: Power Button: Found keys
[ 38.745] (II) evdev: Power Button: Configuring as keyboard
[ 38.745] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1”
[ 38.745] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 38.745] (
) Option “xkb_rules” “evdev”
[ 38.745] () Option “xkb_model” “pc105”
[ 38.745] (
) Option “xkb_layout” “us”
[ 38.745] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 38.745] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 38.746] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 38.746] (
[ 38.746] () evdev: Power Button: Device: “/dev/input/event0”
[ 38.746] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 38.746] (–) evdev: Power Button: Found keys
[ 38.746] (II) evdev: Power Button: Configuring as keyboard
[ 38.746] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0”
[ 38.746] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 38.746] () Option “xkb_rules” “evdev”
[ 38.746] (
[ 38.746] () Option “xkb_layout” “us”
[ 38.746] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/pci0000:00/0000:00:03.0/0000:01:00.0/drm/card0
[ 38.746] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[ 38.746] (II) config/udev: Adding drm device (/dev/dri/card1) card1 /sys/devices/pci0000:00/0000:00:05.0/0000:02:00.0/drm/card1
[ 38.746] (II) config/udev: Ignoring already known drm device (/dev/dri/card1)
[ 38.746] (II) config/udev: Adding input device HDA Intel MID Line (/dev/input/event10)
[ 38.746] (II) No input driver specified, ignoring this device.
[ 38.746] (II) This device may have been added with another device file.
[ 38.746] (II) config/udev: Adding input device HDA Intel MID Line Out Front (/dev/input/event9)
[ 38.746] (II) config/udev: Adding input device HDA Intel MID Line Out Surround (/dev/input/event8)
[ 38.747] (II) config/udev: Adding input device HDA Intel MID Line Out CLFE (/dev/input/event7)
[ 38.747] (II) No input driver specified, ignoring this device.
[ 38.747] (II) This device may have been added with another device file.
[ 38.747] (II) config/udev: Adding input device HDA Intel MID Line Out Side (/dev/input/event6)
[ 38.747] (II) config/udev: Adding input device HDA Intel MID Front Headphone (/dev/input/event5)
[ 38.747] (II) config/udev: Adding input device HDA Intel MID Front Mic (/dev/input/event12)
[ 38.747] (II) config/udev: Adding input device HDA Intel MID Rear Mic (/dev/input/event11)
[ 38.747] (II) config/udev: Adding input device Logitech Optical USB Mouse (/dev/input/event2)
[ 38.748] (
) Logitech Optical USB Mouse: Applying InputClass “evdev pointer catchall”
[ 38.748] (II) Using input driver ‘evdev’ for ‘Logitech Optical USB Mouse’
[ 38.748] () Logitech Optical USB Mouse: always reports core events
[ 38.748] (
) evdev: Logitech Optical USB Mouse: Device: “/dev/input/event2”
[ 38.748] (–) evdev: Logitech Optical USB Mouse: Vendor 0x46d Product 0xc016
[ 38.748] (–) evdev: Logitech Optical USB Mouse: Found 3 mouse buttons
[ 38.748] (–) evdev: Logitech Optical USB Mouse: Found scroll wheel(s)
[ 38.748] (–) evdev: Logitech Optical USB Mouse: Found relative axes
[ 38.748] (–) evdev: Logitech Optical USB Mouse: Found x and y relative axes
[ 38.748] (II) evdev: Logitech Optical USB Mouse: Configuring as mouse
[ 38.748] (II) evdev: Logitech Optical USB Mouse: Adding scrollwheel support
[ 38.748] () evdev: Logitech Optical USB Mouse: YAxisMapping: buttons 4 and 5
[ 38.748] (
) evdev: Logitech Optical USB Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 38.748] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/input/input5/event2”
[ 38.748] (II) XINPUT: Adding extended input device “Logitech Optical USB Mouse” (type: MOUSE, id 8)
[ 38.748] (II) evdev: Logitech Optical USB Mouse: initialized for relative axes.
[ 38.748] (
) Logitech Optical USB Mouse: (accel) keeping acceleration scheme 1
[ 38.748] () Logitech Optical USB Mouse: (accel) acceleration profile 0
[ 38.748] (
) Logitech Optical USB Mouse: (accel) acceleration factor: 2.000
[ 38.748] () Logitech Optical USB Mouse: (accel) acceleration threshold: 4
[ 38.748] (II) config/udev: Adding input device Logitech Optical USB Mouse (/dev/input/mouse0)
[ 38.748] (II) No input driver specified, ignoring this device.
[ 38.748] (II) This device may have been added with another device file.
[ 38.748] (II) config/udev: Adding input device Microsoft Wired Keyboard 600 (/dev/input/event3)
[ 38.748] (
) Microsoft Wired Keyboard 600: Applying InputClass “evdev keyboard catchall”
[ 38.748] (II) Using input driver ‘evdev’ for ‘Microsoft Wired Keyboard 600’
[ 38.748] () Microsoft Wired Keyboard 600: always reports core events
[ 38.748] (
) evdev: Microsoft Wired Keyboard 600: Device: “/dev/input/event3”
[ 38.748] (–) evdev: Microsoft Wired Keyboard 600: Vendor 0x45e Product 0x750
[ 38.748] (–) evdev: Microsoft Wired Keyboard 600: Found keys
[ 38.748] (II) evdev: Microsoft Wired Keyboard 600: Configuring as keyboard
[ 38.748] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/input/input6/event3”
[ 38.748] (II) XINPUT: Adding extended input device “Microsoft Wired Keyboard 600” (type: KEYBOARD, id 9)
[ 38.748] (
[ 38.748] () Option “xkb_model” “pc105”
[ 38.748] (
[ 38.749] (II) config/udev: Adding input device Microsoft Wired Keyboard 600 (/dev/input/event4)
[ 38.749] () Microsoft Wired Keyboard 600: Applying InputClass “evdev keyboard catchall”
[ 38.749] (II) Using input driver ‘evdev’ for ‘Microsoft Wired Keyboard 600’
[ 38.749] (
[ 38.749] () evdev: Microsoft Wired Keyboard 600: Device: “/dev/input/event4”
[ 38.749] (II) evdev: Microsoft Wired Keyboard 600: Using mtdev for this device
[ 38.749] (–) evdev: Microsoft Wired Keyboard 600: Vendor 0x45e Product 0x750
[ 38.749] (–) evdev: Microsoft Wired Keyboard 600: Found 1 mouse buttons
[ 38.749] (–) evdev: Microsoft Wired Keyboard 600: Found scroll wheel(s)
[ 38.749] (–) evdev: Microsoft Wired Keyboard 600: Found relative axes
[ 38.749] (–) evdev: Microsoft Wired Keyboard 600: Found absolute axes
[ 38.749] (–) evdev: Microsoft Wired Keyboard 600: Found absolute multitouch axes
[ 38.749] (–) evdev: Microsoft Wired Keyboard 600: Found x and y absolute axes
[ 38.749] (–) evdev: Microsoft Wired Keyboard 600: Found keys
[ 38.749] (II) evdev: Microsoft Wired Keyboard 600: Forcing relative x/y axes to exist.
[ 38.749] (II) evdev: Microsoft Wired Keyboard 600: Configuring as mouse
[ 38.749] (II) evdev: Microsoft Wired Keyboard 600: Configuring as keyboard
[ 38.749] (II) evdev: Microsoft Wired Keyboard 600: Adding scrollwheel support
[ 38.749] (
) evdev: Microsoft Wired Keyboard 600: YAxisMapping: buttons 4 and 5
[ 38.749] () evdev: Microsoft Wired Keyboard 600: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 38.749] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.1/input/input7/event4”
[ 38.749] (II) XINPUT: Adding extended input device “Microsoft Wired Keyboard 600” (type: KEYBOARD, id 10)
[ 38.749] () Option “xkb_rules” “evdev”
[ 38.749] (
[ 38.749] () Option “xkb_layout” “us”
[ 38.749] (II) evdev: Microsoft Wired Keyboard 600: initialized for relative axes.
[ 38.749] (WW) evdev: Microsoft Wired Keyboard 600: ignoring absolute axes.
[ 38.749] (
) Microsoft Wired Keyboard 600: (accel) keeping acceleration scheme 1
[ 38.749] () Microsoft Wired Keyboard 600: (accel) acceleration profile 0
[ 38.749] (
) Microsoft Wired Keyboard 600: (accel) acceleration factor: 2.000
[ 38.749] () Microsoft Wired Keyboard 600: (accel) acceleration threshold: 4
[ 38.750] (II) config/udev: Adding input device Microsoft Wired Keyboard 600 (/dev/input/js0)
[ 38.750] (II) No input driver specified, ignoring this device.
[ 38.750] (II) This device may have been added with another device file.
[ 48.040] (II) NVIDIA(GPU-0): Display (DELL 1503FP (CRT-0)) does not support NVIDIA 3D
[ 48.040] (II) NVIDIA(GPU-0): Vision stereo.
[ 48.040] (
[ 48.040] () NVIDIA(0): device DELL 1503FP (CRT-0) (Using EDID frequencies has
[ 48.040] (
[ 48.094] (II) NVIDIA(GPU-0): Display (AOC 2236 (DFP-1)) does not support NVIDIA 3D Vision
[ 48.094] (II) NVIDIA(GPU-0): stereo.
[ 48.094] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 48.094] (
[ 48.094] () NVIDIA(0): enabled on all display devices.)
[ 48.482] (II) NVIDIA(0): Setting mode “DVI-I-0: nvidia-auto-select @1024x768 +1920+548, DVI-I-3: nvidia-auto-select @1920x1080 +0+0”
[ 48.870] (II) NVIDIA(GPU-0): Display (DELL 1503FP (CRT-0)) does not support NVIDIA 3D
[ 48.870] (II) NVIDIA(GPU-0): Vision stereo.
[ 48.870] (
[ 48.870] () NVIDIA(0): device DELL 1503FP (CRT-0) (Using EDID frequencies has
[ 48.870] (
[ 48.927] (II) NVIDIA(GPU-0): Display (AOC 2236 (DFP-1)) does not support NVIDIA 3D Vision
[ 48.927] (II) NVIDIA(GPU-0): stereo.
[ 48.927] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 48.927] (
[ 48.927] () NVIDIA(0): enabled on all display devices.)
[ 49.124] (II) NVIDIA(GPU-0): Display (DELL 1503FP (CRT-0)) does not support NVIDIA 3D
[ 49.124] (II) NVIDIA(GPU-0): Vision stereo.
[ 49.124] (
[ 49.124] () NVIDIA(0): device DELL 1503FP (CRT-0) (Using EDID frequencies has
[ 49.124] (
[ 49.181] (II) NVIDIA(GPU-0): Display (AOC 2236 (DFP-1)) does not support NVIDIA 3D Vision
[ 49.181] (II) NVIDIA(GPU-0): stereo.
[ 49.181] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 49.181] (
[ 49.181] () NVIDIA(0): enabled on all display devices.)
[ 49.596] (II) XKB: reuse xkmfile /var/lib/xkb/server-8AA988DD479FAABEC4FC3CCCF4CC29B4948840B4.xkm
[ 49.601] (II) XKB: reuse xkmfile /var/lib/xkb/server-1908D3BB0224FA577B58A32F49D8B4107F7BAFFD.xkm
[ 53.155] (II) XKB: reuse xkmfile /var/lib/xkb/server-1908D3BB0224FA577B58A32F49D8B4107F7BAFFD.xkm
[ 53.157] (II) XKB: reuse xkmfile /var/lib/xkb/server-1908D3BB0224FA577B58A32F49D8B4107F7BAFFD.xkm
[ 53.160] (II) XKB: reuse xkmfile /var/lib/xkb/server-1908D3BB0224FA577B58A32F49D8B4107F7BAFFD.xkm
[ 53.163] (II) XKB: reuse xkmfile /var/lib/xkb/server-1908D3BB0224FA577B58A32F49D8B4107F7BAFFD.xkm
[ 53.166] (II) XKB: reuse xkmfile /var/lib/xkb/server-1908D3BB0224FA577B58A32F49D8B4107F7BAFFD.xkm
[ 53.168] (II) XKB: reuse xkmfile /var/lib/xkb/server-1908D3BB0224FA577B58A32F49D8B4107F7BAFFD.xkm
[ 70.366] (II) NVIDIA(GPU-0): Display (DELL 1503FP (CRT-0)) does not support NVIDIA 3D
[ 70.366] (II) NVIDIA(GPU-0): Vision stereo.
[ 70.366] (
[ 70.366] () NVIDIA(0): device DELL 1503FP (CRT-0) (Using EDID frequencies has
[ 70.366] (
[ 70.424] (II) NVIDIA(GPU-0): Display (AOC 2236 (DFP-1)) does not support NVIDIA 3D Vision
[ 70.424] (II) NVIDIA(GPU-0): stereo.
[ 70.424] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 70.424] (
[ 70.424] (**) NVIDIA(0): enabled on all display devices.)
*** /etc/X11/xorg.conf
*** ls: -rw-r–r-- 1 root root 1573 2015-02-16 10:48:18.340385517 -0800 /etc/X11/xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 304.125 (buildmeister@swio-display-x64-rhel04-14) Mon Dec 1 21:18:22 PST 2014
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier     "Mouse0"
Driver         "mouse"
Option         "Protocol" "auto"
Option         "Device" "/dev/psaux"
Option         "Emulate3Buttons" "no"
Option         "ZAxisMapping" "4 5"
EndSection
Identifier     "Keyboard0"
Driver         "kbd"
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
BusID “PCI:1:0:0”
EndSection
Section “Device”
Identifier “Device1”
Driver “nvidia”
BusID “PCI:2:0:0”
Screen 0
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
Option “SLI” “On”
SubSection “Display”
Depth 24
EndSubSection
EndSection
*** /usr/share/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2014-07-29 17:23:44.000000000 -0700 /usr/share/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems
We don’t simply match on any device since that also adds accelerometers
and other devices that we don’t really want to use. The list below
matches everything but joysticks.
Section “InputClass”
Identifier “evdev pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “evdev”
EndSection
Identifier “evdev keyboard catchall”
MatchIsKeyboard “on”
Driver “evdev”
EndSection
Identifier “evdev touchpad catchall”
MatchIsTouchpad “on”
Driver “evdev”
EndSection
Identifier “evdev tablet catchall”
MatchIsTablet “on”
Driver “evdev”
EndSection
Identifier “evdev touchscreen catchall”
MatchIsTouchscreen “on”
Driver “evdev”
EndSection
*** /usr/share/X11/xorg.conf.d/10-quirks.conf
*** ls: -rw-r–r-- 1 root root 1867 2014-07-29 17:23:44.000000000 -0700 /usr/share/X11/xorg.conf.d/10-quirks.conf
Collection of quirks and blacklist/whitelists for specific devices.
Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
22442 – ThinkPad HDAPS accelerometer gets recognized as MOUSE and makes Xorg unusable
Identifier “ThinkPad HDAPS accelerometer blacklist”
MatchProduct “ThinkPad HDAPS accelerometer data”
Option “Ignore” “on”
EndSection
523914 – Mouse does not move in PV Xen guest under RHEL-5.4
Explicitly tell evdev to not ignore the absolute axes.
Identifier “Xen Virtual Pointer axis blacklist”
MatchProduct “Xen Virtual Pointer”
Option “IgnoreAbsoluteAxes” “off”
Option “IgnoreRelativeAxes” “off”
EndSection
612140 – please make Evoluent VerticalMouse 3 work out of the box
Button mapping on this mouse is quirky
Identifier “Evoluent VerticalMouse 3”
MatchProduct “Evoluent VerticalMouse 3”
# Sets following configuration:
# top button: left
# middle button: middle
# bottom button: right
# wheel click: middle
# thumb button: 8 (back)
Option “ButtonMapping” “1 2 2 4 5 6 7 3 8”
EndSection
55867 – Doesn't know how to tag XI_TRACKBALL
Bug 55867 - Doesn’t know how to tag XI_TRACKBALL
Identifier “Tag trackballs as XI_TRACKBALL”
MatchProduct “trackball”
MatchDriver “evdev”
Option “TypeName” “TRACKBALL”
EndSection
62831 – Mionix Naos 5000 mouse detected incorrectly
Bug 62831 - Mionix Naos 5000 mouse detected incorrectly
Identifier “Tag Mionix Naos 5000 mouse XI_MOUSE”
MatchProduct “La-VIEW Technology Naos 5000 Mouse”
MatchDriver “evdev”
Option “TypeName” “MOUSE”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2014-02-05 01:44:53.000000000 -0800 /usr/share/X11/xorg.conf.d/11-evdev-quirks.conf
Identifier “Avago Technologies mouse quirks (LP: #746639)”
MatchIsPointer “on”
Driver “evdev”
MatchUSBID “192f:0416”
Option “Emulate3Buttons” “True”
Option “Emulate3Timeout” “50”
EndSection
X/Y axis not working due to device reporting absolute axes
Bug #325581 “kensington pocket mouse model #72237 USB 0d62:1000 ...” : Bugs : xserver-xorg-input-evdev package : Ubuntu
32882 – kensington pocket mouse model #72237 USB 0d62:1000 not working
Identifier “Benq m310”
MatchProduct “HID 0d62:1000”
Driver “evdev”
Option “IgnoreAbsoluteAxes” “true”
EndSection
*** /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
*** ls: -rw-r–r-- 1 root root 364 2014-02-05 01:44:53.000000000 -0800 /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
trackpoint users want wheel emulation
Identifier “trackpoint catchall”
MatchIsPointer “true”
MatchProduct “TrackPoint|DualPoint Stick”
Option “Emulate3Buttons” “true”
Option “EmulateWheel” “true”
Option “EmulateWheelButton” “2”
Option “XAxisMapping” “6 7”
Option “YAxisMapping” “4 5”
EndSection
*** /usr/share/X11/xorg.conf.d/50-synaptics.conf
*** ls: -rw-r–r-- 1 root root 1757 2014-04-10 03:04:29.000000000 -0700 /usr/share/X11/xorg.conf.d/50-synaptics.conf
Example xorg.conf.d snippet that assigns the touchpad driver
to all touchpads. See xorg.conf.d(5) for more information on
InputClass.
DO NOT EDIT THIS FILE, your distribution will likely overwrite
it when updating. Copy (and rename) this file into
/etc/X11/xorg.conf.d first.
Additional options may be added in the form of
Option “OptionName” “value”
Identifier “touchpad catchall”
Driver “synaptics”
This option is recommend on all Linux systems using evdev, but cannot be
enabled by default. See the following link for details:
Who-T: How to ignore configuration errors
  MatchDevicePath "/dev/input/event*"
EndSection
Identifier “touchpad ignore duplicates”
MatchOS “Linux”
MatchDevicePath “/dev/input/mouse*”
EndSection
This option enables the bottom right corner to be a right button on
non-synaptics clickpads.
This option is only interpreted by clickpads.
Identifier “Default clickpad buttons”
MatchDriver “synaptics”
Option “SoftButtonAreas” “50% 0 82% 0 0 0 0 0”
To disable the bottom edge area so the buttons only work as buttons,
not for movement, set the AreaBottomEdge
Option “AreaBottomEdge” “82%”
EndSection
This option disables software buttons on Apple touchpads.
Identifier “Disable clickpad buttons on Apple touchpads”
MatchProduct “Apple|bcm5974”
Option “SoftButtonAreas” “0 0 0 0 0 0 0 0”
EndSection
*** /usr/share/X11/xorg.conf.d/50-vmmouse.conf
*** ls: -rw-r–r-- 1 root root 115 2014-02-05 01:48:03.000000000 -0800 /usr/share/X11/xorg.conf.d/50-vmmouse.conf
Identifier “vmmouse”
MatchIsPointer “on”
MatchTag “vmmouse”
Driver “vmmouse”
EndSection
*** /usr/share/X11/xorg.conf.d/50-wacom.conf
*** ls: -rw-r–r-- 1 root root 842 2014-02-05 01:36:00.000000000 -0800 /usr/share/X11/xorg.conf.d/50-wacom.conf
Identifier “Wacom class”
MatchProduct “Wacom|WACOM|Hanwang|PTK-540WL|ISD-V4”
Driver “wacom”
EndSection
Identifier “Wacom serial class”
MatchProduct “Serial Wacom Tablet”
Driver “wacom”
EndSection
Identifier “Wacom serial class identifiers”
MatchProduct “WACf|FUJ02e5|FUJ02e7|FUJ02e9”
Driver “wacom”
EndSection
Waltop tablets
Identifier “Waltop class”
MatchProduct “WALTOP”
MatchIsTablet “on”
Driver “wacom”
EndSection
N-Trig Duosense Electromagnetic Digitizer
Identifier “Wacom N-Trig class”
MatchProduct “HID 1b96:0001|N-Trig Pen”
Driver “wacom”
Option “Button2” “3”
EndSection
*** /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
*** ls: -rw-r–r-- 1 root root 590 2014-04-10 03:04:08.000000000 -0700 /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
Identifier “Dell Inspiron embedded buttons quirks”
MatchTag “inspiron_1011|inspiron_1012”
Driver “synaptics”
Option “JumpyCursorThreshold” “90”
EndSection
Identifier “Dell Inspiron quirks”
MatchTag “inspiron_1120”
Driver “synaptics”
Option “JumpyCursorThreshold” “250”
EndSection
Identifier “HP Mininote quirks”
MatchTag “mininote_1000”
Driver “synaptics”
Option “JumpyCursorThreshold” “20”
EndSection
*** /usr/share/X11/xorg.conf.d/glamoregl.conf
*** ls: lrwxrwxrwx 1 root root 29 2015-02-14 15:53:16.587678293 -0800 /usr/share/X11/xorg.conf.d/glamoregl.conf → /etc/alternatives/glamor_conf
Section “Module”
Disable “glamoregl”
EndSection
ldd /usr/bin/glxinfo
linux-vdso.so.1 =>  (0x00007fffff2c1000)
libGL.so.1 => /usr/lib/nvidia-304/libGL.so.1 (0x00007ffb90ecc000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007ffb90b97000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007ffb907d0000)
libnvidia-tls.so.304.125 => /usr/lib/nvidia-304/tls/libnvidia-tls.so.304.125 (0x00007ffb905cd000)
libnvidia-glcore.so.304.125 => /usr/lib/nvidia-304/libnvidia-glcore.so.304.125 (0x00007ffb8e1e3000)
libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007ffb8dfd0000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007ffb8ddcc000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007ffb8dbad000)
/lib64/ld-linux-x86-64.so.2 (0x00007ffb9120b000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007ffb8d8a6000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007ffb8d6a2000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007ffb8d49c000)
/usr/bin/lspci -d “10de:*” -v -xxx
01:00.0 VGA compatible controller: NVIDIA Corporation GT216 [GeForce 210] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 8a93
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at f3000000 (32-bit, non-prefetchable)
Memory at c0000000 (64-bit, prefetchable)
Memory at f0000000 (64-bit, non-prefetchable)
I/O ports at ac00
[virtual] Expansion ROM at f2fe0000 [disabled]
Capabilities: [60] Power Management version 2
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?> Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nvidia
00: de 10 23 0a 07 00 10 00 a1 00 00 03 00 00 00 00
10: 00 00 00 f3 0c 00 00 c0 00 00 00 00 04 00 00 f0
20: 00 00 00 00 01 ac 00 00 00 00 00 00 62 14 93 8a
30: 00 00 00 00 60 00 00 00 00 00 00 00 0a 01 00 00
40: 62 14 93 8a 00 00 00 00 00 00 00 00 00 00 00 00
50: 01 00 00 00 01 00 00 00 ce d6 23 00 20 00 00 00
60: 01 68 02 00 00 00 00 00 05 78 80 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 00 01 00 e0 84 64 00
80: 10 29 00 00 01 3d 01 00 48 00 81 10 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
02:00.0 VGA compatible controller: NVIDIA Corporation GT216 [GeForce 210] (rev a1) (prog-if 00 [VGA controller])
Memory at f6000000 (32-bit, non-prefetchable)
Memory at d0000000 (64-bit, prefetchable)
Memory at f4000000 (64-bit, non-prefetchable)
I/O ports at bc00
[virtual] Expansion ROM at f7ce0000 [disabled]
10: 00 00 00 f6 0c 00 00 d0 00 00 00 00 04 00 00 f4
20: 00 00 00 00 01 bc 00 00 00 00 00 00 62 14 93 8a
80: 10 28 00 00 01 3d 01 02 48 00 81 10 00 00 00 00
/usr/bin/lspci -d “10b5:*” -v -xxx
/usr/bin/lspci -t
-±[0000:3f]-±00.0
| ±00.1
| ±02.0
| ±02.1
| ±03.0
| ±03.1
| ±03.4
| ±04.0
| ±04.1
| ±04.2
| ±04.3
| ±05.0
| ±05.1
| ±05.2
| -05.3
-[0000:00]-±00.0
±03.0-[01]----00.0
±05.0-[02]----00.0
±08.0
±08.1
±08.2
±08.3
±10.0
±10.1
±1a.0
±1b.0
±1c.0-[07]–
±1c.4-[06]–
±1c.5-[05]–
±1c.6-[04]–±00.0
| -00.1
±1c.7-[03]----00.0
±1d.0
±1e.0-[08]----03.0
±1f.0
±1f.2
±1f.3
-1f.5
/usr/bin/lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation Core Processor DMI [8086:d131] (rev 11)
00:03.0 PCI bridge [0604]: Intel Corporation Core Processor PCI Express Root Port 1 [8086:d138] (rev 11)
00:05.0 PCI bridge [0604]: Intel Corporation Core Processor PCI Express Root Port 3 [8086:d13a] (rev 11)
00:08.0 System peripheral [0880]: Intel Corporation Core Processor System Management Registers [8086:d155] (rev 11)
00:08.1 System peripheral [0880]: Intel Corporation Core Processor Semaphore and Scratchpad Registers [8086:d156] (rev 11)
00:08.2 System peripheral [0880]: Intel Corporation Core Processor System Control and Status Registers [8086:d157] (rev 11)
00:08.3 System peripheral [0880]: Intel Corporation Core Processor Miscellaneous Registers [8086:d158] (rev 11)
00:10.0 System peripheral [0880]: Intel Corporation Core Processor QPI Link [8086:d150] (rev 11)
00:10.1 System peripheral [0880]: Intel Corporation Core Processor QPI Routing and Protocol Registers [8086:d151] (rev 11)
00:1a.0 USB controller [0c03]: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller [8086:3b3c] (rev 05)
00:1b.0 Audio device [0403]: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio [8086:3b56] (rev 05)
00:1c.0 PCI bridge [0604]: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 [8086:3b42] (rev 05)
00:1c.4 PCI bridge [0604]: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 [8086:3b4a] (rev 05)
00:1c.5 PCI bridge [0604]: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 6 [8086:3b4c] (rev 05)
00:1c.6 PCI bridge [0604]: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 7 [8086:3b4e] (rev 05)
00:1c.7 PCI bridge [0604]: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 8 [8086:3b50] (rev 05)
00:1d.0 USB controller [0c03]: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller [8086:3b34] (rev 05)
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 PCI Bridge [8086:244e] (rev a5)
00:1f.0 ISA bridge [0601]: Intel Corporation 5 Series Chipset LPC Interface Controller [8086:3b02] (rev 05)
00:1f.2 IDE interface [0101]: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA IDE Controller [8086:3b20] (rev 05)
00:1f.3 SMBus [0c05]: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller [8086:3b30] (rev 05)
00:1f.5 IDE interface [0101]: Intel Corporation 5 Series/3400 Series Chipset 2 port SATA IDE Controller [8086:3b26] (rev 05)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GT216 [GeForce 210] [10de:0a23] (rev a1)
02:00.0 VGA compatible controller [0300]: NVIDIA Corporation GT216 [GeForce 210] [10de:0a23] (rev a1)
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 03)
04:00.0 SATA controller [0106]: JMicron Technology Corp. JMB363 SATA/IDE Controller [197b:2363] (rev 03)
04:00.1 IDE interface [0101]: JMicron Technology Corp. JMB363 SATA/IDE Controller [197b:2363] (rev 03)
08:03.0 FireWire (IEEE 1394) [0c00]: VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller [1106:3044] (rev c0)
3f:00.0 Host bridge [0600]: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers [8086:2c51] (rev 04)
3f:00.1 Host bridge [0600]: Intel Corporation Core Processor QuickPath Architecture System Address Decoder [8086:2c81] (rev 04)
3f:02.0 Host bridge [0600]: Intel Corporation Core Processor QPI Link 0 [8086:2c90] (rev 04)
3f:02.1 Host bridge [0600]: Intel Corporation Core Processor QPI Physical 0 [8086:2c91] (rev 04)
3f:03.0 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller [8086:2c98] (rev 04)
3f:03.1 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder [8086:2c99] (rev 04)
3f:03.4 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller Test Registers [8086:2c9c] (rev 04)
3f:04.0 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers [8086:2ca0] (rev 04)
3f:04.1 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers [8086:2ca1] (rev 04)
3f:04.2 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers [8086:2ca2] (rev 04)
3f:04.3 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers [8086:2ca3] (rev 04)
3f:05.0 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers [8086:2ca8] (rev 04)
3f:05.1 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers [8086:2ca9] (rev 04)
3f:05.2 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers [8086:2caa] (rev 04)
3f:05.3 Host bridge [0600]: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers [8086:2cab] (rev 04)
/usr/bin/lsusb
Bus 002 Device 004: ID 045e:0750 Microsoft Corp. Wired Keyboard 600
Bus 002 Device 003: ID 046d:c016 Logitech, Inc. Optical Wheel Mouse
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
/usr/sbin/dmidecode
dmidecode 2.12
SMBIOS 2.6 present.
68 structures occupying 2479 bytes.
Table at 0x000F0710.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: 2101
Release Date: 09/27/2012
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 2048 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is suppor
Looks like there was a problem inserting the log in my previous post (very sorry about that, not sure why).
I will try again here:
[code]____________________________________________
command line flags:
*** /etc/issue
jessie/sid
-s
→ Parsing log file:
→ done.
→ done.
→ done.
[ 35.783]
[ 35.811] (
[ 35.812] (
[ 35.812] (
built-ins
[ 35.933] (
[ 35.943] (
[ 38.534] (
[ 38.536] (
[ 38.536] (
[ 38.733] (
[ 38.745] (
[ 38.745] (
[ 38.745] (
[ 38.746] (
[ 38.746] (
[ 38.746] (
[ 38.748] (
[ 38.748] (
[ 38.748] (
[ 38.748] (
[ 38.748] (
[ 38.748] (
[ 38.748] (
[ 38.748] (
[ 38.748] (
[ 38.749] (
[ 38.749] (
[ 38.749] (
[ 38.749] (
[ 38.749] (
[ 38.749] (
[ 48.040] (
[ 48.040] (
[ 48.094] (
[ 48.870] (
[ 48.870] (
[ 48.927] (
[ 49.124] (
[ 49.124] (
[ 49.181] (
[ 70.366] (
[ 70.366] (
[ 70.424] (
EndSection
Section “Files”
EndSection
Identifier     "Mouse0"
Driver         "mouse"
EndSection
Driver         "kbd"
EndSection
Section “Monitor”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Device”
Driver “nvidia”
BusID “PCI:1:0:0”
EndSection
Section “Device”
Driver “nvidia”
BusID “PCI:2:0:0”
Screen 0
EndSection
Section “Screen”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
Option “SLI” “On”
Depth 24
EndSubSection
EndSection
MatchIsPointer “on”
Driver “evdev”
EndSection
Driver “evdev”
EndSection
Driver “evdev”
EndSection
MatchIsTablet “on”
Driver “evdev”
EndSection
Driver “evdev”
EndSection
EndSection
EndSection
# top button: left
EndSection
MatchDriver “evdev”
EndSection
MatchDriver “evdev”
EndSection
MatchIsPointer “on”
Driver “evdev”
EndSection
Driver “evdev”
EndSection
EndSection
InputClass.
Driver “synaptics”
EndSection
MatchOS “Linux”
EndSection
EndSection
EndSection
MatchIsPointer “on”
MatchTag “vmmouse”
Driver “vmmouse”
EndSection
Driver “wacom”
EndSection
Driver “wacom”
EndSection
Driver “wacom”
EndSection
Waltop tablets
MatchIsTablet “on”
Driver “wacom”
EndSection
Driver “wacom”
EndSection
Driver “synaptics”
EndSection
Driver “synaptics”
EndSection
Driver “synaptics”
EndSection
Section “Module”
Disable “glamoregl”
EndSection
I/O ports at ac00
I/O ports at bc00
/usr/bin/lspci -t
-±[0000:3f]-±00.0
| ±00.1
| ±02.0
| ±02.1
| ±03.0
| ±03.1
| ±03.4
| ±04.0
| ±04.1
| ±04.2
| ±04.3
| ±05.0
| ±05.1
| ±05.2
| -05.3
-[0000:00]-±00.0
±03.0-[01]----00.0
±05.0-[02]----00.0
±08.0
±08.1
±08.2
±08.3
±10.0
±10.1
±1a.0
±1b.0
±1c.0-[07]–
±1c.4-[06]–
±1c.5-[05]–
±1c.6-[04]–±00.0
| -00.1
±1c.7-[03]----00.0
±1d.0
±1e.0-[08]----03.0
±1f.0
±1f.2
±1f.3
-1f.5
/usr/bin/lspci -nn
/usr/bin/lsusb
/usr/sbin/dmidecode
dmidecode 2.12
SMBIOS 2.6 present.
BIOS Information
Version: 2101
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 2048 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
EDD is supported
You can’t SLI those cards, plus if you could it’s limited to three displays in SLI.
If you want four monitors you need a single Kepler or Maxwell card that supports four outputs.
Three displays would be just fine - could you / someone possibly help me diagnose what I’m doing wrong?
Not entirely sure what I’m doing wrong (or if I need SLI?)
Ultimately what I want from a user-story perspective is:
3 monitors that can be traversed by the mouse on the desktop. Windows can be dragged from monitor 1, to 2, to 3.
Your help and input are greatly appreciated!
Will gladly send a paypal tip to whomever can solve this one (or to the charity of your choice).
(p.s. I am able to get three displays working in the above mentioned fashion with the Nouveau driver - but I would like to use the nvidia drivers for many reasons)
Do any developers by chance monitor this forum? Not sure where else to turn for guidance - any help would be greatly appreciated indeed.
Just freshening up this post - Does anyone have any idea? Can post any data requested - your help greatly appreciated (in advance, even!)
Still the same issue here - if anyone has any insight I’d greatly appreciate your help.
Much thanks
